Darthvader123
New member
Hi all,
I'm working on my first Teensy 3.2 with audio shield and so far I really love it, so thanks!
However, I do have some issues on loading my own WAV files instead of the public available test files.
I did do some searching in finding any content-requirements/limitations, but couldn't find a page describing this.
At this moment, when loading my own files the device won't play the sound.
The thing that is really different as the sample files is filesize and track length
My track is around 100Mb and has a length of 7 minutes.
(track length is not final, but will stay below 10 minutes)
I named it the same as the sample file("SDTEST1.wav")
I put the files in MediaInfo to see if I could find difference, the only difference I noted was the bitrate and the sampling rate.
Is there anyone on the forum who can tell me how to make this work?
Here are the MediaInfo results (left the Complete Name blank due to privacy reasons):
SampleFile from PJRC:
Complete name :
Format : Wave
File size : 16.0 MiB
Duration : 1 min 35 s
Overall bit rate mode : Constant
Overall bit rate : 1 411 kb/s
Track name : Where You Are Now
Director : Benjamin Orth, featuring Wolf Fly
Comment : http://www.ccmixter.org/files/Benjamin_Orth/33036
Audio
Format : PCM
Format settings : Little / Signed
Codec ID : 1
Bit rate mode : Constant
Bit rate : 1 411.2 kb/s
Channel(s) : 2 channels
Sampling rate : 44.1 kHz
Bit depth : 16 bits
Stream size : 16.0 MiB (100%)
Own file
Complete name :
Format : Wave
File size : 85.1 MiB
Duration : 7 min 44 s
Overall bit rate : 1 536 kb/s
Audio
Format : PCM
Codec ID : 1
Bit rate : 1 536 kb/s
Sampling rate : 48.0 kHz
Bit depth : 16 bits
Stream size : 85.1 MiB (100%)
Thanks in advance
Complete name :
Format : Wave
Audio
Format : PCM
Codec ID : 1
Bit depth : 16 bits
Own file
Complete name :
Format : Wave
Audio
Format : PCM
Codec ID : 1
Bit depth : 16 bits
Thanks in advance
