Has anyone been able to use the addr2line with the .elf generated by PlatformIO?
I’ve tried but no success, get random characters on output
FLASH: code:255076, data:408040, headers:8624 free for files:7454724
RAM1: variables:93408, code:249080, padding:13064 free for local variables:168736
RAM2: variables:341088 free for malloc/new:183200
EXTRAM: variables:7730400
A problem occurred at (system time) 21:3:55
Code was executing from address 0x396A4
CFSR: 82
(DACCVIOL) Data Access Violation
(MMARVALID) Accessed Address: 0x0 (nullptr)
Check code at 0x396A4 - very likely a bug!
Run "addr2line -e mysketch.ino.elf 0x396A4" for filename & line number.
Temperature inside the chip was 59.68 °C
Startup CPU clock speed is 720MHz
Reboot was caused by auto reboot after fault or bad interrupt detected
F:\temp\arduino_build_195491>addr2line -e Brainstorm0015.ino.elf 0x396A4
F:\Temp\arduino_modified_sketch_457628/Oscope.ino:4
