Results 1 to 2 of 2
Thread: Intelligent access control based on ESP32 and LCD
    Apr 2021
    9
    Required materials
    Realized function
    1. card registration.
    2. username and password registration.
    3. card swipe to unlock the electronic lock.
    4. User name and password to unlock the electronic lock.
    Connection diagram
    GUI design
Name:	GUI design.png
    code sharing
    import mfrc522
    import time
    import _thread
    from os import uname
    from machine import Pin, UART
    #from pyb import UART
    #import machine
    suos = Pin(32,Pin.OUT)
    uart2 = UART(2, baudrate=115200, rx=16,tx=17,timeout=10)
    ESP32_HSPI_CLOCK = 14
    ESP32_HSPI_SLAVE_SELECT = 15
    ESP32_HSPI_MISO = 12
    ESP32_HSPI_MOSI = 13
    ESP32_MFRC522_RST = 5
    rx3 = []
    rx_name = []
    user_id_flag = False
    password_flag = False
    temp_id = ''
    temp_mima = ''
    personnel_id = {'zbw':[236,230,169,47],'lbw':[19,165,93,4]}
    personnel_ps = {'zbw':'zbw3366','lbw':'lbwnb'}
    admin_password = ('yyds')
    button_cmd = [16,1]
    edit1_cmd = [16,112]
    edit2_cmd = [16,113]
    edit3_cmd = [16,114]
    if uname()[0] == 'esp32':
    	rdr = mfrc522.MFRC522(ESP32_HSPI_CLOCK, ESP32_HSPI_MOSI, ESP32_HSPI_MISO, ESP32_MFRC522_RST, ESP32_HSPI_SLAVE_SELECT)
    def do_write():
    	try:
    		(stat, tag_type) = rdr.request(rdr.REQIDL)
    		if stat == rdr.OK:
    			(stat, raw_uid) = rdr.anticoll()
    			if stat == rdr.OK:
    				print("New card detected")
    				print("  - tag type: 0x%02x" % tag_type)
    				print("  - uid : 0x%02x%02x%02x%02x" % (raw_uid[0], raw_uid[1], raw_uid[2], raw_uid[3]))
    				print("")
    				if rdr.select_tag(raw_uid) == rdr.OK:
    					key = [0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF]
    					if rdr.auth(rdr.AUTHENT1A, 8, key, raw_uid) == rdr.OK:
    						stat = rdr.write(8, b"\x00\x53\x00\x54\x00\x4F\x00\x4E\x00\x45\x0a\x0b\x  0c\x0d\x0e\x0f")
    						rdr.stop_crypto1()
    						if stat == rdr.OK:
    							print("Data written to card")
    						else:
    							print("Failed to write data to card")
    					else:
    						print("Authentication error")
    				else:
    					print("Failed to select tag")
    	except KeyboardInterrupt:
    		print("write error")
    def do_read():
    	while True:
    		try:
    			if stat == rdr.OK:
    				if stat == rdr.OK:
    					print (raw_uid[0], raw_uid[1], raw_uid[2], raw_uid[3])
    					print("")
    							print("Address 8 data: %s" % rdr.read(8))
    							for ps in personnel_id:
    								if raw_uid[0:4:1] == personnel_id.get(ps):
    									suos.value(1)
    									print(ps)
    									uart_write(ps, *raw_uid[0:4:1])
    									time.sleep(3)
    									uart2.sendbreak()
    									break
    							rdr.stop_crypto1()
    							time.sleep(3)
    							suos.value(0)
    						else:
    					else:
    			if uart2.any()>1:
    				rx2 = []
    				data_name2 = ''
    				bin_data = uart2.read(40)
    				uart2.sendbreak()
    				rx1 = list(bin_data)
    				for item in rx1:
    					rx2.append(chr(item))
    				print(rx2)
    				if rx1[3:5:1] == button_cmd:
    					data_name_len = rx1[6] - 1
    					data_name = rx2[7:data_name_len+7:1]
    					data_name2 = ''.join(data_name)
    					print(data_name2)
    					if data_name2 == 'back3':
    						return
    			print("read error")
    def do_read2 (idd):
    	print(idd)
    	while True:
    		try:
    			if stat == rdr.OK:
    				if stat == rdr.OK:
    					print("")
    							personnel_id[idd] = raw_uid[0:4:1]
    							uart_write3(*raw_uid[0:4:1])
    							rdr.stop_crypto1()
    						else:
    					else:
    			if uart2.any()>1:
    				rx2 = []
    				data_name2 = ''
    				uart2.sendbreak()
    				for item in rx1:
    					print(data_name2)
    				if data_name2 == 'back1':
    					return
    			print("read error")
    def uart_write(text, *ids):
    #	print(text, *ids)
    	uart2.write('ST<{"cmd_code":"set_text","type":"label","widget":"cardname1","text":"'+str(text)+'"}>ET')
    	uart2.write('ST<{"cmd_code":"set_text","type":"label","widget":"cardid1","text":"'+str(ids)+'"}>ET')
    	uart2.write('ST<{"cmd_code":"set_visible","type":"widget","widget":"lock1","visible":true}>ET')
    	time.sleep(3)
    	uart2.write('ST<{"cmd_code":"set_text","type":"label","widget":"cardname1","text":"''"}>ET')
    	uart2.write('ST<{"cmd_code":"set_text","type":"label","widget":"cardid1","text":"''"}>ET')
    	uart2.write('ST<{"cmd_code":"set_visible","type":"widget","widget":"lock1","visible":false}>ET')
    def uart_write2(text,text2):
    	uart2.write('ST<{"cmd_code":"set_text","type":"label","widget":"cardid","text":"'+text+'"}>ET')
    	time.sleep(3)
    	uart2.write('ST<{"cmd_code":"set_text","type":"label","widget":"cardid","text":"'+text2+'"}>ET')
    	uart2.write('ST<{"cmd_code":"set_text","type":"label","widget":"edit2","text":"''"}>ET')
    def uart_write3(*id2):
    	uart2.write('ST<{"cmd_code":"set_text","type":"label","widget":"cardid","text":"'+str(id2)+'"}>ET')
    	time.sleep(3)
    	uart2.write('ST<{"cmd_code":"set_text","type":"label","widget":"cardid","text":"''"}>ET')
    def uart_write4(text,text2):
    	uart2.write('ST<{"cmd_code":"set_text","type":"label","widget":"login","text":"'+text+'"}>ET')
    	time.sleep(1)
    	uart2.write('ST<{"cmd_code":"set_text","type":"label","widget":"login","text":"'+text2+'"}>ET')
    	time.sleep(1)
    	uart2.write('ST<{"cmd_code":"set_text","type":"label","widget":"edit3","text":"''"}>ET')
    	uart2.write('ST<{"cmd_code":"set_text","type":"label","widget":"edit4","text":"''"}>ET')
    	uart2.write('ST<{"cmd_code":"set_text","type":"label","widget":"edit7","text":"''"}>ET')
    def uart_write5():
    	time.sleep(3)
    def card_zhuce():
    	while True:
    		if uart2.any():
    			user_id = ''
    			password = ''
    			rx2 = []
    			rx_num = 0
    			uart2.sendbreak()
    			for item in rx1:
    				rx_num += 1
    			data_end = rx_num-5
    			data_id_st = rx2[8:13:1]
    			data_id_st2 = ''.join(data_id_st)
    			print(data_id_st2)
    			if data_id_st2 == 'edit1':
    				data_id_st3 = rx2[15:data_end:1]
    				data_id_st4 = ''.join(data_id_st3)
    				print(data_id_st4)
    				if data_id_st4 != '':
    					name = True
    			elif data_id_st2 == 'edit2':
    				data_id_st5 = rx2[15:data_end:1]
    				data_id_st6 = ''.join(data_id_st5)
    				if data_id_st6 == admin_password:
    					admin = True
    					uart_write2('Verification passed!','Please place the card!')
    					do_read2(data_id_st4)
    					return
    def mima_zuce():
    	temp_id3 = ''
    	temp_mima3 = ''
    	while True:
    		if uart2.any():
    			user_id = ''
    			password = ''
    			rx2 = []
    			rx_num = 0
    #			data_end = 0
    			uart2.sendbreak()
    			for item in rx1:
    				rx_num += 1
    #				if (rx2[rx_num] == 'T') and (rx2[rx_num-1] == 'E') and (rx2[rx_num-2] == '>'):
    #					break
    			data_end = rx_num-5
    			print(data_id_st2)
    				print(data_name2)
    				if data_name2 == 'back2':
    					return
    			if data_id_st2 == 'edit3':
    				print(data_id_st4)
    				user_id_flag = True
    				temp_id3 = data_id_st4
    #				personnel_ps[temp_id] = raw_uid[0:4:1]
    			elif data_id_st2 == 'edit4':
    				print(data_id_st6)
    #				if personnel_ps.get(temp_id) == data_id_st6:
    				password_flag = True
    				temp_mima3 = data_id_st6
    #					personnel_ps[temp_id] = password_flag
    #			print(rx2,user_id_flag,password_flag)
    			elif data_id_st2 == 'edit7':
    				if (data_id_st6 == admin_password) and (password_flag == True) and (user_id_flag == True):
    					admin = True
    					personnel_ps[temp_id3] = temp_mima3
    					uart_write4('Verification passed!','login was successful!')
    def password_loin():
    	temp_id2 = ''
    	temp_mima = ''
    	while True:
    		if uart2.any():
    			user_id = ''
    			password = ''
    			rx2 = []
    			rx_num = 0
    #			data_end = 0
    			uart2.sendbreak()
    			for item in rx1:
    				rx_num += 1
    #					break
    			data_end = rx_num-5
    			print(data_id_st2)
    				print(data_name2)
    				if data_name2 == 'back4':
    					return
    			if data_id_st2 == 'edit5':
    				print(data_id_st4)
    				if data_id_st4 in personnel_ps:
    					user_id_flag = True
    					temp_id2 = data_id_st4
    			elif data_id_st2 == 'edit6':
    				print(data_id_st6)
    				print(temp_id2)
    				print(personnel_ps)
    				if personnel_ps.get(temp_id2) == data_id_st6:
    					print(user_id_flag,password_flag)
    					if (password_flag == True) and (user_id_flag == True):
    						uart_write(temp_id2,temp_id2)
    						suos.value(1)
    						uart2.write('ST<{"cmd_code":"set_visible","type":"widget","widget":"lock2","visible":true}>ET')
    						uart2.write('ST<{"cmd_code":"set_text","type":"label","widget":"edit5","text":"''"}>ET')
    						uart2.write('ST<{"cmd_code":"set_text","type":"label","widget":"edit6","text":"''"}>ET')
    						time.sleep(3)
    #						uart_write('student','')
    						suos.value(0)
    						uart2.write('ST<{"cmd_code":"set_visible","type":"widget","widget":"lock2","visible":false}>ET')
    						uart2.sendbreak()
    while True:
    	if uart2.any()>1:
    		rx2 = []
    		data_name2 = ''
    #		time.sleep(1)
    		uart2.sendbreak()
    #		time.sleep(1)
    		for item in rx1:
    		print(rx2)
    			print(data_name2)
    			if data_name2 == 'card1':
    				card_zhuce()
    			elif data_name2 == 'password1':
    				mima_zuce()
    			elif data_name2 == 'card2':
    				do_read()
    			elif data_name2 == 'password2':
    				password_loin()
    Video demo
    Aug 2018
    Brisbane, Australia
    79
    Very nice. But does this have anything to do with teensy?
