chrissaich
I have a Teensy 4.1 connected to custom hardware running an MQTT Client based data acquisition system. It's working really well and its fast.
I'm logging data to the SD card, which again is working perfectly, but the dream would be to get data off the SD card without having to remove it from Teensy.
Initially, I'm just looking for advice on the best practical solution and the best libraries to use with Teensy 4.1.
- Best option would be to run Samba server code on the Teensy, but I can't find any suggestion on the forum that suitable libraries exist or that its practical on the T4.1.
- Second best option would be ftp or tftp server code on the Teensy. I have found some but I can't get it to run successfully - tftp client is refused connection.
- Third best option would be WebServer code on the Teensy. Again, I've found some but couldn't get it working and I'm not sure it would allow me to upload a file to a PC, modify it and download it back onto the Teensy SD card would it?
