Teensy 4.1 - Detect Windows /Control Key
Smurf
New member
Hey folks,
I indeed have searched quite a lot on the internet. Apparently nobody needs to detect if the Windows or Control or ALT key was pressed...
My goal is to build a Keyboard/Mouse passthrough. Everything is already working except for the fact that I cannot detect if the Windows / Control / ALT Key was pressed by the user.
Keyboard -> Teensy -> PC
#include "USBHost_t36.h"
KeyboardController keyboard1(myusb);
 myusb.begin();
keyboard1.attachPress(OnPress);
  myusb.Task();
void OnPress(int key)
//Keyboard passthrough
    Keyboard.press(key);
    Keyboard.release(key);
Simple as that and it works for most of the Key but not for all..
The WIndows key for example wont trigger "OnPress"
In the end I would be happy to passthrough any key the user presses
Yes...
Try looking at the Raw keystrokes...
// Simple test of USB Host Mouse/Keyboard
// This example is in the public domain
USBHost myusb;
USBHub hub1(myusb);
USBHub hub2(myusb);
USBHIDParser hid1(myusb);
USBHIDParser hid2(myusb);
USBDriver *drivers[] = {&hub1, &hub2, &keyboard1, &hid1, &hid2};
#define CNT_DEVICES (sizeof(drivers)/sizeof(drivers[0]))
const char * driver_names[CNT_DEVICES] = {"Hub1", "Hub2", "KB1", "HID1" , "HID2"};
bool driver_active[CNT_DEVICES] = {false, false, false, false};
  Serial.println("\n\nUSB Host Testing");
  Serial.println(sizeof(USBHub), DEC);
  myusb.begin();
  keyboard1.attachExtrasPress(OnHIDExtrasPress);
  keyboard1.attachExtrasRelease(OnHIDExtrasRelease);
  keyboard1.attachRawPress(OnRawPress);
  keyboard1.attachRawRelease(OnRawRelease);
  myusb.Task();
  for (uint8_t i = 0; i < CNT_DEVICES; i++) {
    if (*drivers[i] != driver_active[i]) {
      if (driver_active[i]) {
        Serial.printf("*** Device %s - disconnected ***\n", driver_names[i]);
        driver_active[i] = false;
        Serial.printf("*** Device %s %x:%x - connected ***\n", driver_names[i], drivers[i]->idVendor(), drivers[i]->idProduct());
        driver_active[i] = true;
        const uint8_t *psz = drivers[i]->manufacturer();
        if (psz && *psz) Serial.printf("  manufacturer: %s\n", psz);
        psz = drivers[i]->product();
        if (psz && *psz) Serial.printf("  product: %s\n", psz);
        psz = drivers[i]->serialNumber();
        if (psz && *psz) Serial.printf("  Serial: %s\n", psz);
        // Note: with some keyboards there is an issue that they don't output in boot protocol mode
        // and may not work.  The above code can try to force the keyboard into boot mode, but there
        // are issues with doing this blindly with combo devices like wireless keyboard/mouse, which
        // may cause the mouse to not work.  Note: the above id is in the builtin list of
        // vendor IDs that are already forced
        if (drivers[i] == &keyboard1) {
          if (keyboard1.idVendor() == 0x04D9) {
            Serial.println("Gigabyte vendor: force boot protocol");
            // Gigabyte keyboard
            keyboard1.forceBootProtocol();
  Serial.print("key '");
  switch (key) {
    case KEYD_UP       : Serial.print("UP"); break;
    case KEYD_DOWN    : Serial.print("DN"); break;
    case KEYD_LEFT     : Serial.print("LEFT"); break;
    case KEYD_RIGHT   : Serial.print("RIGHT"); break;
    case KEYD_INSERT   : Serial.print("Ins"); break;
    case KEYD_DELETE   : Serial.print("Del"); break;
    case KEYD_PAGE_UP  : Serial.print("PUP"); break;
    case KEYD_PAGE_DOWN: Serial.print("PDN"); break;
    case KEYD_HOME     : Serial.print("HOME"); break;
    case KEYD_END      : Serial.print("END"); break;
    case KEYD_F1       : Serial.print("F1"); break;
    case KEYD_F2       : Serial.print("F2"); break;
    case KEYD_F3       : Serial.print("F3"); break;
    case KEYD_F4       : Serial.print("F4"); break;
    case KEYD_F5       : Serial.print("F5"); break;
    case KEYD_F6       : Serial.print("F6"); break;
    case KEYD_F7       : Serial.print("F7"); break;
    case KEYD_F8       : Serial.print("F8"); break;
    case KEYD_F9       : Serial.print("F9"); break;
    case KEYD_F10      : Serial.print("F10"); break;
    case KEYD_F11      : Serial.print("F11"); break;
    case KEYD_F12      : Serial.print("F12"); break;
    default: Serial.print((char)key); break;
  Serial.print("'  ");
  Serial.print(key);
  Serial.print(" MOD: ");
  Serial.print(keyboard1.getModifiers(), HEX);
  Serial.print(" OEM: ");
  Serial.print(keyboard1.getOemKey(), HEX);
  Serial.print(" LEDS: ");
  Serial.println(keyboard1.LEDS(), HEX);
void OnHIDExtrasPress(uint32_t top, uint16_t key)
  Serial.print("HID (");
  Serial.print(top, HEX);
  Serial.print(") key press:");
  Serial.print(key, HEX);
  if (top == 0xc0000) {
    switch (key) {
      case  0x20 : Serial.print(" - +10"); break;
      case  0x21 : Serial.print(" - +100"); break;
      case  0x22 : Serial.print(" - AM/PM"); break;
      case  0x30 : Serial.print(" - Power"); break;
      case  0x31 : Serial.print(" - Reset"); break;
      case  0x32 : Serial.print(" - Sleep"); break;
      case  0x33 : Serial.print(" - Sleep After"); break;
      case  0x34 : Serial.print(" - Sleep Mode"); break;
      case  0x35 : Serial.print(" - Illumination"); break;
      case  0x36 : Serial.print(" - Function Buttons"); break;
      case  0x40 : Serial.print(" - Menu"); break;
      case  0x41 : Serial.print(" - Menu  Pick"); break;
      case  0x42 : Serial.print(" - Menu Up"); break;
      case  0x43 : Serial.print(" - Menu Down"); break;
      case  0x44 : Serial.print(" - Menu Left"); break;
      case  0x45 : Serial.print(" - Menu Right"); break;
      case  0x46 : Serial.print(" - Menu Escape"); break;
      case  0x47 : Serial.print(" - Menu Value Increase"); break;
      case  0x48 : Serial.print(" - Menu Value Decrease"); break;
      case  0x60 : Serial.print(" - Data On Screen"); break;
      case  0x61 : Serial.print(" - Closed Caption"); break;
      case  0x62 : Serial.print(" - Closed Caption Select"); break;
      case  0x63 : Serial.print(" - VCR/TV"); break;
      case  0x64 : Serial.print(" - Broadcast Mode"); break;
      case  0x65 : Serial.print(" - Snapshot"); break;
      case  0x66 : Serial.print(" - Still"); break;
      case  0x80 : Serial.print(" - Selection"); break;
      case  0x81 : Serial.print(" - Assign Selection"); break;
      case  0x82 : Serial.print(" - Mode Step"); break;
      case  0x83 : Serial.print(" - Recall Last"); break;
      case  0x84 : Serial.print(" - Enter Channel"); break;
      case  0x85 : Serial.print(" - Order Movie"); break;
      case  0x86 : Serial.print(" - Channel"); break;
      case  0x87 : Serial.print(" - Media Selection"); break;
      case  0x88 : Serial.print(" - Media Select Computer"); break;
      case  0x89 : Serial.print(" - Media Select TV"); break;
      case  0x8A : Serial.print(" - Media Select WWW"); break;
      case  0x8B : Serial.print(" - Media Select DVD"); break;
      case  0x8C : Serial.print(" - Media Select Telephone"); break;
      case  0x8D : Serial.print(" - Media Select Program Guide"); break;
      case  0x8E : Serial.print(" - Media Select Video Phone"); break;
      case  0x8F : Serial.print(" - Media Select Games"); break;
      case  0x90 : Serial.print(" - Media Select Messages"); break;
      case  0x91 : Serial.print(" - Media Select CD"); break;
      case  0x92 : Serial.print(" - Media Select VCR"); break;
      case  0x93 : Serial.print(" - Media Select Tuner"); break;
      case  0x94 : Serial.print(" - Quit"); break;
      case  0x95 : Serial.print(" - Help"); break;
      case  0x96 : Serial.print(" - Media Select Tape"); break;
      case  0x97 : Serial.print(" - Media Select Cable"); break;
      case  0x98 : Serial.print(" - Media Select Satellite"); break;
      case  0x99 : Serial.print(" - Media Select Security"); break;
      case  0x9A : Serial.print(" - Media Select Home"); break;
      case  0x9B : Serial.print(" - Media Select Call"); break;
      case  0x9C : Serial.print(" - Channel Increment"); break;
      case  0x9D : Serial.print(" - Channel Decrement"); break;
      case  0x9E : Serial.print(" - Media Select SAP"); break;
      case  0xA0 : Serial.print(" - VCR Plus"); break;
      case  0xA1 : Serial.print(" - Once"); break;
      case  0xA2 : Serial.print(" - Daily"); break;
      case  0xA3 : Serial.print(" - Weekly"); break;
      case  0xA4 : Serial.print(" - Monthly"); break;
      case  0xB0 : Serial.print(" - Play"); break;
      case  0xB1 : Serial.print(" - Pause"); break;
      case  0xB2 : Serial.print(" - Record"); break;
      case  0xB3 : Serial.print(" - Fast Forward"); break;
      case  0xB4 : Serial.print(" - Rewind"); break;
      case  0xB5 : Serial.print(" - Scan Next Track"); break;
      case  0xB6 : Serial.print(" - Scan Previous Track"); break;
      case  0xB7 : Serial.print(" - Stop"); break;
      case  0xB8 : Serial.print(" - Eject"); break;
      case  0xB9 : Serial.print(" - Random Play"); break;
      case  0xBA : Serial.print(" - Select DisC"); break;
      case  0xBB : Serial.print(" - Enter Disc"); break;
      case  0xBC : Serial.print(" - Repeat"); break;
      case  0xBD : Serial.print(" - Tracking"); break;
      case  0xBE : Serial.print(" - Track Normal"); break;
      case  0xBF : Serial.print(" - Slow Tracking"); break;
      case  0xC0 : Serial.print(" - Frame Forward"); break;
      case  0xC1 : Serial.print(" - Frame Back"); break;
      case  0xC2 : Serial.print(" - Mark"); break;
      case  0xC3 : Serial.print(" - Clear Mark"); break;
      case  0xC4 : Serial.print(" - Repeat From Mark"); break;
      case  0xC5 : Serial.print(" - Return To Mark"); break;
      case  0xC6 : Serial.print(" - Search Mark Forward"); break;
      case  0xC7 : Serial.print(" - Search Mark Backwards"); break;
      case  0xC8 : Serial.print(" - Counter Reset"); break;
      case  0xC9 : Serial.print(" - Show Counter"); break;
      case  0xCA : Serial.print(" - Tracking Increment"); break;
      case  0xCB : Serial.print(" - Tracking Decrement"); break;
      case  0xCD : Serial.print(" - Pause/Continue"); break;
      case  0xE0 : Serial.print(" - Volume"); break;
      case  0xE1 : Serial.print(" - Balance"); break;
      case  0xE2 : Serial.print(" - Mute"); break;
      case  0xE3 : Serial.print(" - Bass"); break;
      case  0xE4 : Serial.print(" - Treble"); break;
      case  0xE5 : Serial.print(" - Bass Boost"); break;
      case  0xE6 : Serial.print(" - Surround Mode"); break;
      case  0xE7 : Serial.print(" - Loudness"); break;
      case  0xE8 : Serial.print(" - MPX"); break;
      case  0xE9 : Serial.print(" - Volume Up"); break;
      case  0xEA : Serial.print(" - Volume Down"); break;
      case  0xF0 : Serial.print(" - Speed Select"); break;
      case  0xF1 : Serial.print(" - Playback Speed"); break;
      case  0xF2 : Serial.print(" - Standard Play"); break;
      case  0xF3 : Serial.print(" - Long Play"); break;
      case  0xF4 : Serial.print(" - Extended Play"); break;
      case  0xF5 : Serial.print(" - Slow"); break;
      case  0x100: Serial.print(" - Fan Enable"); break;
      case  0x101: Serial.print(" - Fan Speed"); break;
      case  0x102: Serial.print(" - Light"); break;
      case  0x103: Serial.print(" - Light Illumination Level"); break;
      case  0x104: Serial.print(" - Climate Control Enable"); break;
      case  0x105: Serial.print(" - Room Temperature"); break;
      case  0x106: Serial.print(" - Security Enable"); break;
      case  0x107: Serial.print(" - Fire Alarm"); break;
      case  0x108: Serial.print(" - Police Alarm"); break;
      case  0x150: Serial.print(" - Balance Right"); break;
      case  0x151: Serial.print(" - Balance Left"); break;
      case  0x152: Serial.print(" - Bass Increment"); break;
      case  0x153: Serial.print(" - Bass Decrement"); break;
      case  0x154: Serial.print(" - Treble Increment"); break;
      case  0x155: Serial.print(" - Treble Decrement"); break;
      case  0x160: Serial.print(" - Speaker System"); break;
      case  0x161: Serial.print(" - Channel Left"); break;
      case  0x162: Serial.print(" - Channel Right"); break;
      case  0x163: Serial.print(" - Channel Center"); break;
      case  0x164: Serial.print(" - Channel Front"); break;
      case  0x165: Serial.print(" - Channel Center Front"); break;
      case  0x166: Serial.print(" - Channel Side"); break;
      case  0x167: Serial.print(" - Channel Surround"); break;
      case  0x168: Serial.print(" - Channel Low Frequency Enhancement"); break;
      case  0x169: Serial.print(" - Channel Top"); break;
      case  0x16A: Serial.print(" - Channel Unknown"); break;
      case  0x170: Serial.print(" - Sub-channel"); break;
      case  0x171: Serial.print(" - Sub-channel Increment"); break;
      case  0x172: Serial.print(" - Sub-channel Decrement"); break;
      case  0x173: Serial.print(" - Alternate Audio Increment"); break;
      case  0x174: Serial.print(" - Alternate Audio Decrement"); break;
      case  0x180: Serial.print(" - Application Launch Buttons"); break;
      case  0x181: Serial.print(" - AL Launch Button Configuration Tool"); break;
      case  0x182: Serial.print(" - AL Programmable Button Configuration"); break;
      case  0x183: Serial.print(" - AL Consumer Control Configuration"); break;
      case  0x184: Serial.print(" - AL Word Processor"); break;
      case  0x185: Serial.print(" - AL Text Editor"); break;
      case  0x186: Serial.print(" - AL Spreadsheet"); break;
      case  0x187: Serial.print(" - AL Graphics Editor"); break;
      case  0x188: Serial.print(" - AL Presentation App"); break;
      case  0x189: Serial.print(" - AL Database App"); break;
      case  0x18A: Serial.print(" - AL Email Reader"); break;
      case  0x18B: Serial.print(" - AL Newsreader"); break;
      case  0x18C: Serial.print(" - AL Voicemail"); break;
      case  0x18D: Serial.print(" - AL Contacts/Address Book"); break;
      case  0x18E: Serial.print(" - AL Calendar/Schedule"); break;
      case  0x18F: Serial.print(" - AL Task/Project Manager"); break;
      case  0x190: Serial.print(" - AL Log/Journal/Timecard"); break;
      case  0x191: Serial.print(" - AL Checkbook/Finance"); break;
      case  0x192: Serial.print(" - AL Calculator"); break;
      case  0x193: Serial.print(" - AL A/V Capture/Playback"); break;
      case  0x194: Serial.print(" - AL Local Machine Browser"); break;
      case  0x195: Serial.print(" - AL LAN/WAN Browser"); break;
      case  0x196: Serial.print(" - AL Internet Browser"); break;
      case  0x197: Serial.print(" - AL Remote Networking/ISP Connect"); break;
      case  0x198: Serial.print(" - AL Network Conference"); break;
      case  0x199: Serial.print(" - AL Network Chat"); break;
      case  0x19A: Serial.print(" - AL Telephony/Dialer"); break;
      case  0x19B: Serial.print(" - AL Logon"); break;
      case  0x19C: Serial.print(" - AL Logoff"); break;
      case  0x19D: Serial.print(" - AL Logon/Logoff"); break;
      case  0x19E: Serial.print(" - AL Terminal Lock/Screensaver"); break;
      case  0x19F: Serial.print(" - AL Control Panel"); break;
      case  0x1A0: Serial.print(" - AL Command Line Processor/Run"); break;
      case  0x1A1: Serial.print(" - AL Process/Task Manager"); break;
      case  0x1A2: Serial.print(" - AL Select Tast/Application"); break;
      case  0x1A3: Serial.print(" - AL Next Task/Application"); break;
      case  0x1A4: Serial.print(" - AL Previous Task/Application"); break;
      case  0x1A5: Serial.print(" - AL Preemptive Halt Task/Application"); break;
      case  0x200: Serial.print(" - Generic GUI Application Controls"); break;
      case  0x201: Serial.print(" - AC New"); break;
      case  0x202: Serial.print(" - AC Open"); break;
      case  0x203: Serial.print(" - AC Close"); break;
      case  0x204: Serial.print(" - AC Exit"); break;
      case  0x205: Serial.print(" - AC Maximize"); break;
      case  0x206: Serial.print(" - AC Minimize"); break;
      case  0x207: Serial.print(" - AC Save"); break;
      case  0x208: Serial.print(" - AC Print"); break;
      case  0x209: Serial.print(" - AC Properties"); break;
      case  0x21A: Serial.print(" - AC Undo"); break;
      case  0x21B: Serial.print(" - AC Copy"); break;
      case  0x21C: Serial.print(" - AC Cut"); break;
      case  0x21D: Serial.print(" - AC Paste"); break;
      case  0x21E: Serial.print(" - AC Select All"); break;
      case  0x21F: Serial.print(" - AC Find"); break;
      case  0x220: Serial.print(" - AC Find and Replace"); break;
      case  0x221: Serial.print(" - AC Search"); break;
      case  0x222: Serial.print(" - AC Go To"); break;
      case  0x223: Serial.print(" - AC Home"); break;
      case  0x224: Serial.print(" - AC Back"); break;
      case  0x225: Serial.print(" - AC Forward"); break;
      case  0x226: Serial.print(" - AC Stop"); break;
      case  0x227: Serial.print(" - AC Refresh"); break;
      case  0x228: Serial.print(" - AC Previous Link"); break;
      case  0x229: Serial.print(" - AC Next Link"); break;
      case  0x22A: Serial.print(" - AC Bookmarks"); break;
      case  0x22B: Serial.print(" - AC History"); break;
      case  0x22C: Serial.print(" - AC Subscriptions"); break;
      case  0x22D: Serial.print(" - AC Zoom In"); break;
      case  0x22E: Serial.print(" - AC Zoom Out"); break;
      case  0x22F: Serial.print(" - AC Zoom"); break;
      case  0x230: Serial.print(" - AC Full Screen View"); break;
      case  0x231: Serial.print(" - AC Normal View"); break;
      case  0x232: Serial.print(" - AC View Toggle"); break;
      case  0x233: Serial.print(" - AC Scroll Up"); break;
      case  0x234: Serial.print(" - AC Scroll Down"); break;
      case  0x235: Serial.print(" - AC Scroll"); break;
      case  0x236: Serial.print(" - AC Pan Left"); break;
      case  0x237: Serial.print(" - AC Pan Right"); break;
      case  0x238: Serial.print(" - AC Pan"); break;
      case  0x239: Serial.print(" - AC New Window"); break;
      case  0x23A: Serial.print(" - AC Tile Horizontally"); break;
      case  0x23B: Serial.print(" - AC Tile Vertically"); break;
      case  0x23C: Serial.print(" - AC Format"); break;
void OnHIDExtrasRelease(uint32_t top, uint16_t key)
  Serial.print(") key release:");
  Serial.println(key, HEX);
void OnRawPress(uint8_t keycode) {
  Serial.print("RAW Press: ");
  Serial.println(keycode, HEX);
void OnRawRelease(uint8_t keycode) {
  Serial.print("RAW Release: ");
Also note with: shift, ctrl and Alt, they also set the MOD settings...
Maybe in some future KeyboardController we should consider adding APIs that mirror the USB device Keyboard class, like the non-US layouts, reading as Unicode chars or UTF8 string, and mapping to the same keycodes as device mode uses.
We (mostly) have this sort of API consistency for MIDI and Serial...
Yes...
USBHost myusb;
USBHub hub1(myusb);
USBHub hub2(myusb);
  myusb.begin();
  myusb.Task();
  switch (key) {
  Serial.print("'  ");
  Serial.print(key);
    switch (key) {
Sweet! Thanks.
In fact I already was catching RAW input, but I did it wrong as I can see with your example.
Appriciate the help!
Paul, not sure what you mean here.
Currently the code is setup to convert the raw scan code keyboard data using the keylayouts stuff in core, which I believe should use the keyboard layout option in the tools menu. Have not tried it in a long time, to see if it catches all cases.
The problem keys like the Windows key is that it does not MAP to a normal key in the tables... Also CTRL+SHIFT+ALT are used as modifiers, in the translation... I know there are things we don't probably handle, like ALT+1+3+4 building special key ...
Note we also try to catch in the "Extras" options some of the other Standard but not ASCII stuff, on many keyboards, like the "System Keys" and the like like Volume UP/Down,
Sweet! Thanks.
Your are welcome. Good luck
