Is a non-balancing BMS safe if each cell has individual protection?
I have have 5 3.7V cells that each have some kind of protection circuit on them connected to a basic BMS without balancing.
https://m.aliexpress.com/item/1005001327267228.html
https://m.aliexpress.com/item/32909360073.html
Do I need to care about balancing if each battery should check its voltages stay in range? Is it safe and is there anything I need to be careful with.
As an aside, I want to charge this with 20V from USB-C. Any issues with that?
Thanks.
Be aware of the effect on total pack capacity. Without active balancing, you are limited by the lowest cell capacity. And by any imbalance.
Thanks for the response. I'm not too concerned about capacity right now - I just want it to work safely.
Tags for this Thread
- You may not post replies
- You may not edit your posts
Forum Rules
