h4yn0nnym0u5e
Raised in GitHub as issue #607
Audio/WavFilePlayer.ino example will not compile with cores 7798d24 and audio library 1c5426e
- A complete copy of the code: Audio/examples/WavFilePlayer/WavFilePlayer.ino
- Which Teensy board(s) are you using: Teensy 4.1
- If other hardware is needed to reproduce the issue: n/a
- Which version of Teensyduino: cores 7798d24 and Arduino 1.8.15 were used,
- what Tools menu settings Teensy 4.1 / Serial + MIDI + Audio / 600MHz were chosen, and
- which operating system was used: Windows 10.
In file included from E:\Jonathan\Arduino\libraries\Audio/play_sd_raw.h:32:0,
from E:\Jonathan\Arduino\libraries\Audio/Audio.h:127,
from E:\Jonathan\Arduino\libraries\Audio\examples\WavFilePlayer\WavFilePlayer.ino:28:
C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\SD\src/SD.h:53:7: error: cannot derive from 'final' base 'File' in derived type 'SDFile'
class SDFile : public File
C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\SD\src/SD.h: In member function 'virtual File SDFile::openNextFile(uint8_t)':
C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\SD\src/SD.h:131:41: error: no matching function for call to 'File::File(SDFile*)'
if (file) return File(new SDFile(file));
In file included from C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\SD\src/SD.h:35:0,
from E:\Jonathan\Arduino\libraries\Audio/play_sd_raw.h:32,
C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4/FS.h:130:2: note: candidate: File::File(const File&&)
File(const File&& file) {
C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4/FS.h:130:2: note: no known conversion for argument 1 from 'SDFile*' to 'const File&&'
C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4/FS.h:123:2: note: candidate: File::File(const File&)
File(const File& file) {
C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4/FS.h:123:2: note: no known conversion for argument 1 from 'SDFile*' to 'const File&'
C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4/FS.h:113:2: note: candidate: File::File(FileImpl*)
File(FileImpl *file) {
C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4/FS.h:113:2: note: no known conversion for argument 1 from 'SDFile*' to 'FileImpl*'
C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4/FS.h:106:12: note: candidate: constexpr File::File()
constexpr File() : f(nullptr) { }
C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4/FS.h:106:12: note: candidate expects 0 arguments, 1 provided
C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\SD\src/SD.h: In member function 'virtual File SDClass::open(const char*, uint8_t)':
C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\SD\src/SD.h:164:41: error: no matching function for call to 'File::File(SDFile*)'
Multiple libraries were found for "Audio.h"
Used: E:\Jonathan\Arduino\libraries\Audio
Not used: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio
Used: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\SD
Not used: C:\Program Files (x86)\Arduino\libraries\SD
Error compiling for board Teensy 4.1.
