Results 1 to 5 of 5
Thread: TFT RA8875 fonts
    Nov 2020
    Czech Republic
    49
    TFT RA8875 fonts
    Hey all,
    I tried many web pages but I am not sure hot set font fot my TFT RA8875.
    Teensy 4.0
    #include <RA8875.h>
    #define RA8875_CS 10
    #define RA8875_RESET 9
    RA8875 tft = RA8875(RA8875_CS,RA8875_RESET);
    #include <Fonts/????>
    tft.setCursor(100, 100);
    tft.setFont(&?????);
    tft.println("ARIAL FONT");
    Is there any easy way? I am lost now ;-)
    Thank you for any advice.
    Michal
    New York
    7,551
    Quote Originally Posted by frohr View Post
    Hey all,
    Teensy 4.0
    #include <RA8875.h>
    Michal
    Basically you have to include the font you want to use by name such as:
    // maybe a few GFX FOnts?
    #include <Fonts/FreeMonoBoldOblique12pt7b.h>
    #include <Fonts/FreeSerif12pt7b.h>
    Notice that the file name name describes the font size as well.
    Then when you want to use the that font:
    tft.setFont(&FreeSansOblique12pt7b);
    I am assuming you are using the RA8875 library bundled with Teensyduino. If you are there are a few examples of using fonts in the example folder as well.
    EDIT: To use the ILI9341 type fonts you will need to down the ILI9341 font library as well: https://github.com/mjs513/ILI9341_fonts.
    Apr 2020
    DFW area in Texas
    294
    I am working against the exact same challenge (RA8875 fonts) & I did look at the examples noted. I do have a few additional questions:
    1) what is the path to the font files ??
    2) it seems that only certain sizes are available (as you mention re: the filename), true ??
    3) does that imply that tft.setFontSize is not applicable/useable for these "custom" fonts ??
    Thanks in advance for any additional insight/clarification that you can provide . . .
    Mark J Culross
    KD5RXT
    New York
    7,551
    Quote Originally Posted by kd5rxt-mark View Post
    Mark J Culross
    KD5RXT
    For the Font files you will need two libraries installed into your Arduino Libraries folder:
    1. Adafruit GFX
    and
    2. the ILI9341 font library as well: https://github.com/mjs513/ILI9341_fonts.
    once in your libraries folder just follow the examples posted.
    Yes only those font sizes can be used.
    Yes - its only applicable to internal fonts from what I remember. Think setTextSize still works with those fonts - its been awhile.
    Nov 2020
    Czech Republic
    49
    Hi, I installed https://github.com/mjs513/ILI9341_fonts
    Now my example code looks like:
    #include <RA8875.h>
    #include <font_Arial.h>
      tft.begin(RA8875_800x480);
      tft.setRotation(2);
      tft.setTextColor(RA8875_WHITE, RA8875_BLACK);
      tft.setFont(Arial_8);
      tft.setCursor(50, 50);
      tft.println("TEXT test");
      tft.setFont(Arial_16);
      tft.setCursor(50, 100);
      tft.setFont(Arial_32);
      tft.setCursor(50, 200);
      tft.setFont(Arial_72);
      tft.setCursor(50, 300);
    Works well.
    Thanks a lot!
