it's always pointed out to use the keyword
volatile
with variables which are changed inside an ISR. What if I have a struct with a buffer inside and I want to change values in the buffer inside an ISR. Does the whole struct need to be defined as
volatile
or should only the buffer in the declaration through
typedef
be
volatile
Thank you in advance
