Page 1 of 3 1 2 3 LastLast
Results 1 to 25 of 61
Thread: Teensyduino 1.55 Beta #3
    Administrator Paul's Avatar
    Oct 2012
    415
    Here is a third beta test for Teensyduino 1.55.
    Linux 32 bit:
    https://www.pjrc.com/teensy/td_155-b...nstall.linux32
    Linux 64 bit:
    https://www.pjrc.com/teensy/td_155-b...nstall.linux64
    Linux ARM:
    https://www.pjrc.com/teensy/td_155-b...stall.linuxarm
    Linux ARM64:
    https://www.pjrc.com/teensy/td_155-b...l.linuxaarch64
    MacOS 10.10 to 11.x:
    https://www.pjrc.com/teensy/td_155-b...S_Catalina.zip
    MacOS 10.8 to 10.14:
    https://www.pjrc.com/teensy/td_155-b...inoInstall.dmg
    Windows:
    https://www.pjrc.com/teensy/td_155-b...inoInstall.exe
    Changes since Teensyduino 1.55-beta2:
    SdFat use MAINTAIN_FREE_CLUSTER_COUNT on 32 bit Teensy
    Do not build .lst file - very slow for large code
    Sketch > Export Compiled Binary now saves .ehex, if possible
    Consistent startup sequence on Teensy 3 & 4
    Add startup_default_middle_hook()
    Fix Serial.begin() delay with serial emulation and Teensy 3
    String compatibility with Arduino for C++ iterators
    Fix DMAChannel triggerContinuously() on Teensy 4 (Kurt E)
    Fix CCM_ANALOG_PLL_ENET define (Shawn Silverman)
    Improve arm_dcache_delete() documentation
    Rename LittleFS example folders
    LittleFS_RAM always starts blank
    Update ST7735_t3
    Update TeensyThreads
    Fix Teensy Loader GUI stalls with locked Teensy 4
    Show .ehex filename in status bar when automatically using .ehex
    Clearer messages about hex vs ehex in Verbose Info
    Only show percentage flash used after connecting to real hardware
    Avoid fusewrite fuse memory corruption if different key used
    Improve error messages in fusewrite sketch
    7,548
    Something different - went to install TD but gave me an error that it could upload to the folder. Checked in Task Manager and had 2 copies of Teensy_reboot.exe still running. Once closed it installed without an issue.
    Verified that an .ehex and .hex are both save to the sketch directory.
    verified that the .lst file is not created using Tim's code4code sketch but took about 1:47 seconds to go from upload arrow to when TeensySize prints. Not sure anyway around this for that large of a program.
    Very nice and thank you.
    Not sure how much clearer that can be
    17:58:31.485 (loader): File "Code4Code.ino.hex". 1337344 bytes, 66% used
    17:58:31.485 (loader): File "Code4Code.ino.hex" opened, but "Code4Code.ino.ehex" will actually be used
    17:58:31.532 (loader): elf appears to be for Teensy 4.0 (IMXRT1062) (2031616 bytes)
    17:58:31.532 (loader): elf binary data matches hex file
    17:58:31.532 (loader): elf file is for Teensy 4.0 (IMXRT1062)
    17:58:31.532 (loader): using encrypted ehex (required - secure mode is locked)
    Ok next up is the fusewrite with wrong key and see what happens.
    UPDATE:
    Like the message that TL shows that ehex can not be written because wrong key and nothing uploads and sketch already on T4 continues to run.
    Also checked if the correct key is used with fuse write - nice output to let you know it was already written don't remember if that was there before:
    Decryption key was previously written & locked, so
    it can not be directly verified, but the following
    test will confirm whether decryption works.
    Bus Encryption Engine is active (this program is encrypted)
      Encryption is assumed to be working if this program runs.
    15,074
    Installed okay, no complaints - except I left IDE open even after it told me teensy_ports was open.
    > Backed up both times and completed as desired
    Rebuilt C4CbenchM @4,000 func#()'s WIP okay. Faster without .lst!
    Upload to Locked_Beta and Prod boards worked - but something funny happened - may have triggered second before first was complete?
    > Got bumped from 'AUTO' for fast reboot?
    four _isr rates give this for T4_Locked - not shown yet the 4 rates 24, 48, 96, 192 us update rates on the IntervalTimer:
    PERF _isr() char[] Test % Diff versus production T4:
    	_isr() char[] Test @24 us % Diff of 0.997
    	_isr() char[] Test @48 us % Diff of 0.965
    	_isr() char[] Test @96 us % Diff of 0.945
    	_isr() char[] Test @192 us % Diff of 0.918
    Refining the 'net' diffs from the Cascade versus Direct calls like in Excel.
    15,074
    Just triggered the mystery 'erasing' sequence from TeensyLoader hitting 'TyComm USB Reset' : after Button Upload
    > It doesn't program because TyComm is monitoring for Serial connect and it does?
    Here is full Verbose since Beta 3 loaded ...
    Attached Verbose : B3_log.zip
    Needed to be ZIPped because 296 KB is bigger than limit 195.3
    Long time idle so a big break in time stamps to find the events:
    17:11:46.113 (loader): redraw, image 9
    19:07:11.023 (ports 2): WM_DEVICECHANGE DBT_DEVNODES_CHANGED
    Here is a shorter Log.txt: B3_log2.txt
    > Verify Build
    > TyComm 'Bootloader' on production
    -> Proper upload
    > TyComm 'Reset' on Locked Beta T4
    -> FALSE upload - valid Reset
    > TyComm 'Bootloader' on Locked Beta T4
    -> Proper upload
    NOTE: Works the same doing UPLOAD to EACH of the above, then hitting Reset on the first
    > Verify Build
    -> Proper upload
    -> Proper upload
    > TyComm 'Reset' on production
    15,074
    Just triggered the DUAL LEDS RED & ORANGE:
    > Did a new Verify
    > on Production accidental with TyComm Reset not Bootloader
    > Changed to Beta_T4 : Did TyComm Bootloader
    -->> Looked down and saw DUAL LEDS
    - > last Verify code was NOT uploaded
    Here are Four T_4's running the same variation of Code4Code > C4CbenchM.ino::
    >> Both UPDATED : https://github.com/Defragster/T4LockBeta { c4cbenchM has non printing version of isEncrypt( bool ) for ID string create }
    10379960 nor ns: @600 PERF _isr() char[] Test % Diff versus production T4:
    	_isr() char[] Test @24 us % Diff of 1.000
    	_isr() char[] Test @48 us % Diff of 1.000
    	_isr() char[] Test @96 us % Diff of 1.001
    	_isr() char[] Test @192 us % Diff of 1.000
    10379960 nor ns: @600 PERF Cascade .vs. Direct Func#()'s Test :
    	 Test Diff of 14.019
    	% Diff to Production of 0.999
    10379960 nor ns: @600 PERF with ISR Cascade .vs. Direct Func#()'s Test :
    	 Test Diff of 18.934  {this is most nebulous}
    	% Diff to Production of 0.951
    Hint: this is the locked T4_Beta
    10379970 ENC SM: @600 PERF _isr() char[] Test % Diff versus production T4:
    	_isr() char[] Test @24 us % Diff of 0.996
    	_isr() char[] Test @48 us % Diff of 0.969
    	_isr() char[] Test @96 us % Diff of 0.950
    	_isr() char[] Test @192 us % Diff of 0.892
    10379970 ENC SM: @600 PERF Cascade .vs. Direct Func#()'s Test :
    	 Test Diff of 16.962
    	% Diff to Production of 0.826
    10379970 ENC SM: @600 PERF with ISR Cascade .vs. Direct Func#()'s Test :
    	 Test Diff of 24.728  {this is most nebulous}
    	% Diff to Production of 0.728
    6052840 nor ns: @600 PERF _isr() char[] Test % Diff versus production T4:
    6052840 nor ns: @600 PERF Cascade .vs. Direct Func#()'s Test :
    	 Test Diff of 14.072
    	% Diff to Production of 0.996
    6052840 nor ns: @600 PERF with ISR Cascade .vs. Direct Func#()'s Test :
    	 Test Diff of 20.643  {this is most nebulous}
    	% Diff to Production of 0.872
    6683800 nor ns: @600 PERF _isr() char[] Test % Diff versus production T4:
    6683800 nor ns: @600 PERF Cascade .vs. Direct Func#()'s Test :
    	 Test Diff of 14.020
    6683800 nor ns: @600 PERF with ISR Cascade .vs. Direct Func#()'s Test :
    	 Test Diff of 20.153  {this is most nebulous}
    	% Diff to Production of 0.893
    If you don't see near 1.000 on Production board it comes from nearest build values seen with bool bPrintExtra = true
    25,035
    Here is an attempt to fix the bug where upload sometimes fails (if the pushbutton is pressed again) resulting in both LEDs blinking for several seconds.
    Extract this to {Arduino}/hardware/tools, replacing the copy already installed.
    Attached Files Attached Files
    9,560
    Sounds good,
    Downloaded... Luckily I only hit this I believe twice before, so will try hitting program button and hopefully never see it again...
    7,548
    Ditto from me as well. I only hit it once or twice as well. Did just have one thing happen when I hit PGM button one right after another. 1st did the upload second lock the T4 with only the Orange LED on and had to power off and on to recover. This might have been one of those instances where it would normally have been both LEDs on - can't tell for sure.
    15,074
    My machine refused : "couldn't download - virus detected"?
    Found offending page and hit allow and next try saved:
    Scan with Windows Defender and MalWareBytes find nothing - But EDGE wanted to trash it?
    15,074
    Updated code in use. Not sure how to 'prove the negative' - not sure if anything printed in loader/Verbose? {as Mike wondered}
    IIRC I saw 'DUAL LED blink' four times in some hundred+(?) builds - assuming they all caught my eye.
    Figured out why Code4Code - Bench mark version - moved to RAM was failing ... tried using DMAMEM with init strings that of course don't work.
    Funny: It points out local vars can't be in DMAMEM - but not that DMAMEM can't be initialized
    C:\T_Drive\tCode\T4Encrypt\Code4CodeRAM\CodeMade.i no:22501:25: warning: 'used' attribute ignored [-Wattributes]
    C:\T_Drive\tCode\T4Encrypt\Code4CodeRAM\CodeMade.i no:22502:25: error: section attribute cannot be specified for local variables
    So some dozen builds and gratuitous Button uploads and not seen anything yet.
    Had to downsize to a mere 1400 cascading functions to fit RAM and have enough stack space to not trigger a Crash:
    teensy_size: Memory Usage on Teensy 4.0:
    teensy_size:   FLASH: code:370096, data:121592, headers:9044   free for files:1530884
    teensy_size:    RAM1: variables:45952, code:365656, padding:27560   free for local variables:85120
    teensy_size:    RAM2: variables:24736  free for malloc/new:499552
    Powered 2nd T4 Beta and button pushing code to it ... not sure what sequence triggered the LED Show before ...
    15,074
    TSET command line build works from SubLime
    @Paul - All looking good for general use Arduino and Command line call of the builder - ala TSET!
    > many builds and uploads and no faults or issues - that can't be perhaps explained by jumping between 2 or 4 T4's doing Reset and Bootloader Upload via USB command.
    > Not doing .lst file in each build (plus perhaps local system changes) results in expected build times. with upload just over 10 secs for 10 func() c4cBM and just over 1 minute with 4,000 func()'s
    Not sure I changed anything in TSET (core local file date was 8/28) from Beta1 ... may have been a timing error or caught something since beta improved.
    > The Upload doesn't finish before TyCommander reports 'failed to reset' - but the upload completes - at least with 4K func()'s in C4CbenchM
    NOTES for TSET:
    > answer LAST question "T" not "Y" to upload with TeensyLoader
    > For MULTI INO sketches :: Do the build of Compile.cmd from the MAIN INO! {then any file in folder will run Build right}
    > tested BUILD UPLOAD (normal), Verify (notifies TLoader of new HEX location) , CLEAN (Full rebuild empties TEMP)
    > New copy of TSET on github, as always save or edit CMD1.BAT
    BTW: If you have Multiple of same Teensy online - it works to pick one to upload directly, then Button or GUI 'Bootloader' the others. All work as normal on TyComm serial Monitor.
    And of course don't integrate TyComm for the Beta Locked - then building opens Teensy Loader
    UPDATED :: Defragster/T4LockBeta/tree/main/C4CbenchM
    > had not replaced the .txt content to swap number of funcs() with reduced number of Pi Digits calculated from 60 to 12, so saw ERRORS.
    > Results seem to change with build So for side by side compare use bool bPrintExtra = true; to see the raw numbers.
    -> it does shows the decrypting from FLASH adds overhead, though the 'nebulous' Combo ISR & char[] test are very close so it may be that the decrypt [data & code] happens in parallel, or it is so busy with lost cache that the difference is a wash - or maybe there is an error in the calc logic.
    > Hitting 'Enter' triggers loop() to run repeatedly and show the Temp, and allows resetting of bool "bPrintExtra = false;" at compile time -
    Here is Console output - you can see it is not from IDE because the string "teensy_size:" is present:
    Building Sketch: ".\C4CbenchM.ino"
    Using board 'teensy40' from platform in folder: C:\T_Drive\Arduino_1.8.16_155\hardware\teensy\avr
    Using core 'teensy4' from platform in folder: C:\T_Drive\Arduino_1.8.16_155\hardware\teensy\avr
    Detecting libraries used...
    "C:\\T_Drive\\Arduino_1.8.16_155\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=155 -DARDUINO=10600 -DARDUINO_TEENSY40 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\T_Drive\\Arduino_1.8.16_155\\hardware\\teensy\\avr\\cores\\teensy4" "R:\\temp\\arduino_build_C4CbenchM.ino\\sketch\\C4CbenchM.ino.cpp" -o nul
    "C:\\T_Drive\\Arduino_1.8.16_155\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=155 -DARDUINO=10600 -DARDUINO_TEENSY40 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\T_Drive\\Arduino_1.8.16_155\\hardware\\teensy\\avr\\cores\\teensy4" "R:\\temp\\arduino_build_C4CbenchM.ino\\sketch\\C4CbenchM.ino.cpp" -o "R:\\temp\\arduino_build_C4CbenchM.ino\\preproc\\ctags_target_for_gcc_minus_e.cpp"
    "C:\\T_Drive\\Arduino_1.8.16_155\\tools-builder\\ctags\\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "R:\\temp\\arduino_build_C4CbenchM.ino\\preproc\\ctags_target_for_gcc_minus_e.cpp"
    Compiling sketch...
    "C:\\T_Drive\\Arduino_1.8.16_155\\hardware\\teensy/../tools/precompile_helper" "C:\\T_Drive\\Arduino_1.8.16_155\\hardware\\teensy\\avr/cores/teensy4" "R:\\temp\\arduino_build_C4CbenchM.ino" "C:\\T_Drive\\Arduino_1.8.16_155\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -x c++-header -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=155 -DARDUINO=10600 -DARDUINO_TEENSY40 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\T_Drive\\Arduino_1.8.16_155\\hardware\\teensy\\avr/cores/teensy4" "R:\\temp\\arduino_build_C4CbenchM.ino/pch/Arduino.h" -o "R:\\temp\\arduino_build_C4CbenchM.ino/pch/Arduino.h.gch"
    Using previously compiled file: R:\temp\arduino_build_C4CbenchM.ino\pch\Arduino.h.gch
    "C:\\T_Drive\\Arduino_1.8.16_155\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=155 -DARDUINO=10600 -DARDUINO_TEENSY40 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IR:\\temp\\arduino_build_C4CbenchM.ino/pch" "-IC:\\T_Drive\\Arduino_1.8.16_155\\hardware\\teensy\\avr\\cores\\teensy4" "R:\\temp\\arduino_build_C4CbenchM.ino\\sketch\\C4CbenchM.ino.cpp" -o "R:\\temp\\arduino_build_C4CbenchM.ino\\sketch\\C4CbenchM.ino.cpp.o"
    Compiling libraries...
    Compiling core...
    Using precompiled core: R:\temp\arduino_cache_C4CbenchM.ino\core\core_4291cde6f2aeb6bd53a075bd323e65cd.a
    "C:\\T_Drive\\Arduino_1.8.16_155\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc" -O2 -Wl,--gc-sections,--relax "-TC:\\T_Drive\\Arduino_1.8.16_155\\hardware\\teensy\\avr\\cores\\teensy4/imxrt1062.ld" -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -o "R:\\temp\\arduino_build_C4CbenchM.ino/C4CbenchM.ino.elf" "R:\\temp\\arduino_build_C4CbenchM.ino\\sketch\\C4CbenchM.ino.cpp.o" "R:\\temp\\arduino_build_C4CbenchM.ino/..\\arduino_cache_C4CbenchM.ino\\core\\core_4291cde6f2aeb6bd53a075bd323e65cd.a" "-LR:\\temp\\arduino_build_C4CbenchM.ino" -larm_cortexM7lfsp_math -lm -lstdc++
    "C:\\T_Drive\\Arduino_1.8.16_155\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-objcopy" -O ihex -j .eeprom --set-section-flags=.eeprom=alloc,load --no-change-warnings --change-section-lma .eeprom=0 "R:\\temp\\arduino_build_C4CbenchM.ino/C4CbenchM.ino.elf" "R:\\temp\\arduino_build_C4CbenchM.ino/C4CbenchM.ino.eep"
    "C:\\T_Drive\\Arduino_1.8.16_155\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-objcopy" -O ihex -R .eeprom "R:\\temp\\arduino_build_C4CbenchM.ino/C4CbenchM.ino.elf" "R:\\temp\\arduino_build_C4CbenchM.ino/C4CbenchM.ino.hex"
    "C:\\T_Drive\\Arduino_1.8.16_155\\hardware\\teensy/../tools/teensy_secure" encrypthex TEENSY40 "R:\\temp\\arduino_build_C4CbenchM.ino/C4CbenchM.ino.hex"
    encrypting 1107968 bytes to R:\temp\arduino_build_C4CbenchM.ino/C4CbenchM.ino.ehex
    "C:\\T_Drive\\Arduino_1.8.16_155\\hardware\\teensy/../tools/teensy_post_compile" -file=C4CbenchM.ino "-path=R:\\temp\\arduino_build_C4CbenchM.ino" "-tools=C:\\T_Drive\\Arduino_1.8.16_155\\hardware\\teensy/../tools/" -board=TEENSY40
    "C:\\T_Drive\\Arduino_1.8.16_155\\hardware\\teensy/../tools/stdout_redirect" "R:\\temp\\arduino_build_C4CbenchM.ino/C4CbenchM.ino.sym" "C:\\T_Drive\\Arduino_1.8.16_155\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-objdump" -t -C "R:\\temp\\arduino_build_C4CbenchM.ino/C4CbenchM.ino.elf"
    "C:\\T_Drive\\Arduino_1.8.16_155\\hardware\\teensy/../tools/teensy_size" "R:\\temp\\arduino_build_C4CbenchM.ino/C4CbenchM.ino.elf"
    teensy_size:   FLASH: code:972344, data:134680, headers:9132   free for files:915460
    teensy_size:    RAM1: variables:90848, code:28968, padding:3800   free for local variables:400672
    teensy_size:    RAM2: variables:12384  free for malloc/new:511904
          upload@10379970-Teensy  Uploading to board '10379970-Teensy' (Teensy 4.0)
          upload@10379970-Teensy  Triggering board reboot
          upload@10379970-Teensy  Waiting for Teensy Loader
          upload@10379970-Teensy  Failed to reset board '10379970-Teensy'
    [Finished in 70.9s]
    7,548
    @Paul
    As @defragster said
    All looking good for general use Arduino ........
    > many builds and uploads and no faults or issues - that can't be perhaps explained .......
    Last night and this morning I tried to fault the Locked T4 doing successive uploads of Tim's code4code sketch and then hitting the pgm button a couple of times in between to reload the sketch without any faults. In addition I uploaded several sketches one after the other with PGM button pushes in between without faulting. Only one time did I get the RED and orange light at the same time but that was my fault - I pressed the PGM button at almost the same time as a sketch was uploading I did see a Message window pop up from TL but wasn't on the screen long enough to read it - another PGM push loaded the sketch properly so again was probably me.
    25,035
    Only one time did I get the RED and orange light at the same time but that was my fault - I pressed the PGM button at almost the same time as a sketch was uploading...
    Oh, now that is a valuable piece of info! It very likely may be a bootloader bug in 1.07. The bootloader is supposed to ignore the Program button during certain critical times, but probably isn't in this case with a locked chip.
    Edit: just so you know, this is absolutely not your fault. The both LEDs blink pattern is an error that's never supposed to happen.
    9,560
    Morning all,
    Installed latest beta...
    I am not sure if the SEREMU fix is working properly now in this build? That is I build MTPD sketch (using the in build MTP Disk) and lost most of the startup output and also it felt like I was back to longer delays on startup...
    So Again ran slightly modified test:
    //#include <MTP.h>
      while (!Serial && millis() < 5000) ;
      if (!Serial) Serial.println("!Serial");
      Serial.println(millis(), DEC);
      Serial.print(CrashReport);
      Serial.println("Enter something to go boom");
    uint16_t loop_count = 0;
      if (Serial.read() != -1) {
        uint8_t *ptr = 0;
        *ptr = 99;
      Serial.printf("Loop Count: %u\n", ++loop_count);
      delay(250);
    When I run this With USB type of Serial I get:
    CrashReport:
      A problem occurred at (system time) 5:24:28
      Code was executing from address 0x88
      CFSR: 82
    	(DACCVIOL) Data Access Violation
    	(MMARVALID) Accessed Address: 0x0 (nullptr)
    	  Check code at 0x88 - very likely a bug!
    	  Run "addr2line -e mysketch.ino.elf 0x88" for filename & line number.
      Temperature inside the chip was 48.98 C
      Startup CPU clock speed is 600MHz
      Reboot was caused by auto reboot after fault or bad interrupt detected
    Loop Count: 1
    Loop Count: 2
    Loop Count: 3
    When I run it with USB Type of: MTP Disk (experimental) It runs, but notice difference in how long it takes to run:
    CrashReport:
      A problem occurred at (system time) 5:26:42
      CFSR: 82
      Temperature inside the chip was 48.33 C
    Loop Count: 1
    Loop Count: 2
    Loop Count: 3
    Loop Count: 4
    I ran this both with locked T4 and normal T4... Maybe something screwy on my machine, but ...
    15,074
    Morning all,
    When I tested with the dual while() {blink mostly off then on} on prior thread - the change to .begin() in cores showed function - but it was still slow - where the first 5 second wit exhausted - it didn't make it any faster for Serial to come online with the patch applied.
    i.e.: it worked - but was still slow to come online with MTP_exp
    Just tried that USB==Serial build fine on TyComm with :: firstSerial @462
    -> but never starts on USB==MTP_exp as before
    with USB==MTP_exp Opening IDE and starting t_serial.exe gives :: firstSerial @6851 - hadn't printed first Serial millis() before - but that is what the blinks showed.
    <crosspost - hand edited the PR==608 and it works better here>
    Making Kurts usb_desc.h edits: #elif defined(USB_MTPDISK)
    #define MTP_INTERFACE 1 // MTP Disk
    #define SEREMU_INTERFACE 0 // Serial emulation
    IDE t_SerMon reports a faster and good :: firstSerial @792
    > change doesn't help TyComm for whatever reason.
    Did get same results with CmdLine :: teensy_serialmon.exe -v usb:0/140000/0/6/1/1
    <EDIT> :: BTW - I built the MTP_Boom.ino from TSet {as Serial and MTP_exp} and it worked! { only problem hinted at above } is that not having IDE open means there is no easy way to start a usable SerMon - either open IDE or dig the USB: out of TLoader/Verbose in a DOS box.
    7,548
    Morning all,
    //#include <MTP.h>
        uint8_t *ptr = 0;
        *ptr = 99;
      delay(250);
    Just ran it here on my Win10x64 machine and got very similar results:
    With USB type of Serial = 412
    With USB Type of: MTP Disk (experimental) = 6048
    This is on a locked T4 with the latest updates.
    9,560
    Just ran on Ubuntu machine and with Beta2 and latest, timing was about 880ms with Beta3 about 990... Not sure if real difference or just slight delta... Will see how it runs on MAC next
    7,548
    Went back to the Beta1 thread and found @KurtE's initial timing timing test: https://forum.pjrc.com/threads/67989...l=1#post288241, which shows it was 1011ms. Only thing not 100% sure about is if that was with Windows or Ubuntu. @KurtE?
    9,560
    That one was Windows 10...
    Note on MAC it was about 300ms...
    But I am not sure if MAC has any MTP stuff built in...
    At one point was playing with OpenMTP... But...
    Sorry Paul, I know this is not an MTP release... Am just checking for differences from Beta2 to Beta3 and it felt like it had changed between the two betas...
    Edit: tried running beta 2 with Arduino 15 with current cores\teensy4 same timings... Not sure what changed... Or maybe I was dreaming when it came up in about a second earlier... (Beta 1 thread)
    9,560
    MTP Disk - startup timing differences...
    Figured out what was different, between then and now. I believe I mentioned I had a modified usb_desc.h file that I was trying.
    That I changed it to be closer to Audio...
    That is it has two interfaces: MTP and SEREMU...
    Current in build:
    #define MTP_INTERFACE		0	// MTP Disk
    #define SEREMU_INTERFACE      1 // Serial emulation
    Timeout in this case about: 6 seconds
    Change to:
    Timeout < 1 second:
    CrashReport:
      A problem occurred at (system time) 8:42:21
      CFSR: 82
      Temperature inside the chip was 53.52 C
    Loop Count: 1
    Loop Count: 2
    Loop Count: 3
    To late to change?
    25,035
    Change to:
    To late to change?
    Merged it just now.
    7,548
    @KurtE
    Just made the changed and on my locked T4 shows even better:
    CrashReport:
      A problem occurred at (system time) 11:53:50
      CFSR: 82
      Temperature inside the chip was 57.06 C
    Loop Count: 1
    Loop Count: 2
    Loop Count: 3
    Loop Count: 4
    before booming the T4
    No Crash Data To Report
      Hopefully all is well, but certain types of crashes can't be reported:
    	stuck in an infinite loop (technically, hardware still running properly)
    	remaining in a low power sleep mode
    	access to certain peripherals without their clock enabled (eg, FlexIO)
    	change of CPU or bus clock speed without use of glitchless mux
    Loop Count: 1
    Loop Count: 2
    9,560
    @KurtE
    Thanks,
    I went ahead and created a PR: https://github.com/PaulStoffregen/cores/pull/608
    Edit: I meant to also mention I tried running the same sketch with T3.6, but it does not show the same delays.
    Also does not go boom and does not support CrashReport
  24. #24
    15,074
    Didn't build any LittleFS - but just confirmed all RAM drives : PSRAM or DMAMEM that can generally persist across warm restart for some avenue of utility have been set to destroy on .begin()
    > memset(ptr, 0xFF, size); // always start with blank slate
    Not sure why YMMV loss of utility ... but that is now the case.
    <edit>: yes, I was a big fan of the old awesome behavior.
    > If the user wanted this destructive 'safe' behavior it is easy to do low level format or even Quick format on start in the examples with YMMV note on removing that.
  25. #25
    7,548
    Wouldn't worry too much about LittleFS @KurtE and I have been testing the heck out of it while testing MTP. Think the only thing we haven't tested was QSPI since we have been primarily using the Locked T4. Tested NAND, SPI flash, RAM, Program etc. Works very well with what we have been doing with MTP as well.
