mjs513
Senior Member+
@Paul @KurtE @mjs513 - Been working on updating mscFS.h/cpp. No luck yet. I have attached a zip file with the files below.
The compile error:
Code:/home/wwatson/arduino-1.8.16/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++ -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=155 -DARDUINO=10816 -DARDUINO_TEENSY41 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I/tmp/arduino_build_798727/pch -I/home/wwatson/arduino-1.8.16/hardware/teensy/avr/cores/teensy4 -I/home/wwatson/Arduino/libraries/UsbMscFat-main/src -I/home/wwatson/arduino-1.8.16/hardware/teensy/avr/libraries/USBHost_t36 -I/home/wwatson/arduino-1.8.16/hardware/teensy/avr/libraries/SdFat/src -I/home/wwatson/arduino-1.8.16/hardware/teensy/avr/libraries/SPI /tmp/arduino_build_798727/sketch/listfilesUSB.ino.cpp -o /tmp/arduino_build_798727/sketch/listfilesUSB.ino.cpp.o In file included from /home/wwatson/Arduino/libraries/UsbMscFat-main/examples/listfilesUSB/listfilesUSB.ino:14:0: /home/wwatson/Arduino/libraries/UsbMscFat-main/src/mscFS.h:191:27: error: 'dateTime' has not been declared FsDateTime::setCallback(dateTime); ^ /home/wwatson/Arduino/libraries/UsbMscFat-main/src/mscFS.h:191:35: warning: ISO C++ forbids declaration of 'setCallback' with no type [-fpermissive] FsDateTime::setCallback(dateTime); ^ /home/wwatson/Arduino/libraries/UsbMscFat-main/src/mscFS.h:191:35: error: invalid use of '::' Using library UsbMscFat-main at version 1.0.0 in folder: /home/wwatson/Arduino/libraries/UsbMscFat-main Using library USBHost_t36 at version 0.1 in folder: /home/wwatson/arduino-1.8.16/hardware/teensy/avr/libraries/USBHost_t36 Using library SdFat at version 2.0.5-beta.1 in folder: /home/wwatson/arduino-1.8.16/hardware/teensy/avr/libraries/SdFat Using library SPI at version 1.0 in folder: /home/wwatson/arduino-1.8.16/hardware/teensy/avr/libraries/SPI Error compiling for board Teensy 4.1.
I am using the latest version of arduino and TD along with a brand new clean install of Ubuntu 20.04. Installed the updated cores and SD libraries. It seems like the compiler is not recognizing the dateTime() function? Probably missing something again
Pretty much did as you did but using MTP_t4 to test and having no problems compiling. As a matter of fact just copied your code changes for date and time - looked cleaner than mine. I can copy files to a USB drive and it retains its correct mod and create dates. If I create a new file or directory not working - keep getting 1/1/2021. So something up.
