Results 1 to 5 of 5
Thread: T4.1 Invert I2C pin-out?
    Mar 2020
    18
    I'm making a new "mother" board design with Teensy 4.1 with two slot for "daughter" board.
    As I want slot 1 and slot 2 board can be inverted, I have a pin-out problem
    on slot 1 : PIN 1 : TX6-SCL2 (T4.1 : 24)
    PIN 2 : RX6-SDA2 (T4.1 : 25)
    on slot 2 : PIN 1 : TX4-SDA1 (T4.1 : 17)
    PIN2 : RX4-SCL1 (T4.1 : 16)
    So, I2C pin are inverted on slot 2....
    Is there a way to invert I2C Pin-out on Teensy 4.1?
    Jul 2020
    1,363
    These are hardware mappings set in stone (well silicon). Short of overriding all the relevant #defines for the I2C symbols
    I don't see a way.
    Why would this matter? Just document it! Or wrap in a library layer?
    Mar 2020
    18
    I don't see a way.
    I want to do this because I'm making some daughter board for exemple: i2c on one type and Serial com on a second type. But I want to be able to put any daughter card in any mother board slot.
    Dec 2016
    Wales
    122
    The I2C, as Mark says, is set in silicone. The chips have dedicated hardware to run these busses that are only available on certain pins. If you mean to say you want to swap the pin locations you can't do this using the teensy's hardware.
    I'm not sure I understand why you can't use the appropriate pins, and if you're designing the hardware then definitely you should do this. Otherwise, you could use something like https://github.com/todbot/SoftI2CMaster which is a software I2C library that lets you use any two pins, but at the cost of extra processor usage.
    9,408
    ...which would not be dramatic as the i2c lib is blocking anyway.
