Hi Folks,
I am teaching myself how to use various audio library components in the audio library. I am currently trying to understand the "record queue" and "Play queue" Modules. I have done searches using my favourite search engine and seem to find nothing close to what i am asking. So here are my questions...
for the purposes of the question i am going to set some parameters from my limited knowledge (please correct anything that is wrong, so I can fully understand).
full sample rate: 48000 Hz
per channel sample rate: 24000 Hz
Does the record queue command in simple terms just take the sample rate and divide by 128 for the bandwidth of each slot in the 128 array entries ( so 128 multiply by the bandwidth of each slot will equal the per channel sample rate), So it will fit into one audio packet, or does it take multiple packets to make up the per channel sample rate.
I think asking here will save me months of going down rabbit holes and giving up without ever knowing the answer.
I am just looking for information on the relationship between the per channel sample rate and the contents of the 128 entry buffer. if I can understand what it provided, Then i will understand what I need to do with the buffer. I do NOT require snippets of code or anybody to write code for me, just a basic understanding of the commands.
Thanks in advance
Best regards
Simon.M
Thanks in advance
Best regards
Simon.M
