Results 1 to 8 of 8
Thread: understanding current consumption on the teensy 4.0
    I have the teensy 4.0 as a flight controller on a quadcopter. i have a radio receiver, MPU-6050, and four motors that are being PWM controller and I plan to add a temperature sensor. bluetooth module and 4 ultrasonic sensors later. I wanna know if I can connect 3 regular LEDs using the digital pins of the teensy and a current limiting resistors in series.
    All these electronics are being powered by a 5V 3A power source from the drone, and so then the LEDs' 40mA current is trivial. but everything shares a common power source, so is it possible to control 3 LEDs while the teensy is receiving 5V 3A but also working with other electronics?
    I believe I heard the total current on a pin is 40mA, so does that mean I can 1.2A of powering from the teensy? (40mA x 30 pins). I think the max I heard was 200 or so mA
    25,221
    The pins definitely can't source or sink 40 mA. If you have high power LEDs (most standard LEDs are 20 mA max), you'll need to have the Teensy pin turn on a transistor or other circuitry which can provide so much current.
    i plan to just use a standard 20mA LED. so i don't need a transistor right? i just thought the current limit for the teensy adds up, so if i have 20 pins each powering a 20mA LED, the 400mA would kill the teensy?
    Sep 2015
    Mechelen, Belgium
    38
    I'm afraid you have an error in your calculations.
    If you look at the data on the PJRC site regarding teensy 4.0 than the max recommended current on a i/o pin is 4mA and not 40mA.
    Further is there a max current on the device which should be divided through all the pins which you will use
    Going over either limit would probably kill one or more of the pins or the teensy 4 itself. Using a driver should prevent this.
    Regards.
    May 2015
    USA
    1,084
    Of course application matters, but I have found 1mA to be plenty bright for generic indicator LEDs.
    Cheltenham, UK
    464
    Quote Originally Posted by Hersoft View Post
    Regards.
    Teensy' Tech Spec
    The above table from the PJRC web site lists the allowable current as 10mA per pin.
    Are you saying this is wrong?
    Sep 2015
    Mechelen, Belgium
    38
    https://www.pjrc.com/store/teensy40....ent%20is%204mA.
    This is were I looked.
    So I would stay in the range of this but it does seems to be possible to go higher.
    Regards, Otto
    Cheltenham, UK
    464
    @Paul which is correct 10mA or 4mA?
    One or other of those pages needs changing, or a clarification made.
