Page 1 of 18 1 2 3 11 ... LastLast
Results 1 to 25 of 426
Thread: Teensyduino 1.55 Beta #1
    Administrator Paul's Avatar
    Oct 2012
    415
    Here is a first beta test for Teensyduino 1.55.
    The main new feature is support for Lockable Teensy 4.0 (beta). Scroll down for details.
    Linux 32 bit:
    https://www.pjrc.com/teensy/td_155-b...nstall.linux32
    Linux 64 bit:
    https://www.pjrc.com/teensy/td_155-b...nstall.linux64
    Linux ARM:
    https://www.pjrc.com/teensy/td_155-b...stall.linuxarm
    Linux ARM64:
    https://www.pjrc.com/teensy/td_155-b...l.linuxaarch64
    MacOS 10.10 to 10.15: (coming later...)
    https://www.pjrc.com/teensy/td_155-b...S_Catalina.zip
    MacOS 10.8 to 10.14: (coming later...)
    https://www.pjrc.com/teensy/td_155-b...inoInstall.dmg
    Windows:
    https://www.pjrc.com/teensy/td_155-b...inoInstall.exe
    Changes since Teensyduino 1.54:
    Support for Lockable Teensy 4.0 (beta)
    kinetis.h comments added for required clock gate config on each peripheral
    Fix higher temperature measure on Teensy 4.x (mjs513)
    Fix USB serial transmit autoflush race condition on Teensy 4.x (thanks Frank B)
    Add IMXRT fuse memory functions
    NXPMotionSense add Quaternion access (Ryan Pearl)
    USBHost_t36 bluetooth PS4 improvements (KurtE)
    USBHost_t36 serial DTR & RTS support (KurtE)
    USBHost_t36 serialemu fixes (Frank B)
    Update NativeEthernet & FNET
    To access the new features for Lockable Teensy, in Arduino click Tools > Teensy 4 Security. It will open this new window.
    While I haven't written any proper documentation yet, hopefully the info on this window can explain how it's meant to work.
    Standard Teensy 4.0 made after June 2021 can also run encrypted programs, but the final secure lock mode can't be set. Running encrypted programs that way is akin to locking your door but leaving the window open. Still, might be worth trying. Anyone can open this window, create their own key.pem file, and get .EHEX files created.
    At this moment 5 people have beta test Lockable Teensy 4.0 boards. If things go well over the next few weeks, we'll probably open up the Lockable Teensy beta hardware to more people.
    25,026
    I should mention a known bug which is relatively minor, but confusing. If you try to upload to a locked board and no .EHEX file is available, Teensy Loader shows an error message that it needs an EHEX file, but then it gets stuck and is unresponsive until you either press the button on the locked Teensy or unplug the USB cable. I will fix this in 1.55-beta2...
    New York
    7,546
    Installed 1.55b1 over 1.55 on a Win10x64 home edition. Installed no issues.
    Selecte Teensy 4 security. Window opened as shown in your message. Selected generate Key. It executed a bunch openssl commands with results of the commands shown in the IDE window:
    Step 0: temporary folder setup
    original_working_directory: F:\arduino-1.8.15
    attempt to create folder C:\Users\Merli\AppData\Local\Temp\ts_fdfebe814ff7f26d24f3476cac3af3c9
    temporary folder: C:\Users\Merli\AppData\Local\Temp\ts_fdfebe814ff7f26d24f3476cac3af3c9
    Step 1: run openssl req to create a disposable CA
    Running: req -verbose -newkey rsa:2048 -passout pass:test -subj /CN=ca/ -extensions v3_ca -x509 -keyout cakey.pem -out cacert.pem -days 146100 -config openssl.cnf
    Using configuration from openssl.cnf
    Generating a RSA private key
    writing new private key to 'cakey.pem'
    Step 2: run openssl genrsa to create private key
    Running: genrsa -aes128 -passout pass:test -f4 -out srk.pem 2048
    Generating RSA private key, 2048 bit long modulus (2 primes)
    e is 65537 (0x010001)
    Step 3: run openssl req to create signing request from CA
    Running: req -verbose -new -batch -passin pass:test -subj /CN=me/ -key srk.pem -out req.pem -config openssl.cnf
    Step 4: run openssl ca to create a certificate (according to disposable CA)
    Running: ca -verbose -batch -passin pass:test -md sha256 -in req.pem -cert cacert.pem -notext -keyfile cakey.pem -extfile v3_usr.cnf -out cert.pem -days 146100 -config openssl.cnf
    0 entries loaded from the database
    generating index
    Successfully loaded extensions file v3_usr.cnf
    message digest is sha256
    policy is policy_match
    next serial number is 10
    Certificate Request:
        Data:
            Version: 1 (0x0)
            Subject: CN = me
            Subject Public Key Info:
                Public Key Algorithm: rsaEncryption
                    RSA Public-Key: (2048 bit)
                    Modulus:
                        00:c4:75:ac:05:c1:fa:97:ec:2c:36:bb:1c:b0:92:
                        f1:d8:74:6e:cd:09:ba:d3:11:fc:44:9b:ff:58:3a:
                        f9:b9
                    Exponent: 65537 (0x10001)
            Attributes:
                a0:00
        Signature Algorithm: sha256WithRSAEncryption
             4b:f3:c7:80:d7:0e:51:0c:d5:34:f7:48:c0:8a:82:04:3e:09:
             71:66:0a:88:20:79:5f:93:95:8f:71:54:4d:37:3d:8a:00:90:
             5a:4b:e0:d8
    Check that the request matches the signature
    Signature ok
    The Subject's Distinguished Name is as follows
    commonName            :PRINTABLE:'me'
    Everything appears to be ok, creating and signing the certificate
    Extra configuration file found
    Successfully added extensions from file.
    The subject name appears to be ok, checking data base for clashes
    Certificate is to be certified until Aug 20 18:00:22 2421 GMT (146100 days)
    Write out database with 1 new entries
    writing new certificates
    writing ./10.pem
    Data Base Updated
    Step 5: Create AES-128 key
    Step 6: Write result to D:\Users\Merli\Documents\Arduino\key.pem
    writing to D:\Users\Merli\Documents\Arduino\key.pem
    All steps completed
    and a key.pem file is created.
    Out of curiousity I selected Generate Key again and the warning window appeared:
    When clicking on generate again I now see 2 key files
    key.pem
    key_2.pem
    Ok this is about as far I have have gotten in 5 minutes of use.
    25,026
    Yup, I added that duplicate key dialog box at the last minute. Hopefully it makes things better?
    15,067
    Windows 11 { win 10 with goofy GUI }
    > New unzip of IDE 1.8.15
    > TD 1.55 beta 1
    > ONLY download install first run grief from Windows was 'normal' for the JAVA needing Firewall permission on IDE startup.
    > Teensy Installer and execution to teensy_sermon : No issues
    Opened IDE - forgot to change board from 4.1 - failed 1st upload okay - then worked for T_4.0 - first simple sketch:
    11:12:37.062 (loader): encryption is possible on this Teensy, but not yet configured
    11:12:37.062 (loader): Device came online, code_size = 2031616
    11:12:37.062 (loader): Board is: Teensy 4.0 (IMXRT1062), version 1.07
    11:12:37.080 (loader): elf binary data matches hex file
    11:12:37.080 (loader): elf file is for Teensy 4.1 (IMXRT1062)
    11:12:37.080 (loader): Incompatible file, showing warning dialog
    11:12:37.202 (serialmon 6): Begin, version=1.55-beta1, high-res time
    ... // board change
    11:18:32.627 (loader): elf appears to be for Teensy 4.0 (IMXRT1062) (2031616 bytes)
    New York
    7,546
    Ok Step 2. FUSE With Sketch
    Clicking Fuse with sketch opens a new sketch that writes the encryption to T4
    Next up - running the sketch created to fuse the keys. The sketch output to serial monitor let me it completed successfully and:
    Notice: Secure mode is not yet set, unencrypted
            programs are still allowed to run
    Really nice touch and if you read and follow the instructions is easy even for me
    Next I clicked on Verify Sketch and a new sketch opens up: VerifySketch.ino with an output of:
    Verify secure code is running properly
    Pass: Bus Encryption Engine is active
    Pass: Encryption region starts at proper address
    Pass: Program data is entirely within encrypted region
    Pass: title_function() is within encrypted region
    All Tests Passed.  :-)
    Ok now I am lost - how do I upload the ehex file or is it automatic since I have a key.pem file?
    EDIT: Looked in the log and am seeing same as @defragster:
    14:29:49.431 (loader): Board is: Teensy 4.0 (IMXRT1062), version 1.07
    14:29:49.445 (loader): File "C:\Users\Merli\AppData\Local\Temp\arduino_build_841596\littlefs_teensy_test1a-UPDATED.ino.hex", 86016 bytes
    14:29:49.455 (loader): File "C:\Users\Merli\AppData\Local\Temp\arduino_build_841596\littlefs_teensy_test1a-UPDATED.ino.ehex", 86016 bytes, 4960 extra
    14:29:49.456 (loader): ehex is valid, key hash: 3C...................................................................
    14:29:49.456 (loader): set background IMG_ONLINE
    14:29:49.472 (loader): File "C:\Users\Merli\AppData\Local\Temp\arduino_build_841596\littlefs_teensy_test1a-UPDATED.ino.hex", 86016 bytes
    14:29:49.482 (loader): File "C:\Users\Merli\AppData\Local\Temp\arduino_build_841596\littlefs_teensy_test1a-UPDATED.ino.ehex", 86016 bytes, 4960 extra
    14:29:49.482 (loader): ehex is valid, key hash: 3.................................
    14:29:49.483 (loader): elf appears to be for Teensy 4.0 (IMXRT1062) (2031616 bytes)
    14:29:49.484 (loader): elf binary data matches hex file
    14:29:49.484 (loader): elf file is for Teensy 4.0 (IMXRT1062)
    14:29:49.484 (loader): using encrypted ehex (optional - secure mode not yet locked)
    14:29:49.517 (loader): begin operation
    14:29:49.527 (reboot 20): Status: 1, 1, 1, 4, 0, 1, C:\Users\Merli\AppData\Local\Temp\arduino_build_841596\, littlefs_teensy_test1a-UPDATED.ino.hex
    With this message does it mean its using the encrypted version?
    15,067
    @Mike - does TeensyLoader show file path with eHex after Verify?
    Minor oddity: New unzip of IDE 1.8.15 did not use prior setting for SKETCHBOOK?
    > I saw in security dialog it was pointing to 'default' location for libraries/sketchbook - and checked and that was set?
    Not sure if something in PJRC JAVA could affect that? IDE was not opened before TD 1.55b1 was installed.
    This is same IDE version as before and I had not noticed that eve happen with fresh unzip? It always used existing sketchbook folder ... so it could not find sketchbook/libraries.
    <edit>: t 4 Security now showing key.pem will be placed into ROOT of chosen sketchbook folder.
    New York
    7,546
    Personally I like it - think it will help manage keys if you are so inclined to use multiple keys.
    One suggestion though. In the future instead of putting the keys directly in the Arduino folder would it be possible to put it a subdirectory like ../Arduino/keys?
    New York
    7,546
    Didn't bother with verify went straight to upload.
    The build folder has the elf and the hex and ehex files as Paul said. Where I am stuck on is that final step.
    Interesting though is that the ehex is smaller than the hex
    15,067
    Fuse Write : opened sketch - 'assumed' I needed to Upload and it worked.
    Verify Sketch : opened sketch : Clicked UPLOAD and IDE showed "Unable to open COM9". Pressed Button and it uploaded and says all is well.
    > TeensyLoader shows : VerifySecure.ino.hex > expected to see it say .eHex?
    loader Verbose:
    11:40:55.741 (loader): Board is: Teensy 4.0 (IMXRT1062), version 1.07
    11:40:55.754 (loader): File "C:\Users\Tim\AppData\Local\Temp\arduino_build_691339\VerifySecure.ino.hex", 20480 bytes
    11:40:55.765 (loader): File "C:\Users\Tim\AppData\Local\Temp\arduino_build_691339\VerifySecure.ino.ehex", 20480 bytes, 4960 extra
    11:40:55.774 (loader): ehex is valid, key hash: 85A79CC1 B7C7F866 7F5BB3ED 0F9C9BA5 B4149EE2 72846D35 86B63863 B0699942
    11:40:55.783 (loader): set background IMG_ONLINE
    11:40:55.798 (loader): File "C:\Users\Tim\AppData\Local\Temp\arduino_build_691339\VerifySecure.ino.hex", 20480 bytes
    11:40:55.809 (loader): File "C:\Users\Tim\AppData\Local\Temp\arduino_build_691339\VerifySecure.ino.ehex", 20480 bytes, 4960 extra
    11:40:55.817 (loader): ehex is valid, key hash: 85A79CC1 B7C7F866 7F5BB3ED 0F9C9BA5 B4149EE2 72846D35 86B63863 B0699942
    11:40:55.827 (loader): elf appears to be for Teensy 4.0 (IMXRT1062) (2031616 bytes)
    11:40:55.835 (loader): elf binary data matches hex file
    11:40:55.843 (loader): elf file is for Teensy 4.0 (IMXRT1062)
    11:40:55.851 (loader): using encrypted ehex (optional - secure mode not yet locked)...
    Loader Verbose suggests it is always uploading the HEX not eHex? Even when the key.pem exists ... or if renamed?:
    11:49:01.813 (loader): elf appears to be for Teensy 4.0 (IMXRT1062) (2031616 bytes)
    11:49:01.821 (loader): elf binary data matches hex file
    11:49:01.829 (loader): elf file is for Teensy 4.0 (IMXRT1062)
    11:49:01.838 (loader): using encrypted ehex (optional - secure mode not yet locked)
    11:49:01.882 (loader): begin operation
    11:49:01.906 (reboot 46): Status: 1, 1, 1, 9, 0, 1, C:\Users\Tim\AppData\Local\Temp\arduino_build_141784\, T4MemInfoDump.ino.hex
    New York
    7,546
    Not sure. What I did was open a different sketch with the pem.key file in the Arduino Directory. Compile verbose showed:
    "F:\\arduino-1.8.15\\hardware\\teensy/../tools/teensy_secure" encrypthex TEENSY40 "C:\\Users\\Merli\\AppData\\Local\\Temp\\arduino_build_228995/uncannyEyes_async_st7789_240x240.ino.hex"
    No key .pem file found, skipping .ehex encryption
    And if you look in the Log:
    14:55:43.555 (loader): Board is: Teensy 4.0 (IMXRT1062), version 1.07
    14:55:43.635 (loader): File "C:\Users\Merli\AppData\Local\Temp\arduino_build_228995\uncannyEyes_async_st7789_240x240.ino.hex", 651264 bytes
    14:55:43.636 (loader): set background IMG_ONLINE
    14:55:43.719 (loader): File "C:\Users\Merli\AppData\Local\Temp\arduino_build_228995\uncannyEyes_async_st7789_240x240.ino.hex", 651264 bytes
    14:55:43.721 (loader): elf appears to be for Teensy 4.0 (IMXRT1062) (2031616 bytes)
    14:55:43.721 (loader): elf binary data matches hex file
    14:55:43.721 (loader): elf file is for Teensy 4.0 (IMXRT1062)
    14:55:43.721 (loader): no valid ehex file, use hex
    14:55:43.758 (loader): begin operation
    So it looks like if there is no valid ehex file in the builder folder then it will just use the .hex, if not it uses the ehex - I think???????
    New York
    7,546
    So far running unencrypted and encrypted without any issues with out locking yet.
    EDIT: Created about a 1.2Mb Flash disk using a LittleFS test sketch unencrypted and the UncannyEyes sketch encrypted with a memory at the LittleFS baseaddr: 0x600c0000 without an issue:
    Init
    Create display #0
    Create display #1
    ST7789_t3::init mode: 0
    Init ST77xx display #0
    Rotate
    Init ST77xx display #1
    Rotate
    done
    Display logo
    $0: Using Frame buffer
    $1: Using Frame buffer
    LittleFS Test
    baseaddr = 600c0000
    TotalSize (Bytes): 1245184
    printDirectory
    FILE	bigfile.txt  		616448
    DIR	structureData1 /
    	FILE	temp_test.txt		76
     0 dirs with 1 files of Size 76 Bytes
    FILE	temp_test1.txt		76
    FILE	temp_test2.txt		76
    FILE	temp_test3.txt		4096
     1 dirs with 4 files of Size 620696 Bytes
    *** LittleFS Dump ***
    600C0000 - 41 00 00 00 F0 0F FF F7  6C 69 74 74 6C 65 66 73  : A....... littlefs
    600C0010 - 2F E0 00 10 00 00 02 00  00 10 00 00 30 01 00 00  : /....... ....0...
    600C0020 - 27 00 00 00 FF FF FF 7F  FE 03 00 00 70 1F FC 48  : '....... ....p..H
    600C0030 - AF 95 B4 58 FF FF FF FF  FF FF FF FF FF FF FF FF  : ...X.... ........
    600C0040 - FF FF FF FF FF FF FF FF  FF FF FF FF FF FF FF FF  : ........ ........
    ...	 250 duplicate line(s) removed.
    600C0FF0 - FF FF FF FF FF FF FF FF  FF FF FF FF FF FF FF FF  : ........ ........
    600C1000 - 42 00 00 00 F0 0F FF F7  6C 69 74 74 6C 65 66 73  : B....... littlefs
    600C1010 - 2F E0 00 10 00 00 02 00  00 10 00 00 30 01 00 00  : /....... ....0...
    600C1020 - 27 00 00 00 FF FF FF 7F  FE 03 00 00 70 1F FC 48  : '....... ....p..H
    600C1030 - CB A0 66 1E FF FF FF FF  FF FF FF FF FF FF FF FF  : ..f..... ........
    600C1040 - FF FF FF FF FF FF FF FF  FF FF FF FF FF FF FF FF  : ........ ........
    ...	 2 duplicate line(s) removed.
    600C1070 - FF FF FF FF FF FF FF FF  FF FF FF FF FF FF FF FF  : ........ ........
    600C1080 - 10 1F F8 50 40 30 00 0E  73 74 72 75 63 74 75 72  : ...P@0.. structur
    600C1090 - 65 44 61 74 61 31 20 20  00 06 CB 00 00 00 CC 00  : eData1   ........
    600C10A0 - 00 00 40 0F F8 00 CB 00  00 00 CC 00 00 00 30 00  : ..@..... ......0.
    600C10B0 - 00 46 82 DD F8 E9 FF FF  FF FF FF FF FF FF FF FF  : .F...... ........
    600C10C0 - FF FF FF FF FF FF FF FF  FF FF FF FF FF FF FF FF  : ........ ........
    600C10F0 - FF FF FF FF FF FF FF FF  FF FF FF FF FF FF FF FF  : ........ ........
    600C1100 - 10 1F F4 4E 40 00 00 0E  74 65 6D 70 5F 74 65 73  : ...N@... temp_tes
    600C1110 - 74 31 2E 74 78 74 20 00  00 0E 70 1F F4 62 6B 1E  : t1.txt . ..p..bk.
    600C1120 - A9 92 FF FF FF FF FF FF  FF FF FF FF FF FF FF FF  : ........ ........
    600C1130 - FF FF FF FF FF FF FF FF  FF FF FF FF FF FF FF FF  : ........ ........
    ...	 3 duplicate line(s) removed.
    600C1170 - FF FF FF FF FF FF FF FF  FF FF FF FF FF FF FF FF  : ........ ........
    600C1180 - 70 1F F4 71 53 4F 4D 45  20 44 41 54 41 20 54 4F  : p..qSOME  DATA TO
    600C1190 - 20 54 45 53 54 0D 0A 70  1F F4 76 C0 70 0E 0E FF  :  TEST..p ..v.p...
    600C11A0 - FF FF FF FF FF FF FF FF  FF FF FF FF FF FF FF FF  : ........ ........
    ...	 4 duplicate line(s) removed.
    600C11F0 - FF FF FF FF FF FF FF FF  FF FF FF FF FF FF FF FF  : ........ ........
    600C1200 - 10 1F F0 65 40 00 00 0E  74 65 6D 70 5F 74 65 73  : ...e@... temp_tes
    600C1210 - 74 32 2E 74 78 74 20 00  00 0E 70 1F F0 62 36 EE  : t2.txt . ..p..b6.
    600C1220 - 27 80 FF FF FF FF FF FF  FF FF FF FF FF FF FF FF  : '....... ........
    600C1230 - FF FF FF FF FF FF FF FF  FF FF FF FF FF FF FF FF  : ........ ........
    600C1270 - FF FF FF FF FF FF FF FF  FF FF FF FF FF FF FF FF  : ........ ........
    600C1280 - 70 1F F0 71 53 4F 4D 45  20 44 41 54 41 20 54 4F  : p..qSOME  DATA TO
    600C1290 - 20 54 45 53 54 0D 0A 70  1F F0 76 3F FF DF 91 FF  :  TEST..p ..v?....
    600C12A0 - FF FF FF FF FF FF FF FF  FF FF FF FF FF FF FF FF  : ........ ........
    600C12F0 - FF FF FF FF FF FF FF FF  FF FF FF FF FF FF FF FF  : ........ ........
    600C1300 - 10 1F EC 65 40 00 00 0E  74 65 6D 70 5F 74 65 73  : ...e@... temp_tes
    600C1310 - 74 33 2E 74 78 74 20 00  00 0E 70 1F EC 62 A2 A7  : t3.txt . ..p..b..
    600C1320 - E1 AB FF FF FF FF FF FF  FF FF FF FF FF FF FF FF  : ........ ........
    600C1330 - FF FF FF FF FF FF FF FF  FF FF FF FF FF FF FF FF  : ........ ........
    600C1370 - FF FF FF FF FF FF FF FF  FF FF FF FF FF FF FF FF  : ........ ........
    600C1380 - 70 2F EC 6A CD 00 00 00  00 04 00 00 70 2F EC 78  : p/.j.... ....p/.x
    600C1390 - 6C AE E7 CF FF FF FF FF  FF FF FF FF FF FF FF FF  : l....... ........
    600C13A0 - FF FF FF FF FF FF FF FF  FF FF FF FF FF FF FF FF  : ........ ........
    600C13F0 - FF FF FF FF FF FF FF FF  FF FF FF FF FF FF FF FF  : ........ ........
    600C1400 - 10 1F F8 70 40 00 00 0D  62 69 67 66 69 6C 65 2E  : ...p@... bigfile.
    600C1410 - 74 78 74 20 20 20 00 00  0D 70 1F F8 63 A7 D9 AD  : txt   .. .p..c...
    600C1420 - 19 FF FF FF FF FF FF FF  FF FF FF FF FF FF FF FF  : ........ ........
    600C1430 - FF FF FF FF FF FF FF FF  FF FF FF FF FF FF FF FF  : ........ ........
    600C1470 - FF FF FF FF FF FF FF FF  FF FF FF FF FF FF FF FF  : ........ ........
    600C1480 - 70 2F F8 6B 36 00 00 00  00 68 09 00 70 2F F8 78  : p/.k6... .h..p/.x
    600C1490 - 88 2E C7 1D FF FF FF FF  FF FF FF FF FF FF FF FF  : ........ ........
    600C14A0 - FF FF FF FF FF FF FF FF  FF FF FF FF FF FF FF FF  : ........ ........
    600C14F0 - FF FF FF FF FF FF FF FF  FF FF FF FF FF FF FF FF  : ........ ........
    600C1500 - 70 1F F0 56 53 4F 4D 45  20 44 41 54 41 20 54 4F  : p..VSOME  DATA TO
    600C1510 - 20 54 45 53 54 0D 0A 53  4F 4D 45 20 44 41 54 41  :  TEST..S OME DATA
    600C1520 - 20 54 4F 20 54 45 53 54  0D 0A 70 1F F0 74 A7 2A  :  TO TEST ..p..t.*
    600C1530 - C0 43 FF FF FF FF FF FF  FF FF FF FF FF FF FF FF  : .C...... ........
    600C1540 - FF FF FF FF FF FF FF FF  FF FF FF FF FF FF FF FF  : ........ ........
    600C1570 - FF FF FF FF FF FF FF FF  FF FF FF FF FF FF FF FF  : ........ ........
    600C1580 - 70 1F EC 74 53 4F 4D 45  20 44 41 54 41 20 54 4F  : p..tSOME  DATA TO
    600C1590 - 20 54 45 53 54 0D 0A 53  4F 4D 45 20 44 41 54 41  :  TEST..S OME DATA
    600C15A0 - 20 54 4F 20 54 45 53 54  0D 0A 70 1F EC 74 1B C0  :  TO TEST ..p..t..
    600C15B0 - 53 49 FF FF FF FF FF FF  FF FF FF FF FF FF FF FF  : SI...... ........
    600C15C0 - FF FF FF FF FF FF FF FF  FF FF FF FF FF FF FF FF  : ........ ........
    600C15F0 - FF FF FF FF FF FF FF FF  FF FF FF FF FF FF FF FF  : ........ ........
    600C1600 - 70 2F E8 5A 37 00 00 00  00 08 00 00 70 2F E8 78  : p/.Z7... ....p/.x
    600C1610 - 5D 65 44 DC FF FF FF FF  FF FF FF FF FF FF FF FF  : ]eD..... ........
    600C1620 - FF FF FF FF FF FF FF FF  FF FF FF FF FF FF FF FF  : ........ ........
    600C1670 - FF FF FF FF FF FF FF FF  FF FF FF FF FF FF FF FF  : ........ ........
    600C1680 - 70 1F F0 49 53 4F 4D 45  20 44 41 54 41 20 54 4F  : p..ISOME  DATA TO
    600C1690 - 20 54 45 53 54 0D 0A 53  4F 4D 45 20 44 41 54 41  :  TEST..S OME DATA
    600C16A0 - 20 54 4F 20 54 45 53 54  0D 0A 53 4F 4D 45 20 44  :  TO TEST ..SOME D
    600C16B0 - 41 54 41 20 54 4F 20 54  45 53 54 0D 0A 70 1F F0  : ATA TO T EST..p..
    600C16C0 - 06 76 1C 9E 94 FF FF FF  FF FF FF FF FF FF FF FF  : .v...... ........
    600C16D0 - FF FF FF FF FF FF FF FF  FF FF FF FF FF FF FF FF  : ........ ........
    ...	 1 duplicate line(s) removed.
    600C16F0 - FF FF FF FF FF FF FF FF  FF FF FF FF FF FF FF FF  : ........ ........
    600C1700 - 70 1F EC 06 53 4F 4D 45  20 44 41 54 41 20 54 4F  : p...SOME  DATA TO
    600C1710 - 20 54 45 53 54 0D 0A 53  4F 4D 45 20 44 41 54 41  :  TEST..S OME DATA
    600C1720 - 20 54 4F 20 54 45 53 54  0D 0A 53 4F 4D 45 20 44  :  TO TEST ..SOME D
    600C1730 - 41 54 41 20 54 4F 20 54  45 53 54 0D 0A 70 1F EC  : ATA TO T EST..p..
    600C1740 - 06 54 22 02 88 FF FF FF  FF FF FF FF FF FF FF FF  : .T"..... ........
    600C1750 - FF FF FF FF FF FF FF FF  FF FF FF FF FF FF FF FF  : ........ ........
    600C1770 - FF FF FF FF FF FF FF FF  FF FF FF FF FF FF FF FF  : ........ ........
    600C1780 - 70 2F E8 37 38 00 00 00  00 0C 00 00 70 2F E8 78  : p/.78... ....p/.x
    600C1790 - 1F 64 40 13 FF FF FF FF  FF FF FF FF FF FF FF FF  : .d@..... ........
    600C17A0 - FF FF FF FF FF FF FF FF  FF FF FF FF FF FF FF FF  : ........ ........
    600C17F0 - FF FF FF FF FF FF FF FF  FF FF FF FF FF FF FF FF  : ........ ........
    600C1800 - 70 1F F0 3C 53 4F 4D 45  20 44 41 54 41 20 54 4F  : p..<SOME  DATA TO
    600C1810 - 20 54 45 53 54 0D 0A 53  4F 4D 45 20 44 41 54 41  :  TEST..S OME DATA
    600C1820 - 20 54 4F 20 54 45 53 54  0D 0A 53 4F 4D 45 20 44  :  TO TEST ..SOME D
    600C1830 - 41 54 41 20 54 4F 20 54  45 53 54 0D 0A 53 4F 4D  : ATA TO T EST..SOM
    600C1840 - 45 20 44 41 54 41 20 54  4F 20 54 45 53 54 0D 0A  : E DATA T O TEST..
    600C1850 - 70 1F F0 60 7C 77 DC 48  FF FF FF FF FF FF FF FF  : p..`|w.H ........
    600C1860 - FF FF FF FF FF FF FF FF  FF FF FF FF FF FF FF FF  : ........ ........
    600C1870 - FF FF FF FF FF FF FF FF  FF FF FF FF FF FF FF FF  : ........ ........
    600C1880 - 70 1F EC 60 53 4F 4D 45  20 44 41 54 41 20 54 4F  : p..`SOME  DATA TO
    600C1890 - 20 54 45 53 54 0D 0A 53  4F 4D 45 20 44 41 54 41  :  TEST..S OME DATA
    600C18A0 - 20 54 4F 20 54 45 53 54  0D 0A 53 4F 4D 45 20 44  :  TO TEST ..SOME D
    600C18B0 - 41 54 41 20 54 4F 20 54  45 53 54 0D 0A 53 4F 4D  : ATA TO T EST..SOM
    600C18C0 - 45 20 44 41 54 41 20 54  4F 20 54 45 53 54 0D 0A  : E DATA T O TEST..
    600C18D0 - 70 1F EC 60 36 09 97 4F  FF FF FF FF FF FF FF FF  : p..`6..O ........
    600C18E0 - FF FF FF FF FF FF FF FF  FF FF FF FF FF FF FF FF  : ........ ........
    600C18F0 - FF FF FF FF FF FF FF FF  FF FF FF FF FF FF FF FF  : ........ ........
    600C1900 - 70 2F E8 24 37 00 00 00  00 10 00 00 70 2F E8 78  : p/.$7... ....p/.x
    600C1910 - C0 C7 67 C8 FF FF FF FF  FF FF FF FF FF FF FF FF  : ..g..... ........
    600C1920 - FF FF FF FF FF FF FF FF  FF FF FF FF FF FF FF FF  : ........ ........
    ...	 108 duplicate line(s) removed.
    600C1FF0 - FF FF FF FF FF FF FF FF  FF FF FF FF FF FF FF FF  : ........ ........
    600C2000 - 2F 01 00 00 2E 01 00 00  7A 7A 7A 7A 7A 7A 7A 7A  : /....... zzzzzzzz
    600C2010 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    ...	 253 duplicate line(s) removed.
    600C2FF0 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    600C3000 - 02 00 00 00 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : ....zzzz zzzzzzzz
    600C3010 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    600C3FF0 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    600C4000 - 03 00 00 00 02 00 00 00  2E 01 00 00 7A 7A 7A 7A  : ........ ....zzzz
    600C4010 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    600C4FF0 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    600C5000 - 04 00 00 00 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : ....zzzz zzzzzzzz
    600C5010 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    600C5FF0 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    600C6000 - 05 00 00 00 04 00 00 00  7A 7A 7A 7A 7A 7A 7A 7A  : ........ zzzzzzzz
    600C6010 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    600C6FF0 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    600C7000 - 06 00 00 00 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : ....zzzz zzzzzzzz
    600C7010 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    600C7FF0 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    600C8000 - 07 00 00 00 06 00 00 00  04 00 00 00 2E 01 00 00  : ........ ........
    600C8010 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    600C8FF0 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    600C9000 - 08 00 00 00 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : ....zzzz zzzzzzzz
    600C9010 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    600C9FF0 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    600CA000 - 09 00 00 00 08 00 00 00  7A 7A 7A 7A 7A 7A 7A 7A  : ........ zzzzzzzz
    600CA010 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    600CAFF0 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    600CB000 - 0A 00 00 00 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : ....zzzz zzzzzzzz
    600CB010 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    600CBFF0 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    600CC000 - 0B 00 00 00 0A 00 00 00  08 00 00 00 7A 7A 7A 7A  : ........ ....zzzz
    600CC010 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    600CCFF0 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    600CD000 - 0C 00 00 00 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : ....zzzz zzzzzzzz
    600CD010 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    600CDFF0 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    600CE000 - 0D 00 00 00 0C 00 00 00  7A 7A 7A 7A 7A 7A 7A 7A  : ........ zzzzzzzz
    600CE010 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    600CEFF0 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    600CF000 - 0E 00 00 00 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : ....zzzz zzzzzzzz
    600CF010 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    600CFFF0 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    600D0000 - 0F 00 00 00 0E 00 00 00  0C 00 00 00 08 00 00 00  : ........ ........
    600D0010 - 2E 01 00 00 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : ....zzzz zzzzzzzz
    600D0020 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    ...	 252 duplicate line(s) removed.
    600D0FF0 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    600D1000 - 10 00 00 00 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : ....zzzz zzzzzzzz
    600D1010 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    600D1FF0 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    600D2000 - 11 00 00 00 10 00 00 00  7A 7A 7A 7A 7A 7A 7A 7A  : ........ zzzzzzzz
    600D2010 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    600D2FF0 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    600D3000 - 12 00 00 00 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : ....zzzz zzzzzzzz
    600D3010 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    600D3FF0 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    600D4000 - 13 00 00 00 12 00 00 00  10 00 00 00 7A 7A 7A 7A  : ........ ....zzzz
    600D4010 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    600D4FF0 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    600D5000 - 14 00 00 00 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : ....zzzz zzzzzzzz
    600D5010 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    600D5FF0 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    600D6000 - 15 00 00 00 14 00 00 00  7A 7A 7A 7A 7A 7A 7A 7A  : ........ zzzzzzzz
    600D6010 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    600D6FF0 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    600D7000 - 16 00 00 00 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : ....zzzz zzzzzzzz
    600D7010 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    600D7FF0 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    600D8000 - 17 00 00 00 16 00 00 00  14 00 00 00 10 00 00 00  : ........ ........
    600D8010 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    600D8FF0 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    600D9000 - 18 00 00 00 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : ....zzzz zzzzzzzz
    600D9010 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    600D9FF0 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    600DA000 - 19 00 00 00 18 00 00 00  7A 7A 7A 7A 7A 7A 7A 7A  : ........ zzzzzzzz
    600DA010 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    600DAFF0 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    600DB000 - 1A 00 00 00 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : ....zzzz zzzzzzzz
    600DB010 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    600DBFF0 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    600DC000 - 1B 00 00 00 1A 00 00 00  18 00 00 00 7A 7A 7A 7A  : ........ ....zzzz
    600DC010 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    600DCFF0 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    600DD000 - 1C 00 00 00 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : ....zzzz zzzzzzzz
    600DD010 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    600DDFF0 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    600DE000 - 1D 00 00 00 1C 00 00 00  7A 7A 7A 7A 7A 7A 7A 7A  : ........ zzzzzzzz
    600DE010 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    600DEFF0 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    600DF000 - 1E 00 00 00 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : ....zzzz zzzzzzzz
    600DF010 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    600DFFF0 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    600E0000 - 1F 00 00 00 1E 00 00 00  1C 00 00 00 18 00 00 00  : ........ ........
    600E0010 - 10 00 00 00 2E 01 00 00  0E 01 00 00 CE 00 00 00  : ........ ........
    600E0020 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    600E0FF0 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    600E1000 - 20 00 00 00 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  :  ...zzzz zzzzzzzz
    600E1010 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    600E1FF0 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    600E2000 - 21 00 00 00 20 00 00 00  7A 7A 7A 7A 7A 7A 7A 7A  : !... ... zzzzzzzz
    600E2010 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    600E2FF0 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    600E3000 - 22 00 00 00 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : "...zzzz zzzzzzzz
    600E3010 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    600E3FF0 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    600E4000 - 23 00 00 00 22 00 00 00  20 00 00 00 7A 7A 7A 7A  : #..."...  ...zzzz
    600E4010 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    600E4FF0 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    600E5000 - 24 00 00 00 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : $...zzzz zzzzzzzz
    600E5010 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    600E5FF0 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    600E6000 - 25 00 00 00 24 00 00 00  7A 7A 7A 7A 7A 7A 7A 7A  : %...$... zzzzzzzz
    600E6010 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    600E6FF0 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    600E7000 - 26 00 00 00 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : &...zzzz zzzzzzzz
    600E7010 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    600E7FF0 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    600E8000 - 27 00 00 00 26 00 00 00  24 00 00 00 20 00 00 00  : '...&... $... ...
    600E8010 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    600E8FF0 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    600E9000 - 28 00 00 00 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : (...zzzz zzzzzzzz
    600E9010 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    600E9FF0 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    600EA000 - 29 00 00 00 28 00 00 00  7A 7A 7A 7A 7A 7A 7A 7A  : )...(... zzzzzzzz
    600EA010 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    600EAFF0 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    600EB000 - 2A 00 00 00 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : *...zzzz zzzzzzzz
    600EB010 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    600EBFF0 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    600EC000 - 2B 00 00 00 2A 00 00 00  28 00 00 00 7A 7A 7A 7A  : +...*... (...zzzz
    600EC010 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    600ECFF0 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    600ED000 - 2C 00 00 00 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : ,...zzzz zzzzzzzz
    600ED010 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    600EDFF0 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    600EE000 - 2D 00 00 00 2C 00 00 00  7A 7A 7A 7A 7A 7A 7A 7A  : -...,... zzzzzzzz
    600EE010 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    600EEFF0 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    600EF000 - 2E 00 00 00 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : ....zzzz zzzzzzzz
    600EF010 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    600EFFF0 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    600F0000 - 2F 00 00 00 2E 00 00 00  2C 00 00 00 28 00 00 00  : /....... ,...(...
    600F0010 - 20 00 00 00 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  :  ...zzzz zzzzzzzz
    600F0020 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    600F0FF0 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    600F1000 - 30 00 00 00 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : 0...zzzz zzzzzzzz
    600F1010 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    600F1FF0 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    600F2000 - 31 00 00 00 30 00 00 00  7A 7A 7A 7A 7A 7A 7A 7A  : 1...0... zzzzzzzz
    600F2010 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    600F2FF0 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    600F3000 - 32 00 00 00 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : 2...zzzz zzzzzzzz
    600F3010 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    600F3FF0 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    600F4000 - 33 00 00 00 32 00 00 00  30 00 00 00 7A 7A 7A 7A  : 3...2... 0...zzzz
    600F4010 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    600F4FF0 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    600F5000 - 34 00 00 00 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : 4...zzzz zzzzzzzz
    600F5010 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    600F5FF0 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    600F6000 - 35 00 00 00 34 00 00 00  7A 7A 7A 7A 7A 7A 7A 7A  : 5...4... zzzzzzzz
    600F6010 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    ...	 199 duplicate line(s) removed.
    600F6C90 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    600F6CA0 - FF FF FF FF FF FF FF FF  FF FF FF FF FF FF FF FF  : ........ ........
    ...	 52 duplicate line(s) removed.
    600F6FF0 - FF FF FF FF FF FF FF FF  FF FF FF FF FF FF FF FF  : ........ ........
    600F7000 - 54 65 73 74 20 66 6F 72  20 53 4F 4D 45 20 44 41  : Test for  SOME DA
    600F7010 - 54 41 20 54 4F 20 54 45  53 54 00 54 65 73 74 20  : TA TO TE ST.Test
    600F7020 - 66 6F 72 20 53 4F 4D 45  20 44 41 54 41 20 54 4F  : for SOME  DATA TO
    600F7030 - 20 54 45 53 54 00 54 65  73 74 20 66 6F 72 20 53  :  TEST.Te st for S
    600F7040 - 4F 4D 45 20 44 41 54 41  20 54 4F 20 54 45 53 54  : OME DATA  TO TEST
    600F7050 - 00 54 65 73 74 20 66 6F  72 20 53 4F 4D 45 20 44  : .Test fo r SOME D
    600F7060 - 41 54 41 20 54 4F 20 54  45 53 54 00 54 65 73 74  : ATA TO T EST.Test
    600F7070 - 20 66 6F 72 20 53 4F 4D  45 20 44 41 54 41 20 54  :  for SOM E DATA T
    600F7080 - 4F 20 54 45 53 54 00 54  65 73 74 20 66 6F 72 20  : O TEST.T est for
    600F7090 - 53 4F 4D 45 20 44 41 54  41 20 54 4F 20 54 45 53  : SOME DAT A TO TES
    600F70A0 - 54 00 54 65 73 74 20 66  6F 72 20 53 4F 4D 45 20  : T.Test f or SOME
    600F70B0 - 44 41 54 41 20 54 4F 20  54 45 53 54 00 54 65 73  : DATA TO  TEST.Tes
    600F70C0 - 74 20 66 6F 72 20 53 4F  4D 45 20 44 41 54 41 20  : t for SO ME DATA
    600F70D0 - 54 4F 20 54 45 53 54 00  54 65 73 74 20 66 6F 72  : TO TEST. Test for
    600F70E0 - 20 53 4F 4D 45 20 44 41  54 41 20 54 4F 20 54 45  :  SOME DA TA TO TE
    600F70F0 - 53 54 00 54 65 73 74 20  66 6F 72 20 53 4F 4D 45  : ST.Test  for SOME
    600F7100 - 20 44 41 54 41 20 54 4F  20 54 45 53 54 00 54 65  :  DATA TO  TEST.Te
    600F7110 - 73 74 20 66 6F 72 20 53  4F 4D 45 20 44 41 54 41  : st for S OME DATA
    600F7120 - 20 54 4F 20 54 45 53 54  00 54 65 73 74 20 66 6F  :  TO TEST .Test fo
    600F7130 - 72 20 53 4F 4D 45 20 44  41 54 41 20 54 4F 20 54  : r SOME D ATA TO T
    600F7140 - 45 53 54 00 54 65 73 74  20 66 6F 72 20 53 4F 4D  : EST.Test  for SOM
    600F7150 - 45 20 44 41 54 41 20 54  4F 20 54 45 53 54 00 54  : E DATA T O TEST.T
    600F7160 - 65 73 74 20 66 6F 72 20  53 4F 4D 45 20 44 41 54  : est for  SOME DAT
    600F7170 - 41 20 54 4F 20 54 45 53  54 00 54 65 73 74 20 66  : A TO TES T.Test f
    600F7180 - 6F 72 20 53 4F 4D 45 20  44 41 54 41 20 54 4F 20  : or SOME  DATA TO
    600F7190 - 54 45 53 54 00 54 65 73  74 20 66 6F 72 20 53 4F  : TEST.Tes t for SO
    600F71A0 - 4D 45 20 44 41 54 41 20  54 4F 20 54 45 53 54 00  : ME DATA  TO TEST.
    600F71B0 - 54 65 73 74 20 66 6F 72  20 53 4F 4D 45 20 44 41  : Test for  SOME DA
    600F71C0 - 54 41 20 54 4F 20 54 45  53 54 00 54 65 73 74 20  : TA TO TE ST.Test
    600F71D0 - 66 6F 72 20 53 4F 4D 45  20 44 41 54 41 20 54 4F  : for SOME  DATA TO
    600F71E0 - 20 54 45 53 54 00 FF FF  FF FF FF FF FF FF FF FF  :  TEST... ........
    600F71F0 - FF FF FF FF FF FF FF FF  FF FF FF FF FF FF FF FF  : ........ ........
    600F7200 - 54 65 73 74 20 66 6F 72  20 53 4F 4D 45 20 44 41  : Test for  SOME DA
    600F7210 - 54 41 20 54 4F 20 54 45  53 54 00 54 65 73 74 20  : TA TO TE ST.Test
    600F7220 - 66 6F 72 20 53 4F 4D 45  20 44 41 54 41 20 54 4F  : for SOME  DATA TO
    600F7230 - 20 54 45 53 54 00 54 65  73 74 20 66 6F 72 20 53  :  TEST.Te st for S
    600F7240 - 4F 4D 45 20 44 41 54 41  20 54 4F 20 54 45 53 54  : OME DATA  TO TEST
    600F7250 - 00 54 65 73 74 20 66 6F  72 20 53 4F 4D 45 20 44  : .Test fo r SOME D
    600F7260 - 41 54 41 20 54 4F 20 54  45 53 54 00 54 65 73 74  : ATA TO T EST.Test
    600F7270 - 20 66 6F 72 20 53 4F 4D  45 20 44 41 54 41 20 54  :  for SOM E DATA T
    600F7280 - 4F 20 54 45 53 54 00 54  65 73 74 20 66 6F 72 20  : O TEST.T est for
    600F7290 - 53 4F 4D 45 20 44 41 54  41 20 54 4F 20 54 45 53  : SOME DAT A TO TES
    600F72A0 - 54 00 54 65 73 74 20 66  6F 72 20 53 4F 4D 45 20  : T.Test f or SOME
    600F72B0 - 44 41 54 41 20 54 4F 20  54 45 53 54 00 54 65 73  : DATA TO  TEST.Tes
    600F72C0 - 74 20 66 6F 72 20 53 4F  4D 45 20 44 41 54 41 20  : t for SO ME DATA
    600F72D0 - 54 4F 20 54 45 53 54 00  54 65 73 74 20 66 6F 72  : TO TEST. Test for
    600F72E0 - 20 53 4F 4D 45 20 44 41  54 41 20 54 4F 20 54 45  :  SOME DA TA TO TE
    600F72F0 - 53 54 00 54 65 73 74 20  66 6F 72 20 53 4F 4D 45  : ST.Test  for SOME
    600F7300 - 20 44 41 54 41 20 54 4F  20 54 45 53 54 00 54 65  :  DATA TO  TEST.Te
    600F7310 - 73 74 20 66 6F 72 20 53  4F 4D 45 20 44 41 54 41  : st for S OME DATA
    600F7320 - 20 54 4F 20 54 45 53 54  00 54 65 73 74 20 66 6F  :  TO TEST .Test fo
    600F7330 - 72 20 53 4F 4D 45 20 44  41 54 41 20 54 4F 20 54  : r SOME D ATA TO T
    600F7340 - 45 53 54 00 54 65 73 74  20 66 6F 72 20 53 4F 4D  : EST.Test  for SOM
    600F7350 - 45 20 44 41 54 41 20 54  4F 20 54 45 53 54 00 54  : E DATA T O TEST.T
    600F7360 - 65 73 74 20 66 6F 72 20  53 4F 4D 45 20 44 41 54  : est for  SOME DAT
    600F7370 - 41 20 54 4F 20 54 45 53  54 00 54 65 73 74 20 66  : A TO TES T.Test f
    600F7380 - 6F 72 20 53 4F 4D 45 20  44 41 54 41 20 54 4F 20  : or SOME  DATA TO
    600F7390 - 54 45 53 54 00 54 65 73  74 20 66 6F 72 20 53 4F  : TEST.Tes t for SO
    600F73A0 - 4D 45 20 44 41 54 41 20  54 4F 20 54 45 53 54 00  : ME DATA  TO TEST.
    600F73B0 - 54 65 73 74 20 66 6F 72  20 53 4F 4D 45 20 44 41  : Test for  SOME DA
    600F73C0 - 54 41 20 54 4F 20 54 45  53 54 00 54 65 73 74 20  : TA TO TE ST.Test
    600F73D0 - 66 6F 72 20 53 4F 4D 45  20 44 41 54 41 20 54 4F  : for SOME  DATA TO
    600F73E0 - 20 54 45 53 54 00 FF FF  FF FF FF FF FF FF FF FF  :  TEST... ........
    600F73F0 - FF FF FF FF FF FF FF FF  FF FF FF FF FF FF FF FF  : ........ ........
    600F7400 - 54 65 73 74 20 66 6F 72  20 53 4F 4D 45 20 44 41  : Test for  SOME DA
    600F7410 - 54 41 20 54 4F 20 54 45  53 54 00 54 65 73 74 20  : TA TO TE ST.Test
    600F7420 - 66 6F 72 20 53 4F 4D 45  20 44 41 54 41 20 54 4F  : for SOME  DATA TO
    600F7430 - 20 54 45 53 54 00 54 65  73 74 20 66 6F 72 20 53  :  TEST.Te st for S
    600F7440 - 4F 4D 45 20 44 41 54 41  20 54 4F 20 54 45 53 54  : OME DATA  TO TEST
    600F7450 - 00 54 65 73 74 20 66 6F  72 20 53 4F 4D 45 20 44  : .Test fo r SOME D
    600F7460 - 41 54 41 20 54 4F 20 54  45 53 54 00 54 65 73 74  : ATA TO T EST.Test
    600F7470 - 20 66 6F 72 20 53 4F 4D  45 20 44 41 54 41 20 54  :  for SOM E DATA T
    600F7480 - 4F 20 54 45 53 54 00 54  65 73 74 20 66 6F 72 20  : O TEST.T est for
    600F7490 - 53 4F 4D 45 20 44 41 54  41 20 54 4F 20 54 45 53  : SOME DAT A TO TES
    600F74A0 - 54 00 54 65 73 74 20 66  6F 72 20 53 4F 4D 45 20  : T.Test f or SOME
    600F74B0 - 44 41 54 41 20 54 4F 20  54 45 53 54 00 54 65 73  : DATA TO  TEST.Tes
    600F74C0 - 74 20 66 6F 72 20 53 4F  4D 45 20 44 41 54 41 20  : t for SO ME DATA
    600F74D0 - 54 4F 20 54 45 53 54 00  54 65 73 74 20 66 6F 72  : TO TEST. Test for
    600F74E0 - 20 53 4F 4D 45 20 44 41  54 41 20 54 4F 20 54 45  :  SOME DA TA TO TE
    600F74F0 - 53 54 00 54 65 73 74 20  66 6F 72 20 53 4F 4D 45  : ST.Test  for SOME
    600F7500 - 20 44 41 54 41 20 54 4F  20 54 45 53 54 00 54 65  :  DATA TO  TEST.Te
    600F7510 - 73 74 20 66 6F 72 20 53  4F 4D 45 20 44 41 54 41  : st for S OME DATA
    600F7520 - 20 54 4F 20 54 45 53 54  00 54 65 73 74 20 66 6F  :  TO TEST .Test fo
    600F7530 - 72 20 53 4F 4D 45 20 44  41 54 41 20 54 4F 20 54  : r SOME D ATA TO T
    600F7540 - 45 53 54 00 54 65 73 74  20 66 6F 72 20 53 4F 4D  : EST.Test  for SOM
    600F7550 - 45 20 44 41 54 41 20 54  4F 20 54 45 53 54 00 54  : E DATA T O TEST.T
    600F7560 - 65 73 74 20 66 6F 72 20  53 4F 4D 45 20 44 41 54  : est for  SOME DAT
    600F7570 - 41 20 54 4F 20 54 45 53  54 00 54 65 73 74 20 66  : A TO TES T.Test f
    600F7580 - 6F 72 20 53 4F 4D 45 20  44 41 54 41 20 54 4F 20  : or SOME  DATA TO
    600F7590 - 54 45 53 54 00 54 65 73  74 20 66 6F 72 20 53 4F  : TEST.Tes t for SO
    600F75A0 - 4D 45 20 44 41 54 41 20  54 4F 20 54 45 53 54 00  : ME DATA  TO TEST.
    600F75B0 - 54 65 73 74 20 66 6F 72  20 53 4F 4D 45 20 44 41  : Test for  SOME DA
    600F75C0 - 54 41 20 54 4F 20 54 45  53 54 00 54 65 73 74 20  : TA TO TE ST.Test
    600F75D0 - 66 6F 72 20 53 4F 4D 45  20 44 41 54 41 20 54 4F  : for SOME  DATA TO
    600F75E0 - 20 54 45 53 54 00 FF FF  FF FF FF FF FF FF FF FF  :  TEST... ........
    600F75F0 - FF FF FF FF FF FF FF FF  FF FF FF FF FF FF FF FF  : ........ ........
    600F7600 - 54 65 73 74 20 66 6F 72  20 53 4F 4D 45 20 44 41  : Test for  SOME DA
    600F7610 - 54 41 20 54 4F 20 54 45  53 54 00 54 65 73 74 20  : TA TO TE ST.Test
    600F7620 - 66 6F 72 20 53 4F 4D 45  20 44 41 54 41 20 54 4F  : for SOME  DATA TO
    600F7630 - 20 54 45 53 54 00 54 65  73 74 20 66 6F 72 20 53  :  TEST.Te st for S
    600F7640 - 4F 4D 45 20 44 41 54 41  20 54 4F 20 54 45 53 54  : OME DATA  TO TEST
    600F7650 - 00 54 65 73 74 20 66 6F  72 20 53 4F 4D 45 20 44  : .Test fo r SOME D
    600F7660 - 41 54 41 20 54 4F 20 54  45 53 54 00 54 65 73 74  : ATA TO T EST.Test
    600F7670 - 20 66 6F 72 20 53 4F 4D  45 20 44 41 54 41 20 54  :  for SOM E DATA T
    600F7680 - 4F 20 54 45 53 54 00 54  65 73 74 20 66 6F 72 20  : O TEST.T est for
    600F7690 - 53 4F 4D 45 20 44 41 54  41 20 54 4F 20 54 45 53  : SOME DAT A TO TES
    600F76A0 - 54 00 54 65 73 74 20 66  6F 72 20 53 4F 4D 45 20  : T.Test f or SOME
    600F76B0 - 44 41 54 41 20 54 4F 20  54 45 53 54 00 54 65 73  : DATA TO  TEST.Tes
    600F76C0 - 74 20 66 6F 72 20 53 4F  4D 45 20 44 41 54 41 20  : t for SO ME DATA
    600F76D0 - 54 4F 20 54 45 53 54 00  54 65 73 74 20 66 6F 72  : TO TEST. Test for
    600F76E0 - 20 53 4F 4D 45 20 44 41  54 41 20 54 4F 20 54 45  :  SOME DA TA TO TE
    600F76F0 - 53 54 00 54 65 73 74 20  66 6F 72 20 53 4F 4D 45  : ST.Test  for SOME
    600F7700 - 20 44 41 54 41 20 54 4F  20 54 45 53 54 00 54 65  :  DATA TO  TEST.Te
    600F7710 - 73 74 20 66 6F 72 20 53  4F 4D 45 20 44 41 54 41  : st for S OME DATA
    600F7720 - 20 54 4F 20 54 45 53 54  00 54 65 73 74 20 66 6F  :  TO TEST .Test fo
    600F7730 - 72 20 53 4F 4D 45 20 44  41 54 41 20 54 4F 20 54  : r SOME D ATA TO T
    600F7740 - 45 53 54 00 54 65 73 74  20 66 6F 72 20 53 4F 4D  : EST.Test  for SOM
    600F7750 - 45 20 44 41 54 41 20 54  4F 20 54 45 53 54 00 54  : E DATA T O TEST.T
    600F7760 - 65 73 74 20 66 6F 72 20  53 4F 4D 45 20 44 41 54  : est for  SOME DAT
    600F7770 - 41 20 54 4F 20 54 45 53  54 00 54 65 73 74 20 66  : A TO TES T.Test f
    600F7780 - 6F 72 20 53 4F 4D 45 20  44 41 54 41 20 54 4F 20  : or SOME  DATA TO
    600F7790 - 54 45 53 54 00 54 65 73  74 20 66 6F 72 20 53 4F  : TEST.Tes t for SO
    600F77A0 - 4D 45 20 44 41 54 41 20  54 4F 20 54 45 53 54 00  : ME DATA  TO TEST.
    600F77B0 - 54 65 73 74 20 66 6F 72  20 53 4F 4D 45 20 44 41  : Test for  SOME DA
    600F77C0 - 54 41 20 54 4F 20 54 45  53 54 00 54 65 73 74 20  : TA TO TE ST.Test
    600F77D0 - 66 6F 72 20 53 4F 4D 45  20 44 41 54 41 20 54 4F  : for SOME  DATA TO
    600F77E0 - 20 54 45 53 54 00 FF FF  FF FF FF FF FF FF FF FF  :  TEST... ........
    600F77F0 - FF FF FF FF FF FF FF FF  FF FF FF FF FF FF FF FF  : ........ ........
    600F7800 - 54 65 73 74 20 66 6F 72  20 53 4F 4D 45 20 44 41  : Test for  SOME DA
    600F7810 - 54 41 20 54 4F 20 54 45  53 54 00 54 65 73 74 20  : TA TO TE ST.Test
    600F7820 - 66 6F 72 20 53 4F 4D 45  20 44 41 54 41 20 54 4F  : for SOME  DATA TO
    600F7830 - 20 54 45 53 54 00 54 65  73 74 20 66 6F 72 20 53  :  TEST.Te st for S
    600F7840 - 4F 4D 45 20 44 41 54 41  20 54 4F 20 54 45 53 54  : OME DATA  TO TEST
    600F7850 - 00 54 65 73 74 20 66 6F  72 20 53 4F 4D 45 20 44  : .Test fo r SOME D
    600F7860 - 41 54 41 20 54 4F 20 54  45 53 54 00 54 65 73 74  : ATA TO T EST.Test
    600F7870 - 20 66 6F 72 20 53 4F 4D  45 20 44 41 54 41 20 54  :  for SOM E DATA T
    600F7880 - 4F 20 54 45 53 54 00 54  65 73 74 20 66 6F 72 20  : O TEST.T est for
    600F7890 - 53 4F 4D 45 20 44 41 54  41 20 54 4F 20 54 45 53  : SOME DAT A TO TES
    600F78A0 - 54 00 54 65 73 74 20 66  6F 72 20 53 4F 4D 45 20  : T.Test f or SOME
    600F78B0 - 44 41 54 41 20 54 4F 20  54 45 53 54 00 54 65 73  : DATA TO  TEST.Tes
    600F78C0 - 74 20 66 6F 72 20 53 4F  4D 45 20 44 41 54 41 20  : t for SO ME DATA
    600F78D0 - 54 4F 20 54 45 53 54 00  54 65 73 74 20 66 6F 72  : TO TEST. Test for
    600F78E0 - 20 53 4F 4D 45 20 44 41  54 41 20 54 4F 20 54 45  :  SOME DA TA TO TE
    600F78F0 - 53 54 00 54 65 73 74 20  66 6F 72 20 53 4F 4D 45  : ST.Test  for SOME
    600F7900 - 20 44 41 54 41 20 54 4F  20 54 45 53 54 00 54 65  :  DATA TO  TEST.Te
    600F7910 - 73 74 20 66 6F 72 20 53  4F 4D 45 20 44 41 54 41  : st for S OME DATA
    600F7920 - 20 54 4F 20 54 45 53 54  00 54 65 73 74 20 66 6F  :  TO TEST .Test fo
    600F7930 - 72 20 53 4F 4D 45 20 44  41 54 41 20 54 4F 20 54  : r SOME D ATA TO T
    600F7940 - 45 53 54 00 54 65 73 74  20 66 6F 72 20 53 4F 4D  : EST.Test  for SOM
    600F7950 - 45 20 44 41 54 41 20 54  4F 20 54 45 53 54 00 54  : E DATA T O TEST.T
    600F7960 - 65 73 74 20 66 6F 72 20  53 4F 4D 45 20 44 41 54  : est for  SOME DAT
    600F7970 - 41 20 54 4F 20 54 45 53  54 00 54 65 73 74 20 66  : A TO TES T.Test f
    600F7980 - 6F 72 20 53 4F 4D 45 20  44 41 54 41 20 54 4F 20  : or SOME  DATA TO
    600F7990 - 54 45 53 54 00 54 65 73  74 20 66 6F 72 20 53 4F  : TEST.Tes t for SO
    600F79A0 - 4D 45 20 44 41 54 41 20  54 4F 20 54 45 53 54 00  : ME DATA  TO TEST.
    600F79B0 - 54 65 73 74 20 66 6F 72  20 53 4F 4D 45 20 44 41  : Test for  SOME DA
    600F79C0 - 54 41 20 54 4F 20 54 45  53 54 00 54 65 73 74 20  : TA TO TE ST.Test
    600F79D0 - 66 6F 72 20 53 4F 4D 45  20 44 41 54 41 20 54 4F  : for SOME  DATA TO
    600F79E0 - 20 54 45 53 54 00 FF FF  FF FF FF FF FF FF FF FF  :  TEST... ........
    600F79F0 - FF FF FF FF FF FF FF FF  FF FF FF FF FF FF FF FF  : ........ ........
    600F7A00 - 54 65 73 74 20 66 6F 72  20 53 4F 4D 45 20 44 41  : Test for  SOME DA
    600F7A10 - 54 41 20 54 4F 20 54 45  53 54 00 54 65 73 74 20  : TA TO TE ST.Test
    600F7A20 - 66 6F 72 20 53 4F 4D 45  20 44 41 54 41 20 54 4F  : for SOME  DATA TO
    600F7A30 - 20 54 45 53 54 00 54 65  73 74 20 66 6F 72 20 53  :  TEST.Te st for S
    600F7A40 - 4F 4D 45 20 44 41 54 41  20 54 4F 20 54 45 53 54  : OME DATA  TO TEST
    600F7A50 - 00 54 65 73 74 20 66 6F  72 20 53 4F 4D 45 20 44  : .Test fo r SOME D
    600F7A60 - 41 54 41 20 54 4F 20 54  45 53 54 00 54 65 73 74  : ATA TO T EST.Test
    600F7A70 - 20 66 6F 72 20 53 4F 4D  45 20 44 41 54 41 20 54  :  for SOM E DATA T
    600F7A80 - 4F 20 54 45 53 54 00 54  65 73 74 20 66 6F 72 20  : O TEST.T est for
    600F7A90 - 53 4F 4D 45 20 44 41 54  41 20 54 4F 20 54 45 53  : SOME DAT A TO TES
    600F7AA0 - 54 00 54 65 73 74 20 66  6F 72 20 53 4F 4D 45 20  : T.Test f or SOME
    600F7AB0 - 44 41 54 41 20 54 4F 20  54 45 53 54 00 54 65 73  : DATA TO  TEST.Tes
    600F7AC0 - 74 20 66 6F 72 20 53 4F  4D 45 20 44 41 54 41 20  : t for SO ME DATA
    600F7AD0 - 54 4F 20 54 45 53 54 00  54 65 73 74 20 66 6F 72  : TO TEST. Test for
    600F7AE0 - 20 53 4F 4D 45 20 44 41  54 41 20 54 4F 20 54 45  :  SOME DA TA TO TE
    600F7AF0 - 53 54 00 54 65 73 74 20  66 6F 72 20 53 4F 4D 45  : ST.Test  for SOME
    600F7B00 - 20 44 41 54 41 20 54 4F  20 54 45 53 54 00 54 65  :  DATA TO  TEST.Te
    600F7B10 - 73 74 20 66 6F 72 20 53  4F 4D 45 20 44 41 54 41  : st for S OME DATA
    600F7B20 - 20 54 4F 20 54 45 53 54  00 54 65 73 74 20 66 6F  :  TO TEST .Test fo
    600F7B30 - 72 20 53 4F 4D 45 20 44  41 54 41 20 54 4F 20 54  : r SOME D ATA TO T
    600F7B40 - 45 53 54 00 54 65 73 74  20 66 6F 72 20 53 4F 4D  : EST.Test  for SOM
    600F7B50 - 45 20 44 41 54 41 20 54  4F 20 54 45 53 54 00 54  : E DATA T O TEST.T
    600F7B60 - 65 73 74 20 66 6F 72 20  53 4F 4D 45 20 44 41 54  : est for  SOME DAT
    600F7B70 - 41 20 54 4F 20 54 45 53  54 00 54 65 73 74 20 66  : A TO TES T.Test f
    600F7B80 - 6F 72 20 53 4F 4D 45 20  44 41 54 41 20 54 4F 20  : or SOME  DATA TO
    600F7B90 - 54 45 53 54 00 54 65 73  74 20 66 6F 72 20 53 4F  : TEST.Tes t for SO
    600F7BA0 - 4D 45 20 44 41 54 41 20  54 4F 20 54 45 53 54 00  : ME DATA  TO TEST.
    600F7BB0 - 54 65 73 74 20 66 6F 72  20 53 4F 4D 45 20 44 41  : Test for  SOME DA
    600F7BC0 - 54 41 20 54 4F 20 54 45  53 54 00 54 65 73 74 20  : TA TO TE ST.Test
    600F7BD0 - 66 6F 72 20 53 4F 4D 45  20 44 41 54 41 20 54 4F  : for SOME  DATA TO
    600F7BE0 - 20 54 45 53 54 00 FF FF  FF FF FF FF FF FF FF FF  :  TEST... ........
    600F7BF0 - FF FF FF FF FF FF FF FF  FF FF FF FF FF FF FF FF  : ........ ........
    600F7C00 - 54 65 73 74 20 66 6F 72  20 53 4F 4D 45 20 44 41  : Test for  SOME DA
    600F7C10 - 54 41 20 54 4F 20 54 45  53 54 00 54 65 73 74 20  : TA TO TE ST.Test
    600F7C20 - 66 6F 72 20 53 4F 4D 45  20 44 41 54 41 20 54 4F  : for SOME  DATA TO
    600F7C30 - 20 54 45 53 54 00 54 65  73 74 20 66 6F 72 20 53  :  TEST.Te st for S
    600F7C40 - 4F 4D 45 20 44 41 54 41  20 54 4F 20 54 45 53 54  : OME DATA  TO TEST
    600F7C50 - 00 54 65 73 74 20 66 6F  72 20 53 4F 4D 45 20 44  : .Test fo r SOME D
    600F7C60 - 41 54 41 20 54 4F 20 54  45 53 54 00 54 65 73 74  : ATA TO T EST.Test
    600F7C70 - 20 66 6F 72 20 53 4F 4D  45 20 44 41 54 41 20 54  :  for SOM E DATA T
    600F7C80 - 4F 20 54 45 53 54 00 54  65 73 74 20 66 6F 72 20  : O TEST.T est for
    600F7C90 - 53 4F 4D 45 20 44 41 54  41 20 54 4F 20 54 45 53  : SOME DAT A TO TES
    600F7CA0 - 54 00 54 65 73 74 20 66  6F 72 20 53 4F 4D 45 20  : T.Test f or SOME
    600F7CB0 - 44 41 54 41 20 54 4F 20  54 45 53 54 00 54 65 73  : DATA TO  TEST.Tes
    600F7CC0 - 74 20 66 6F 72 20 53 4F  4D 45 20 44 41 54 41 20  : t for SO ME DATA
    600F7CD0 - 54 4F 20 54 45 53 54 00  54 65 73 74 20 66 6F 72  : TO TEST. Test for
    600F7CE0 - 20 53 4F 4D 45 20 44 41  54 41 20 54 4F 20 54 45  :  SOME DA TA TO TE
    600F7CF0 - 53 54 00 54 65 73 74 20  66 6F 72 20 53 4F 4D 45  : ST.Test  for SOME
    600F7D00 - 20 44 41 54 41 20 54 4F  20 54 45 53 54 00 54 65  :  DATA TO  TEST.Te
    600F7D10 - 73 74 20 66 6F 72 20 53  4F 4D 45 20 44 41 54 41  : st for S OME DATA
    600F7D20 - 20 54 4F 20 54 45 53 54  00 54 65 73 74 20 66 6F  :  TO TEST .Test fo
    600F7D30 - 72 20 53 4F 4D 45 20 44  41 54 41 20 54 4F 20 54  : r SOME D ATA TO T
    600F7D40 - 45 53 54 00 54 65 73 74  20 66 6F 72 20 53 4F 4D  : EST.Test  for SOM
    600F7D50 - 45 20 44 41 54 41 20 54  4F 20 54 45 53 54 00 54  : E DATA T O TEST.T
    600F7D60 - 65 73 74 20 66 6F 72 20  53 4F 4D 45 20 44 41 54  : est for  SOME DAT
    600F7D70 - 41 20 54 4F 20 54 45 53  54 00 54 65 73 74 20 66  : A TO TES T.Test f
    600F7D80 - 6F 72 20 53 4F 4D 45 20  44 41 54 41 20 54 4F 20  : or SOME  DATA TO
    600F7D90 - 54 45 53 54 00 54 65 73  74 20 66 6F 72 20 53 4F  : TEST.Tes t for SO
    600F7DA0 - 4D 45 20 44 41 54 41 20  54 4F 20 54 45 53 54 00  : ME DATA  TO TEST.
    600F7DB0 - 54 65 73 74 20 66 6F 72  20 53 4F 4D 45 20 44 41  : Test for  SOME DA
    600F7DC0 - 54 41 20 54 4F 20 54 45  53 54 00 54 65 73 74 20  : TA TO TE ST.Test
    600F7DD0 - 66 6F 72 20 53 4F 4D 45  20 44 41 54 41 20 54 4F  : for SOME  DATA TO
    600F7DE0 - 20 54 45 53 54 00 FF FF  FF FF FF FF FF FF FF FF  :  TEST... ........
    600F7DF0 - FF FF FF FF FF FF FF FF  FF FF FF FF FF FF FF FF  : ........ ........
    600F7E00 - 54 65 73 74 20 66 6F 72  20 53 4F 4D 45 20 44 41  : Test for  SOME DA
    600F7E10 - 54 41 20 54 4F 20 54 45  53 54 00 54 65 73 74 20  : TA TO TE ST.Test
    600F7E20 - 66 6F 72 20 53 4F 4D 45  20 44 41 54 41 20 54 4F  : for SOME  DATA TO
    600F7E30 - 20 54 45 53 54 00 54 65  73 74 20 66 6F 72 20 53  :  TEST.Te st for S
    600F7E40 - 4F 4D 45 20 44 41 54 41  20 54 4F 20 54 45 53 54  : OME DATA  TO TEST
    600F7E50 - 00 54 65 73 74 20 66 6F  72 20 53 4F 4D 45 20 44  : .Test fo r SOME D
    600F7E60 - 41 54 41 20 54 4F 20 54  45 53 54 00 54 65 73 74  : ATA TO T EST.Test
    600F7E70 - 20 66 6F 72 20 53 4F 4D  45 20 44 41 54 41 20 54  :  for SOM E DATA T
    600F7E80 - 4F 20 54 45 53 54 00 54  65 73 74 20 66 6F 72 20  : O TEST.T est for
    600F7E90 - 53 4F 4D 45 20 44 41 54  41 20 54 4F 20 54 45 53  : SOME DAT A TO TES
    600F7EA0 - 54 00 54 65 73 74 20 66  6F 72 20 53 4F 4D 45 20  : T.Test f or SOME
    600F7EB0 - 44 41 54 41 20 54 4F 20  54 45 53 54 00 54 65 73  : DATA TO  TEST.Tes
    600F7EC0 - 74 20 66 6F 72 20 53 4F  4D 45 20 44 41 54 41 20  : t for SO ME DATA
    600F7ED0 - 54 4F 20 54 45 53 54 00  54 65 73 74 20 66 6F 72  : TO TEST. Test for
    600F7EE0 - 20 53 4F 4D 45 20 44 41  54 41 20 54 4F 20 54 45  :  SOME DA TA TO TE
    600F7EF0 - 53 54 00 54 65 73 74 20  66 6F 72 20 53 4F 4D 45  : ST.Test  for SOME
    600F7F00 - 20 44 41 54 41 20 54 4F  20 54 45 53 54 00 54 65  :  DATA TO  TEST.Te
    600F7F10 - 73 74 20 66 6F 72 20 53  4F 4D 45 20 44 41 54 41  : st for S OME DATA
    600F7F20 - 20 54 4F 20 54 45 53 54  00 54 65 73 74 20 66 6F  :  TO TEST .Test fo
    600F7F30 - 72 20 53 4F 4D 45 20 44  41 54 41 20 54 4F 20 54  : r SOME D ATA TO T
    600F7F40 - 45 53 54 00 54 65 73 74  20 66 6F 72 20 53 4F 4D  : EST.Test  for SOM
    600F7F50 - 45 20 44 41 54 41 20 54  4F 20 54 45 53 54 00 54  : E DATA T O TEST.T
    600F7F60 - 65 73 74 20 66 6F 72 20  53 4F 4D 45 20 44 41 54  : est for  SOME DAT
    600F7F70 - 41 20 54 4F 20 54 45 53  54 00 54 65 73 74 20 66  : A TO TES T.Test f
    600F7F80 - 6F 72 20 53 4F 4D 45 20  44 41 54 41 20 54 4F 20  : or SOME  DATA TO
    600F7F90 - 54 45 53 54 00 54 65 73  74 20 66 6F 72 20 53 4F  : TEST.Tes t for SO
    600F7FA0 - 4D 45 20 44 41 54 41 20  54 4F 20 54 45 53 54 00  : ME DATA  TO TEST.
    600F7FB0 - 54 65 73 74 20 66 6F 72  20 53 4F 4D 45 20 44 41  : Test for  SOME DA
    600F7FC0 - 54 41 20 54 4F 20 54 45  53 54 00 54 65 73 74 20  : TA TO TE ST.Test
    600F7FD0 - 66 6F 72 20 53 4F 4D 45  20 44 41 54 41 20 54 4F  : for SOME  DATA TO
    600F7FE0 - 20 54 45 53 54 00 FF FF  FF FF FF FF FF FF FF FF  :  TEST... ........
    600F7FF0 - FF FF FF FF FF FF FF FF  FF FF FF FF FF FF FF FF  : ........ ........
    600F8000 - CD 00 00 00 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : ....zzzz zzzzzzzz
    600F8010 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    600F8FF0 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    600F9000 - 35 00 00 00 34 00 00 00  7A 7A 7A 7A 7A 7A 7A 7A  : 5...4... zzzzzzzz
    600F9010 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    600F9FF0 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    600FA000 - 39 00 00 00 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : 9...zzzz zzzzzzzz
    600FA010 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    600FAFF0 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    600FB000 - 3A 00 00 00 39 00 00 00  34 00 00 00 30 00 00 00  : :...9... 4...0...
    600FB010 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    600FBFF0 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    600FC000 - 3B 00 00 00 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : ;...zzzz zzzzzzzz
    600FC010 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    600FCFF0 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    600FD000 - 3C 00 00 00 3B 00 00 00  7A 7A 7A 7A 7A 7A 7A 7A  : <...;... zzzzzzzz
    600FD010 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    600FDFF0 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    600FE000 - 3D 00 00 00 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : =...zzzz zzzzzzzz
    600FE010 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    600FEFF0 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    600FF000 - 3E 00 00 00 3D 00 00 00  3B 00 00 00 7A 7A 7A 7A  : >...=... ;...zzzz
    600FF010 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    600FFFF0 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    60100000 - 3F 00 00 00 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : ?...zzzz zzzzzzzz
    60100010 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    60100FF0 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    60101000 - 40 00 00 00 3F 00 00 00  7A 7A 7A 7A 7A 7A 7A 7A  : @...?... zzzzzzzz
    60101010 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    60101FF0 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    60102000 - 41 00 00 00 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : A...zzzz zzzzzzzz
    60102010 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    60102FF0 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    60103000 - 42 00 00 00 41 00 00 00  3F 00 00 00 3B 00 00 00  : B...A... ?...;...
    60103010 - 30 00 00 00 20 00 00 00  7A 7A 7A 7A 7A 7A 7A 7A  : 0... ... zzzzzzzz
    60103020 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    60103FF0 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    60104000 - 43 00 00 00 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : C...zzzz zzzzzzzz
    60104010 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    60104FF0 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    60105000 - 44 00 00 00 43 00 00 00  7A 7A 7A 7A 7A 7A 7A 7A  : D...C... zzzzzzzz
    60105010 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    60105FF0 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    60106000 - 45 00 00 00 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : E...zzzz zzzzzzzz
    60106010 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    60106FF0 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    60107000 - 46 00 00 00 45 00 00 00  43 00 00 00 7A 7A 7A 7A  : F...E... C...zzzz
    60107010 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    60107FF0 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    60108000 - 47 00 00 00 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : G...zzzz zzzzzzzz
    60108010 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    60108FF0 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    60109000 - 48 00 00 00 47 00 00 00  7A 7A 7A 7A 7A 7A 7A 7A  : H...G... zzzzzzzz
    60109010 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    60109FF0 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    6010A000 - 49 00 00 00 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : I...zzzz zzzzzzzz
    6010A010 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    6010AFF0 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    6010B000 - 4A 00 00 00 49 00 00 00  47 00 00 00 43 00 00 00  : J...I... G...C...
    6010B010 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    6010BFF0 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    6010C000 - 4B 00 00 00 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : K...zzzz zzzzzzzz
    6010C010 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    6010CFF0 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    6010D000 - 4C 00 00 00 4B 00 00 00  7A 7A 7A 7A 7A 7A 7A 7A  : L...K... zzzzzzzz
    6010D010 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    6010DFF0 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    6010E000 - 4D 00 00 00 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : M...zzzz zzzzzzzz
    6010E010 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    6010EFF0 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    6010F000 - 4E 00 00 00 4D 00 00 00  4B 00 00 00 7A 7A 7A 7A  : N...M... K...zzzz
    6010F010 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    6010FFF0 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    60110000 - 4F 00 00 00 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : O...zzzz zzzzzzzz
    60110010 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    60110FF0 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    60111000 - 50 00 00 00 4F 00 00 00  7A 7A 7A 7A 7A 7A 7A 7A  : P...O... zzzzzzzz
    60111010 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    60111FF0 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    60112000 - 51 00 00 00 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : Q...zzzz zzzzzzzz
    60112010 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    60112FF0 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    60113000 - 52 00 00 00 51 00 00 00  4F 00 00 00 4B 00 00 00  : R...Q... O...K...
    60113010 - 43 00 00 00 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : C...zzzz zzzzzzzz
    60113020 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    60113FF0 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    60114000 - 53 00 00 00 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : S...zzzz zzzzzzzz
    60114010 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    60114FF0 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    60115000 - 54 00 00 00 53 00 00 00  7A 7A 7A 7A 7A 7A 7A 7A  : T...S... zzzzzzzz
    60115010 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    60115FF0 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    60116000 - 55 00 00 00 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : U...zzzz zzzzzzzz
    60116010 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    60116FF0 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    60117000 - 56 00 00 00 55 00 00 00  53 00 00 00 7A 7A 7A 7A  : V...U... S...zzzz
    60117010 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    60117FF0 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    60118000 - 57 00 00 00 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : W...zzzz zzzzzzzz
    60118010 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    60118FF0 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    60119000 - 58 00 00 00 57 00 00 00  7A 7A 7A 7A 7A 7A 7A 7A  : X...W... zzzzzzzz
    60119010 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    60119FF0 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    6011A000 - 59 00 00 00 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : Y...zzzz zzzzzzzz
    6011A010 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    6011AFF0 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    6011B000 - 5A 00 00 00 59 00 00 00  57 00 00 00 53 00 00 00  : Z...Y... W...S...
    6011B010 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    6011BFF0 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    6011C000 - 5B 00 00 00 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : [...zzzz zzzzzzzz
    6011C010 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    6011CFF0 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    6011D000 - 5C 00 00 00 5B 00 00 00  7A 7A 7A 7A 7A 7A 7A 7A  : \...[... zzzzzzzz
    6011D010 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    6011DFF0 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    6011E000 - 5D 00 00 00 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : ]...zzzz zzzzzzzz
    6011E010 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    6011EFF0 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    6011F000 - 5E 00 00 00 5D 00 00 00  5B 00 00 00 7A 7A 7A 7A  : ^...]... [...zzzz
    6011F010 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    6011FFF0 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    60120000 - 5F 00 00 00 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : _...zzzz zzzzzzzz
    60120010 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    60120FF0 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    60121000 - 60 00 00 00 5F 00 00 00  7A 7A 7A 7A 7A 7A 7A 7A  : `..._... zzzzzzzz
    60121010 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    60121FF0 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    60122000 - 61 00 00 00 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : a...zzzz zzzzzzzz
    60122010 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    60122FF0 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    60123000 - 62 00 00 00 61 00 00 00  5F 00 00 00 5B 00 00 00  : b...a... _...[...
    60123010 - 53 00 00 00 43 00 00 00  20 00 00 00 7A 7A 7A 7A  : S...C...  ...zzzz
    60123020 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    60123FF0 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    60124000 - 63 00 00 00 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : c...zzzz zzzzzzzz
    60124010 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    60124FF0 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    60125000 - 64 00 00 00 63 00 00 00  7A 7A 7A 7A 7A 7A 7A 7A  : d...c... zzzzzzzz
    60125010 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    60125FF0 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    60126000 - 65 00 00 00 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : e...zzzz zzzzzzzz
    60126010 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    60126FF0 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    60127000 - 66 00 00 00 65 00 00 00  63 00 00 00 7A 7A 7A 7A  : f...e... c...zzzz
    60127010 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    60127FF0 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    60128000 - 67 00 00 00 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : g...zzzz zzzzzzzz
    60128010 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    60128FF0 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    60129000 - 68 00 00 00 67 00 00 00  7A 7A 7A 7A 7A 7A 7A 7A  : h...g... zzzzzzzz
    60129010 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    60129FF0 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    6012A000 - 69 00 00 00 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : i...zzzz zzzzzzzz
    6012A010 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    6012AFF0 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    6012B000 - 6A 00 00 00 69 00 00 00  67 00 00 00 63 00 00 00  : j...i... g...c...
    6012B010 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    6012BFF0 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    6012C000 - 6B 00 00 00 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : k...zzzz zzzzzzzz
    6012C010 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    6012CFF0 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    6012D000 - 6C 00 00 00 6B 00 00 00  7A 7A 7A 7A 7A 7A 7A 7A  : l...k... zzzzzzzz
    6012D010 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    6012DFF0 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    6012E000 - 6D 00 00 00 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : m...zzzz zzzzzzzz
    6012E010 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    6012EFF0 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    6012F000 - 6E 00 00 00 6D 00 00 00  6B 00 00 00 7A 7A 7A 7A  : n...m... k...zzzz
    6012F010 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    6012FFF0 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    60130000 - 6F 00 00 00 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : o...zzzz zzzzzzzz
    60130010 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    60130FF0 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    60131000 - 70 00 00 00 6F 00 00 00  7A 7A 7A 7A 7A 7A 7A 7A  : p...o... zzzzzzzz
    60131010 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    60131FF0 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    60132000 - 71 00 00 00 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : q...zzzz zzzzzzzz
    60132010 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    60132FF0 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    60133000 - 72 00 00 00 71 00 00 00  6F 00 00 00 6B 00 00 00  : r...q... o...k...
    60133010 - 63 00 00 00 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : c...zzzz zzzzzzzz
    60133020 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    60133FF0 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    60134000 - 73 00 00 00 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : s...zzzz zzzzzzzz
    60134010 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    60134FF0 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    60135000 - 74 00 00 00 73 00 00 00  7A 7A 7A 7A 7A 7A 7A 7A  : t...s... zzzzzzzz
    60135010 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    60135FF0 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    60136000 - 75 00 00 00 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : u...zzzz zzzzzzzz
    60136010 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    60136FF0 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    60137000 - 76 00 00 00 75 00 00 00  73 00 00 00 7A 7A 7A 7A  : v...u... s...zzzz
    60137010 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    60137FF0 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    60138000 - 77 00 00 00 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : w...zzzz zzzzzzzz
    60138010 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    60138FF0 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    60139000 - 78 00 00 00 77 00 00 00  7A 7A 7A 7A 7A 7A 7A 7A  : x...w... zzzzzzzz
    60139010 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    60139FF0 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    6013A000 - 79 00 00 00 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : y...zzzz zzzzzzzz
    6013A010 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    6013AFF0 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    6013B000 - 7A 00 00 00 79 00 00 00  77 00 00 00 73 00 00 00  : z...y... w...s...
    6013B010 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    6013BFF0 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    6013C000 - 7B 00 00 00 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : {...zzzz zzzzzzzz
    6013C010 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    6013CFF0 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    6013D000 - 7C 00 00 00 7B 00 00 00  7A 7A 7A 7A 7A 7A 7A 7A  : |...{... zzzzzzzz
    6013D010 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    6013DFF0 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    6013E000 - 7D 00 00 00 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : }...zzzz zzzzzzzz
    6013E010 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    6013EFF0 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    6013F000 - 7E 00 00 00 7D 00 00 00  7B 00 00 00 7A 7A 7A 7A  : ~...}... {...zzzz
    6013F010 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    6013FFF0 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    60140000 - 7F 00 00 00 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : ....zzzz zzzzzzzz
    60140010 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    60140FF0 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    60141000 - 80 00 00 00 7F 00 00 00  7A 7A 7A 7A 7A 7A 7A 7A  : ........ zzzzzzzz
    60141010 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    60141FF0 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    60142000 - 81 00 00 00 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : ....zzzz zzzzzzzz
    60142010 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    60142FF0 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    60143000 - 82 00 00 00 81 00 00 00  7F 00 00 00 7B 00 00 00  : ........ ....{...
    60143010 - 73 00 00 00 63 00 00 00  7A 7A 7A 7A 7A 7A 7A 7A  : s...c... zzzzzzzz
    60143020 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    60143FF0 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    60144000 - 83 00 00 00 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : ....zzzz zzzzzzzz
    60144010 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    60144FF0 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    60145000 - 84 00 00 00 83 00 00 00  7A 7A 7A 7A 7A 7A 7A 7A  : ........ zzzzzzzz
    60145010 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    60145FF0 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    60146000 - 85 00 00 00 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : ....zzzz zzzzzzzz
    60146010 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    60146FF0 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    60147000 - 86 00 00 00 85 00 00 00  83 00 00 00 7A 7A 7A 7A  : ........ ....zzzz
    60147010 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    60147FF0 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    60148000 - 87 00 00 00 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : ....zzzz zzzzzzzz
    60148010 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    60148FF0 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    60149000 - 88 00 00 00 87 00 00 00  7A 7A 7A 7A 7A 7A 7A 7A  : ........ zzzzzzzz
    60149010 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    60149FF0 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    6014A000 - 89 00 00 00 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : ....zzzz zzzzzzzz
    6014A010 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    6014AFF0 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    6014B000 - 8A 00 00 00 89 00 00 00  87 00 00 00 83 00 00 00  : ........ ........
    6014B010 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    6014BFF0 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    6014C000 - 8B 00 00 00 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : ....zzzz zzzzzzzz
    6014C010 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    6014CFF0 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    6014D000 - 8C 00 00 00 8B 00 00 00  7A 7A 7A 7A 7A 7A 7A 7A  : ........ zzzzzzzz
    6014D010 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    6014DFF0 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    6014E000 - 8D 00 00 00 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : ....zzzz zzzzzzzz
    6014E010 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    6014EFF0 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    6014F000 - 8E 00 00 00 8D 00 00 00  8B 00 00 00 7A 7A 7A 7A  : ........ ....zzzz
    6014F010 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    6014FFF0 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    60150000 - 8F 00 00 00 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : ....zzzz zzzzzzzz
    60150010 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    60150FF0 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    60151000 - 90 00 00 00 8F 00 00 00  7A 7A 7A 7A 7A 7A 7A 7A  : ........ zzzzzzzz
    60151010 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    60151FF0 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    60152000 - 91 00 00 00 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : ....zzzz zzzzzzzz
    60152010 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    60152FF0 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    60153000 - 92 00 00 00 91 00 00 00  8F 00 00 00 8B 00 00 00  : ........ ........
    60153010 - 83 00 00 00 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : ....zzzz zzzzzzzz
    60153020 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    60153FF0 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    60154000 - 93 00 00 00 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : ....zzzz zzzzzzzz
    60154010 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    60154FF0 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    60155000 - 94 00 00 00 93 00 00 00  7A 7A 7A 7A 7A 7A 7A 7A  : ........ zzzzzzzz
    60155010 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    60155FF0 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    60156000 - 95 00 00 00 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : ....zzzz zzzzzzzz
    60156010 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    60156FF0 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    60157000 - 96 00 00 00 95 00 00 00  93 00 00 00 7A 7A 7A 7A  : ........ ....zzzz
    60157010 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    60157FF0 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    60158000 - 97 00 00 00 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : ....zzzz zzzzzzzz
    60158010 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    60158FF0 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    60159000 - 98 00 00 00 97 00 00 00  7A 7A 7A 7A 7A 7A 7A 7A  : ........ zzzzzzzz
    60159010 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    60159FF0 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    6015A000 - 99 00 00 00 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : ....zzzz zzzzzzzz
    6015A010 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    6015AFF0 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    6015B000 - 9A 00 00 00 99 00 00 00  97 00 00 00 93 00 00 00  : ........ ........
    6015B010 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    6015BFF0 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    6015C000 - 9B 00 00 00 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : ....zzzz zzzzzzzz
    6015C010 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    6015CFF0 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    6015D000 - 9C 00 00 00 9B 00 00 00  7A 7A 7A 7A 7A 7A 7A 7A  : ........ zzzzzzzz
    6015D010 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    6015DFF0 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    6015E000 - 9D 00 00 00 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : ....zzzz zzzzzzzz
    6015E010 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    6015EFF0 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    6015F000 - 9E 00 00 00 9D 00 00 00  9B 00 00 00 7A 7A 7A 7A  : ........ ....zzzz
    6015F010 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    6015FFF0 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    60160000 - 9F 00 00 00 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : ....zzzz zzzzzzzz
    60160010 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    60160FF0 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    60161000 - A0 00 00 00 9F 00 00 00  7A 7A 7A 7A 7A 7A 7A 7A  : ........ zzzzzzzz
    60161010 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    60161FF0 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    60162000 - A1 00 00 00 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : ....zzzz zzzzzzzz
    60162010 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    60162FF0 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    60163000 - A2 00 00 00 A1 00 00 00  9F 00 00 00 9B 00 00 00  : ........ ........
    60163010 - 93 00 00 00 83 00 00 00  63 00 00 00 20 00 00 00  : ........ c... ...
    60163020 - CE 00 00 00 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : ....zzzz zzzzzzzz
    60163030 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    ...	 251 duplicate line(s) removed.
    60163FF0 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    60164000 - A3 00 00 00 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : ....zzzz zzzzzzzz
    60164010 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    60164FF0 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    60165000 - A4 00 00 00 A3 00 00 00  7A 7A 7A 7A 7A 7A 7A 7A  : ........ zzzzzzzz
    60165010 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    60165FF0 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    60166000 - A5 00 00 00 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : ....zzzz zzzzzzzz
    60166010 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    60166FF0 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    60167000 - A6 00 00 00 A5 00 00 00  A3 00 00 00 7A 7A 7A 7A  : ........ ....zzzz
    60167010 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    ...	 253 duplicate line(s) removed.
    60167FF0 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    60168000 - A7 00 00 00 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : ....zzzz zzzzzzzz
    60168010 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    60168FF0 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    60169000 - A8 00 00 00 A7 00 00 00  7A 7A 7A 7A 7A 7A 7A 7A  : ........ zzzzzzzz
    60169010 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    60169FF0 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    6016A000 - A9 00 00 00 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : ....zzzz zzzzzzzz
    6016A010 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    6016AFF0 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    6016B000 - AA 00 00 00 A9 00 00 00  A7 00 00 00 A3 00 00 00  : ........ ........
    6016B010 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    6016BFF0 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    6016C000 - AB 00 00 00 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : ....zzzz zzzzzzzz
    6016C010 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    6016CFF0 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    6016D000 - AC 00 00 00 AB 00 00 00  7A 7A 7A 7A 7A 7A 7A 7A  : ........ zzzzzzzz
    6016D010 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    6016DFF0 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    6016E000 - AD 00 00 00 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : ....zzzz zzzzzzzz
    6016E010 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    6016EFF0 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    6016F000 - AE 00 00 00 AD 00 00 00  AB 00 00 00 7A 7A 7A 7A  : ........ ....zzzz
    6016F010 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    6016FFF0 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    60170000 - AF 00 00 00 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : ....zzzz zzzzzzzz
    60170010 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    60170FF0 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    60171000 - B0 00 00 00 AF 00 00 00  7A 7A 7A 7A 7A 7A 7A 7A  : ........ zzzzzzzz
    60171010 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    60171FF0 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    60172000 - B1 00 00 00 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : ....zzzz zzzzzzzz
    60172010 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    60172FF0 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    60173000 - B2 00 00 00 B1 00 00 00  AF 00 00 00 AB 00 00 00  : ........ ........
    60173010 - A3 00 00 00 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : ....zzzz zzzzzzzz
    60173020 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    60173FF0 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    60174000 - B3 00 00 00 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : ....zzzz zzzzzzzz
    60174010 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    60174FF0 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    60175000 - B4 00 00 00 B3 00 00 00  7A 7A 7A 7A 7A 7A 7A 7A  : ........ zzzzzzzz
    60175010 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    60175FF0 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    60176000 - B5 00 00 00 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : ....zzzz zzzzzzzz
    60176010 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    60176FF0 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    60177000 - B6 00 00 00 B5 00 00 00  B3 00 00 00 7A 7A 7A 7A  : ........ ....zzzz
    60177010 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    60177FF0 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    60178000 - B7 00 00 00 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : ....zzzz zzzzzzzz
    60178010 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    60178FF0 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    60179000 - B8 00 00 00 B7 00 00 00  7A 7A 7A 7A 7A 7A 7A 7A  : ........ zzzzzzzz
    60179010 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    60179FF0 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    6017A000 - B9 00 00 00 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : ....zzzz zzzzzzzz
    6017A010 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    6017AFF0 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    6017B000 - BA 00 00 00 B9 00 00 00  B7 00 00 00 B3 00 00 00  : ........ ........
    6017B010 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    6017BFF0 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    6017C000 - BB 00 00 00 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : ....zzzz zzzzzzzz
    6017C010 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    6017CFF0 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    6017D000 - BC 00 00 00 BB 00 00 00  7A 7A 7A 7A 7A 7A 7A 7A  : ........ zzzzzzzz
    6017D010 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    6017DFF0 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    6017E000 - BD 00 00 00 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : ....zzzz zzzzzzzz
    6017E010 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    6017EFF0 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    6017F000 - BE 00 00 00 BD 00 00 00  BB 00 00 00 7A 7A 7A 7A  : ........ ....zzzz
    6017F010 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    6017FFF0 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    60180000 - BF 00 00 00 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : ....zzzz zzzzzzzz
    60180010 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    60180FF0 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    60181000 - C0 00 00 00 BF 00 00 00  7A 7A 7A 7A 7A 7A 7A 7A  : ........ zzzzzzzz
    60181010 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    60181FF0 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    60182000 - C1 00 00 00 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : ....zzzz zzzzzzzz
    60182010 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    60182FF0 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    60183000 - C2 00 00 00 C1 00 00 00  BF 00 00 00 BB 00 00 00  : ........ ........
    60183010 - B3 00 00 00 A3 00 00 00  7A 7A 7A 7A 7A 7A 7A 7A  : ........ zzzzzzzz
    60183020 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    ...	 252 duplicate line(s) removed.
    60183FF0 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    60184000 - C3 00 00 00 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : ....zzzz zzzzzzzz
    60184010 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    60184FF0 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    60185000 - C4 00 00 00 C3 00 00 00  7A 7A 7A 7A 7A 7A 7A 7A  : ........ zzzzzzzz
    60185010 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    60185FF0 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    60186000 - C5 00 00 00 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : ....zzzz zzzzzzzz
    60186010 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    60186FF0 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    60187000 - C6 00 00 00 C5 00 00 00  C3 00 00 00 7A 7A 7A 7A  : ........ ....zzzz
    60187010 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    60187FF0 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    60188000 - C7 00 00 00 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : ....zzzz zzzzzzzz
    60188010 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    60188FF0 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    60189000 - C8 00 00 00 C7 00 00 00  7A 7A 7A 7A 7A 7A 7A 7A  : ........ zzzzzzzz
    60189010 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    60189FF0 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    6018A000 - C9 00 00 00 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : ....zzzz zzzzzzzz
    6018A010 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    6018AFF0 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    6018B000 - 0D 01 00 00 AF F0 03 87  30 01 92 5F FF FF FF FF  : ........ 0.._....
    6018B010 - FF FF FF FF FF FF FF FF  FF FF FF FF FF FF FF FF  : ........ ........
    ...	 5 duplicate line(s) removed.
    6018B070 - FF FF FF FF FF FF FF FF  FF FF FF FF FF FF FF FF  : ........ ........
    6018B080 - 10 1F FC 78 40 00 00 0D  74 65 6D 70 5F 74 65 73  : ...x@... temp_tes
    6018B090 - 74 2E 74 78 74 20 00 00  0D 70 1F FC 63 C0 A4 B4  : t.txt .. .p..c...
    6018B0A0 - B7 FF FF FF FF FF FF FF  FF FF FF FF FF FF FF FF  : ........ ........
    6018B0B0 - FF FF FF FF FF FF FF FF  FF FF FF FF FF FF FF FF  : ........ ........
    ...	 3 duplicate line(s) removed.
    6018B0F0 - FF FF FF FF FF FF FF FF  FF FF FF FF FF FF FF FF  : ........ ........
    6018B100 - 70 1F FC 70 53 4F 4D 45  20 44 41 54 41 20 54 4F  : p..pSOME  DATA TO
    6018B110 - 20 54 45 53 54 0D 0A 70  1F FC 76 58 0C F9 6B FF  :  TEST..p ..vX..k.
    6018B120 - FF FF FF FF FF FF FF FF  FF FF FF FF FF FF FF FF  : ........ ........
    ...	 4 duplicate line(s) removed.
    6018B170 - FF FF FF FF FF FF FF FF  FF FF FF FF FF FF FF FF  : ........ ........
    6018B180 - 70 1F FC 43 53 4F 4D 45  20 44 41 54 41 20 54 4F  : p..CSOME  DATA TO
    6018B190 - 20 54 45 53 54 0D 0A 53  4F 4D 45 20 44 41 54 41  :  TEST..S OME DATA
    6018B1A0 - 20 54 4F 20 54 45 53 54  0D 0A 70 1F FC 74 12 10  :  TO TEST ..p..t..
    6018B1B0 - D1 E7 FF FF FF FF FF FF  FF FF FF FF FF FF FF FF  : ........ ........
    6018B1C0 - FF FF FF FF FF FF FF FF  FF FF FF FF FF FF FF FF  : ........ ........
    ...	 2 duplicate line(s) removed.
    6018B1F0 - FF FF FF FF FF FF FF FF  FF FF FF FF FF FF FF FF  : ........ ........
    6018B200 - 70 1F FC 6B 53 4F 4D 45  20 44 41 54 41 20 54 4F  : p..kSOME  DATA TO
    6018B210 - 20 54 45 53 54 0D 0A 53  4F 4D 45 20 44 41 54 41  :  TEST..S OME DATA
    6018B220 - 20 54 4F 20 54 45 53 54  0D 0A 53 4F 4D 45 20 44  :  TO TEST ..SOME D
    6018B230 - 41 54 41 20 54 4F 20 54  45 53 54 0D 0A 70 1F FC  : ATA TO T EST..p..
    6018B240 - 06 16 2F 6A 51 FF FF FF  FF FF FF FF FF FF FF FF  : ../jQ... ........
    6018B250 - FF FF FF FF FF FF FF FF  FF FF FF FF FF FF FF FF  : ........ ........
    ...	 1 duplicate line(s) removed.
    6018B270 - FF FF FF FF FF FF FF FF  FF FF FF FF FF FF FF FF  : ........ ........
    6018B280 - 70 1F FC 73 53 4F 4D 45  20 44 41 54 41 20 54 4F  : p..sSOME  DATA TO
    6018B290 - 20 54 45 53 54 0D 0A 53  4F 4D 45 20 44 41 54 41  :  TEST..S OME DATA
    6018B2A0 - 20 54 4F 20 54 45 53 54  0D 0A 53 4F 4D 45 20 44  :  TO TEST ..SOME D
    6018B2B0 - 41 54 41 20 54 4F 20 54  45 53 54 0D 0A 53 4F 4D  : ATA TO T EST..SOM
    6018B2C0 - 45 20 44 41 54 41 20 54  4F 20 54 45 53 54 0D 0A  : E DATA T O TEST..
    6018B2D0 - 70 1F FC 60 1C 5A BB F9  FF FF FF FF FF FF FF FF  : p..`.Z.. ........
    6018B2E0 - FF FF FF FF FF FF FF FF  FF FF FF FF FF FF FF FF  : ........ ........
    ...	 208 duplicate line(s) removed.
    6018BFF0 - FF FF FF FF FF FF FF FF  FF FF FF FF FF FF FF FF  : ........ ........
    6018C000 - 0B 01 00 00 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : ....zzzz zzzzzzzz
    6018C010 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    6018CFF0 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    6018D000 - CA 00 00 00 C9 00 00 00  C7 00 00 00 C3 00 00 00  : ........ ........
    6018D010 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    ...	 509 duplicate line(s) removed.
    6018EFF0 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    6018F000 - CE 00 00 00 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : ....zzzz zzzzzzzz
    6018F010 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    6018FFF0 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    60190000 - CF 00 00 00 CE 00 00 00  7A 7A 7A 7A 7A 7A 7A 7A  : ........ zzzzzzzz
    60190010 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    60190FF0 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    60191000 - D0 00 00 00 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : ....zzzz zzzzzzzz
    60191010 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    60191FF0 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    60192000 - D1 00 00 00 D0 00 00 00  CE 00 00 00 7A 7A 7A 7A  : ........ ....zzzz
    60192010 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    60192FF0 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    60193000 - D2 00 00 00 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : ....zzzz zzzzzzzz
    60193010 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    60193FF0 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    60194000 - D3 00 00 00 D2 00 00 00  7A 7A 7A 7A 7A 7A 7A 7A  : ........ zzzzzzzz
    60194010 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    60194FF0 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    60195000 - D4 00 00 00 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : ....zzzz zzzzzzzz
    60195010 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    60195FF0 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    60196000 - D5 00 00 00 D4 00 00 00  D2 00 00 00 CE 00 00 00  : ........ ........
    60196010 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    60196FF0 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    60197000 - D6 00 00 00 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : ....zzzz zzzzzzzz
    60197010 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    60197FF0 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    60198000 - D7 00 00 00 D6 00 00 00  7A 7A 7A 7A 7A 7A 7A 7A  : ........ zzzzzzzz
    60198010 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    60198FF0 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    60199000 - D8 00 00 00 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : ....zzzz zzzzzzzz
    60199010 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    60199FF0 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    6019A000 - D9 00 00 00 D8 00 00 00  D6 00 00 00 7A 7A 7A 7A  : ........ ....zzzz
    6019A010 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    6019AFF0 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    6019B000 - DA 00 00 00 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : ....zzzz zzzzzzzz
    6019B010 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    6019BFF0 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    6019C000 - DB 00 00 00 DA 00 00 00  7A 7A 7A 7A 7A 7A 7A 7A  : ........ zzzzzzzz
    6019C010 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    6019CFF0 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    6019D000 - DC 00 00 00 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : ....zzzz zzzzzzzz
    6019D010 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    6019DFF0 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    6019E000 - DD 00 00 00 DC 00 00 00  DA 00 00 00 D6 00 00 00  : ........ ........
    6019E010 - CE 00 00 00 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : ....zzzz zzzzzzzz
    6019E020 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    6019EFF0 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    6019F000 - DE 00 00 00 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : ....zzzz zzzzzzzz
    6019F010 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    6019FFF0 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    601A0000 - DF 00 00 00 DE 00 00 00  7A 7A 7A 7A 7A 7A 7A 7A  : ........ zzzzzzzz
    601A0010 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    601A0FF0 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    601A1000 - E0 00 00 00 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : ....zzzz zzzzzzzz
    601A1010 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    601A1FF0 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    601A2000 - E1 00 00 00 E0 00 00 00  DE 00 00 00 7A 7A 7A 7A  : ........ ....zzzz
    601A2010 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    601A2FF0 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    601A3000 - E2 00 00 00 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : ....zzzz zzzzzzzz
    601A3010 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    601A3FF0 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    601A4000 - E3 00 00 00 E2 00 00 00  7A 7A 7A 7A 7A 7A 7A 7A  : ........ zzzzzzzz
    601A4010 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    601A4FF0 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    601A5000 - E4 00 00 00 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : ....zzzz zzzzzzzz
    601A5010 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    601A5FF0 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    601A6000 - E5 00 00 00 E4 00 00 00  E2 00 00 00 DE 00 00 00  : ........ ........
    601A6010 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    601A6FF0 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    601A7000 - E6 00 00 00 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : ....zzzz zzzzzzzz
    601A7010 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    601A7FF0 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    601A8000 - E7 00 00 00 E6 00 00 00  7A 7A 7A 7A 7A 7A 7A 7A  : ........ zzzzzzzz
    601A8010 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    601A8FF0 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    601A9000 - E8 00 00 00 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : ....zzzz zzzzzzzz
    601A9010 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    601A9FF0 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    601AA000 - E9 00 00 00 E8 00 00 00  E6 00 00 00 7A 7A 7A 7A  : ........ ....zzzz
    601AA010 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    601AAFF0 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    601AB000 - EA 00 00 00 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : ....zzzz zzzzzzzz
    601AB010 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    601ABFF0 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    601AC000 - EB 00 00 00 EA 00 00 00  7A 7A 7A 7A 7A 7A 7A 7A  : ........ zzzzzzzz
    601AC010 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    601ACFF0 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    601AD000 - EC 00 00 00 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : ....zzzz zzzzzzzz
    601AD010 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    601ADFF0 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    601AE000 - ED 00 00 00 EC 00 00 00  EA 00 00 00 E6 00 00 00  : ........ ........
    601AE010 - DE 00 00 00 CE 00 00 00  7A 7A 7A 7A 7A 7A 7A 7A  : ........ zzzzzzzz
    601AE020 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    601AEFF0 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    601AF000 - EE 00 00 00 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : ....zzzz zzzzzzzz
    601AF010 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    601AFFF0 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    601B0000 - EF 00 00 00 EE 00 00 00  7A 7A 7A 7A 7A 7A 7A 7A  : ........ zzzzzzzz
    601B0010 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    601B0FF0 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    601B1000 - F0 00 00 00 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : ....zzzz zzzzzzzz
    601B1010 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    601B1FF0 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    601B2000 - F1 00 00 00 F0 00 00 00  EE 00 00 00 7A 7A 7A 7A  : ........ ....zzzz
    601B2010 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    601B2FF0 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    601B3000 - F2 00 00 00 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : ....zzzz zzzzzzzz
    601B3010 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    601B3FF0 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    601B4000 - F3 00 00 00 F2 00 00 00  7A 7A 7A 7A 7A 7A 7A 7A  : ........ zzzzzzzz
    601B4010 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    601B4FF0 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    601B5000 - F4 00 00 00 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : ....zzzz zzzzzzzz
    601B5010 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    601B5FF0 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    601B6000 - F5 00 00 00 F4 00 00 00  F2 00 00 00 EE 00 00 00  : ........ ........
    601B6010 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    601B6FF0 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    601B7000 - F6 00 00 00 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : ....zzzz zzzzzzzz
    601B7010 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    601B7FF0 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    601B8000 - F7 00 00 00 F6 00 00 00  7A 7A 7A 7A 7A 7A 7A 7A  : ........ zzzzzzzz
    601B8010 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    601B8FF0 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    601B9000 - F8 00 00 00 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : ....zzzz zzzzzzzz
    601B9010 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    601B9FF0 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    601BA000 - F9 00 00 00 F8 00 00 00  F6 00 00 00 7A 7A 7A 7A  : ........ ....zzzz
    601BA010 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    601BAFF0 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    601BB000 - FA 00 00 00 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : ....zzzz zzzzzzzz
    601BB010 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    601BBFF0 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    601BC000 - FB 00 00 00 FA 00 00 00  7A 7A 7A 7A 7A 7A 7A 7A  : ........ zzzzzzzz
    601BC010 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    601BCFF0 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    601BD000 - FC 00 00 00 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : ....zzzz zzzzzzzz
    601BD010 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    601BDFF0 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    601BE000 - FD 00 00 00 FC 00 00 00  FA 00 00 00 F6 00 00 00  : ........ ........
    601BE010 - EE 00 00 00 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : ....zzzz zzzzzzzz
    601BE020 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    601BEFF0 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    601BF000 - FE 00 00 00 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : ....zzzz zzzzzzzz
    601BF010 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    601BFFF0 - 7A 7A 7A 7A 7A 7A 7A 7A  7A 7A 7A 7A 7A 7A 7A 7A  : zzzzzzzz zzzzzzzz
    42
    36
    38
    37
    37
    15,067
    @Mike - yes I see that as well with no pem.key.
    With pem.key it does make encrypt ehex - but TeensyLoader Verbose suggests it is uploading the .hex as noted above?
    Compiling core...
    Using precompiled core: C:\Users\Tim\AppData\Local\Temp\arduino_cache_42603\core\core_cde230c268154177edb21ee291c1c116.a
    Linking everything together...
    "T:\\Arduino_1.8.15td155\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc" -O2 -Wl,--gc-sections,--relax "-TT:\\Arduino_1.8.15td155\\hardware\\teensy\\avr\\cores\\teensy4/imxrt1062.ld" -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -o "C:\\Users\\Tim\\AppData\\Local\\Temp\\arduino_build_141784/T4MemInfoDump.ino.elf" "C:\\Users\\Tim\\AppData\\Local\\Temp\\arduino_build_141784\\sketch\\T4MemInfoDump.ino.cpp.o" "C:\\Users\\Tim\\AppData\\Local\\Temp\\arduino_build_141784\\libraries\\MemoryHexDump\\MemoryHexDump.cpp.o" "C:\\Users\\Tim\\AppData\\Local\\Temp\\arduino_build_141784/..\\arduino_cache_42603\\core\\core_cde230c268154177edb21ee291c1c116.a" "-LC:\\Users\\Tim\\AppData\\Local\\Temp\\arduino_build_141784" -larm_cortexM7lfsp_math -lm -lstdc++
    "T:\\Arduino_1.8.15td155\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-objcopy" -O ihex -j .eeprom --set-section-flags=.eeprom=alloc,load --no-change-warnings --change-section-lma .eeprom=0 "C:\\Users\\Tim\\AppData\\Local\\Temp\\arduino_build_141784/T4MemInfoDump.ino.elf" "C:\\Users\\Tim\\AppData\\Local\\Temp\\arduino_build_141784/T4MemInfoDump.ino.eep"
    "T:\\Arduino_1.8.15td155\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-objcopy" -O ihex -R .eeprom "C:\\Users\\Tim\\AppData\\Local\\Temp\\arduino_build_141784/T4MemInfoDump.ino.elf" "C:\\Users\\Tim\\AppData\\Local\\Temp\\arduino_build_141784/T4MemInfoDump.ino.hex"
    "T:\\Arduino_1.8.15td155\\hardware\\teensy/../tools/teensy_secure" encrypthex TEENSY40 "C:\\Users\\Tim\\AppData\\Local\\Temp\\arduino_build_141784/T4MemInfoDump.ino.hex"
    encrypting 35840 bytes to C:\Users\Tim\AppData\Local\Temp\arduino_build_141784/T4MemInfoDump.ino.ehex
    "T:\\Arduino_1.8.15td155\\hardware\\teensy/../tools/stdout_redirect" "C:\\Users\\Tim\\AppData\\Local\\Temp\\arduino_build_141784/T4MemInfoDump.ino.lst" "T:\\Arduino_1.8.15td155\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-objdump" -d -S -C "C:\\Users\\Tim\\AppData\\Local\\Temp\\arduino_build_141784/T4MemInfoDump.ino.elf"
    "T:\\Arduino_1.8.15td155\\hardware\\teensy/../tools/stdout_redirect" "C:\\Users\\Tim\\AppData\\Local\\Temp\\arduino_build_141784/T4MemInfoDump.ino.sym" "T:\\Arduino_1.8.15td155\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-objdump" -t -C "C:\\Users\\Tim\\AppData\\Local\\Temp\\arduino_build_141784/T4MemInfoDump.ino.elf"
    "T:\\Arduino_1.8.15td155\\hardware\\teensy/../tools/teensy_post_compile" -file=T4MemInfoDump.ino "-path=C:\\Users\\Tim\\AppData\\Local\\Temp\\arduino_build_141784" "-tools=T:\\Arduino_1.8.15td155\\hardware\\teensy/../tools/" -board=TEENSY40
    "T:\\Arduino_1.8.15td155\\hardware\\teensy/../tools/teensy_size" "C:\\Users\\Tim\\AppData\\Local\\Temp\\arduino_build_141784/T4MemInfoDump.ino.elf"
    Memory Usage on Teensy 4.0:
      FLASH: code:29148, data:6680, headers:8200   free for files:1987588
       RAM1: variables:17088, code:25576, padding:7192   free for local variables:474432
       RAM2: variables:12384  free for malloc/new:511904
    Using library MemoryHexDump at version 1.0.0 in folder: T:\tCode\libraries\MemoryHexDump
    T:\Arduino_1.8.15td155\hardware\teensy/../tools/teensy_post_compile -file=T4MemInfoDump.ino -path=C:\Users\Tim\AppData\Local\Temp\arduino_build_141784 -tools=T:\Arduino_1.8.15td155\hardware\teensy/../tools -board=TEENSY40 -reboot -port=usb:0/140000/0/6/1/4 -portlabel=hid#vid_16c0&pid_0478 Bootloader -portprotocol=Teensy
    Invalid library found in T:\tCode\libraries\MemoryHexDump: Missing 'author' from library
    @KurtE - library needs an 'author' entry
    In TeensyLoader manually opened the ehex and did Button, that shows as uploaded with two notes bold below:
    > read errors?
    > elf file is for Unknown Board
    12:12:59.633 (loader): Open File event
    12:13:02.315 (loader): File "C:\Users\Tim\AppData\Local\Temp\arduino_build_141784\T4MemInfoDump.ino.ehex", 44032 bytes, 4960 extra
    12:13:02.322 (loader): ehex is valid, key hash: 85A79CC1 B7C7F866 7F5BB3ED 0F9C9BA5 B4149EE2 72846D35 86B63863 B0699942
    12:13:09.825 (serialmon 64): teensy read ov error
    12:13:09.825 (serialmon 64): teensy read error
    12:13:09.829 (ports 5): WM_DEVICECHANGE DBT_DEVICEREMOVECOMPLETE
    12:13:09.829 (serialmon 64): WM_DEVICECHANGE DBT_DEVICEREMOVECOMPLETE
    12:13:09.831 (ports 5): remove: loc=usb:0/140000/0/6/1/4
    12:13:09.831 (ports 5): usb_remove: usb:0/140000/0/6/1/4
    12:13:09.831 (ports 5): nothing new, skipping HID & Ports enum
    12:13:09.831 (serialmon 64): remove: loc=usb:0/140000/0/6/1/4
    12:13:09.831 (serialmon 64): usb_remove: usb:0/140000/0/6/1/4
    12:13:09.831 (serialmon 64): Disconnect \\.\COM9
    12:13:09.831 (serialmon 64): nothing new, skipping HID & Ports enum
    12:13:09.855 (serialmon 64): WM_DEVICECHANGE DBT_DEVNODES_CHANGED
    12:13:09.855 (serialmon 64): WM_DEVICECHANGE DBT_DEVICEREMOVECOMPLETE
    12:13:09.855 (serialmon 64): nothing new, skipping HID & Ports enum
    12:13:10.000 (ports 5): WM_DEVICECHANGE DBT_DEVICEREMOVECOMPLETE
    12:13:10.001 (ports 5): nothing new, skipping HID & Ports enum
    12:13:10.001 (ports 5): WM_DEVICECHANGE DBT_DEVNODES_CHANGED
    12:13:10.245 (serialmon 64): WM_DEVICECHANGE DBT_DEVICEARRIVAL
    12:13:10.246 (ports 5): WM_DEVICECHANGE DBT_DEVICEARRIVAL
    12:13:10.247 (serialmon 64): found_usb_device, id=\\?\usb#vid_16c0&pid_0478#000fd6ad#{a5dcbf10-6530-11d2-901f-00c04fb951ed}
    12:13:10.247 (serialmon 64): found_usb_device, loc=usb:0/140000/0/6/1/4    Port_#0004.Hub_#0008
    12:13:10.247 (serialmon 64): found_usb_device, hwid=USB\VID_16C0&PID_0478&REV_0107
    12:13:10.247 (serialmon 64): found_usb_device, devinst=00000005
    12:13:10.247 (serialmon 64): add: loc=usb:0/140000/0/6/1/4, class=HID, vid=16C0, pid=0478, ver=0107, serial=000fd6ad, dev=\\?\usb#vid_16c0&pid_0478#000fd6ad#{a5dcbf10-6530-11d2-901f-00c04fb951ed}
    12:13:10.247 (serialmon 64): hiddev_from_devinst_list: iface=0
    12:13:10.247 (ports 5): found_usb_device, id=\\?\usb#vid_16c0&pid_0478#000fd6ad#{a5dcbf10-6530-11d2-901f-00c04fb951ed}
    12:13:10.247 (ports 5): found_usb_device, loc=usb:0/140000/0/6/1/4    Port_#0004.Hub_#0008
    12:13:10.247 (ports 5): found_usb_device, hwid=USB\VID_16C0&PID_0478&REV_0107
    12:13:10.247 (ports 5): found_usb_device, devinst=00000019
    12:13:10.247 (ports 5): add: loc=usb:0/140000/0/6/1/4, class=HID, vid=16C0, pid=0478, ver=0107, serial=000fd6ad, dev=\\?\usb#vid_16c0&pid_0478#000fd6ad#{a5dcbf10-6530-11d2-901f-00c04fb951ed}
    12:13:10.247 (ports 5): hiddev_from_devinst_list: iface=0
    12:13:10.247 (serialmon 64): found_usb_device complete
    12:13:10.248 (ports 5): found_usb_device complete
    12:13:10.248 (serialmon 64): usb_add: usb:0/140000/0/6/1/4
    12:13:10.248 (serialmon 64): ignoring partial USB device discovery (Windows XP issue?)
    12:13:10.249 (ports 5): usb_add: usb:0/140000/0/6/1/4  [no_device] (Teensy 4.0) Bootloader
    12:13:10.334 (serialmon 64): WM_DEVICECHANGE DBT_DEVNODES_CHANGED
    12:13:10.334 (serialmon 64): hid, found devinst=0000000B
    12:13:10.336 (serialmon 64): hid, found devinst=0000000B
    12:13:10.390 (ports 5): WM_DEVICECHANGE DBT_DEVNODES_CHANGED
    12:13:10.392 (ports 5): hid, found devinst=0000001A
    12:13:10.392 (ports 5): hid, path=\\?\hid#vid_16c0&pid_0478#8&31719e78&0&0000#{4d1e55b2-f16f-11cf-88cb-001111000030}
    12:13:10.392 (ports 5): hid,  opened handle
    12:13:10.392 (ports 5):  devinst=0000001A, location=usb:0/140000/0/6/1/4
    12:13:10.392 (ports 5):  vid=16C0, pid=0478, ver=0107, usepage=FF9C, use=0024
    12:13:10.392 (ports 5):  devpath=\\?\hid#vid_16c0&pid_0478#8&31719e78&0&0000#{4d1e55b2-f16f-11cf-88cb-001111000030}
    12:13:10.392 (ports 5): usb_add: usb:0/140000/0/6/1/4  hid#vid_16c0&pid_0478 (Teensy 4.0) Bootloader
    12:13:10.566 (loader): encryption is optional, public key hash: 85A79CC1 B7C7F866 7F5BB3ED 0F9C9BA5 B4149EE2 72846D35 86B63863 B0699942
    12:13:10.572 (loader): Device came online, code_size = 2031616
    12:13:10.580 (loader): Board is: Teensy 4.0 (IMXRT1062), version 1.07
    12:13:10.592 (serialmon 64): retry device discovery (Windows XP workaround)
    12:13:10.594 (serialmon 64): hid, found devinst=0000000B
    12:13:10.596 (loader): File "C:\Users\Tim\AppData\Local\Temp\arduino_build_141784\T4MemInfoDump.ino.ehex", 44032 bytes, 4960 extra
    12:13:10.603 (loader): ehex is valid, key hash: 85A79CC1 B7C7F866 7F5BB3ED 0F9C9BA5 B4149EE2 72846D35 86B63863 B0699942
    12:13:10.750 (loader): set background IMG_ONLINE
    12:13:10.768 (loader): File "C:\Users\Tim\AppData\Local\Temp\arduino_build_141784\T4MemInfoDump.ino.ehex", 44032 bytes, 4960 extra
    12:13:10.782 (loader): ehex is valid, key hash: 85A79CC1 B7C7F866 7F5BB3ED 0F9C9BA5 B4149EE2 72846D35 86B63863 B0699942
    12:13:10.847 (serialmon 64): retry device discovery (Windows XP workaround)
    12:13:10.848 (serialmon 64): hid, found devinst=0000000B
    12:13:10.942 (loader): elf file is for Unknown Board
    12:13:10.950 (loader): using encrypted ehex (optional - secure mode not yet locked)
    12:13:10.997 (loader): begin operation
    15,067
    Found this in verbose - it is told about ehex - but seems to be pointed to .hex for upload?
    12:29:40.682 (loader): file changed
    12:29:40.699 (loader): File "C:\Users\Tim\AppData\Local\Temp\arduino_build_141784\T4MemInfoDump.ino.hex", 44032 bytes
    12:29:40.791 (post_compile 80): Status: 1, 1, 0, 17, 0, 0, C:\Users\Tim\AppData\Local\Temp\arduino_build_141784\, T4MemInfoDump.ino.hex
    12:29:40.791 (post_compile 80): Sending command: dir:C:\Users\Tim\AppData\Local\Temp\arduino_build_141784\
    12:29:40.804 (loader): remote cmd from 3248: "file:T4MemInfoDump.ino.hex"
    12:29:40.805 (post_compile 80): Sending command: file:T4MemInfoDump.ino.hex
    12:29:40.833 (loader): File "C:\Users\Tim\AppData\Local\Temp\arduino_build_141784\T4MemInfoDump.ino.hex", 44032 bytes
    12:29:40.844 (loader): File "C:\Users\Tim\AppData\Local\Temp\arduino_build_141784\T4MemInfoDump.ino.ehex", 44032 bytes, 4960 extra
    12:29:40.854 (loader): ehex is valid, key hash: 85A79CC1 B7C7F866 7F5BB3ED 0F9C9BA5 B4149EE2 72846D35 86B63863 B0699942
    12:29:40.880 (loader): remote cmd from 3248: "status"
    12:29:40.888 (post_compile 80): Status: 1, 1, 0, 17, 0, 0, C:\Users\Tim\AppData\Local\Temp\arduino_build_141784\, T4MemInfoDump.ino.hex
    Updated LIB properties for MemoryHexDump to remove 'error' - needed author and maintainer - bumped ver to 1.0.1
    New York
    7,546
    Next up to lock the T4.
    Oh, btw 15second restore works. After previous test I did the restore, and it loaded the blink sketch with out issue.
    New York
    7,546
    @Tim
    Yeah went in again and looked and yep looks like its using the hex file and not the ehex file:
    15:39:20.176 (loader): elf appears to be for Teensy 4.0 (IMXRT1062) (2031616 bytes)
    15:39:20.176 (loader): elf binary data matches hex file
    15:39:20.176 (loader): elf file is for Teensy 4.0 (IMXRT1062)
    15:39:20.178 (loader): using encrypted ehex (optional - secure mode not yet locked)
    15:39:20.212 (loader): begin operation
    15:39:20.223 (reboot 4): Status: 1, 1, 1, 1, 0, 1, C:\Users\Merli\AppData\Local\Temp\arduino_build_930863\, uncannyEyes_async_st7789_240x240.ino.hex
    15:39:20.230 (loader): flash, block=0, bs=1024, auto=1
    15:39:20.230 (loader): flash, block=1, bs=1024, auto=1
    15:39:20.230 (loader): flash, block=2, bs=1024, auto=1
    15:39:20.595 (loader): remote cmd from 1440: "status"
    15:39:20.596 (loader): flash, block=3, bs=1024, auto=1
    15:39:20.596 (loader): flash, block=4, bs=1024, auto=1
    15:39:20.596 (reboot 4): Status: 1, 1, 1, 1, 0, 1, C:\Users\Merli\AppData\Local\Temp\arduino_build_930863\, uncannyEyes_async_st7789_240x240.ino.hex
    and thenwhen it reboots as well
    EDIT: so the question I asked in post #6 still stands. Or are we missing something
    EDIT1: Not seeing unknown board though - see red highligthed text
    Germany
    9,255
    And does it encrypt additional flash (qspi), too? I guess no, because encyption needs additional code - right (or is it possible in hardware)? Do you think it is possible to add this?
    Does the decryption need time - is it as fast as before?
    Does it keep littlefs files on new uploads? (i've seen no mention, so I assume, no?)
    New York
    7,546
    So far haven't run into an issue with it keeping the files. This assumes you don't overwrite LittleFS with a sketch that runs into the LittleFS disk.
    15,067
    @Mike - unknown board is when the .eHex was manually : File / Open HEX in T_loader
    Maybe this is by design that during DEV the .hex is used and when .eHex is desired it takes manual Open? Except once LOCKED that would fail?
    It then uploaded the .eHex - but complained about the ELF as unknown.
    Connected 2nd lockable beta T_4 : STILL Virgin not ever given Secure 'Fuse Write' : ran same IDE Upload and it works sending over the .hex
    But doing open to .eHex it fails as expected:
    12:56:11.711 (loader): File "C:\Users\Tim\AppData\Local\Temp\arduino_build_141784\T4MemInfoDump.ino.ehex", 44032 bytes, 4960 extra
    12:56:11.715 (loader): ehex is valid, key hash: 85A79CC1 B7C7F866 7F5BB3ED 0F9C9BA5 B4149EE2 72846D35 86B63863 B0699942
    12:56:11.863 (loader): elf file is for Unknown Board
    12:56:11.873 (loader): using hex file - Teensy not configured for encryption
    Germany
    9,255
    Oh, great that it keeps the files now!
    15,067
    @Paul: Once T_Loader is pointed to a .eHex file the UI locks out any File / Open. {when not seeing fuse lockable T_4}
    > Even unplugging of Closing the Teensy.exe
    This was noted above - but may be an extra step? Switching to non-Fuse T_4 stays wholly locked.
    IDE Fresh Upload to get it to take a NEW HEX fails:
    Teensy Loader is currently busy with another operation (p).  Please try again in a few seconds, or restart Teensy Loader.
    Using library MemoryHexDump at version 1.0.1 in folder: T:\tCode\libraries\MemoryHexDump
    quitexit status 1
    Error compiling for board Teensy 4.0.
    This happens with Unlocked Beta with unset fuses - or a current production T_4.
    <edit>: also stays in that state with a T_4.1 plugged in
    Only plugging in a Fuse Set T_4 relaxes the T_Loader to allow programming any other T_4.
    <edit>: When non Fuse Set 1062 plugged in it aborts upload taking it out of AUTO Mode whether a T_4 or T_4.1
    Last edited by defragster; 08-17-2021 at 08:29 PM. Reason: also locked out with T_4.1
    New York
    7,546
    @Paul - @Tim
    Tried using the Teensyloader to upload the ehex file and it seems to hang:
    16:29:13.668 (loader): encryption is optional, public key hash: 3CD8795F 9A168642 4FCF82ED AFC620F1 BCFECAB3 B978FA67 0D47FE2D F09253DD
    16:29:13.668 (loader): Device came online, code_size = 2031616
    16:29:13.668 (loader): Board is: Teensy 4.0 (IMXRT1062), version 1.07
    16:29:13.749 (loader): File "C:\Users\Merli\AppData\Local\Temp\arduino_build_930863\uncannyEyes_async_st7789_240x240.ino.ehex", 683008 bytes, 4960 extra
    16:29:13.749 (loader): ehex is valid, key hash: 3CD8...
    16:29:13.872 (loader): set background IMG_ONLINE
    16:29:13.918 (loader): HID/win32: HidD_GetPreparsedData ok, device still online :-)
    16:29:28.551 (loader): Verbose Info event
    Ok so what are we missing
    15,067
    @Paul - @Tim
    Simple .eHex sketch here uploaded and ran - with noted verbose events above - but no problem to running.
    This is w/FuseWrite but Not Locked.
    Is yours 'Locked' ?
    New York
    7,546
    Is yours 'Locked' ?
    No mine is with fuseWrite but not locked. Maybe I did teensyloader wrong will try again
    EEDIT:
    Ok must have selected wrong file because now it works with TeensyLoader:
    16:38:42.282 (loader): Board is: Teensy 4.0 (IMXRT1062), version 1.07
    16:38:42.370 (loader): File "C:\Users\Merli\AppData\Local\Temp\arduino_build_930863\uncannyEyes_async_st7789_240x240.ino.ehex", 683008 bytes, 4960 extra
    16:38:42.372 (loader): ehex is valid, key hash: 3CD8795F 9A168642 4FCF82ED AFC620F1 BCFECAB3 B978FA67 0D47FE2D F09253DD
    16:38:42.498 (loader): set background IMG_ONLINE
    16:38:42.579 (loader): File "C:\Users\Merli\AppData\Local\Temp\arduino_build_930863\uncannyEyes_async_st7789_240x240.ino.ehex", 683008 bytes, 4960 extra
    16:38:42.581 (loader): ehex is valid, key hash: 3CD...
    16:38:42.706 (loader): elf file is for Unknown Board
    16:38:42.707 (loader): using encrypted ehex (optional - secure mode not yet locked)
    16:38:42.740 (loader): begin operation
    16:38:42.759 (loader): flash, block=0, bs=1024, auto=1
    16:38:42.759 (loader): flash, block=1, bs=1024, auto=1
    16:38:42.760 (loader): flash, block=2, bs=1024, auto=1
    16:38:44.771 (loader): flash, block=3, bs=1024, auto=1
    16:38:44.771 (loader): flash, block=4, bs=1024, auto=1
    16:38:44.771 (ports 5): WM_DEVICECHANGE DBT_DEVNODES_CHANGED
    16:38:44.772 (ports 5): nothing new, skipping HID & Ports enum
    New York
    7,546
    @Tim - so you have to manually upload an encrypted sketch????
    Oh by the way TyCommander is going to have to get updated at some point to upload an encrypted sketch I guess.
