=== Drive index 0 found ===
connected: 1
initialized: 1
USB Vendor ID: 0951
USB Product ID: 1666
HUB Number: 1
HUB Port: 1
Device Address: 2
Removable Device: YES
VendorID: Kingston
ProductID: DataTraveler 3.0
RevisionID:
Version: 6
Sector Count: 241660915
Sector size: 512
Disk Capacity: 123730388480 Bytes
Partition Table
part,boot,bgnCHS[3],type,endCHS[3],start,length
exFAT: 1,0,0x4,0x1,0x4,0x7,0xFE,0xC2,0xFF,2048,241657856
pt_#0: 2,0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0,0
pt_#0: 3,0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0,0
pt_#0: 4,0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0,0
< unused area starting at: 241659904 length 1011 >
=== File system (0) ===
Manufacturer: Kingston
Product: DataTraveler 3.0
Serial Number: 4CEDFB74A418F4A0D96A029
Volume name: 128GEXFAT
Volume type: FAT64
Cluster Size: 131072 bytes
Volume size: 123723579392 bytes
Space used: 419168256 bytes (91 ms to compute)
Files:
2019-01-01 00:00 56863276 armaged.wav
2019-01-01 00:07 43025728 DeffLepardAnimal.wav
2019-01-01 00:07 7502713 StatusQuoWhateverYouWant.mp3
2019-01-01 00:09 35639166 ThePaperboysMolinos.wav
2019-01-01 00:10 36381082 ThePaperboysMolinosI'veJustSeenaFace.wav
2019-01-01 00:56 94519514 YouareLazyJimmyBarnesJoeBonamassa.wav
2022-01-01 00:00 32768000 32MEGfile.dat
2019-01-01 00:00 13166660 YouareLazyJimmyBarnesJoeBonamassa.mp3
2019-01-01 00:52 32768000 bench.dat
2022-01-01 00:00 32768000 test.txt
2022-01-01 00:00 32768000 copy.txt
2022-01-01 00:00 2043 datalog.txt
=== Drive index 1 found ===
connected: 1
initialized: 1
USB Vendor ID: 0951
HUB Number: 1
HUB Port: 4
Device Address: 3
VendorID: Kingston
RevisionID:
Version: 6
Sector Count: 30218841
Sector size: 512
Disk Capacity: 15472046592 Bytes
Partition Table
exFAT: 1,0,0x4,0x1,0x4,0x7,0xFE,0xC2,0xFF,2048,17928192
FAT32: 2,0,0xFE,0xC2,0xFF,0xB,0xFE,0xC2,0xFF,17930240,12288000
< unused area starting at: 30218240 length 601 >
=== File system (1) ===
Serial Number: D067E516489AF1B0B60F06F
Volume name: EXFATP1
Volume type: FAT64
Cluster Size: 32768 bytes
Volume size: 9176088576 bytes
Space used: 103710720 bytes (34 ms to compute)
Files:
2022-02-21 14:13 16976 pathname
2022-02-21 14:13 974 pathname.c
2022-02-21 13:23 2352 pathname.o
2021-11-20 14:13 14916 playFSwav.cpp
2021-11-20 14:11 3659 playFSwav.h
2022-03-05 14:58 17184 qsortStructArray
2022-03-05 15:01 1384 qsortStructArray.c
2022-03-05 14:58 3224 qsortStructArray.o
2022-03-05 14:20 17352 qsortTest
2022-03-05 11:16 4418 qsortTest.c
2022-03-05 09:35 5776 qsortTest.o
2021-11-23 18:25 319806 Screenshot at 2021-11-23 17-25-06.png
2021-12-05 18:39 102879394 YoureLazyJimmyBarnesJoeBonamassa.wav
=== File system (2) ===
Volume name: FAT32P2
Volume type: FAT32
Cluster Size: 4096 bytes
Volume size: 6279168000 bytes
Space used: 334946304 bytes (0 ms to compute)
Files:
2019-01-01 00:03 56862764 armaged.wav
2019-01-01 00:02 43025216 DeffLepardAnimal.wav
2019-01-01 00:03 60148386 StatusQuoWhateverYouWant.wav
2019-01-01 00:03 35638654 ThePaperboysMolinos.wav
2019-01-01 00:03 36380570 ThePaperboysMolinosI'veJustSeenaFace.wav
2019-01-01 00:02 102878370 YoureLazyJimmyBarnesJoeBonamassa.wav
*** enter any key to run again ***
