When VIN-VUSB is cut to prevent backfeed of power to the PC the Teensy will not run.
When not cut, it still won't run on the VIN supply. It will, however, run on VUSB.
VIN (under load with the Teensy & a Raspberry PI connected) is a steady 4.93 volts provided by a switch mode on board supply.
VUSB (which also powers the RPI since they are on the same power rail on the PCB) is a steady 4.96 volts.
One more detail: If I power up my project (on its own 4.93 volt supply) and then very briefly connect the USB to the PC, the Teensy starts.
I've built essentially the same project previously with Teensy 3.2 and 3.5 using the same power supply and never had this problem.
Ideas?
Ideas?
