Results 1 to 5 of 5
Thread: How to change the MIDI input circuit for 6N137 instead of 6N138?
    Feb 2021
    7
    I'm trying to figure out what modifications to make to the MIDI input section of this circuit to use 6N137 IC instead of the 6N138 shown.
    In my searches I'm finding incomplete and conflicting info. Any solid answer? (I'm using Teensy 4.0 and 4.1 if that makes a difference)
    May 2020
    1
    6n137 vs 6n138
    use the teensy 3.3v as pull-up on 6n137. See https://electronics.stackexchange.co...d-opto-coupler
    Quote Originally Posted by dannytaurus View Post
    Feb 2021
    7
    Thanks for the link jimr but I decided to go the easy route and source some 6N138 instead. I see a lot of conflicting information about the 6N137 and I'm too new to this to make sense of it.
    Apr 2020
    DFW area in Texas
    305
    @dannytaurus:
    Have a look at <this thread>, which appears to describe a successful implementation with the 6N137.
    Mark J Culross
    KD5RXT
    Senior Member oddson's Avatar
    Feb 2013
    Isle in the Salish Sea
    1,410
    While not qualified to say, what I read is the 137 can tolerate a much higher impedance pullup and so the using the internal one makes sense to me.
    I believe lower value pullups would still work and that higher values are recommended to mitigate high-frequency noise from the fast switching speed.
    The Darlington pair in the 138 switches much more slowly and needs a more aggressive (lower impedance) pull-up to work, even an MIDI speeds.
