caroeisbaer
New member
Hello hello!
I am quite new to programming and stumbled upon the teensy board a while ago.
I am using it for a perfromance in which sound is being played from the sd card and triggered by a distance sensor. the distance modulates teh sound with the help of a bit crsuher - the closer the ppl get to the object with the sensor the less the effect of the bitcrusher.
so far so good. 3 out of 5 are working, the last 2 though are not being detected by the port as soon as i insert the sd card in the audio shield. As soon as I insert it while the teensy is connected via usb to the computer the port serial port disappears.
Any ideas??
The show starts on friday, so i would reallyyyyy appreacite fast help
merci!
Any ideas??
merci!
AudioPlaySdWav playWav1; //xy=326,518
AudioSynthSimpleDrum drum1; //xy=343,424
AudioSynthNoiseWhite noise1; //xy=350,351
AudioEffectBitcrusher bitcrusher1; //xy=508,450
AudioEffectChorus chorus1; //xy=518,351
AudioMixer4 mixer1; //xy=713,411
AudioOutputI2S audioOutput; //xy=861,442
AudioConnection patchCord1(playWav1, 0, bitcrusher1, 0);
AudioConnection patchCord2(drum1, 0, mixer1, 1);
AudioConnection patchCord3(noise1, chorus1);
AudioConnection patchCord4(bitcrusher1, 0, mixer1, 2);
AudioConnection patchCord5(chorus1, 0, mixer1, 0);
AudioConnection patchCord6(mixer1, 0, audioOutput, 0);
AudioConnection patchCord7(mixer1, 0, audioOutput, 1);
AudioControlSGTL5000 sgtl5000_1; //xy=440,688
#define SDCARD_CS_PIN 10
#define SDCARD_MOSI_PIN 7
#define SDCARD_SCK_PIN 14
long timeInterval = 10000;
unsigned long previousMillis;
// VL53L0X.h IR DISTANCE SENSOR SETUP
#include "Adafruit_VL53L0X.h"
Adafruit_VL53L0X lox = Adafruit_VL53L0X();
//Serial.begin(9600);
// wait until serial port opens for native USB devices
//while (! Serial) {
//delay(1);
Serial.println("Adafruit VL53L0X test");
if (!lox.begin()) {
Serial.println(F("Failed to boot VL53L0X"));
while (1);
// power
Serial.println(F("VL53L0X API Simple Ranging example\n\n"));
// Audio connections require memory to work. For more
AudioMemory(8);
// Comment these out if not using the audio adaptor board.
// This may wait forever if the SDA & SCL pins lack
// pullup resistors
sgtl5000_1.enable();
sgtl5000_1.volume(1);
noise1.amplitude(0.3);
mixer1.gain(0, 0.5);
mixer1.gain(1, 0.5);
mixer1.gain(2, 0.5);
mixer1.gain(3, 0.5);
bitcrusher1.bits(16);
bitcrusher1.sampleRate(8000);
drum1.frequency(600);
drum1.length(200);
SPI.setMOSI(SDCARD_MOSI_PIN);
SPI.setSCK(SDCARD_SCK_PIN);
// stop here, but print a message repetitively
while (1) {
Serial.print("Playing file: ");
Serial.println(filename);
// Start playing the file. This sketch continues to
// run while the file plays.
playWav1.play(filename);
// A brief delay for the library read WAV info
delay(25);
// Simply wait for the file to finish playing.
while (playWav1.isPlaying()) {
VL53L0X_RangingMeasurementData_t measure;
lox.rangingTest(&measure, false); // pass in 'true' to get debug data printout!
uint16_t distance = constrain(pow(measure.RangeMilliMeter, 1.0), 0, 1000);
uint16_t crushAmount = map(distance, 0, 1000, 44100, 0);
Serial.println(crushAmount);
bitcrusher1.sampleRate(crushAmount);
// uncomment these lines if you audio shield
// has the optional volume pot soldered
//float vol = analogRead(15);
//vol = vol / 1024;
// sgtl5000_1.volume(vol);
// bitcrusher1.sampleRate(8000);
unsigned long currentMillis = millis();
Serial.print("Reading a measurement... ");
if (measure.RangeStatus != 4) { // phase failures have incorrect data
Serial.print("Distance (mm): "); Serial.println(measure.RangeMilliMeter);
Serial.println(" out of range ");
mixer1.gain(0, 0.0);
mixer1.gain(1, 0.0);
if (measure.RangeMilliMeter < 600) {
mixer1.gain(0, 0.1);
//mixer1.gain(1, 0.1);
playFile("HYPERL.WAV"); // filenames are always uppercase 8.3 format
delay (500);
} else if (measure.RangeMilliMeter < 2000){
float vol = map(measure.RangeMilliMeter, 600, 2000, 100, 0);
mixer1.gain(0, vol/100.0);
//mixer1.gain(1, vol/100.0);
// play a sample every second
if(currentMillis - previousMillis >= timeInterval) {
previousMillis = currentMillis;
mixer1.gain(1,0.8);
drum1.noteOn();
Serial.println("click");
else if (measure.RangeStatus < 800) {
playFile("RAUSCHEN.WAV"); // filenames are always uppercase 8.3 format
delay (500);
else if (measure.RangeStatus < 1000) {
playFile("POTATO.WAV"); // filenames are always uppercase 8.3 format
delay (500);
Serial.println(ldrVal);
Serial.println(pot);
