Page 1 of 2 1 2 LastLast
Results 1 to 25 of 28
Thread: Serial Midi Input not working
    Oct 2021
    15
    Hello out there, since three days I try to get serial midi to work but to no avail. So this is my last resort to get it working.
    I suspect I am making a silly mistake somewhere and hope someone will spot the error. So here I go.
    I am using a Teensy 4.0 but want to use a 4.1 with audio board in the end. The 4.0 is just for testing/breadboard use.
    The Programm I use is the Example Input Programm on the pjrc Midi page.
    The circuit I am using is the one build here https://youtu.be/l34CNfwfuIY?t=1030.
    My optocoupler is labelled A6N138. The diode is 1N4148. The resistors top to bottom are: 220, 10k, 470 ohm.
    My board is in usb mode Serial + Midi + Audio.
    My computer is sending Midi notes to the Port via a known working interface/cable.
    When running the program all I get is "MIDI Input Test" and later "(inactivity)"
    I tried with teensy 4.1.
    I tried different serial ports.
    I tried different USB-Modes.
    I read the first to pages worth of google result for "teensy serial midi".
    I tried programs that seem to work for other people.
    I tried downgrading the midi library to 4.3.
    Any help is welcome.
    Cheltenham, UK
    460
    Found this:-
    MIDIbox Newbie
    stevegs
    Members
    0
    Posted August 17, 2014 (edited)
    This thread might be 8 years old - but here goes before anyone comes a cropper with propagation delays...
    The PC900 is a digital opto-coupler - ie. if the input current to the emitting diode increases slowly, the output will snap from one state to the other when a threshold is reached. As the input current decreases, the output will snap back at a lower level - so you won't get jittering at a critical level. This is called 'hysteresis'.
    Long cables (MIDI or otherwise) will slow up a signal, so a digital opto-coupler will square it up to maintain signal integrity. Or so it should...
    The problem with the PC900 is it's quite slow - and even worse it takes longer to react to a decreasing current than to an increasing one (typically 2us for increasing and 5us for decreasing). Result: a skew where an original 50/50 square wave could become 60/40.
    MIDI runs at 31.5kBd, ie. the time for one byte is typically 300us - so with the stop and start bits, each bit is only 30us. A 3us skew is 10% of this, so if you daisychain several MIDI devices together, data arriving at the last risks being corrupted. If the PC900's rise and fall times were the same, there wouldn't be a problem - nobody would notice a delay of milliseconds, let alone microseconds!
    The 6N138 isn't digital at all. It's a simple linear Darlington coupler, ie. the output current is (roughly) proportional to the input current. This is translated to a voltage by your pull-up resistor (R6). So you risk ringing, jitter and all sorts of signal corruption problems!
    You need a fast digital optocoupler, such as the HCPL2200. The rise and fall times are much shorter (typically 160ns and 180ns respectively), so there is negligible skew.
    Although the maximum cable length in the MIDI spec. is 15m, I've successfully sent a signal down a 100m drum of cable as a trial before using MIDI in our theatre as a lighting control signal - the distance involved there is about 40m.
    HTH
    Steve G-S
    Edited August 17, 2014 by stevegs
    Not sure if it helps. I wonder if the 470R is a bit low.
    Oct 2021
    15
    Quote Originally Posted by BriComp View Post
    Found this:-Not sure if it helps. I wonder if the 470R is a bit low.
    Thanks BriComp. Though interesting sadly I don't think it helps much. I changed the 470R to 660R but it does not make a difference.
    Cheltenham, UK
    460
    Others use 1.2k to 4.7k for that resistor.
    Oct 2021
    15
    Got my hopes up. Tried with 3.3k. Nothing. Measured all connections. All seems fine.
    May 2019
    133
    Lower that 220R a bit. And try various alternative to that 470R Or just use a faster optocoupler?
    Senior Member PaulS's Avatar
    Apr 2015
    Netherlands
    696
    From your photo it looks like there is a 10K(?) resistor from pin 5 of the optocoupler to GND?
    Paul
    May 2019
    133
    I just checked an old project of mine. My 6N138 opto worked fine with the default 220R as drive limiter and 470R as the receive side.
    Oct 2021
    15
    Paul
    Hi Paul,
    yes. I did try that. Just before the "Basic Usage" headline on the midi page it is stated that a 10k resistor might be needed there.
    Oct 2021
    15
    Quote Originally Posted by tschrama View Post
    Hi Tschrama, thank you. Maybe my opto is broken.
    I ordered a few new ones and a HCPL2200-300e and the capacitor from the schematics just to be sure. But that's a stretch...
    Apr 2015
    Netherlands
    696
    Quote Originally Posted by Holzdev View Post
    Hi Paul,
    It states: Many work with pin 7 unconnected, but some may require a 10K resistor from pin 7 to ground.
    You have a 10K resistor from pin 5 to GND. The RX line will not be able to appear LOW to the Teensy with a 10K resistor there.
    Paul
    Oct 2021
    15
    Nice catch Paul. Pin 5 is now connected to ground and pin 7 is connected to ground with the 10K resistor. Sadly no change in behaviour
    May 2019
    133
    Yep, good catch Paul.
    Oct 2021
    15
    Changed back the 470 for the 3.3k Resistor. Pin 7 is now wired with 10K to ground. Pin 5 is wired to ground.
    Tested two different input devices. Nothing.
    May 2019
    133
    Can you measure the DC voltages with the input low and also with input high?
    Oct 2021
    15
    I'm not sure. I have a multimeter but am not sure what you want me to do. Im sorry, I'm more of a software guy so measuring hardware is new to me.
    If you walk me through it I should be able to.
    Oct 2021
    15
    I ordered some things to better troubleshoot the problem. Some resistors and capacitors and solder breadboard as well as crocodile clamps for my multimeter. Hopefully I will be able to get things going. Thank you all very much for your input und suggestions. Things should arrive in the next days and I will keep this thread postet.
    May 2019
    133
    One more thing you could try, is connect the midi signals direct, no opto coupler.
    Oct 2021
    15
    I have my multimeter set up to measure up voltage between opto pin 2 and din pin 4. I thought I would see something here while sending midi messages. Or won't I be able to see something with a simple multimeter?
    May 2019
    133
    The signal will be too fast. But if you put 5v DC at the opto coupler input, tell us what you see at the ouput. And if you gnd the input?
    Oct 2021
    15
    So I put 5v from Teensy to pin 8 on the optocoupler. I put my multimeter between pin 6 on the opto and ground on the teensy. My multimeter is set to measure 200v AC. The moment I plug in the usb it reads 0.2. Same with the multimeter between pin 5 (gnd) and teensy ground.
    If I put the multimeter to measure DC between 200mv and 2000mv it reads between -1 and 0.01 which does not make sense for me.
    Oct 2021
    15
    Oh man. Did not know to measure in parallel. Doing it now. Between in and out are 5v dc.
    Oct 2021
    15
    ... And if you gnd the input?
    What did you mean by this?
    Jul 2020
    1,363
    Grounding the input means connecting it to ground (0V normally). Gnd is short for ground
    Oct 2021
    15
    But if I Put 5v on the input and connecting it to ground won't it short?
