Results 1 to 4 of 4
Thread: Teensy 4.0 reseting on button click
    Sep 2021
    2
    We have wired a teensy 4.0 to a single button and are trying to identify when the button is pressed, but once the button is pressed we only get that the teensy resets.
    HTML Code:
      pinMode(4,INPUT_PULLUP);
     if( digitalRead(4) == HIGH){
      Serial.println("Button Pressed");
    Wiring:
    singal Pin -> to 10 k resitor to -> ground and the other side of the button
    3.3 v to one side of the button
    Any ideas why this could be hapenning.
    15,095
    Have only seen something similar when 'main 3.3V' shorted to Ground.
    With INPUT_PULLUP the pin is pulled up to 3.3V internally, there is no need to connect "3.3 v to one side of the button".
    Using the button to GND that would result use this test: if( digitalRead(4) == LOW){
    Try:
    > signal Pin -> to one side of button
    > 10 k resistor to the other side of the button to ground
    Sep 2021
    2
    That worked, thank you so much!
    15,095
    - Awesome.
