Results 1 to 4 of 4
Thread: Help with granular effect
    Sep 2021
    3
    Question Help with granular effect
    Hello every one, i am super new with the teensy, arduino and all the digital stuffs, now im trying to program a simple granular effect, until now im usin two 20K knobs on A1 and A2 to control beginFreeze and setSpeed and so far everything kinda work (even tho the speed changes weirdly), now im trying to add a push button for the beginFreeze but cant really write the code for it. Also my teensy 4.0 board doesent detect A4/5/6 etc only until A3 is this normal, same for digital inputs.
    here is the code i have made so far
    Please feel free to edit it if you feel it, any advice would be higly appreciated.
    AudioInputI2S i2s1; //xy=440,372
    AudioMixer4 mixer1; //xy=660,396
    AudioEffectGranular granular1; //xy=901,444
    AudioOutputI2S i2s2; //xy=1089,399
    AudioConnection patchCord1(i2s1, 0, mixer1, 0);
    AudioConnection patchCord2(mixer1, granular1);
    AudioConnection patchCord3(granular1, 0, i2s2, 0);
    AudioConnection patchCord4(granular1, 0, i2s2, 1);
    AudioControlSGTL5000 sgtl5000_1; //xy=526,143
    #define GRANULAR_MEMORY_SIZE 12800 // enough for 290 ms at 44.1 kHz
    int16_t granularMemory[GRANULAR_MEMORY_SIZE];
    // inputs
    #define pot1 A1 // beginFreeze
    #define pot2 A2 // setSpeed
    // Audio connections require memory to work. For more
    AudioMemory(10);
    // I2S audio init
    sgtl5000_1.enable();
    sgtl5000_1.volume(5);
    AudioInterrupts();
    // read pot levels
    float knob1 = (float)analogRead(pot1) / 1023.0; // beginFreeze
    float knob2 = (float)analogRead(pot2) / 1023.0; // setSpeed
    mixer1.gain(0, 5); // unused, gain 0
    mixer1.gain(1,0.5); // granular1 (wet) gain
    mixer1.gain(3, 5); // unused, gain 0
    // the Granular effect requires memory to operate
    granular1.begin(granularMemory, GRANULAR_MEMORY_SIZE);
    granular1.beginFreeze(knob1);
    granular1.beginPitchShift(knob2);
    Serial.print("%, beginFreeze: ");
    Serial.print(knob1 * 100.0);
    Serial.print("%, setSpeed: ");
    Serial.print(knob2 * 100.0);
    Serial.print("%, Dry Level: ");
    Serial.print("% / ");
    Cheltenham, UK
    416
    If you really want people to help you with your code then present it properly - enclose it within [CODE] tags using the # button below.
    See how much easier it is to read when done properly.
    // inputs
    	AudioMemory(10);
    	// I2S audio init
    	AudioInterrupts();
    	// read pot levels
    	mixer1.gain(1, 0.5); // granular1 (wet) gain
    Sep 2021
    3
    Thank you as Iíve said Iím a newbie and actually this is my first thread ever, btw thanks for the tip will take it in mind.
    Btw any clue about my question?
    Cheltenham, UK
    416
    Sorry never worked with audio.
