Results 1 to 3 of 3
Thread: Making a. Raw audio file by hand.
    May 2015
    442
    Would the proper way to make an audio board compatible mono raw audio file (sine wave) be to just write a u16_t’s with the proper phase adjustment per 1/44,100 seconds? If I wanted the amplitude to read -6dm in Audicaty would the peak to peak be 2^8 or does the Audicaty add some “head room”? I want to compare what I send to a device vs what I get back level wise and adjust it's internal gain so they match.
    Jul 2020
    1,365
    Audacity has 0dB as full scale, no headroom.
    WAV samples are signed unless 8 bit, IIRC. For 16 bit that's +/-16384 for -6dB.
    I just use wav files and chop the header off if needed raw.
    Soundcards don't usually have calibrated inputs or outputs, and generally they will be different levels, so you'll need to
    calibrate with a loopback connection. The same applies to any audio codec chip like the SGTL5000.
    May 2015
    442
    Thanks for the help! It's not a sound card.... they are 20 year old pagers for fire departmens that need the channel announcements restored after they got scrambled.
Tags for this Thread
