Page 2 of 2 FirstFirst 1 2
Results 26 to 34 of 34
Thread: DMX hardware rec for Teensy 3.2?
  1. #26
    Mar 2017
    Oakland, CA, USA
    344
    (Note: you need an “end code” when wrapping code — [/CODE].)
    data[7] = 0;
    data[8] = 128;
    data[9] = 128;
    Etc…
    It works in the setup section because that’s one of several syntaxes for “creating an array of length 7 and then initializing it with some values.” You’re trying to do an assignment and C++ doesn’t have “assign several things to an array at once, starting from a specific index.”
  2. #27
    Excellent Shawn! Thanks... I was sucessfull at applying that technique but it seemed unweildly so I tried to get fancy. Thanks again.
    The light show is simple but there are a lot of mechanics and sound that is taking a ton of time too. I don't work this hard at work!
    Photos soon
  3. #28
    Opening Night... Tonight!
    Thanks for everybody's help with this! I got everything working except addressing individual lights (Case 8 in the DMX Function section shows one of many attempts). Other than that, the show is exactly what I hoped for and is going to be fun for a lot of kids who will hopefully turn to STEM in education. For me? I learned a ton about coding the Teensy and balancing coding, mechanics and soldering under a time constraint. I am literally writing this while my thumb is bleeding.
    Anyway, here is my 2021 Halloween Show "Paper Moon". I'll send video soon; the music really makes it...
    Jeff
      Holiday Show Control - v1.1 10/15/21
      by Jeff W. Parisse - 09/09/2021
      jparisse@me.com
      TeensyDMX library (c) 2019-2020 Shawn Silverman
      Adafruit Servo Driver Library Written by Limor Fried/Ladyada for Adafruit Industries.
      Thanks to Shawn and Paul S. for their help on the PJRC Forums.
      This program acts as a show controller for holiday show projects. It runs on a Teesy 3.2 and controls servos via
      a I2C servo controller, addressable LEDs via an external processor, sound via an 16Mb Sound F/C Controller and
      DMX via a CTC-DRA-10-R2 Arduino Shield.
      Processor: Teensy 3.2
      PIR Sensor: 5V In, 3.3V Logic HIGH on Detect
      DMX Shield: Generic using TeensyDMX Library
      NEO Processor; Adafruit Itsy Bitsy M4 Express, LOW to trigger
      Sound F/X Board: LOW to trigger
      Servo Driver: I2C Address A1 (despite hardware A0 selected)
      AC Relays: HIGH to turn ON
      Pin Outs:
        Pin 0   RX    Serial In
        Pin 1   TX    Serial Out
        Pin 2   DMX   DOUT
        Pin 3   PIR   DIN
        Pin 4   AUX   DIN
        Pin 5   NEO   DOUT
        Pin 6   AC1   DOUT
        Pin 7   AC2   DOUT
        Pin 8   SFX0  DOUT
        Pin 9   SFX1  DOUT
        Pin 10  SFX2  DOUT
        Pin 11  SFX3  DOUT
        Pin 12  SFX4  DOUT
        Pin 13  LED   DOUT
        Pin 14  SFX5  DOUT
        Pin 15  SFX6  DOUT
        Pin 16  SFX7  DOUT
        Pin 17  SFX8  DOUT
        Pin 18  SDA   I2C
        Pin 19  SCL   I2C
        Pin 22  VOL+  DOUT (v1.1 not used)
        Pin 23  VOL-  DOUT (v1.1 not used)
    #include <Adafruit_PWMServoDriver.h>
    #include <TeensyDMX.h>
    #define dmxPin 2
    #define pirPin 3
    #define auxPin 4
    #define neoPin 5
    #define ac1Pin 6
    #define ac2Pin 7
    #define sfx0Pin 8
    #define sfx1Pin 9
    #define sfx2Pin 10
    #define sfx3Pin 11
    #define sfx4Pin 12
    #define ledPin 13
    #define sfx5Pin 14
    #define sfx6Pin 15
    #define sfx7Pin 16
    #define sfx8Pin 17
    #define volupPin 22
    #define voldnPin 23
    #define servoFreq 50                 // ~50 Hz servo updates
    Adafruit_PWMServoDriver pwm = Adafruit_PWMServoDriver(0x41);
    namespace teensydmx = ::qindesign::teensydmx;
    teensydmx::Sender dmxTx{Serial1};
    // DMX Variables
    uint8_t data[7] = {255, 0, 0, 0, 0, 0, 0};          // Default: OFF
    unsigned long dmxInterval = 1000;                   // 1sec
    unsigned long previousDmxMillis = 0;
    uint8_t dmxPick = 1;                                // Default
    uint8_t x = 0;                                      // For Loop Counter
    // Servo Variables
    uint8_t servo1 = 0;
    uint8_t servo2 = 1;
    uint8_t servo3 = 2;
    uint8_t servo4 = 3;
    uint8_t servo5 = 4;
    uint8_t servo6 = 5;
    uint8_t servo7 = 6;
    uint8_t servo8 = 7;
    uint8_t servo9 = 8;
    uint8_t servo10 = 9;
    uint8_t servo11 = 10;
    uint8_t servo12 = 11;
    uint8_t servo13 = 12;
    uint8_t servo14 = 13;
    uint8_t servo15 = 14;
    uint8_t servo16 = 15;
    // Servo Timer
    boolean servoDirection = LOW;
    uint16_t servoMin = 167;                       // 900ms This is the 'minimum' pulse length count (out of 4096)
    uint16_t servoCenter = 279;                    // 900ms This is the 'minimum' pulse length count (out of 4096)
    uint16_t servoMax = 390;                       // 2100ms This is the 'maximum' pulse length count (out of 4096)
    unsigned long servoInterval = 500;             // Default
    unsigned long previousServoMillis = 0;
    // Moon Timer (Blocking)
    boolean moonState = LOW;
    uint16_t moonUp = 167;                        // 900ms This is the 'minimum' pulse length count (out of 4096)
    uint16_t moonDown = 390;                      // 2100ms This is the 'maximum' pulse length count (out of 4096)
    unsigned long moonSongInterval = 30000;       // Length of Song #1 - Paper Moon
    // Show Timer
    boolean showState = LOW;
    int showMin = 120000;                         // 120,000 ms = 00:02:00 (two minutes)
    int showMax = 180000;                         // 180,000 ms = 00:03:00 (three minutes)
    unsigned long showInterval = 120000;          // Default: 120,000 ms = 00:02:00
    unsigned long previousShowMillis = 0;
    // Delay Timer
    boolean delayState = LOW;
    int delayMin = 60000;                        // 60,000 ms = 00:01:00 (one minute)
    int delayMax = 120000;                       // 120,000 ms = 00:02:00 (two minutes)
    unsigned long delayInterval = 30000;         // Default: 30,000 ms = 00:00:30
    unsigned long previousDelayMillis = 0;
    int songPick = 1;                            // Start with Song #1
    int intervalPick = 2;                        // Default
    int danceStep = 250;                         // Default
      // Serial.begin(115200);
      pwm.begin();
      pwm.setOscillatorFrequency(27000000);
      pwm.setPWMFreq(servoFreq);                 // Analog servos run at ~50 Hz updates
      pinMode(pirPin, INPUT);
      pinMode(auxPin, INPUT_PULLUP);
      pinMode(dmxPin, OUTPUT);
      pinMode(neoPin, OUTPUT);
      pinMode(ac1Pin, OUTPUT);
      pinMode(ac2Pin, OUTPUT);
      pinMode(ledPin, OUTPUT);
      pinMode(sfx0Pin, OUTPUT);
      pinMode(sfx1Pin, OUTPUT);
      pinMode(sfx2Pin, OUTPUT);
      pinMode(sfx3Pin, OUTPUT);
      pinMode(sfx4Pin, OUTPUT);
      pinMode(sfx5Pin, OUTPUT);
      pinMode(sfx6Pin, OUTPUT);
      pinMode(sfx7Pin, OUTPUT);
      pinMode(sfx8Pin, OUTPUT);
      pinMode(volupPin, OUTPUT);
      pinMode(voldnPin, OUTPUT);
      // Turn everything OFF
      pwm.setPWM(servo9, 0, moonDown);          // Moon Servo
      digitalWrite(dmxPin, HIGH);               // Set DMX TX Pin to HIGH
      for (x = 1; x <= 23; x = x + 7) {         // Set DMX Lights to OFF
        dmxTx.set(x, data, 7);
      dmxTx.begin();                            // Start DMX
      digitalWrite(neoPin, LOW);                // LEDs OFF
      digitalWrite(ac1Pin, LOW);                // Black Light OFF
      digitalWrite(ac2Pin, LOW);                // Mirrored Ball & Spotlight OFF
      digitalWrite(ledPin, LOW);                // Trigger Indicator OFF
      soundOff();                               // All sounds OFF
      delay(3000);                              // Wait 3 seconds for PIR Module to go LOW
      digitalWrite(sfx0Pin, LOW);               // Ambient Sound ON
      unsigned long currentMillis = millis();                                       // Check Time
      boolean pirState = digitalRead(pirPin);                                       // Check PIR Trigger
      if (pirState == HIGH) {                                                       // If PIR triggered, change showState to HIGH
        showState = HIGH;
        digitalWrite(ledPin, HIGH);
      else {
      if (currentMillis - previousDelayMillis >= delayInterval) {
        previousDelayMillis = currentMillis;
        delayState = HIGH;
      if (showState == HIGH && delayState == HIGH) {
        digitalWrite(sfx0Pin, HIGH);                                               // Ambient Sound OFF
        if (moonState == LOW) {                                                    // Check if Moon Show has run
          digitalWrite(ac1Pin, HIGH);                                              // Black Lights ON
          digitalWrite(sfx1Pin, LOW);                                              // Play Paper Moon
          for (uint16_t moonPos = moonDown; moonPos >= moonUp; --moonPos) {        // Moon UP
            pwm.setPWM(servo9, 0, moonPos);
            delay(10);
          delay(moonSongInterval);
          for (uint16_t moonPos = moonUp; moonPos <= moonDown; ++moonPos) {        // Moon DOWN
            delay(10);
          digitalWrite(ac1Pin, LOW);                                               // Black Lights OFF
          soundOff();                                                              // All sound OFF
          moonState = HIGH;                                                        // Moon Show has run
        // Dance Show Starts Here
        digitalWrite(ac2Pin, HIGH);                                                // Mirror Ball ON
        digitalWrite(neoPin, HIGH);                                                // Neopixels ON
        playSong();        // Start Music
        if (currentMillis - previousDmxMillis >= dmxInterval) {
          previousDmxMillis = currentMillis;
          playDmx();
        if (servoDirection == LOW) {
          uint16_t pulseLengthLow1 = random(servoMin, servoCenter);
          uint16_t pulseLengthLow2 = random(servoMin, servoCenter);
          pwm.setPWM(servo1, 0, pulseLengthLow1);
          pwm.setPWM(servo2, 0, pulseLengthLow2);
          servoInterval = getDanceStep();
          servoDirection = HIGH;
        else {
          uint16_t pulseLengthHigh1 = random(servoCenter, servoMax);
          uint16_t pulseLengthHigh2 = random(servoCenter, servoMax);
          pwm.setPWM(servo1, 0, pulseLengthHigh1);
          pwm.setPWM(servo2, 0, pulseLengthHigh2);
        if (currentMillis - previousShowMillis >= showInterval) {       // Check for End of Show
          previousShowMillis = currentMillis;
          showState = LOW;
          delayState = LOW;
          moonState = LOW;
          pwm.setPWM(servo1, 0, servoCenter);                           // Center Servo1
          pwm.setPWM(servo2, 0, servoCenter);                           // Center Servo2
          pwm.setPWM(servo9, 0, moonDown);                              // Moon DOWN
          digitalWrite(neoPin, LOW);                                    // Turn NeoPixels Off
          digitalWrite(ac2Pin, LOW);                                    // AC 2 OFF - Mirrored Ball & Pin Spot
          soundOff();                                                   // Turn Sound OFF
          dmxOff();                                                     // Turn DMX OFF
          digitalWrite(sfx0Pin, LOW);                                   // Sound #0 ON - Scene 0
          ++songPick;                                                   // Advance Song List by 1
          if (songPick >= 8) {                                          // If >7, Rollover Song List
            songPick = 1;
          showInterval = random(showMin, showMax);                      // Pick new show interval.
          delayInterval = random(delayMin, delayMax);                   // Pick new delay interval.
    // Functions
    void soundOff() {
      digitalWrite(sfx1Pin, HIGH);
      digitalWrite(sfx2Pin, HIGH);
      digitalWrite(sfx3Pin, HIGH);
      digitalWrite(sfx4Pin, HIGH);
      digitalWrite(sfx5Pin, HIGH);
      digitalWrite(sfx6Pin, HIGH);
      digitalWrite(sfx7Pin, HIGH);
      digitalWrite(sfx8Pin, HIGH);
      digitalWrite(volupPin, HIGH);
      digitalWrite(voldnPin, HIGH);
    void dmxOff() {
      data[0] = 255;
      data[1] = 0;
      data[2] = 0;
      data[3] = 0;
      data[4] = 0;
      data[5] = 0;
      data[6] = 0;
    void playSong() {
      switch (songPick) {
        case 1:
          digitalWrite(sfx2Pin, LOW);
        case 2:
          digitalWrite(sfx3Pin, LOW);
        case 3:
          digitalWrite(sfx4Pin, LOW);
        case 4:
          digitalWrite(sfx5Pin, LOW);
        case 5:
          digitalWrite(sfx6Pin, LOW);
        case 6:
          digitalWrite(sfx7Pin, LOW);
        case 7:
          digitalWrite(sfx8Pin, LOW);
    void playDmx() {
      dmxPick = random(1, 11);
      switch (dmxPick) {
        case 1: // Red
          data[0] = 255;
          data[1] = 255;
          data[2] = 0;
          data[3] = 0;
          data[4] = 0;
          data[5] = 0;
          data[6] = 0;
        case 2: // Green
          data[0] = 255;
          data[1] = 0;
          data[2] = 255;
          data[3] = 0;
          data[4] = 0;
          data[5] = 0;
          data[6] = 0;
        case 3: // Blue
          data[0] = 255;
          data[1] = 0;
          data[2] = 0;
          data[3] = 255;
          data[4] = 0;
          data[5] = 0;
          data[6] = 0;
        case 4: // White
          data[0] = 255;
          data[1] = 255;
          data[2] = 255;
          data[3] = 255;
          data[4] = 0;
          data[5] = 0;
          data[6] = 0;
        case 5: // Yellow
          data[0] = 255;
          data[1] = 255;
          data[2] = 255;
          data[3] = 0;
          data[4] = 0;
          data[5] = 0;
          data[6] = 0;
        case 6: // Purple
          data[0] = 255;
          data[1] = 255;
          data[2] = 0;
          data[3] = 255;
          data[4] = 0;
          data[5] = 0;
          data[6] = 0;
        case 7: // Cyan
          data[0] = 255;
          data[1] = 0;
          data[2] = 255;
          data[3] = 255;
          data[4] = 0;
          data[5] = 0;
          data[6] = 0;
        case 8: // Spotlight Dancer #1
          data[0] = 255;
          data[1] = 255;
          data[2] = 255;
          data[3] = 255;
          data[4] = 0;
          data[5] = 0;
          data[6] = 0;
          for (x = 1; x <= 16; x = x + 7) {
        case 9: // Spotlight Dancer #2
        case 10: // Red Spot Dancer #2
    int getDanceStep() {
      intervalPick = random(1, 5);
      switch (intervalPick) {
        case 1:
          danceStep = 125;
        case 2:
          danceStep = 250;
        case 3:
          danceStep = 375;
        case 4:
          danceStep = 500;
      return danceStep;
  4. #29
    I revised the code to clean up timing events and remove a dance code bug:
      jparisse@me.com
      Pin Outs:
        Pin 0   RX    Serial In
        Pin 1   TX    Serial Out
        Pin 2   DMX   DOUT
        Pin 3   PIR   DIN
        Pin 4   AUX   DIN
        Pin 5   NEO   DOUT
        Pin 6   AC1   DOUT
        Pin 7   AC2   DOUT
        Pin 8   SFX0  DOUT
        Pin 9   SFX1  DOUT
        Pin 10  SFX2  DOUT
        Pin 11  SFX3  DOUT
        Pin 12  SFX4  DOUT
        Pin 13  LED   DOUT
        Pin 14  SFX5  DOUT
        Pin 15  SFX6  DOUT
        Pin 16  SFX7  DOUT
        Pin 17  SFX8  DOUT
        Pin 18  SDA   I2C
        Pin 19  SCL   I2C
    #define dmxPin 2
    #define pirPin 3
    #define auxPin 4
    #define neoPin 5
    #define ac1Pin 6
    #define ac2Pin 7
    #define sfx0Pin 8
    #define sfx1Pin 9
    #define sfx2Pin 10
    #define sfx3Pin 11
    #define sfx4Pin 12
    #define ledPin 13
    #define sfx5Pin 14
    #define sfx6Pin 15
    #define sfx7Pin 16
    #define sfx8Pin 17
    #define volupPin 22
    #define voldnPin 23
    // DMX Variables
    boolean dmxToggle = HIGH;
    // Servo Variables
    uint8_t servo1 = 0;
    uint8_t servo2 = 1;
    uint8_t servo3 = 2;
    uint8_t servo4 = 3;
    uint8_t servo5 = 4;
    uint8_t servo6 = 5;
    uint8_t servo7 = 6;
    uint8_t servo8 = 7;
    uint8_t servo9 = 8;
    // Servo Timer
    // Show Timer
    // Delay Timer (Blocking)
    int delayMin = 15000;                        // 15,000 ms = 00:00:15 (fifteen seconds)
    int delayMax = 60000;                        // 60,000 ms = 00:01:00 (one minute)
    int randomDelay = 0;                         // Default
    // Show Default Variables
      pwm.begin();
      digitalWrite(ac2Pin, LOW);                // Mirrored Ball & Spotlight OFF (Not Used)
        showState = HIGH;
      else {
      if (delayState == HIGH) {
        delay(randomDelay);
        delayState = LOW;
      if (showState == HIGH) {
            delay(10);
          delay(moonSongInterval);                                                 // Wait for Song
            delay(10);
        if (currentMillis - previousServoMillis >= servoInterval) {      //
          previousServoMillis = currentMillis;
          playServo();
          if (dmxToggle == HIGH); {
          playDmx();
          dmxToggle = !dmxToggle;
          showState = LOW;
          moonState = LOW;
          delayState = HIGH;
            songPick = 1;
          randomDelay = random(delayMin, delayMax);                     // Pick new delay interval.
    // Functions
    void soundOff() {
    void dmxOff() {
      data[0] = 255;
      data[1] = 0;
      data[2] = 0;
      data[3] = 0;
      data[4] = 0;
      data[5] = 0;
      data[6] = 0;
    void playSong() {
      switch (songPick) {
        case 1:
        case 2:
        case 3:
        case 4:
        case 5:
        case 6:
        case 7:
    void playServo() {
      else {
        case 1:
          danceStep = 125;
        case 2:
          danceStep = 250;
        case 3:
          danceStep = 375;
        case 4:
          danceStep = 500;
      return danceStep;
    void playDmx() {
      switch (dmxPick) {
        case 1: // Red
          data[0] = 255;
          data[1] = 255;
          data[2] = 0;
          data[3] = 0;
          data[4] = 0;
          data[5] = 0;
          data[6] = 0;
        case 2: // Green
          data[0] = 255;
          data[1] = 0;
          data[2] = 255;
          data[3] = 0;
          data[4] = 0;
          data[5] = 0;
          data[6] = 0;
        case 3: // Blue
          data[0] = 255;
          data[1] = 0;
          data[2] = 0;
          data[3] = 255;
          data[4] = 0;
          data[5] = 0;
          data[6] = 0;
        case 4: // White
          data[0] = 255;
          data[1] = 255;
          data[2] = 255;
          data[3] = 255;
          data[4] = 0;
          data[5] = 0;
          data[6] = 0;
        case 5: // Yellow
          data[0] = 255;
          data[1] = 255;
          data[2] = 255;
          data[3] = 0;
          data[4] = 0;
          data[5] = 0;
          data[6] = 0;
        case 6: // Purple
          data[0] = 255;
          data[1] = 255;
          data[2] = 0;
          data[3] = 255;
          data[4] = 0;
          data[5] = 0;
          data[6] = 0;
        case 7: // Cyan
          data[0] = 255;
          data[1] = 0;
          data[2] = 255;
          data[3] = 255;
          data[4] = 0;
          data[5] = 0;
          data[6] = 0;
        case 8: // White
          data[0] = 255;
          data[1] = 255;
          data[2] = 255;
          data[3] = 255;
          data[4] = 0;
          data[5] = 0;
          data[6] = 0;
        case 9: // Yellow
          data[0] = 255;
          data[1] = 255;
          data[2] = 255;
          data[3] = 0;
          data[4] = 0;
          data[5] = 0;
          data[6] = 0;
        case 10: // Red
          data[0] = 255;
          data[1] = 255;
          data[2] = 0;
          data[3] = 0;
          data[4] = 0;
          data[5] = 0;
          data[6] = 0;
    2021 Halloween Show - Teensy 3.2
    The song selection, show length and intermission length are randomized so the show is slightly different each time. There is a dance party of 5 year olds that show up every evening. The show is a big hit in the neighborhood. Thanks for everyone’s help.
    Note to Shawn: I wasn’t able to individually address the fixtures. When I used a “for” loop to set less than all four fixtures, I just got black from all. I’d love to discuss if you have time.
    Jeff
    https://youtu.be/F-0MqxYrnBw
  6. #31
    Mar 2017
    Oakland, CA, USA
    344
    It looks like you have an extra semicolon here:
    playDmx();
  7. #32
    Quote Originally Posted by shawn View Post
    playDmx();
    Oh wow! I wonder why the compiler didn’t flag it. The code snippet makes the lights change at half time (of the skeleton tempo) and I can confirm that it works. I’ll change it out immediately however. Thanks for looking it over! The show is a big hit and the lighting changes make it. I will use my controller for every holiday so I intend to learn more about DMX and programming in general…
  8. #33
    Jul 2020
    1,348
    You need a style-checking tool like lint for catching this sort of mistake - there's nothing wrong with the C code as it stands,
    you are allowed to use empty statements and redundant block statements however you want, they are part of the language.
    Why is the bool variable dmxToggle set to HIGH rather than true BTW? Its not a pin state as far as I can tell, just a bool.
    I'd reserve HIGH and LOW names for digital pin input and output where it makes sense.
    Or in short:
      if (dmxToggle)
        playDmx();
  9. #34
    Mark,
    Thanks for the explanation! As to the question, I noticed when referencing Boolean that “true” and “false” are expected but panicked because I was too close to opening night to make the change especially when I read that HIGH and LOW will work as substitutes. Even though the show is on until Halloween, I still wish to improve my code and make changes especially the last two suggested since they will help me conform to generally accepted practices. I want to use this controller every holiday to entertain the neighbors but also as a opportunity to learn more about coding. Thanks for the help, I will rework the Boolean variables to the true/false nomenclature.
    Jeff
