#include <MTP_Teensy.h>
#include <USBHost_t36.h>
#include <USBHost_ms.h>
// Add in MTPD objects
MTPStorage storage;
MTPD mtpd(&storage);
// Add USBHost objectsUsbFs
USBHost myusb;
USBHub hub1(myusb);
USBHub hub2(myusb);
USBHub hub(myusb);
// MSC objects.
msController drive1(myusb);
msController drive2(myusb);
msController drive3(myusb);
msFilesystem msFS1(myusb);
msFilesystem msFS2(myusb);
msFilesystem msFS3(myusb);
msFilesystem msFS4(myusb);
msFilesystem msFS5(myusb);
// Quick and dirty
msFilesystem *pmsFS[] = {&msFS1, &msFS2, &msFS3, &msFS4, &msFS5};
#define CNT_MSC (sizeof(pmsFS)/sizeof(pmsFS[0]))
uint32_t pmsfs_store_ids[CNT_MSC] = {0xFFFFFFFFUL, 0xFFFFFFFFUL, 0xFFFFFFFFUL, 0xFFFFFFFFUL, 0xFFFFFFFFUL};
char pmsFS_display_name[CNT_MSC][20];
msController *pdrives[] {&drive1, &drive2, &drive3};
#define CNT_DRIVES (sizeof(pdrives)/sizeof(pdrives[0]))
bool drive_previous_connected[CNT_DRIVES] = {false, false, false};
//Add SD Card
#define USE_BUILTIN_SDCARD
#if defined(USE_BUILTIN_SDCARD) && defined(BUILTIN_SDCARD)
#define CS_SD BUILTIN_SDCARD
#else
#define CS_SD 10
#define COUNT_MYFS 2 // could do by count, but can limit how many are created...
typedef struct {
uint8_t csPin;
const char *name;
SDClass sd;
} SDList_t;
SDList_t myFS[] = {
{BUILTIN_SDCARD, "SDIO"},
{10, "SPI10"}
// Experiment add memory FS to mainly hold the storage index
// May want to wrap this all up as well
#include <LittleFS.h>
#define LFSRAM_SIZE 65536 // probably more than enough...
LittleFS_RAM lfsram;
FS *myfs = &lfsram;
File myFile, dataFile;
int iRecord = 0;
int line = 0;
#define BUFFER_SIZE_INDEX 128
uint8_t write_buffer[BUFFER_SIZE_INDEX];
#define buffer_mult 4
uint8_t buffer_temp[buffer_mult*BUFFER_SIZE_INDEX];
int bytesRead;
uint32_t drive_index = 0;
// These can likely be left unchanged
#define MYBLKSIZE 2048 // 2048
#define SLACK_SPACE 40960 // allow for overhead slack space :: WORKS on FLASH {some need more with small alloc units}
#define size_bigfile 1024*1024*24 //24 mb file
// Various Globals
const uint32_t lowOffset = 'a' - 'A';
const uint32_t lowShift = 13;
uint32_t errsLFS = 0, warnLFS = 0; // Track warnings or Errors
uint32_t lCnt = 0, LoopCnt = 0; // loop counters
uint64_t rdCnt = 0, wrCnt = 0; // Track Bytes Read and Written
int filecount = 0;
int loopLimit = 0; // -1 continuous, otherwise # to count down to 0
bool bWriteVerify = true; // Verify on Write Toggle
File file3; // Single FILE used for all functions
while (!Serial && millis() < 5000);
if (CrashReport) {
Serial.print(CrashReport);
delay(3000);
mtpd.begin();
bool storage_added = false;
for (uint8_t i = 0; i < COUNT_MYFS; i++) {
if (myFS[i].sd.begin(myFS[i].csPin)) {
storage_added = true;
storage.addFilesystem(myFS[i].sd, myFS[i].name);
if (!storage_added) {
Serial.println("Failed to add any valid storage objects");
pinMode(13, OUTPUT);
while (1) {
digitalToggleFast(13);
delay(250);
// lets initialize a RAM drive.
if (lfsram.begin(LFSRAM_SIZE)) {
Serial.printf("Ram Drive of size: %u initialized\n", LFSRAM_SIZE);
uint32_t istore = storage.addFilesystem(lfsram, "RAM");
//if (istore != 0xFFFFFFFFUL)
// storage.setIndexStore(istore);
//Serial.printf("Set Storage Index drive to %u\n", istore);
myusb.begin();
Serial.print("Initializing MSC Drives ...");
Serial.println("\nInitializing USB MSC drives...");
Serial.println("MSC and MTP initialized.");
checkMSCChanges();
menu();
checkMSCChanges();
mtpd.loop();
if (Serial.available()) {
uint8_t command = Serial.read();
int ch = Serial.read();
drive_index = CommandLineReadNextNumber(ch, 0);
while (ch == ' ')
ch = Serial.read();
switch (command) {
case '1': {
// first dump list of storages:
uint32_t fsCount = storage.getFSCount();
Serial.printf("\nDump Storage list(%u)\n", fsCount);
for (uint32_t ii = 0; ii < fsCount; ii++) {
Serial.printf("store:%u storage:%x name:%s fs:%x\n", ii,
mtpd.Store2Storage(ii), storage.getStoreName(ii),
(uint32_t)storage.getStoreFS(ii));
Serial.println("\nDump Index List");
storage.dumpIndexList();
} break;
case '2':
Serial.printf("Drive # %d Selected\n", drive_index);
myfs = storage.getStoreFS(drive_index);
case 'l':
listFiles();
case 'b':
bigFile( 0 ); // delete
command = 0;
case 'B':
bigFile( 1 ); // CREATE
command = 0;
case 's':
bigFile2MB( 0 ); // CREATE
command = 0;
case 'S':
bigFile2MB( 1 ); // CREATE
command = 0;
case 'n': // No Verify on write
bWriteVerify = !bWriteVerify;
bWriteVerify ? Serial.print(" Write Verify on: ") : Serial.print(" Write Verify off: ");
command = 0;
case 'R':
Serial.print(" RESTART Teensy ...");
SCB_AIRCR = 0x05FA0004;
case '\r':
case '\n':
case 'h':
menu();
default:
menu();
while (Serial.read() != -1)
; // remove rest of characters.
void checkMSCChanges() {
myusb.Task();
USBMSCDevice mscDrive;
PFsLib pfsLIB;
for (uint8_t i=0; i < CNT_DRIVES; i++) {
if (*pdrives[i]) {
if (!drive_previous_connected[i]) {
if (mscDrive.begin(pdrives[i])) {
Serial.printf("\nUSB Drive: %u connected\n", i);
pfsLIB.mbrDmp(&mscDrive, (uint32_t)-1, Serial);
Serial.printf("\nTry Partition list");
pfsLIB.listPartitions(&mscDrive, Serial);
drive_previous_connected[i] = true;
drive_previous_connected[i] = false;
bool send_device_reset = false;
for (uint8_t i = 0; i < CNT_MSC; i++) {
if (*pmsFS[i] && (pmsfs_store_ids[i] == 0xFFFFFFFFUL)) {
Serial.printf("Found new Volume:%u\n", i); Serial.flush();
// Lets see if we can get the volume label:
char volName[20];
if (pmsFS[i]->mscfs.getVolumeLabel(volName, sizeof(volName)))
snprintf(pmsFS_display_name[i], sizeof(pmsFS_display_name[i]), "MSC%d-%s", i, volName);
snprintf(pmsFS_display_name[i], sizeof(pmsFS_display_name[i]), "MSC%d", i);
pmsfs_store_ids[i] = storage.addFilesystem(*pmsFS[i], pmsFS_display_name[i]);
// Try to send store added. if > 0 it went through = 0 stores have not been enumerated
if (mtpd.send_StoreAddedEvent(pmsfs_store_ids[i]) < 0) send_device_reset = true;
// Or did volume go away?
else if ((pmsfs_store_ids[i] != 0xFFFFFFFFUL) && !*pmsFS[i] ) {
if (mtpd.send_StoreRemovedEvent(pmsfs_store_ids[i]) < 0) send_device_reset = true;
storage.removeFilesystem(pmsfs_store_ids[i]);
pmsfs_store_ids[i] = 0xFFFFFFFFUL;
if (send_device_reset) mtpd.send_DeviceResetEvent();
void menu() {
Serial.println("Menu Options:");
Serial.printf("\n%s","1 - List USB Drives (Step 1)");
Serial.printf("\n%s","2 - Select USB Drive for Logging (Step 2)");
Serial.printf("\n%s","l - List files on disk");
Serial.printf("\n%s","'B, or b': Make Big file half of free space, or remove all Big files");
Serial.printf("\n%s","'S, or s': Make 2MB file , or remove all 2MB files");
Serial.printf("\n%s","'n' No verify on Write- TOGGLE");
Serial.printf("\n%s","'h' - Menu");
void listFiles() {
Serial.print("\n Space Used = ");
Serial.println(myfs->usedSize());
Serial.print("Filesystem Size = ");
Serial.println(myfs->totalSize());
File root = myfs->open("/");
printDirectory(root, 0);
root.close();
void printDirectory(File dir, int numSpaces) {
DateTimeFields dtf;
while (true) {
File entry = dir.openNextFile();
if (!entry) {
// Serial.println("** no more files **");
printSpaces(numSpaces);
Serial.print(entry.name());
printSpaces(36 - numSpaces - strlen(entry.name()));
if (entry.getCreateTime(dtf)) {
Serial.printf(" C: %02u/%02u/%04u %02u:%02u", dtf.mon + 1, dtf.mday, dtf.year + 1900, dtf.hour, dtf.min );
if (entry.getModifyTime(dtf)) {
Serial.printf(" M: %02u/%02u/%04u %02u:%02u", dtf.mon + 1, dtf.mday, dtf.year + 1900, dtf.hour, dtf.min );
if (entry.isDirectory()) {
Serial.println(" /");
printDirectory(entry, numSpaces + 2);
// files have sizes, directories do not
Serial.print(" ");
Serial.println(entry.size(), DEC);
entry.close();
void printSpaces(int num) {
for (int i = 0; i < num; i++) {
Serial.print(" ");
uint32_t CommandLineReadNextNumber(int &ch, uint32_t default_num) {
while (ch == ' ')
ch = Serial.read();
if ((ch < '0') || (ch > '9'))
return default_num;
uint32_t return_value = 0;
while ((ch >= '0') && (ch <= '9')) {
return_value = return_value * 10 + ch - '0';
ch = Serial.read();
return return_value;
void readVerify( char szPath[], char chNow ) {
uint32_t timeMe = micros();
file3 = myfs->open(szPath);
if ( 0 == file3 ) {
Serial.printf( "\tV\t Fail File open %s\n", szPath );
errsLFS++;
char mm;
char chNow2 = chNow + lowOffset;
uint32_t ii = 0;
while ( file3.available() ) {
file3.read( &mm , 1 );
rdCnt++;
//Serial.print( mm ); // show chars as read
ii++;
if ( 0 == (ii / lowShift) % 2 ) {
if ( chNow2 != mm ) {
Serial.printf( "<Bad Byte! %c! = %c [0x%X] @%u\n", chNow2, mm, mm, ii );
errsLFS++;
else {
if ( chNow != mm ) {
Serial.printf( "<Bad Byte! %c! = %c [0x%X] @%u\n", chNow, mm, mm, ii );
errsLFS++;
Serial.printf( " Verify %u Bytes ", ii );
if (ii != file3.size()) {
Serial.printf( "\n\tRead Count fail! :: read %u != f.size %llu", ii, file3.size() );
errsLFS++;
file3.close();
timeMe = micros() - timeMe;
Serial.printf( " @KB/sec %5.2f", ii / (timeMe / 1000.0) );
bool bigVerify( char szPath[], char chNow ) {
uint64_t fSize;
if ( 0 == file3 ) {
return false;
char mm;
uint32_t ii = 0;
uint32_t kk = file3.size() / 50;
fSize = file3.size();
Serial.printf( "\tVerify %s bytes %lu : ", szPath, fSize );
rdCnt++;
ii++;
if ( !(ii % kk) ) Serial.print('.');
errsLFS++;
if ( ii > fSize ) { // catch over length return makes bad loop !!!
Serial.printf( "\n\tFile LEN Corrupt! FS returning over %u bytes\n", fSize );
errsLFS++;
Serial.printf( "\n\tRead Count fail! :: read %u != f.size %llu\n", ii, file3.size() );
errsLFS++;
Serial.printf( "\tGOOD! >> bytes %lu", ii );
file3.close();
Serial.printf( "\n\tBig read&compare KBytes per second %5.2f \n", ii / (timeMe / 1000.0) );
if ( 0 == ii ) return false;
return true;
void bigFile( int doThis ) {
char myFile[] = "/0_bigfile.txt";
char fileID = '0' - 1;
DateTimeFields dtf = {0, 10, 7, 0, 22, 7, 121};
if ( 0 == doThis ) { // delete File
Serial.printf( "\nDelete with read verify all #bigfile's\n");
do {
fileID++;
myFile[1] = fileID;
if ( myfs->exists(myFile) && bigVerify( myFile, fileID) ) {
filecount--;
myfs->remove(myFile);
else break; // no more of these
} while ( 1 );
else { // FILL DISK
uint32_t resW = 1;
char someData[MYBLKSIZE];
uint32_t xx, toWrite;
toWrite = (myfs->totalSize()) - myfs->usedSize();
if ( toWrite < 65535 ) {
Serial.print( "Disk too full! DO :: reformat");
return;
toWrite = size_bigfile;
toWrite -= SLACK_SPACE;
xx = toWrite;
Serial.printf( "\nStart Big write of %u Bytes", xx);
file3 = nullptr;
do {
if ( file3 ) file3.close();
fileID++;
myFile[1] = fileID;
file3 = myfs->open(myFile, FILE_WRITE);
} while ( fileID < '9' && file3.size() > 0);
if ( fileID == '9' ) {
Serial.print( "Disk has 9 halves 0-8! DO :: b or q or F");
return;
memset( someData, fileID, 2048 );
int hh = 0;
while ( toWrite > 2048 && resW > 0 ) {
resW = file3.write( someData , 2048 );
hh++;
if ( !(hh % 40) ) Serial.print('.');
toWrite -= 2048;
xx = toWrite;
file3.setCreateTime(dtf);
file3.setModifyTime(dtf);
file3.close();
if ( file3.size() > 0 ) {
filecount++;
Serial.printf( "\nBig write %s took %5.2f Sec for %lu Bytes : file3.size()=%llu", myFile , timeMe / 1000000.0, xx, file3.size() );
if ( file3 != 0 ) file3.close();
Serial.printf( "\n\tBig write KBytes per second %5.2f \n", xx / (timeMe / 1000.0) );
Serial.printf("\nBytes Used: %llu, Bytes Total:%llu\n", myfs->usedSize(), myfs->totalSize());
if ( myfs->usedSize() == myfs->totalSize() ) {
Serial.printf("\n\n\tWARNING: DISK FULL >>>>> Bytes Used: %llu, Bytes Total:%llu\n\n", myfs->usedSize(), myfs->totalSize());
warnLFS++;
if ( resW < 0 ) {
Serial.printf( "\nBig write ERR# %i 0x%X \n", resW, resW );
errsLFS++;
void bigFile2MB( int doThis ) {
char myFile[] = "/0_2MBfile.txt";
do {
fileID++;
myFile[1] = fileID;
filecount--;
} while ( 1 );
else { // FILL DISK
uint32_t resW = 1;
char someData[2048];
toWrite = 2048 * 1000;
if ( toWrite > (65535 + (myfs->totalSize() - myfs->usedSize()) ) ) {
Serial.print( "Disk too full! DO :: q or F");
return;
xx = toWrite;
file3 = nullptr;
do {
fileID++;
myFile[1] = fileID;
Serial.print( "Disk has 9 files 0-8! DO :: b or q or F");
return;
int hh = 0;
while ( toWrite >= 2048 && resW > 0 ) {
hh++;
toWrite -= 2048;
xx -= toWrite;
file3.close();
filecount++;
warnLFS++;
if ( resW < 0 ) {
errsLFS++;
