Results 1 to 5 of 5
Thread: Teensy 4.0 and I2C
    Sep 2021
    2
    Teensy 4.0 and I2C
    What would cause an I2C scan to show all addresses being active when there should be no for this to happen? That is what happens when I run my simple I2C bus scanner script on a Teensy 4.0. I have never seen this before.
    # Import all board pins.
    from machine import SoftI2C, Pin
    from micropython import const
    HW_I2C0_SDA                     = const(18)
    HW_I2C0_SCL                     = const(19)
    HW_I2C1_SDA                     = const(17)
    HW_I2C1_SCL                     = const(16)
    TP_SDA = Pin(HW_I2C0_SDA)
    TP_SCL = Pin(HW_I2C0_SCL)
    # Create the I2C interface.
    i2c = SoftI2C(sda=TP_SDA, scl=TP_SCL, freq=400000)
    print()
    print("Simple I2C bus scanner")
    print()
    scan = i2c.scan()
    if scan:
    	print("Devices on the I2C bus:")
    	for addr in scan:
    		print("\tDecimal: {0:3d}, Hex: {1}".format(addr, hex(addr)))
    else:
      print("There are no devices on the I2C bus")
    print()
    8-Dale
    Apr 2020
    DFW area in Texas
    305
    Quote Originally Posted by hybotics View Post
    print()
    print()
    scan = i2c.scan()
    if scan:
    	for addr in scan:
    else:
    print()
    8-Dale
    Did you post the actual source that you are building & loading into the T4.0 ?? Are you using the Arduino IDE to build ?? What you posted does not build in the Arduino IDE & throws syntax errors on the first line.
    I must be missing something obvious . . . I'd like to help, but will need more info to make that possible !!
    Mark J Culross
    KD5RXT
    Aug 2018
    Brisbane, Australia
    79
    Umm Mark. Its python not C++
    Sep 2021
    2
    Quote Originally Posted by kd5rxt-mark View Post
    It is Micropython code that runs right on an MCU.
    Of course, it does not build in the Arduino IDE. I am surprised that you did not recognize it is not Arduino code.
    MicroPython v1.16-236-gb51e7e9d0 on 2021-08-21; Teensy 4.0 with MIMXRT1062DVJ6A
    8-Dale
    Apr 2020
    DFW area in Texas
    305
    8-Dale
    8-Dale:
    I was missing something very obvious !! I have not used MicroPython, so not recognizable as such to me. Sorry (both that I didn't recognize it & that I can't be of any help) !!
    Mark J Culross
    KD5RXT
