The last time I coded anything was a billion years ago in Basic. I've been learning Arduino for a project I'm working on using a Teensy, but I'm stuck. The sketch shown here is cobbled together, but works with one exception. Functionally, it reads a key stroke on a typewriter. The individual key bar contacts a resistance strip, and analog 0 senses the voltage. That number is then put through a filter to clean it up (average/median), then drops down through a filter to determine which key was read. The good news is that I've finally got it all working, with one exception that is driving me nuts and I'm too new to this all to debug. When, for example, I press the "A" key it reads the right number range and gives me an A. However, when I move to another key -- say "B" -- the first key press on B also returns an A. Any key press after the first correctly returns a B. This is true anywhere on the keyboard. I understand that the last key press is somehow still being retained in the variable, but I can't figure out where or how to fix it, believe me I've tried. I understand that I don't know enough to be doing this, but I'm almost there Other critiques and suggestions are welcomed!
I've attached the code as a file, but in case I messed that up here it is:
The Analog median and average sketch used below is by Tom Igoe
The program reads an analog input and gives the average of 9 readings,
and sorts the list of readings and delivers the median number.
The sketch used to read the key tritter switch is from a tutorial on Youtube.
The rest is my own halting, beginner's effort
//my added variables
const int BUTTON_PIN = 2; // the number of the pushbutton pin
int lastState = LOW; // the previous state from the input pin
int currentState; // the current reading from the input pin
int buttonPress;
int test_counts;
//end added variables
int numReadings = 9; // number of samples to take
int median = 0; // median of the sorted samples
int readingNumber; // counter for the sample array
int counts = 0;
// variables for subroutines:
byte i = 0;
byte j = 0;
byte position = 0;
int analogValues[9];
//function prototypes:
void bubbleSort();
int averageArray();
pinMode(BUTTON_PIN, INPUT_PULLUP);
//added button code
READ:
currentState = digitalRead(BUTTON_PIN);
if(lastState == HIGH && currentState == LOW)
else if(lastState == LOW && currentState == HIGH)
// save the the last state
lastState = currentState;
if(currentState == LOW)
goto READKEYS;
else if (currentState == HIGH) goto READ;
//end added button code
READKEYS:
delay(25);
for (readingNumber = 0; readingNumber < numReadings; readingNumber++) {
//get the reading:
analogValues[readingNumber] = analogRead(0);
// increment the counter:
readingNumber++;
// sort the array using a bubble sort:
bubbleSort();
// get the middle element:
median = analogValues[numReadings / 2];
// print the results:
// print the array, nicely ASCII-formatted:
// Serial.print("Array: [");
for (j = 0; j < numReadings; j++) {
//Serial.print(analogValues[j], DEC);
// Serial.print (", ");
// Serial.print("]\r\n");
// average the array:
/*Serial.print(" Average = ");
Serial.print(averageArray(), DEC);
Serial.print("\tMedian = ");
Serial.print(median, DEC);
Serial.print("\r\n");
//Serial.println(counts);
delay(50);
// average the values in the array:
int averageArray() {
int total = 0;
int average = 0;
for (i = 0; i< numReadings; i++) {
total = total + analogValues[i];
average = total/(numReadings + 1);
return average;
void bubbleSort() {
int out, in, swapper;
for(out=0 ; out < numReadings; out++) { // outer loop
for(in=out; in<(numReadings-1); in++) { // inner loop
if( analogValues[in] > analogValues[in+1] ) { // out of order?
// swap them:
swapper = analogValues[in];
analogValues [in] = analogValues[in+1];
analogValues[in+1] = swapper;
counts = 0;
counts = median;
if (counts >887&& counts <907) Serial.println ("a");
if (counts >552&& counts <572) Serial.println ("b");
if (counts >690&& counts <710) Serial.println ("c");
if (counts >720&& counts <740) Serial.println ("d");
if (counts >741&& counts <761) Serial.println ("e");
if (counts >650&& counts <670) Serial.println ("f");
if (counts >588&& counts <608) Serial.println ("g");
if (counts >518&& counts <538) Serial.println ("h");
if (counts >400&& counts <420) Serial.println ("i");
if (counts >450&& counts <470) Serial.println ("j");
if (counts >378&& counts <398) Serial.println ("k");
if (counts >274&& counts <294) Serial.println ("l");
if (counts >423&& counts <443) Serial.println ("m");
if (counts >490&& counts <510) Serial.println ("n");
if (counts >310&& counts <330) Serial.println ("o");
if (counts >210&& counts <230) Serial.println ("p");
if (counts >912&& counts <932) Serial.println ("q");
if (counts >673&& counts <693) Serial.println ("r");
if (counts >800&& counts <820) Serial.println ("s");
if (counts >602&& counts <622) Serial.println ("t");
if (counts >467&& counts <487) Serial.println ("u");
if (counts >623&& counts <643) Serial.println ("v");
if (counts >825&& counts <845) Serial.println ("w");
if (counts >718&& counts <738) Serial.println ("x");
if (counts >537&& counts <557) Serial.println ("y");
if (counts >852&& counts <872) Serial.println ("z");
if (counts >-10&& counts <10) Serial.println ("1");
if (counts >-10&& counts <10) Serial.println ("2");
if (counts >-10&& counts <10) Serial.println ("3");
if (counts >-10&& counts <10) Serial.println ("4");
if (counts >-10&& counts <10) Serial.println ("5");
if (counts >-10&& counts <10) Serial.println ("6");
if (counts >-10&& counts <10) Serial.println ("7");
if (counts >-10&& counts <10) Serial.println ("8");
if (counts >-10&& counts <10) Serial.println ("9");
if (counts >-10&& counts <10) Serial.println ("10");
if (counts >-10&& counts <10) Serial.println ("11");
if (counts >-10&& counts <10) Serial.println ("12");
if (counts >-10&& counts <10) Serial.println ("13");
if (counts >-10&& counts <10) Serial.println ("14");
if (counts >-10&& counts <10) Serial.println ("15");
if (counts >-10&& counts <10) Serial.println ("16");
if (counts >-10&& counts <10) Serial.println ("17");
counts = 0;
