Teensy 4_1 freezes opening SD Card
I'm working on a project that uses Teensy Threads and the Built In SD Card, I open the SD on my void setup but at the moment that I try to open it on any thread the teensy freezes, this code used to run on a Teensy 4.0 with an external SD Reader and everything worked
I found this other thread with the same problem, but this guy's conclusion was to stop using teensy threads, the issue is that my project requires the threads.
https://forum.pjrc.com/threads/66905-Teensy-4-1-freeze-after-first-save-to-onboard-SD-card
Could you help me to find any solution to this :(:(:(
  • EventThreadsDevicev2.ino
