Results 1 to 5 of 5
Thread: Teensy 4 with TWO pcm5102 DAC ?
    Dec 2018
    149
    I have been using the PCM5102 for various projects. These DACs are cheap and deliver high quality audio.
    I am wondering if it is possible to use 2 of them to get 4 audio channel outputs ?
    Thank you
    Emmanuel
    Senior Member PaulS's Avatar
    Apr 2015
    Netherlands
    642
    Hi Emmanuel,
    I guess it's possible, see the example at File > Examples > Audio > HardwareTesting > PassThroughQuad.
    Connect one PCM5102 board to pins 7, 20, 21 and the other board to pins 32, 20, 21.
    Code [not tested by me]:
    AudioSynthWaveformSine   sine1;
    AudioOutputI2SQuad       i2s_quad2;
    AudioConnection          patchCord1(sine1, 0, i2s_quad2, 2);
    AudioConnection          patchCord2(sine1, 0, i2s_quad2, 3);
    AudioConnection          patchCord3(sine1, 0, i2s_quad2, 0);
    AudioConnection          patchCord4(sine1, 0, i2s_quad2, 1);
      AudioMemory(12);
      sine1.frequency(1000);
      sine1.amplitude(0.5); // -6dB
    Paul
    Jul 2020
    1,218
    Or I think you can use AudioOutputI2S and AudioOutputI2S2 together if on an Teensy 4.x
    25,022
    Yes, either AudioOutputI2SQuad or AudioOutputI2S & AudioOutputI2S2 should work fine.
    You could connect up to 5 of those PCM5102 boards if you use AudioOutputI2SOct and AudioOutputI2S2. But one of the required pins is on the bottom side of Teensy 4.0, so the wiring is easier if using Teensy 4.1.
    Dec 2018
    149
    Thank you.
    It works !
    Emmanuel
