Results 1 to 23 of 23
Thread: MQS output from SD card
    I'm trying play WAV file from SD card. I connect SD to SPI2 (CS pin 36). There are 2 dinamics on 10 and 12 pins (left and right channels). But working left channel only.
    Attached Files Attached Files
    9,643
    I guess you confused left and right?
    10 is the right channel.
    12 does not work, because it is MISO from SPI
    As far I know there is no way to fix that - other than just not to use SPI. The T4 has a by far better port, where you connected CS. Connect the sd-socket there (with all pins)
    Channel 12 is working (MISO from SPI). Don't work channel 10 (CS from SPI).
    In sketch I defined CS pin 36
    9,643
    Please post the connections in more detail - are you using a Teensy 4.0 ? Or 4.1? To which pins is the SD Slot connected? Post all connected pins.
    Also, which Teensyduino-version?
    Teensy 4.0
    Teensyduino v1.54
    CS - pin 36
    MISO - pin 34
    MOSI - pin 35
    SCK - pin 37
    These pins connected to SD card.
    I using audio amplifier "arduino module amplifier PAM8403 mini 5V 2x3W". It connected to 10 and 12 pins.
    There is sound from pin 12. Pin 10 don't work, no sound.
    9,643
    Sorry, I have no Idea how can hear any sound anywhere, and I don't know how the SD libary automagically uses SPI2. Perhaps I'm not up to date regarding the new SD Library. From my understanding nothing should work.
    For SDIO you need _all_pins on the backside (4-bit parallel transfer), but you don't use it anyway, because you use CS=36.
    So, I hope some else can answer your question.
    You have pinMode(10,OUTPUT); (!<-- remove that!) , too - this stops any mqs on pin 10 - but it does not matter, because the program should stop before that...and print the error message. So, it's over my head.
    @Others: Does the SD Library automatically use SPI2 ??
    Yes, automagically and 12 pin working, music from SD card playing in speaker.
    pinMode(10,OUTPUT) I've tried to delete. Did not helped
    9,643
    Okay.. seems the new lib is smart ..
    But I don't know why MQSR does not work after removing pinMode. It should.
    9,643
    Your file is stereo? :-)
    Edit, ah yes, you're using the examples.
    9,643
    Try to output a sine or any ther signal (nothing from SD), perhaps...
    well, actually, I've added pinMode trying to solve problem with sound So problem was before I added this.
    okay, I'm trying
    It works. So problem in using SD or incorrect using gui
    9,643
    Quote Originally Posted by taltsutamatu View Post
    Interesting!
    Looks like a bug in the SD lib. I'll take a closer look this evening. Perhaps it accesses pin 10 - but shouldn't
    thx There is a video: https://youtu.be/WEkGye7nsIc
    Speaker on pin 10 stops working after SD card initialization (SD.begin(SDCARD_CS_PIN))
    9,643
    Yup... but i could not find the exact problem so far.. Please post that in the current 1.55 beta thread. It really seems to be a bug, that needs to be fixed.
    1.55 version of what?
    9,643
    thank you a lot
