Page 1 of 2 1 2 LastLast
Results 1 to 25 of 29
Thread: SPI issues with external ADC
    Aug 2021
    13
    I am using SPI for the first time in a real project and I am experiencing a few issues.
    - Teensy 3.2
    - ADC: MCP33121-10
    https://www.mouser.de/datasheet/2/26...-1-1749951.pdf
    Project: The goal is to convert the voltage (set by potentiometer), to learn how the ADC is working (with a bigger project in mind.).
    Problem: I only read 2^16 = 65535 (this should be.. 1111 1111 1111 1111) from the serial interface, despite changing (&checking with my multimeter) the analog input voltage Ain+. Below, you also find a Screenshot from my Scope, but I cant really learn whats going wrong from it. The datasheet states that 1111 .....1111 is the "error" code indicating a voltage above VRef, or VRef itself, still it occurs whichever voltage I apply on the input pin. I am quite generous with the timing, so this shouldnīt be a problem of the ADC lacking time to convert the value and present it on the SPI.
    Funny thing is that I tried to see what happens, when you donīt connect DIN on the Teensy. Still, I get 2^16, no matter what. Thanks a lot guys! I am ready to learn, so please feel free to mention everything you notice.
    I already tried lowering the SPI CLK, as the setup is currently on breakout/bread boards and flimsy jumper wires.
Name:	Notiz 16.08.2021.jpg
    The decoded value on the scope is very unstable and jumping around all the time. The teensy serial monitor stays rock solid at 2^16, no matter what. (CLK: yellow, DIN: blue, CS: pink)
    #define CS 10
    #define CNVST 4
    #define BAUDRATE 115200
    const uint32_t SPI_CLK = 1E6;
    uint16_t MSB;
    uint16_t LSB;
    uint16_t iVal;
    SPISettings settingsA(SPI_CLK, MSBFIRST, SPI_MODE1);
    void Read(){
     SPI.beginTransaction(settingsA);
      digitalWriteFast(CS, LOW); //changed to normal digitalWrite
      MSB = SPI.transfer(0); //send  0XFF = 255, so rx only
      LSB = SPI.transfer(0); //send  0XFF = 255, so rx only
      digitalWriteFast(CS, HIGH); //changed to normal digitalWrite
        SPI.endTransaction();
      iVal = (((uint16_t)MSB << 8) | LSB);
      //iVal = iVal >> 2; //to obtain 14 bit data
    void setup(){
    pinMode(CS, OUTPUT);
    pinMode(CNVST, OUTPUT);
    digitalWriteFast(CNVST, LOW);
    Serial.begin(BAUDRATE);
    SPI.begin();
    void loop(){
    delayMicroseconds(4);
    digitalWriteFast(CNVST, HIGH);
    Read();
    //Serial.println(MSB);
    //Serial.println(LSB);
    Serial.println(iVal);
    iVal = 0;
    Aug 2021
    13
    any ideas? I tripled checked all connections and kind find a hint..
    I disconnected the ADC from the breadboard, just with the cables in place. Still, the SPI interface is reading 65535, despite the ADC not being connected.
    Aug 2021
    13
    out of curiosity, I checked the voltages with my multimeter. The DIN-PIN (12) outputs 3.043V! Is this normal?
    Currently Odessa, Ukraine
    35
    @Jetsream:
    It looks to me like your A/D is putting out a signal level on the SIO pin of around 1.8 Volts which the Teensy will not recognize. The schematic you show is very difficult to read, so I have no idea why your A/D is not putting out the full 3.3v signal to the Din pin of the Teensy. The other two signals are coming from the Teensy so they look alright. I would suggest you read the data sheet again very carefully to see if there may be some error with the A/D's power input pins.
    3,316
    You misunderstood the ADC
    this is not for SPI but you should I2S port
    connect
    clk to Teensy clk
    dout to Teensy Din
    cnvst to Teensy FS
    din to DV+
    Aug 2021
    13
    Quote Originally Posted by sbfreddie View Post
    @Jetsream:
    Thanks for the answer @sbfreddie.
    I will do so! But is it normal to have 3V to ground between DIN (Pin 12)?
    Senior Member PaulS's Avatar
    Apr 2015
    Netherlands
    642
    Right, the DIN/MISO [blue] signal does not look good.
    But I noticed from the schematic that you use the AGND of the Teensy as the general GND for the circuit?
    You better connect all the grounds to the Teensy GND pins instead. On a Teensy 3.2, GND is not the same as AGND.
    Paul
    35
    Quote Originally Posted by Jetsream View Post
    It depends on the A/D, some devices use a high as an idle state, and some devices use a low as an idle state. I was looking at the data sheet and you should study page 38 very carefully. I think it should clear up a few things.
    @WMXZ It is an SPI device as mentioned on the front page of the data sheet, with the details on page 38. It is a very strange SPI device though.
    Ed
    Aug 2021
    13
    @PaulS thx, I didnīt know there was a difference. I thought GND and AGND are the same, as they are connected to each other..
    @Sbfreddie. I had a few errors in my setup, which I now corrected. I had a separated CNVST signal and was not using CS as a physical line (which was plain stupid from my side!). Now itīs just as in the datasheet, with CS managing CNVST, still the output is rock solid at 2^16.. could it be, that the SDO pin on the ADC changes to high-z (I suppose thatīs high impedance?) when the last bit was clocked out? Why is it a strange SPI-device? Just curious to learn.
    maybe its easier to read like this: (the CNVST on Teensy Pin 4 does no longer exist, I connected CNVST directly to pin 10(CS), with adapted code)
    https://forum.pjrc.com/attachment.ph...9&d=1629208155
    Edit:
    Could it be the SPI sampling frequency? I just noticed, there are minima required by the adc. I increased mine to 16Mhz which should be fine for some 400ksps.. still, only getting 65535 on the readout
    35
    @Jetsream:
    The CNVST timing is very critical and I don't think the Teensy's CS output from the SPI logic can be precisely controlled to get just the right timing. Make sure you read carefully the CNVST timing requirements in the data sheet. You may also have to check out the Teensy's different SPI modes to get this A/D to work correctly. You will never get anything correct out of this A/D until you cleanup the grounds, and get the Data Out pin to put out the proper logic levels (0 -> 3.3v). Perhaps use your Scope to verify the right logic levels.
    All that ringing on the Data Out pin is probably caused by bad grounding.
    Working with high speed A/D is a challenge.
    All the best,
    Ed
    Apr 2015
    Netherlands
    642
    AGND and GND are connected by means of a small ferrite [L3 on the schematic here]
    This ferrite has a certain impedance and AGND is therefor not a firm GND for digital signals.
    Paul
    3,316
    Ed
    I know it reads so, but I used a lot of similar ADC's with I2S port (in PCM mode) for years now
    35
Name:	Screen Shot 2021-08-18 at 6.07.42 PM.jpg
ID:	25591@Jetsream: I found this page at the manufactures website from their custom testing board that costs $200. It appears that the output Dout requires a pull-up resistor, check out this schematic:
    Apr 2015
    Netherlands
    642
    Now you got me intrigued & curious. How would that work from a software point of view? Should I use the I2S input object from Audio library?
    Here is the timing diagram of the MCP33121:
    So the CNVST pin should be connected to the I2S LRCLK signal? [I assume you called that "FS" in message #5].
    And the SCLK pin should be connected to the I2S BCLK signal?
    Thanks,
    Paul
    3,316
    Thanks,
    Paul
    Yes the connections are the one I'm using.
    Not sure is stock I2S works, as it is tuned to codecs (setup is defined in output)
    Anyhow,
    key is to configure sync as short as possible
    eg for a mono ADC
      I2S0_RCR4 = I2S_RCR4_FRSZ(0) | I2S_RCR4_SYWD(0) | I2S_RCR4_MF | I2S_RCR4_FSE ;
      I2S0_RCR5 = I2S_RCR5_WNW(31) | I2S_RCR5_W0W(31) | I2S_RCR5_FBT(31);
    here the frame-sync is 1 clock long
    so what I did, I cloned the stock i2s module and modified ir according to my needs.
    critical issue is figuring out when to sample (polarity of clock) and the FramsSyncEarly (FSE)
    but this can be solved by trying and reading the manuals
    35
    After reviewing this data sheet with a finer tooth comb, I agree with WMXZ, this A/D will not work with I2C or SPI. Perhaps some sort of bitbanging or as WMX suggests using I2S which has been customized specifically for this A/D.
    Regards,
    Ed
    Aug 2021
    13
    guys I just want to say thanks for your help and dedication! It really helps me out a lot. I added a pull-up on MISO and a pull-down on SC/CNVST, but with no real difference. Still, my logic level is far too small, despite checking every connection.
    Any suggestions for another ADC to use, something that is slightly more beginner friendly and works with stock SPI/I2C?
    I want to read the video output of a spectrometer. The spectrometer provides TRG for readout, and the data is presented at 200kHz. So I suppose (one reading per channel is enough for my needs) something at like 250ksps should be fine. Maybe something like a AD7980?
    Jul 2020
    1,217
    You're missing the 1uF decoupling cap on AVdd mentioned in the datasheet...
    Aug 2021
    13
    @MarkT its actually connected.. I was just being to lazy to paint them all into the shematic. Still, doesnīt this just influence some rippling in the analog supply?
    3,316
    looking into the timing diagram, I would simply try to use the stock Audio library I2S module.
    Only one channel will get data.
    Adjusting sampling frequency and clock timings for final application can be done later
    Jul 2020
    1,217
    Who knows - you certainly shouldn't expect datasheet performance if you neglect analog decoupling.
    Wait a minute, are you really expecting to get 1.8V out of a LM317 with 3.3V in? The minimum input to output differential is 3V.
    Aug 2021
    13
    Quote Originally Posted by UhClem View Post
    it was an error in the shematic, sorry! It is hooked up to the 5V line and the output is stabel at 1.8
    Aug 2021
    13
    @WMXZ is the timing really this critical? I thought the datasheet talks about the "minimum" times. So if they say, a conversion takes 1300ns, is it this critical to lower CNVST ( and subsequently start the readout) after.. 2000ns? or 2500ns?
    Any suggestions for another ADC in this range? Something with like minimum 250ksps and a easy to use SPI/I2C?
    @MarkT still, thanks for looking at it in detail very much appreciated!
    35
    @Jetsream:
    In further consideration of your interesting problem, I think I have figured out why your getting all x0FFFF's back from the A/D.
    If you look carefully at the MCP33121 data sheet page 38 timing diagram, you will find out why you are getting all x0FFFF's. The length of the CNVST positive cycle (rising edge to falling edge) is critical. If the CS/ signal from the Teensy is very short CS/ high state the A/D will not have time to complete the conversion when the Teensy SPI starts to shift out the data bits. As note 2 from the timing diagram says: "Any SCLK toggling events (dummy clocks) before CNVST is changed to "Low" are ignored". If you look at Timing Diagram for SDO you will see that SDO is in Hi-Z (tristate) for all the tCNV time plus tEN time, which is the convert time plus the time for enabling the SDO pin. (The convert time is set by an internal clock and cannot be changed)
    As you can see you are trying to sample the DIO pin before the conversion is complete where the SDO pin is in Hi-Z which will give you a reading of x0FFFF's. Now after reviewing the LPSPI section of the RT1060 processor pages 2823-2824 you can see that the timing of the SCKPCS, PCSSCK, DBT, and SCKDIV can be set in the LPSPI Clock Configuration Register (CCR). I think if you experimented with these settings you could probably make this A/D work with the Teensy.
    However if you have no idea what I am talking about with the last sentence perhaps you should consider using a more friendly A/D like the LTC2367-16, which has BUSY pin which you could use as an interrupt, thus eliminating some of these odd timing problems.
    Regards,
    Ed
