We finally have reached a milestone with our lathe turret project. A microcontroller was needed to interface between a Centroid Acorn motion controller and a couple stepper motor drivers as well as a lot of other circuitry. Due to it's small size and power, we decided to use the Teensy. While we were originally using a Teensy LC, a major change was needed and more interface pins were required so we went to a Teensy 3.5. (The board is designed to work with a 3.6 or a 4.1, as well.)
The goal, here, was to use the turret from the Portable Production Lathe so that it could be installed on a bigger CNC lathe. Finally, everything is working. The Teensy microcontroller allows several different interfacing methods to be used for a CNC motion controller to control a lathe turret.
For more information there is this post: https://5cfab.com/demo-video-of-the-...-lathe-turret/
Older information can be found here: https://5cfab.com/blogs/
ID:	25963Click image for larger version.
Here is a video of the turret working: https://www.youtube.com/watch?v=eiTkd5Gu3xA
Here is a video of the turret changing tooling: https://www.youtube.com/watch?v=OrdlqpU-ulc
A schematic of the Turret Interface Board, with the Teensy, is here: https://5cfab.com/wp-content/uploads...ematic-4_1.pdf
Some history of the board development:
https://5cfab.com/turret-interface-board-development-2/
https://5cfab.com/five-generations-o...rd-prototypes/
https://5cfab.com/turret-interface-boards/
https://5cfab.com/turret-interface-b...g-is-complete/
Best Regards!
