Page 1 of 3 1 2 3 LastLast
Results 1 to 25 of 71
Thread: New Guy Looking For Teensy DSP programming tips
    Sep 2021
    American living in France
    78
    I'm a retired DSP software design engineer. I want to continue my previous activities from time to time. I have been working on several projects with the Arduino Nano, UNO. I just bought a Teensy 4.0 board and audio shield. I want to start a new project as soon as I receive the headers for the shield.
    I've studied the Teensy GUI Audio Design Tool which looks very useful for open-loop algorithms. However, I would like to create an Automatic Gain Control for my TV or mp3 player so that I won't need to continuously push the +- remote control button every time a louder commercial interrupts the film or my next mp3 song was recorded at a different volume level.
    Basically, my question concerns, how can I write a Teensy AGC audio function (non-optimized at first). Below, I am providing a Matlab code for the details. Thanks.
    ---------------------------------------------- Matlab Code ----------------------------------
    clear;
    close all;
    filename='Baez.wav';
    filename=input('input wav filename: ','s');
    [sig, fs]=audioread(filename);
    T=1/fs;
    [nsamp,dummy]=size(sig);
    fclose('all');
    k=.00001;
    ref=.07;
    gain(1)=0.5;
    numiter=nsamp;
    for iter=1:numiter
    sigout(iter)=sig(iter)*gain(iter);
    t(iter)=(iter-1)*T;
    err(iter)=abs(sigout(iter))-ref;
    gain(iter+1)=gain(iter)-err(iter)*k;
    end
    figure
    plot(t,sig,'b');
    grid on;
    zoom on;
    hold on;
    plot(t,sigout,'r');
    hold off;
    title('Input Signal(blue), Output Signal(red)');
    xlabel('seconds');
    Sep 2021
    78
    I forgot figure 1.Click image for larger version.
    Member Moo's Avatar
    Oct 2016
    UK
    57
    have a look at the source code for existing components in the audio library and try to change them. see if you can make small changes and then try compiling them. see if you can add a parameter, perhaps an extra gain param to start with.
    copy AudioEffectGain.h and .cpp in the audio library, rename it, and see if you can translate each matlab function one by one to a cloned version of AudioEffectGain.
    look through the other audio library source code to see what functions are available, how to import them, #include <math> , for instance, to add square root, there are lots of great examples and teensy audio library is a great place to see how the basic functions are implemented. unfortunate there will be a learning curve writing classes etc in c++, however it is worth the learning curve, in my experience.
    hope that helps. i had a look at your matlab code, but I didnít understand gain() function.
    Member Moo's Avatar
    Oct 2016
    UK
    57
    before you write an audio class, you could write a simple arduino sketch which takes an array and writes the gain for each sample to the serial port.
    int16_t sig[10] = { 0, 1, 2, 1, 0, -1 … }
    double gain = 0.5;
    for (int i=0; i<10; i++) {
    gain = …;
    Serial.printf(“gain for sample %i is %d”, i, gain);
    once you have that working as expected, it should be much easier to transfer to an audio class.
    Sep 2021
    78
    thanks
    Don't want to change the library. Just want to write my agc function in the Arduino code loop(). I don't know how to get and send data from my Arduino code to the I/O I2S objects. Sure would be great to have an example sketch of copying input samples to output samples via a declared buffer in my sketch. Maybe I need play and record objects using queues?
    As for your misunderstanding of my Matlab code: If you're not familiar with Matlab, it's difficult to understand. I always simulate functions before I code them and the forum rules recommend furnishing current code. The gain is just the multiplier applied to each input sample to obtained the output sample's desired absolute average level.
    1,768
    The code below should use the queues to just pass input from line-in to the output.
    You can then modify the loop which does the copying to implement the AGC. I may have a shot at it myself
    Pete
    // AGC - see https://forum.pjrc.com/threads/68320
    AudioInputI2S            i2s1;           //xy=305.8833312988281,324.8833312988281
    AudioRecordQueue         queue1;         //xy=569.8833312988281,248.88333129882812
    AudioPlayQueue           queue2;         //xy=759.8833312988281,249.88333129882812
    AudioOutputI2S           i2s2;           //xy=683.8833312988281,319.8833312988281
    AudioConnection          patchCord1(i2s1, 0, queue1, 0);
    AudioConnection          patchCord2(queue2, 0, i2s2, 0);
    AudioConnection          patchCord3(queue2, 0, i2s2, 1);
    AudioControlSGTL5000     sgtl5000_1;     //xy=97.88333129882812,111
    void setup(void)
      while(!Serial);
      AudioMemory(32);
      sgtl5000_1.enable();
      sgtl5000_1.volume(0.75);
      // Start the record queue
      queue1.begin();
    void loop(void)
      short *bp1,*bp2;
      // When an input buffer becomes available
      // process it
      if (queue1.available() >= 1) {
        bp1 = queue1.readBuffer();
        bp2 = queue2.getBuffer();
        // Copy from input to output buffer
        for(int i = 0;i < AUDIO_BLOCK_SAMPLES;i++) {
          *bp2++ = *bp1++;
        // Free the input audio buffer
        queue1.freeBuffer();
        // and play it back into the audio queue
        queue2.playBuffer();
      // volume control
      static int volume = 0;
      // Volume control
      int n = analogRead(15);
      if (n != volume) {
        volume = n;
        sgtl5000_1.volume(n / 1023.);
    Sep 2021
    78
    Oh Great! Just what I needed. I will try it as soon as I get those rare headers to connect the audio shield. Amazon or AliExpress don't have them and the delay from the PJRC store to my home in France is several weeks.
    Yes, try it out if you want. It's the AGC algo similar to the one I used for the V.32bis modem when I was working. However, the adaptation step size was much faster than this one.
    1. I am surprised that there are very few closed-loop algorithms (LMS, AGC, DPLL, etc.) in the Teensy library. Maybe later on? I don't believe there is a mips issue with a Cortex M7 core.
    2. Not enough or haven't found sufficient documentation to do basic setups like what you have just shown me.
    Thanx!
    Sep 2021
    78
    Ah, just one more question so I don't flood the forum with my newguy questions. Can you please show me how the GUItool looks like for automatically generating this code? Thanx again!
    Sep 2021
    78
    Better display of the agc Click image for larger version.
    Cheltenham, UK
    464
    If you can't find these why not use use these with these.
    They can even be made from a much longer strip for ease of supply.
    If making them from a longer strip, don't forget to allow for scrapping the
    pin between the two 14 pin strips, i.e a 28 pin strip will not make two 14 pin strips. You will need at least 29 pins.
    Or you could use two 10 + 4 socket headers and two 14 pin headers from this kit. You should be able to get that tomorrow with Prime.
    Apr 2020
    DFW area in Texas
    305
    Quote Originally Posted by Bill Glass View Post
    Bill:
    I hope this answers the question that you are asking. Using Pete's code as follows as an example:
    void setup(void)
      while(!Serial);
      AudioMemory(32);
      queue1.begin();
    void loop(void)
      short *bp1,*bp2;
      // process it
          *bp2++ = *bp1++;
      // volume control
      // Volume control
      if (n != volume) {
        volume = n;
    You can cut/paste everything between the two "// GUItool" comments & "Import" that excerpt into the GUItool.
    This allows you to duplicate the layout & connections that someone (or yourself) has defined/designed. Any changes/additions/corrections that you make can then be "Exported" back into your program. Hope that helps . . .
    Feel free to ask any other questions that you may have. This is a wonderful forum, as there are several individuals on here that are always willing to answer questions & to help with understanding any & all aspects of the Teensy & its peripherals.
    Mark J Culross
    KD5RXT
    Sep 2021
    78
    I ordered female header (long)pins from EBAY for the Teensy so I can optionally plug the sound card with male headers (short)pins on top and also optionally plug the both or just the Teensy to a perfboard with female header (short)pins on it. Hope that makes sense.
    Sep 2021
    78
    Quote Originally Posted by kd5rxt-mark View Post
    Bill:
    void setup(void)
      while(!Serial);
      AudioMemory(32);
      queue1.begin();
    void loop(void)
      short *bp1,*bp2;
      // process it
          *bp2++ = *bp1++;
      // volume control
      // Volume control
      if (n != volume) {
        volume = n;
    Mark J Culross
    KD5RXT
    GREAT! THANX!
    Oct 2015
    Vermont, USA
    314
    If all you want is AGC, then the audio processing block that you're looking for is a "compressor". I've always been suprised that there isn't one in the Teensy Audio Library. I'd do one myself, but my integer math skills are lacking. Instead...
    You're running a Teensy 4, which means that you can do floating point math as fast as integer math. Therefore, you are not limited to the Teensy Audio Library (with it's focus on integer math). There are several folks with floating-point extensions of the Teensy Audio Library. You can run any one of them without penalty.
    One choice is the OpenAudio library (https://github.com/chipaudette/OpenAudio_ArduinoLibrary). I started it, but it is now maintained by others. Most important for you is that it has two different compressors that you can use. I'd start with the simpler one. One of the examples that comes with the library shows you how to use it: https://github.com/chipaudette/OpenA...mpressor_Float
    Here's a blog post explaining its approach...it's a totally standard dynamic range compressor: https://openaudio.blogspot.com/search/label/Compression
    Chip
    Sep 2021
    78
    Quote Originally Posted by chipaudette View Post
    Chip
    Yes, I will look into this. I have developed my fixed point code inside the Arduino loop() but I'm still waiting for hardware before I can test it. Simulations work in Matlab for floating point and C (mingw64) for fixed point. I'm using I/O audio wav files for now. It would be interesting to compare the number of cycles per sample needed for the floating point compressor and the fixed point agc. Click image for larger version.
ID:	26056Click image for larger version.
    Sep 2021
    78
    I thought about the similarities and differences between an AGC and a compressor. I have never compared 2 audio clips processed by, respectively, the 2 algorithms. But it seems that we would lose the "nuances" (dynamic range) in a song processed by compression. With an AGC using a small adaptation constant (step size), we would observe the different passages played at pp(pianissimo) or ff(fortissimo). With the compression, we would hear, most likely, mf(mezzo forte) or f(forte). My goal is to maintain the high fidelity on 2 different songs recorded with 2 different recording levels.
    Voila, my thoughts of the day.
    Bill
    Sep 2021
    78
    Pete
    Thanx for the help. I was able to implement your program & modify it with the agc that I plan to use for my TV, stereo. I perform a current agcGain to L&R queues and play them. I then update the agcGain according to the sum of the 128 samples compared to a reference. I'll try and show the results below (I'm not yet very skilled on using the tools on this forum). It works. I finally got the headers I needed for attaching the audio shield to the Teensy 4.0. I have 3 questions.
    1. Before I used the Line in input, I loaded the wav file on the SD card and looped on it. The SD player froze up a few times. Has anyone else noticed that?
    2. How do I determine the size x for AudioMemory(x)? I needed to put 128 to reduce the SD player's freezing up.
    3. Is there a way to find the number of instruction cycles needed to process each sample queue?
    //#define USE_SD //audio from SD card instead of linein
    //#define PASSTHRU //direct copy of input to output samples
    #ifdef USE_SD
    AudioPlaySdWav           playSdWav1;
    #else
    AudioInputI2S            i2s1;           //xy=139.1999969482422,214.99998474121094
    AudioRecordQueue         queue1;         //xy=369.20001220703125,209.99998474121094
    AudioRecordQueue         queue3;         //xy=370.20001220703125,262.20001220703125
    AudioPlayQueue           queue2;         //xy=546.2000122070312,210.1999969482422
    AudioPlayQueue           queue4;         //xy=548.2000122070312,268.20001220703125
    AudioOutputI2S           i2s2;           //xy=750.2000122070312,216.99998474121094
    #ifdef USE_SD
    AudioConnection          patchCord1(playSdWav1, 0, queue1, 0);
    AudioConnection          patchCord2(playSdWav1, 1, queue3, 0);
    #else
    AudioConnection          patchCord2(i2s1, 1, queue3, 0);
    AudioConnection          patchCord3(queue2, 0, i2s2, 0);
    AudioConnection          patchCord4(queue4, 0, i2s2, 1);
    AudioControlSGTL5000     sgtl5000_1;     //xy=132.20001220703125,142
    #ifdef USE_SD
    #define SDCARD_CS_PIN    10
    #define SDCARD_MOSI_PIN  7
    #define SDCARD_SCK_PIN   14
    #else
    int32_t agcGain1=0x08000000;//.5 in Q3.29 format
    int32_t agcGain2=0x08000000;//.5 in Q3.29 format
    void setup(void)
      AudioMemory(128);
      sgtl5000_1.volume(0.5);
    #ifdef USE_SD
      SPI.setMOSI(SDCARD_MOSI_PIN);
      SPI.setSCK(SDCARD_SCK_PIN);
        while (1) {
    #else
      queue1.begin();
      queue3.begin();
    void loop(void)
      int16_t *bp1,*bp2,*bp3,*bp4;
      int32_t sum,err;
      int32_t ref=293504;//.07*AUDIO_BLOCK_SAMPLES in Q15 format(2293*128)
    #ifdef USE_SD
      if (playSdWav1.isPlaying() == false)
        Serial.println("Start playing");
    //    playSdWav1.play("test.wav");
        playSdWav1.play("Tower.wav");
        delay(10);
      // process it
    #ifdef PASSTHRU
          *bp2++ = *bp1++;
    #else
        // Apply agcGain on input with saturation to output buffer
          //ref. dspinst.h in Teensy audio library
          //*bp2++=saturate16((((int32_t)(*bp1++))*(agcGain1>>15))>>13);
          *bp2++=saturate16(signed_multiply_32x16b(agcGain1>>12,(*bp1++)));
        sum=0;
        // Calculate sum of abs values of output buffer
           sum+=(int32_t)(abs(*bp2++));
        // Calculate new agcGain for next input buffer
        err=ref-sum;
        agcGain1+=err>>3; //update gain
        agcGain1=min(agcGain1,0x3fffffff); //keep agcGain < 4.0
      if (queue3.available() >= 1) {
        bp3 = queue3.readBuffer();
        bp4 = queue4.getBuffer();
    #ifdef PASSTHRU
          *bp4++ = *bp3++;
    #else
          //*bp4++=saturate16((((int32_t)(*bp3++))*(agcGain2>>15))>>13);
          *bp4++=saturate16(signed_multiply_32x16b(agcGain2>>12,(*bp3++)));
        sum=0;
           sum+=(int32_t)(abs(*bp4++));
        err=ref-sum;
        agcGain2+=err>>3; //update gain
        agcGain2=min(agcGain2,0x3fffffff); //keep agcGain < 4.0
        queue3.freeBuffer();
        queue4.playBuffer();
      // volume control
      // Volume control
      int n = analogRead(0);
      if (n != volume)
        volume = n;
        sgtl5000_1.volume((float)n / 1023.);
    Germany
    9,421
    Unfortunately, that's normal for the waveplayer
    I dont' think that that helps, because the player does not use the additional memory.
    You can find out more about memory here:
    https://www.pjrc.com/teensy/td_libs_...onnection.html
    For your code?
    Yes, you can use micros() - gives you the microseconds counter.
    Or, better, you can use ARM_DWT_CYCCNT - that gives you exacty cycles (32Bit-counter - and 600MHZ will roll it pretty fast)
    uint32_t t = ARM_DWT_CYCCNT;
    //*do your stuff *
    t = ARM_DWT_CYCCNT - t;
    Sep 2021
    78
    For your code?
    //*do your stuff *
    OK
    For the SD card, I don't intend to use it anyway but it's good to know that what I observed appears to be normal.
    I found that I use 15 cycles/sample with AGC ON and 4 in PASSTHRU. Guess there should be about (13605-15) free cycles @ fs=44100 & fclk=600 MHz. Not bad!
    I found AudioMemoryUsageMax=7.
    Looks like there's some working space and time left over for some more complicated projects. I like this Teensy!
    Thank you for the info!
    BR Bill
    Sep 2021
    78
    Not because I need to, but because I'm curious to see if I can optimize the number of cycles/sample in my AGC program. In my AUDIO_BLOCK_SAMPLES loop for calculating and applying the agcGain, I have created only 1 loop per channel instead of 2 to obtain 12 instead of 15 cycles per sample(see my last post showing the code). I then tried to take advantage of the ARM capability of performing 2 instructions simultaneously. I now get 8.8 cycles per sample. I am trying to take advantage of the dspinst.h list of optimized instructions list. The new code is shown below if anyone is interested in commenting. Thanks.
    //#define NCYCLES
    #ifdef USE_SD
    #else
    #ifdef USE_SD
    #else
    #ifdef USE_SD
    #else
    #ifdef NCYCLES
    uint32_t iter=0;
    void setup(void)
      AudioMemory(32);
    #ifdef USE_SD
        while (1) {
    #else
      queue1.begin();
      queue3.begin();
    void loop(void)
      int16_t *bp1,*bp2,*bp1a,*bp2a,*bp3,*bp4,*bp3a,*bp4a;
      int32_t sum,sum1,err,res,res1;
    #ifdef NCYCLES
      uint32_t t;
    #ifdef USE_SD
        delay(10);
      // process it
    #ifdef NCYCLES
        t = ARM_DWT_CYCCNT;
        bp1a= bp1+1;
        bp2a= bp2+1;
    #ifdef PASSTHRU
          *bp2++ = *bp1++;
    #else
        sum=0;
        sum1=0;
        for(int i = 0;i < AUDIO_BLOCK_SAMPLES/2;i++)
          res=signed_multiply_32x16b(agcGain1>>12,*bp1);
          res1=signed_multiply_32x16b(agcGain1>>12,*bp1a);
          *bp2=saturate16(res);
          *bp2a=saturate16(res1);
          sum+=abs(res);
          sum1+=abs(res1);
          bp1+=2;bp1a+=2;bp2+=2;bp2a+=2;
        sum+=sum1;
        err=ref-sum;
    #ifdef NCYCLES
        iter++;
        if (iter==1000)
          iter=0;
          Serial.print("cycles for left channel AGC on 128 samples: "); //1122 cycles or 8.8 cycles/sample
          Serial.print(t);
          Serial.print(" AudioMemoryUsageMax: ");
          Serial.println(AudioMemoryUsageMax()); //32
      } //if (queue1.available() >= 1)
        bp3a=bp3+1;
        bp4a=bp4+1;
    #ifdef PASSTHRU
          *bp4++ = *bp3++;
    #else
        sum=0;
        sum1=0;
          res=signed_multiply_32x16b(agcGain1>>12,*bp3);
          res1=signed_multiply_32x16b(agcGain1>>12,*bp3a);
          *bp4=saturate16(res);
          *bp4a=saturate16(res1);
          sum+=abs(res);
          sum1+=abs(res1);
          bp3+=2;bp3a+=2;bp4+=2;bp4a+=2;
        sum+=sum1;
        err=ref-sum;
      } //if (queue3.available() >= 1)
      // volume control
      // Volume control
      if (n != volume)
        volume = n;
    Germany
    9,421
    That looks pretty good.
    If you want to play a bit more, you can try to use 32Bit reads and writes and to process two samples per channel at once.
    It *may* be a little faster as two reads and stores less would be done on each loop, but may need a shift. Often the ARM can do that sidline and is costless, worst case it needs 1 cycle per shift (the CPU has a barrel-shifter)
    As said if you want to try - it may safe a few cycles more. ( Edit: And it automatically unrolls the loop by two)
    An other option is to try to just unroll the loop a little more.
    It all depends on the free registers. If the compiler needs more than registers inside the loop than the CPU has available things might become slower.
    Sep 2021
    78
    Thanks for the tip. I might try those 32-bit R/W's. I'll let you know. Bye
    Sep 2021
    78
    FYI
    1. 32-bit R/W with signed_multiply_32x16b and signed_multiply_32x16t requires a few more cycles.
    2. Unrolling my last code that I showed you but processing 4 samples/loop requires 7 instead of 8.8 cycles/sample.
    I think I'll stop playing. Thanks.
    Sep 2021
    78
    And the final code
    //#define DEBUG
    #ifdef USE_SD
    #else
    #ifdef USE_SD
    #else
    #ifdef USE_SD
    #else
    #ifdef DEBUG
    uint32_t iter=0;
    void setup(void)
      AudioMemory(32);
    #ifdef USE_SD
        while (1) {
    #else
      queue1.begin();
      queue3.begin();
    void loop(void)
    #ifdef DEBUG
      uint32_t t;
    #ifdef USE_SD
        delay(10);
    //--------------------------- Left channel -----------------------------
      if (queue1.available() >= 1) //Left Channel
    #ifdef DEBUG
        t = ARM_DWT_CYCCNT;
        agcCalc(queue1.readBuffer(),queue2.getBuffer(),&agcGain1);
    #ifdef DEBUG
        iter++;
        if (iter==1000)
          iter=0;
          Serial.print("left queue processing duration in cycles/sample: "); //7.7 cycles/sample
          Serial.print((float)t/(float)AUDIO_BLOCK_SAMPLES);
          Serial.print(AudioMemoryUsageMax()); //32
          Serial.print(" agcGain: ");
          Serial.println((float)agcGain1/(float)0x10000000);
    //--------------------------- Right channel -----------------------------
        agcCalc(queue3.readBuffer(),queue4.getBuffer(),&agcGain2);
    //--------------------------- volume control ----------------------------
      // Volume control
      if (n != volume)
        volume = n;
    void agcCalc(int16_t *inbuf,int16_t *outbuf,int32_t *agcGain)
      int16_t *bp1,*bp2;
      int32_t sum,sum1,sum2,sum3,res,res1,res2,res3,err;
      bp1=inbuf;
      bp2=outbuf;
    #ifdef PASSTHRU
          *bp2++ = *bp1++;
    #else
        sum=0;
        sum1=0;
        sum2=0;
        sum3=0;
        for(int i = 0;i < AUDIO_BLOCK_SAMPLES>>2;i++)
          res=signed_multiply_32x16b(*agcGain>>12,*bp1++);
          res1=signed_multiply_32x16b(*agcGain>>12,*bp1++);
          res2=signed_multiply_32x16b(*agcGain>>12,*bp1++);
          res3=signed_multiply_32x16b(*agcGain>>12,*bp1++);
          *bp2++=saturate16(res);
          *bp2++=saturate16(res1);
          *bp2++=saturate16(res2);
          *bp2++=saturate16(res3);
          sum+=abs(res);
          sum1+=abs(res1);
          sum2+=abs(res2);
          sum3+=abs(res3);
        sum+=(sum1+sum2+sum3);
        err=ref-sum;
        *agcGain+=err>>3; //update gain
        *agcGain=min(*agcGain,0x3fffffff); //keep agcGain < 4.0
    Sep 2021
    78
    Once I receive all the HW I ordered for hooking up the AGC to my TV/Stereo, I want to add a pre-emphasis filter upstream to the AGC. It's for higher frequencies for us older folks. I have used the FIR library programmed with coefficients I designed offline. I am able to make it work with the AGC (see attached template and recording of a composite sine wave at the sound card's stereo headphone jack. I would like to know if anyone has an easy method for tracing the digital-only xfer function without going thru the sound card (maybe viaClick image for larger version.
ID:	26194Click image for larger version.
ID:	26195 the SD card??). This would be especially useful for selective biquad designs. Thanks.
