TEENSY4.0 MTP responder on USB2
bomber
New member
I have a teensy 4.0 with serial and MTP operating on the primary USB port. Unfortunately the primary USB connection will not be available in the enclosure but I can get wires onto the 2nd ports pads on the underside. Only MTP will be required on this port, serial and code loading could remain on the primary port. Can the software easily be configured to support this configuration?
regards
Ian
