I have written code that uses adc0 and adc1 and store these values into 2 dma buffers, and then writes to SD card using Arduino IDE 1.8.15. It works for t3.5, and t3.6, but when I try to load onto t4.1 I've gotten alot of errors.I was able to fix a handful, but this current error has got me wanting to dive into datasheet and fix manually.....id prefer not to.
But issue is with DMAchannel.h. Heres code I'm having issues with and where error stops
error:dma2 - 'ADC0_RA' was not declared in this scope
Has anyone else has issues with dmachannel.h and t4.1?
#include <ADC.h>
#include <DMAChannel.h>
#include "array"
//#include <SdFat.h>
DMAChannel dma1; // used to declare the dma.### object
DMAChannel dma2; // used to declare the dma.### object
std::array<volatile uint16_t, (uint32_t)64 * 512> buffer __attribute__ ((aligned (16 * 1024))); // size of buffer is limited due to the Teensy's program memory
ADC *adc = new ADC(); // adc object; // used to declare the adc.### object
std::array<volatile uint16_t, (uint32_t)64 * 512> buffer1 __attribute__ ((aligned (16 * 1024)));
char str[128] ;
typeof(*dma1.TCD) tcd_mem[4] __attribute__ ((aligned (32))) ;
typeof(*dma2.TCD) tcd1_mem[4] __attribute__ ((aligned (32))) ;
adc->adc0->startSingleRead(MeasurementPin);
adc->adc0->setAveraging(1); // set number of averages
adc->adc0->setResolution(16);
adc->adc0->setConversionSpeed ( ADC_CONVERSION_SPEED::HIGH_SPEED);
adc->adc0->setSamplingSpeed ( ADC_SAMPLING_SPEED:: VERY_LOW_SPEED );
adc->adc0->setReference(ADC_REFERENCE::REF_3V3); //set ADC reference voltage
dma2.source(ADC0_RA);
dma2.transferSize(2);
dma2.triggerAtHardwareEvent (DMAMUX_SOURCE_ADC0);
adc->adc1->startSingleRead(MeasurementPin2);
adc->adc1->setAveraging(1); // set number of averages
adc->adc1->setResolution(16);
adc->adc1->setConversionSpeed ( ADC_CONVERSION_SPEED:: HIGH_SPEED);
adc->adc1->setSamplingSpeed ( ADC_SAMPLING_SPEED:: VERY_LOW_SPEED );
adc->adc1->setReference(ADC_REFERENCE::REF_3V3); //set ADC reference voltage
dma1.source (ADC1_RA);
dma1.transferSize(2);
dma1.triggerAtHardwareEvent (DMAMUX_SOURCE_ADC1);
