Results 1 to 8 of 8
Thread: How do I fix the cycle time for the canbus signal?
    I have the time set I thought for both Canbus msgs but it seems one is perfect 5.0 and the other is 0.2. I need them both 5.0 and I'm a little bit stumped as coding is not my strong suit. Actually I'm really stumped and coding is not even a suit in my world but I'm trying.
    #include <FlexCAN_T4.h>
    const int ledPin = 13;
    FlexCAN_T4<CAN1, RX_SIZE_256, TX_SIZE_16> Can1;
    pinMode(ledPin, OUTPUT);
    Can1.begin();
    Can1.setBaudRate(500*1000);
    CAN_message_t frame;
    frame.id = 0x201;
    frame.len = 8;
    frame.buf[0] = 0x0C;
    frame.buf[1] = 0x80;
    frame.buf[2] = 0x00;
    frame.buf[3] = 0x00;
    frame.buf[4] = 0x27;
    frame.buf[5] = 0x10;
    frame.buf[6] = 0x14;
    frame.buf[7] = 0x00;
    Can1.write(frame);
    frame.id = 0x432;
    frame.len = 8;
    frame.buf[0] = 0x00;
    frame.buf[1] = 0x00;
    frame.buf[4] = 0x00;
    frame.buf[5] = 0x00;
    frame.buf[6] = 0x00;
    frame.buf[7] = 0x08;
    Can1.write(frame);
    ;Can1.write(frame);
    if ( Can1.read(frame) )
    Serial.print("CAN1 ");
    Serial.print(" ID: 0x"); Serial.print(frame.id, HEX );
    digitalWrite(ledPin, !digitalRead(ledPin));
    delay (5);
    This is what happens. I don't see why the cycle times are different.
    Dec 2016
    Montreal, Canada
    3,902
    I would remove the delay(5) and use millis() so it doesn't block your loop.
    in the loop():
    static uint32_t t = millis();
    if ( millis() -t > 5000 ) {
      // write your Can1 frames here... non blocking every 5 seconds.
      t = millis(); // reset 5 second counter
    the Can1.read() can be ran outside of that scope as it doesn't need a delay
    I ended up commenting out this line. Once I did that it ran perfect and turned on the unit. Works beautiful.
    //;Can1.write(frame);
    Thank you Tony for your help.
    in the loop():
    I am also going to try your way tomorrow with the millis. It is a better way.
    Tony, worked beautifully. Had to change the 5000 to just 4 to get my cycles correct but it works great. Thank you again.
    Dec 2016
    Montreal, Canada
    3,902
    Also not sure if it helps since you are not running interrupts, add Can1.events() in your loop
    Not sure how to use it or where to add it.
    Dec 2016
    Montreal, Canada
    3,902
    anywhere in the loop(), outside of your timer scope. it doesn't need delays
      Can1.events();
      // other code
