I am collecting a data stream from an I2C device on Teensy 4.0, and timestamping this data based on Teensy micros(). We believe that the teensy micros() is drifting by 100 ms per hour. Following is our source code, is there a way to correct for this timestamp without external RTC. I understand Teensy 4.0 has internal RTC, any code sample on how to use it would also be helpful. Thank you
#include <Wire.h> //For I2C/SMBus
#include <stdio.h>
unsigned long counter = 0;
Wire.begin(); // join i2c bus (address optional for master)
Serial.begin(115200); // start serial for output
Serial.flush();
while (!Serial) {
; // wait for serial port to connect. Needed for native USB port only
void readDataFromSensor(short address, short *data, unsigned long *myTime)
*****fetch data*****
*myTime = millis();
short data1; unsigned long myTime1;
byte i2cAddress1 = 0x11;
readDataFromSensor(i2cAddress1, &data1, &myTime1);
Serial.print("{");
Serial.print(i2cAddress1);
Serial.print(",");
Serial.print(myTime1);
Serial.print(",");
Serial.print(data1);
Serial.print(",");
Serial.print(counter);
Serial.println("}");
short data2; unsigned long myTime2;
byte i2cAddress2 = 0x05;
readDataFromSensor(i2cAddress2, &data2, &myTime2);
Serial.print("{");
Serial.print(i2cAddress2);
Serial.print(",");
Serial.print(myTime2);
Serial.print(",");
Serial.print(data2);
Serial.print(",");
counter += 1;
#include <stdio.h>
Serial.flush();
while (!Serial) {
*myTime = millis();
Serial.print("{");
Serial.print(",");
Serial.print(",");
Serial.print(",");
Serial.print("{");
Serial.print(",");
Serial.print(",");
Serial.print(",");
counter += 1;
