From the sym files it looks like it uses - in my example -60 Bytes DTCM + some more for code. Not clear how much.
60 Bytes are negletible. Even the RAM gaps and padding are way larger. However, someone should look how much code it needs, and if it can used in FLASH. Didn't want to fiddel too much now (after midnight here) so've just put it into ITCM.
So.. seems to be a reasonable way. And no code-change needed.
