Results 1 to 7 of 7
Thread: teensy_size.exe : Access is denied.
    Jan 2018
    Livermore
    27
    Hello. Just a small question:
    I got new teensy 4.1 today, load Arduino and teensyduino, but cannot build peobram on Windows 10. Getting following message:
    Opening Teensy Loader...
    fork/exec C:\Users\isandler\programs\arduino\hardware\teensy/../tools/teensy_size.exe: Access is denied.
    Error compiling for board Teensy 4.1.
    trying to reinstall all the things in different locations, same result. Finally I noticed Carbon Black antivirus software was complaining:
    Does somebody saw same issue? What could be done? Probably simple solution would be to switch to linux?
    15,270
    It is a simple - very simple - .exe file - not seen it reported as matching the description of 'Malware' before. It came out with T_4.0 in some fashion and had some updates, but not reported here or elsewhere as a problem.
    Assuming since all is NEW that TeensyDuino 1.55 was installed? If not try that - the EXE has some change IIRC that might not trip the detection.
    If using 1.55 - if possible submit the EXE with request for better eval that it is not an infectious agent.
    > and maybe do a second unzip install - put on TD 1.54 and take the Teensy_size from there? It will have somewhat different EXE without the recent change that was made. That might not get caught as bad, though some small edits to the numbers presented will be off.
    Jan 2018
    Livermore
    27
    I'm using 1.55 version.
    teensy_size.exe attached.. maybe it could be possible to check if it is OK. Will fight Carbon Black antivirus then. And probably switch to Linux anyway.
    Attached Files Attached Files
    Jan 2018
    Livermore
    27
    Tried Ubuntu Linux 20.04, everything installed correctly. When I select "examples/Blink" application and push "verify", it starts compiling, then "teensy" window opens but arduino tells me
    Arduino: 1.8.16 (Linux), TD: 1.55, Board: "Teensy 4.1, Serial, 600 MHz, Faster, US English"
    /home/igor/Downloads/arduino-1.8.16/arduino-builder -dump-prefs -logger=machine -hardware /home/igor/Downloads/arduino-1.8.16/hardware -tools /home/igor/Downloads/arduino-1.8.16/tools-builder -tools /home/igor/Downloads/arduino-1.8.16/hardware/tools/avr -built-in-libraries /home/igor/Downloads/arduino-1.8.16/libraries -libraries /home/igor/Arduino/libraries -fqbn=teensy:avr:teensy41:usb=serial,speed=600,opt=o2std,keys=en-us -ide-version=10816 -build-path /tmp/arduino_build_845691 -warnings=none -build-cache /tmp/arduino_cache_358760 -verbose /home/igor/Downloads/arduino-1.8.16/examples/Teensy/Tutorial2/UsingVariable/UsingVariable.pde
    /home/igor/Downloads/arduino-1.8.16/arduino-builder -compile -logger=machine -hardware /home/igor/Downloads/arduino-1.8.16/hardware -tools /home/igor/Downloads/arduino-1.8.16/tools-builder -tools /home/igor/Downloads/arduino-1.8.16/hardware/tools/avr -built-in-libraries /home/igor/Downloads/arduino-1.8.16/libraries -libraries /home/igor/Arduino/libraries -fqbn=teensy:avr:teensy41:usb=serial,speed=600,opt=o2std,keys=en-us -ide-version=10816 -build-path /tmp/arduino_build_845691 -warnings=none -build-cache /tmp/arduino_cache_358760 -verbose /home/igor/Downloads/arduino-1.8.16/examples/Teensy/Tutorial2/UsingVariable/UsingVariable.pde
    Using board 'teensy41' from platform in folder: /home/igor/Downloads/arduino-1.8.16/hardware/teensy/avr
    Using core 'teensy4' from platform in folder: /home/igor/Downloads/arduino-1.8.16/hardware/teensy/avr
    Detecting libraries used...
    /home/igor/Downloads/arduino-1.8.16/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=155 -DARDUINO=10816 -DARDUINO_TEENSY41 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I/home/igor/Downloads/arduino-1.8.16/hardware/teensy/avr/cores/teensy4 /tmp/arduino_build_845691/sketch/UsingVariable.pde.cpp -o /dev/null
    /home/igor/Downloads/arduino-1.8.16/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=155 -DARDUINO=10816 -DARDUINO_TEENSY41 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I/home/igor/Downloads/arduino-1.8.16/hardware/teensy/avr/cores/teensy4 /tmp/arduino_build_845691/sketch/UsingVariable.pde.cpp -o /tmp/arduino_build_845691/preproc/ctags_target_for_gcc_minus_e.cpp
    /home/igor/Downloads/arduino-1.8.16/tools-builder/ctags/5.8-arduino11/ctags -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives /tmp/arduino_build_845691/preproc/ctags_target_for_gcc_minus_e.cpp
    Compiling sketch...
    /home/igor/Downloads/arduino-1.8.16/hardware/teensy/../tools/precompile_helper /home/igor/Downloads/arduino-1.8.16/hardware/teensy/avr/cores/teensy4 /tmp/arduino_build_845691 /home/igor/Downloads/arduino-1.8.16/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++ -x c++-header -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=155 -DARDUINO=10816 -DARDUINO_TEENSY41 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I/home/igor/Downloads/arduino-1.8.16/hardware/teensy/avr/cores/teensy4 /tmp/arduino_build_845691/pch/Arduino.h -o /tmp/arduino_build_845691/pch/Arduino.h.gch
    Using previously compiled file: /tmp/arduino_build_845691/pch/Arduino.h.gch
    /home/igor/Downloads/arduino-1.8.16/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++ -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=155 -DARDUINO=10816 -DARDUINO_TEENSY41 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I/tmp/arduino_build_845691/pch -I/home/igor/Downloads/arduino-1.8.16/hardware/teensy/avr/cores/teensy4 /tmp/arduino_build_845691/sketch/UsingVariable.pde.cpp -o /tmp/arduino_build_845691/sketch/UsingVariable.pde.cpp.o
    Compiling libraries...
    Compiling core...
    Using precompiled core: /tmp/arduino_cache_358760/core/core_c2c4de23571db61e611d76fa31dbb9ba.a
    /home/igor/Downloads/arduino-1.8.16/hardware/teensy/../tools/arm/bin/arm-none-eabi-gcc -O2 -Wl,--gc-sections,--relax -T/home/igor/Downloads/arduino-1.8.16/hardware/teensy/avr/cores/teensy4/imxrt1062_t41.ld -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -o /tmp/arduino_build_845691/UsingVariable.pde.elf /tmp/arduino_build_845691/sketch/UsingVariable.pde.cpp.o /tmp/arduino_build_845691/../arduino_cache_358760/core/core_c2c4de23571db61e611d76fa31dbb9ba.a -L/tmp/arduino_build_845691 -larm_cortexM7lfsp_math -lm -lstdc++
    /home/igor/Downloads/arduino-1.8.16/hardware/teensy/../tools/arm/bin/arm-none-eabi-objcopy -O ihex -j .eeprom --set-section-flags=.eeprom=alloc,load --no-change-warnings --change-section-lma .eeprom=0 /tmp/arduino_build_845691/UsingVariable.pde.elf /tmp/arduino_build_845691/UsingVariable.pde.eep
    /home/igor/Downloads/arduino-1.8.16/hardware/teensy/../tools/arm/bin/arm-none-eabi-objcopy -O ihex -R .eeprom /tmp/arduino_build_845691/UsingVariable.pde.elf /tmp/arduino_build_845691/UsingVariable.pde.hex
    /home/igor/Downloads/arduino-1.8.16/hardware/teensy/../tools/teensy_secure encrypthex TEENSY41 /tmp/arduino_build_845691/UsingVariable.pde.hex
    No key .pem file found, skipping .ehex encryption
    /home/igor/Downloads/arduino-1.8.16/hardware/teensy/../tools/teensy_post_compile -file=UsingVariable.pde -path=/tmp/arduino_build_845691 -tools=/home/igor/Downloads/arduino-1.8.16/hardware/teensy/../tools/ -board=TEENSY41
    Unable find Teensy Loader.  (p)  Is the Teensy Loader application running?
    quitexit status 1
    Teensy information window:
    12:59:37.103 (loader): Teensy Loader 1.55, begin program
    12:59:37.113 (loader): Unable to listen for remote control
    12:59:37.113 (loader): initialized, showing main window
    13:01:03.836 (loader): Verbose Info event
    15,270
    Quote Originally Posted by ig-or View Post
    Downloaded the zip and extracted
    Both tools here saw it as BUG free : Windows Defender and MalwareBytes
    Did a compare of the TD 1.55 version here and it matches
    Before I could Run it under Windows - given it came from download zip - it had to be 'Un Blocked', but then it ran
    Don't see any reason to suggest it is anything but a false positive from 'Carbon Black'
    If you can override that detection, or report it to them as 'known good' they might clean up their over zealous detection.
    25,217
    Yes, confirmed, this file is ok. It is an exact match to the original copy created on my Linux machine.
    I build all of Teensy's Windows software by cross compiling from Linux. The files are them copied to Windows machines for testing. This file I used for comparison is the original build still on my Linux machine.
    Yup. Anti-virus false positives are sadly a pretty common occurrence. Please report it to them.
    Jan 2018
    Livermore
    27
    Thanks for this check. This CarbonBlack sometimes is too much.
