Page 1 of 3 1 2 3 LastLast
Results 1 to 25 of 59
Thread: Teensyduino 1.56 Beta #2
    Administrator Paul's Avatar
    Oct 2012
    418
    Here is a second beta test for Teensyduino 1.56.
    Linux 32 bit:
    https://www.pjrc.com/teensy/td_156-b...nstall.linux32
    Linux 64 bit:
    https://www.pjrc.com/teensy/td_156-b...nstall.linux64
    Linux ARM:
    https://www.pjrc.com/teensy/td_156-b...stall.linuxarm
    Linux ARM64:
    https://www.pjrc.com/teensy/td_156-b...l.linuxaarch64
    MacOS 10.10 to 10.15:
    https://www.pjrc.com/teensy/td_156-b...S_Catalina.zip
    MacOS 10.8 to 10.14:
    https://www.pjrc.com/teensy/td_156-b...inoInstall.dmg
    Windows:
    https://www.pjrc.com/teensy/td_156-b...inoInstall.exe
    Changes since Teensyduino 1.56-beta1:
    Add FS format() and mediaPresent()
    Add String compatibility to FS,SD,LittleFS,etc
    Add LittleFS format() (mjs513)
    Add SD format() and mediaPresent()
    Update SdFat to version 2.1.0 and enable UTF8 filenames
    Edit SdFat examples to compile on Teensy 3 & 4
    Audio fix PT8211 when no audio data input (Frank B)
    Audio i2s2 slave mode (alex6679)
    Update FastCRC (Frank B)
    USBHost_t36 HID support 1000 Hz update (Kurt E)
    USBHost_t36 Keyboard forward API and example (Kurt E)
    Reduce wasted memory during linking (Frank B)
    Fix MTP detection on Linux
    Fix serial monitor on Linux with MTP
    Fix rare serial monitor stall on Windows
    Fix rare Null Pointer Exception when closing serial monitor
    New York
    7,684
    Installed over beta1 with no issues - no blue screens no warnings etc. Ran the mtp-test sketch - compiled and ran (see other thread for issues). But there were no conflicts or errors which is good. Ok back to playing
    9,752
    I installed and it runs !
    Although probably still using mostly my private versions of libraries.
    Currently pulling out hair on getting format to exit nicely if the format is going to take a minute or so...
    Still working on it. more later
    Mar 2017
    Oakland, CA, USA
    350
    Is it desired to put pull request reminders here, or is that not appropriate in these beta threads? I did for 1.54 and a PR got in, but not for 1.55.
    15,271
    Installed and it runs ! Win 11 over old on IDE 1.8.16.
    Playing with alternate Serial sketch finally. @Paul seemed you wanted a HEX counter? Here is 9 digits of HEX:
    Waiting...Start.
    FFFFFFFF1<<<>>>___[[[]]]---{{{}}}___!
    FFFFFFFF2<<<>>>___[[[]]]---{{{}}}___!
    FFFFFFFF3<<<>>>___[[[]]]---{{{}}}___!
    FFFFFFFF4<<<>>>___[[[]]]---{{{}}}___!
    FFFFFFFF5<<<>>>___[[[]]]---{{{}}}___!
    FFFFFFFF6<<<>>>___[[[]]]---{{{}}}___!
    FFFFFFFF7<<<>>>___[[[]]]---{{{}}}___!
    FFFFFFFF8<<<>>>___[[[]]]---{{{}}}___!
    FFFFFFFF9<<<>>>___[[[]]]---{{{}}}___!
    FFFFFFFFA<<<>>>___[[[]]]---{{{}}}___!
    FFFFFFFFB<<<>>>___[[[]]]---{{{}}}___!
    FFFFFFFFC<<<>>>___[[[]]]---{{{}}}___!
    FFFFFFFFD<<<>>>___[[[]]]---{{{}}}___!
    FFFFFFFFE<<<>>>___[[[]]]---{{{}}}___!
    FFFFFFFFF<<<>>>___[[[]]]---{{{}}}___!
           00<<<>>>___[[[]]]---{{{}}}___!
           01<<<>>>___[[[]]]---{{{}}}___!
           02<<<>>>___[[[]]]---{{{}}}___!
           03<<<>>>___[[[]]]---{{{}}}___!
    That is finally printing FASTER than prior code - instead of 145 Mbps with delay( 1500 us ) showing over 220 Mbps with that same delay. Actually I unrolled 16 prints (getting the 9th hex-digit) - so delayNanoseconds( 24000 ); takes it back down to the same plus a couple Mbps.
    I think Windows USB driver is too fast - not slower than others, just fills buffers and gets bored - Just seems to not give the thread good perf to munge the data?
      260D34F<<<>>>___[[[]]]---{{{}}}___!
    3800000 Bytes in 59130 us = 514.12 Mbps // First reported value before buffers got big.
      260D350<<<>>>___[[[]]]---{{{}}}___!
    Seeing some errors in T_sermon - each of these one line - the middle of three - and the counted line after:
       3BE0BB<<<>>>___[[[]]]---{{{}}}___!
       3BE0BC<<<>>>___[[[]]]---{{{{{}}}___!
       3BE0D8<<<>>>___[[[]]]---{{{}}}___!
       3BE378<<<>>>___[[[]]]---{{{}}}___!
       3BE379<<<>>>_>___[[[]]]---{{{}}}___!
       3BE395<<<>>>___[[[]]]---{{{}}}___!
       3BE635<<<>>>___[[[]]]---{{{}}}___!
         3BE651<<<>>>___[[[]]]---{{{}}}___!
       3BE652<<<>>>___[[[]]]---{{{}}}___!
       3BE8F1<<<>>>___[[[]]]---{{{}}}___!
       3BE8F2<<<>>>___[[[]]]-----{{{}}}___!
       3BE90E<<<>>>___[[[]]]---{{{}}}___!
       3BEBAE<<<>>>___[[[]]]---{{{}}}___!
       3BEBAF<<<<<>>>___[[[]]]---{{{}}}___!
       3BEBCB<<<>>>___[[[]]]---{{{}}}___!
       3BF127<<<>>>___[[[]]]---{{{}}}___!
       3BF128<<<>>>___[[[][]]]---{{{}}}___!
       3BF144<<<>>>___[[[]]]---{{{}}}___!
       3BF66A<<<>>>___[[[]]]---{{{}}}___!
       3BF66B<<<>>>___[[[]]]---{{{}}}___>___[[[]]]---{{{}}}___!
       3BF695<<<>>>___[[[]]]---{{{}}}___!
    Just updated github for SerialTest2.ino and .c: defragster/cdcbench
    SerialTest2.exe COM38 SZ38
    or
    SerialTest2.exe COM38 SZ38 Q
    2 hours into my next trip around the sun - time to sleep.
    25,224
    Maybe we should continue discussion of the sustained fast serial data issues with Windows on the 1.56-beta1 thread, since that's where all the other messages about that issue are located, and 1.56-beta2 didn't really change anything about usb_serial.c.
    25,224
    Quote Originally Posted by shawn View Post
    Sure, not a problem.
    1,768
    I installed b2 over b1 and have run into a problem. The example/SD/SdFat_Usage does not compile (but it does compile with 1.55).
    In file included from C:\arduino-1.8.16_1.56_b2\hardware\teensy\avr\libraries\SdFat\src\ExFatLib\upcase.cpp:25:0:
    C:\arduino-1.8.16_1.56_b2\hardware\teensy\avr\libraries\SdFat\src\ExFatLib\upcase.h:31:25: error: 'ExChar16_t' does not name a type
                       const ExChar16_t* name, size_t offset, size_t n);
    C:\arduino-1.8.16_1.56_b2\hardware\teensy\avr\libraries\SdFat\src\ExFatLib\upcase.h:33:30: error: 'ExChar16_t' does not name a type
     uint16_t exFatHashName(const ExChar16_t* name, size_t n, uint16_t hash);
    C:\arduino-1.8.16_1.56_b2\hardware\teensy\avr\libraries\SdFat\src\ExFatLib\upcase.cpp:207:25: error: 'ExChar16_t' does not name a type
                       const ExChar16_t* name, size_t offset, size_t n) {
    C:\arduino-1.8.16_1.56_b2\hardware\teensy\avr\libraries\SdFat\src\ExFatLib\upcase.cpp:230:30: error: 'ExChar16_t' does not name a type
     uint16_t exFatHashName(const ExChar16_t* name, size_t n, uint16_t hash) {
     Used: C:\arduino-1.8.16_1.56_b2\hardware\teensy\avr\libraries\SD
     Not used: C:\arduino-1.8.16_1.56_b2\libraries\SD
    Using library SD at version 2.0.0 in folder: C:\arduino-1.8.16_1.56_b2\hardware\teensy\avr\libraries\SD
    Using library SdFat at version 2.1.0 in folder: C:\arduino-1.8.16_1.56_b2\hardware\teensy\avr\libraries\SdFat
    Using library SPI at version 1.0 in folder: C:\arduino-1.8.16_1.56_b2\hardware\teensy\avr\libraries\SPI
    Error compiling for board Teensy 3.6.
    I see a couple of mentions of ExChar16_t in other threads but nothing which would solve this.
    Pete
    Oct 2021
    18
    I hope this is the right place to post -- there are more details in https://forum.pjrc.com/threads/68382...-dropping-data but I was asked there to post the data here. Basically, I have simple Teensy 4.0 code to write lots of data back to the host and if it writes more than ~1 MB, the transfer starts to slow down. Often this is also associated with data loss, but under Linux and with the attached firmware, there is no data loss or corruption, but the transfer speed is about 32 MBPS for a 0.8MB transfer or less, but a 6.4MB is 4.3 MBPS and a 25.6MB file crawls to 0.3 MBPS.
    Using the 1.56beta2 and the attached firmware, I used wireshark to capture all the USB packets. I've attached wireshark captures of a short fast transfer (0.8MB, 32 MBPS) and a long slow transfer (6.4MB, 4.3 MBPS). I'm hoping the USB packets might shed light on why the transfer is slowing down (and maybe this will also shed some light to data corruption that happens around the same file sizes in some circumstances). Since the data slow down happens on Linux and Windows, python and (anecdotally) C#, it seems likely that the Teensy is the source of the problem somehow.
    Here is the python code I use to receive data. Aside from also having dropped data, this happens on Windows as well.
    import serial, struct,time
    import numpy as np
    wordsToGet = 400000
    wordSize = 2
    ser = serial.Serial('/dev/ttyACM0',115200,timeout=2)
    expectedData = np.array(range(wordsToGet))
    expectedData = expectedData.astype(np.uint16)
    ser.write('{}\n'.format(wordsToGet).encode())
    data=b''
    received = 0
    start = time.time()
    while( wordsToGet != received):
        packetSize = min(1024,wordsToGet-received)
        packet = ser.read(packetSize*wordSize)
        if (len(packet) != packetSize*wordSize):
            print('Error, got only {} bytes, but expecting {}, received {} of {} bytes total'.format(len(packet),packetSize*wordSize,received,wordsToGet))
            break
        data += packet
        received += packetSize
    stop = time.time()
    data = np.array(struct.unpack('H'*int(len(data)/wordSize),data))
    diffSquared = (data-expectedData[0:len(data)])*(data-expectedData[0:len(data)])
    print('Length of data received: {}/{}'.format(len(data),len(expectedData)))
    if (np.sum(diffSquared) != 0):
        errorIndices = (data-expectedData[0:len(data)] != 0).nonzero()[0]
        print('Error, data returned not as expected. {} data points of {} are incorrect ({:01f}%)'.format(len(errorIndices),len(expectedData),100*len(errorIndices)/len(expectedData)))
        print(errorIndices)
        print('{} words received, {} MBytes in {:0.2f} seconds ({:0.2f}MBPS)'.format(len(data),len(data)*wordSize/1e6,stop-start,len(data)*wordSize/(stop-start)/1e6))
    else:
        print('{} words successfully received, {} MBytes in {:0.2f} seconds ({:0.2f}MBPS)'.format(wordsToGet,wordsToGet*wordSize/1e6,stop-start,wordsToGet*wordSize/(stop-start)/1e6))
    del ser
    Attached Files Attached Files
    Apr 2020
    DFW area in Texas
    305
    Pete
    I just loaded TD1.56b2 over 1.55 & I'm seeing the same "ExChar16_t" error reported (& failure to compile/link) for a sketch that previously built & ran correctly under 1.55:
    In file included from C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\SdFat\src\ExFatLib\upcase.cpp:25:0:
    C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\SdFat\src\ExFatLib\upcase.h:31:25: error: 'ExChar16_t' does not name a type
    C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\SdFat\src\ExFatLib\upcase.h:33:30: error: 'ExChar16_t' does not name a type
    C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\SdFat\src\ExFatLib\upcase.cpp:207:25: error: 'ExChar16_t' does not name a type
    C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\SdFat\src\ExFatLib\upcase.cpp:230:30: error: 'ExChar16_t' does not name a type
     Used: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\SD
     Not used: C:\Program Files (x86)\Arduino\libraries\SD
    Error compiling for board Teensy 4.1.
    Mark J Culross
    KD5RXT
    Apr 2020
    DFW area in Texas
    305
    Quote Originally Posted by kd5rxt-mark View Post
    Mark J Culross
    KD5RXT
    Tried going back to TD1.56b1 (not sure if this is valid, but it's what I did !!) & get a different error report, but still fails to build:
    C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\SdFat\src\ExFatLib\ExFatName.cpp:48:66: error: no 'bool ExFatFile::cmpName(const DirName_t*, ExName_t*)' member function declared in class 'ExFatFile'
     bool ExFatFile::cmpName(const DirName_t* dirName, ExName_t* fname) {
    C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\SdFat\src\ExFatLib\ExFatName.cpp:69:52: error: no 'size_t ExFatFile::getName7(char*, size_t)' member function declared in class 'ExFatFile'
     size_t ExFatFile::getName7(char* name, size_t count) {
    C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\SdFat\src\ExFatLib\ExFatName.cpp:100:52: error: no 'size_t ExFatFile::getName8(char*, size_t)' member function declared in class 'ExFatFile'
     size_t ExFatFile::getName8(char* name, size_t count) {
    C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\SdFat\src\ExFatLib\ExFatName.cpp:157:41: error: no 'bool ExFatFile::hashName(ExName_t*)' member function declared in class 'ExFatFile'
     bool ExFatFile::hashName(ExName_t* fname) {
    Error downloading http://files.tinycircuits.com/ArduinoBoards/package_tinycircuits_index.json
    UPDATE: Re-installing Arduino+TD1.56b1 allows successful build. (Re)confirmed that going backwards in versions is not really recommended/supported, but it was quick & easy to try.
    Mark J Culross
    KD5RXT
    Last edited by kd5rxt-mark; 10-10-2021 at 11:48 PM. Reason: Updated (re-install vs. overwrite with earlier version)
    Mar 2017
    Oakland, CA, USA
    350
    I went through a few of my outstanding issues and made a few PRs (including an updated one that doesn't have an attached issue):
    Upcoming is another attempt at adding state to IntervalTimer's callback functions. The Arduino style of having callbacks with no state hinders passing information to the callbacks without some hoops and breaks compatibility with other libraries that use the API. I'd love to see this get into the core. (coming soon™)
    Germany
    9,428
    Let me extend that for *all* 60 PRs and ~50 issues and all the PRs and Issues in other libraries (i.e. 60/30 for Audio, etc..).
    The users have all invested their time.
    New York
    7,684
    Pete
    1.56beta's pretty much all deal with making improvements and changes to File System support which has involved changes to FS.h, SDFat, and SD primarily (see https://forum.pjrc.com/threads/68139...ng-MTP-and-MSC). I ran the SD_Usage example an it is compiling fine with the latest changes that will probably be rolled into beta3 (don't ask me when). Right now would probably stick with beta1 or update to the lasted libraries for SD and SDFat. Don;t think we made any changes to FS.h since beta1.
    Hope this helps explain whats going on.
    Mike
    Germany
    9,428
    There were two files in the wrong directory
    1,768
    Thanks to all for info about the ExChar16_t problem in SD. I installed a fresh Arduino 1.8.16 and put TD 1.56.b2 on top and the example now compiles, as do a couple of my sketches which failed.
    Pete
    15,271
    Posted on T_MMod was this:
    Using this in a Windows CMD.exe - DOS box : "{local install}\hardware\tools\teensy_ports.exe"
    Starts teensy_ports.exe that will display info on the connect state and type of connected Teensy.
      "address": "usb:0/140000/0/6/1/3",
      "online": true,
      "label": "COM36 (Teensy 4.1) Serial",
      "vid": "16C0",
      "pid": "0483",
      "iserial": "970638",
      "boardName": "Teensy 4.1",
      "protocol": "Teensy"
      "address": "usb:0/140000/0/6/1/4",
      "online": true,
      "label": "COM11 (Teensy 4.1) Serial",
      "vid": "16C0",
      "pid": "0483",
      "iserial": "100038",
    At this point IDE is closed and Teensy Loader is not running.
    Is this expected?
    With that running showing two running T_4.1's and pushing both Buttons results in this - the LOCKED T_4.1 { "iserial": "970638",} does not go to Bootloader or light the RED LED? It just goes to: "online": false
      "online": true,
      "label": "[no_device] (Teensy 4.1) Bootloader",
      "vid": "16C0",
      "pid": "0478",
      "online": true,
      "label": "hid#vid_16c0&pid_0478 (Teensy 4.1) Bootloader",
      "vid": "16C0",
      "pid": "0478",
      "online": false
    <edit>: It works and programs correctly when T_Loader is running: "12:26:39.972 (loader): using encrypted ehex (required - secure mode is locked)"
    > the second T_4.1 beta lockable - is not yet locked the RED LED does appear with Button : (optional - secure mode not yet locked)
    BTW: After days of running the SerialTest code on multiple Teensy's 'something' caused my Win 11 USB to IGNORE ALL Teensy events and I/O ( didn't try other USB devices before restart ).
    Oct 2021
    18
    Please ignore my previous post (https://forum.pjrc.com/threads/68386...l=1#post290757) about throughput slowing down for large transfers. The speed issues were artifacts of my python code. See https://forum.pjrc.com/threads/68382...ing-data/page2 for more details. Sorry for the noise / distraction.
    15,271
    @Paul - not sure if this VERBOSE log shows you anything - at the end.
    <edit>: As before it works fine on restart. Both times USB was lost on IDE Upload of sketch. The first time the wonder was if I uploaded faulty code ... that wasn't it. Uploaded same code this time after restart and it ran fine.
    Windows 11 seems to have LOST USB system again (second time). Only been up 15 hours and I think the SerialTest fast output Teensy were mostly off - only one connected at most? First time it had been up for days with 3 T_4.1's running that code???
    Programmed T_4.1 "using encrypted ehex (required - secure mode is locked)" and it never returned?
    Swapped another T_4.1 and pressed Button and it went to a RED LED one sec On/Off blink - so it seems I need to reboot to restore USB?
    23:18:38.203 (ports 5): WM_DEVICECHANGE DBT_DEVNODES_CHANGED
    23:18:38.205 (ports 5): nothing new, skipping HID & Ports enum
    23:18:40.544 (ports 5): WM_DEVICECHANGE DBT_DEVNODES_CHANGED
    23:18:40.545 (ports 5): nothing new, skipping HID & Ports enum
    23:18:41.313 (ports 5): WM_DEVICECHANGE DBT_DEVNODES_CHANGED
    23:18:41.314 (ports 5): nothing new, skipping HID & Ports enum
    23:19:43.893 (post_compile 1): Begin, version=1.56-beta2, high-res time
    23:19:44.930 (loader): Teensy Loader 1.56-beta2, begin program
    23:19:45.027 (loader): Listening for remote control on port 3149
    23:19:45.027 (loader): initialized, showing main window
    23:19:45.170 (loader): remote connection 1236 opened
    23:19:45.170 (loader): remote cmd from 1236: "comment: Teensyduino 1.56-beta2 - WINDOWS (teensy_post_compile)"
    23:19:45.170 (loader): remote cmd from 1236: "status"
    23:19:45.172 (post_compile 1): Sending command: comment: Teensyduino 1.56-beta2 - WINDOWS (teensy_post_compile)
    23:19:45.178 (loader): HID/win32:  vid:046D pid:C52B ver:1211  usb:0/140000/0/9/4/2/4
    23:19:45.179 (loader): HID/win32:  vid:046D pid:C52B ver:1211  usb:0/140000/0/9/4/2/4
    23:19:45.180 (loader): HID/win32:  vid:046D pid:C52B ver:1211  usb:0/140000/0/9/4/2/4
    23:19:45.181 (loader): HID/win32:  vid:046D pid:C52B ver:1211  usb:0/140000/0/9/4/2/3
    23:19:45.181 (loader): HID/win32:  vid:046D pid:C52B ver:1211  usb:0/140000/0/9/4/2/4
    23:19:45.182 (loader): HID/win32:  vid:046D pid:C52B ver:1211  usb:0/140000/0/9/4/2/3
    23:19:45.183 (loader): HID/win32:  vid:046D pid:C52B ver:1211  usb:0/140000/0/9/4/2/3
    23:19:45.183 (loader): HID/win32:  vid:046D pid:C52B ver:1211  usb:0/140000/0/9/4/2/4
    23:19:45.188 (post_compile 1): Status: 0, 0, 0, 0, 0, 0, R:\TEMP\arduino_build_680952\, SerialTestT.ino.ehex
    23:19:45.188 (post_compile 1): Sending command: dir:R:\Temp\arduino_build_8523\
    23:19:45.188 (loader): remote cmd from 1236: "dir:R:\Temp\arduino_build_8523\"
    23:19:45.188 (loader): remote cmd from 1236: "file:SerialTest2.ino.hex"
    23:19:45.188 (post_compile 1): Sending command: file:SerialTest2.ino.hex
    23:19:45.191 (loader): File "R:\Temp\arduino_build_8523\SerialTest2.ino.hex", 45056 bytes
    23:19:45.191 (loader): File "R:\Temp\arduino_build_8523\SerialTest2.ino.ehex", 45056 bytes, and 4992 loader utility
    23:19:45.191 (loader): ehex is valid, key hash: 85A79CC1 B7C7F866 7F5BB3ED 0F9C9BA5 B4149EE2 72846D35 86B63863 B0699942
    23:19:45.191 (loader): File "SerialTest2.ino.hex". 45056 bytes
    23:19:45.272 (loader): remote cmd from 1236: "status"
    23:19:45.272 (loader): remote cmd from 1236: "auto:on"
    23:19:45.281 (post_compile 1): Status: 1, 0, 0, 0, 0, 0, R:\Temp\arduino_build_8523\, SerialTest2.ino.hex
    23:19:45.281 (post_compile 1): Sending command: auto:on
    23:19:45.281 (post_compile 1): Disconnect
    23:19:45.336 (loader): remote connection 1236 closed
    23:19:45.729 (loader): remote connection 1400 opened
    23:19:45.729 (loader): remote cmd from 1400: "comment: Teensyduino 1.56-beta2 - WINDOWS (teensy_post_compile)"
    23:19:45.729 (loader): remote cmd from 1400: "status"
    23:19:45.729 (loader): remote cmd from 1400: "dir:R:\Temp\arduino_build_8523\"
    23:19:45.729 (loader): remote cmd from 1400: "file:SerialTest2.ino.hex"
    23:19:45.734 (post_compile 2): Begin, version=1.56-beta2, high-res time
    23:19:45.740 (post_compile 2): Sending command: comment: Teensyduino 1.56-beta2 - WINDOWS (teensy_post_compile)
    23:19:45.743 (post_compile 2): Status: 1, 1, 0, 0, 0, 0, R:\Temp\arduino_build_8523\, SerialTest2.ino.hex
    23:19:45.743 (post_compile 2): Sending command: dir:R:\Temp\arduino_build_8523\
    23:19:45.744 (post_compile 2): Sending command: file:SerialTest2.ino.hex
    23:19:45.745 (loader): File "R:\Temp\arduino_build_8523\SerialTest2.ino.hex", 45056 bytes
    23:19:45.745 (loader): File "R:\Temp\arduino_build_8523\SerialTest2.ino.ehex", 45056 bytes, and 4992 loader utility
    23:19:45.745 (loader): ehex is valid, key hash: 85A79CC1 B7C7F866 7F5BB3ED 0F9C9BA5 B4149EE2 72846D35 86B63863 B0699942
    23:19:45.745 (loader): File "SerialTest2.ino.hex". 45056 bytes
    23:19:45.745 (loader): remote cmd from 1400: "status"
    23:19:45.763 (post_compile 2): Status: 1, 1, 0, 0, 0, 0, R:\Temp\arduino_build_8523\, SerialTest2.ino.hex
    23:19:45.763 (post_compile 2): Disconnect
    23:19:45.776 (loader): remote connection 1400 closed
    23:19:45.776 (loader): remote connection 1364 opened
    23:19:45.776 (post_compile 3): Running teensy_reboot: "C:\T_Drive\Arduino_1.8.16_155\hardware\teensy\..\tools\teensy_reboot.exe" teensy_reboot.exe "-board=TEENSY41" "-port=usb:0/140000/0/6/1/3" "-portlabel=COM7 Dual Serial" "-portprotocol=Teensy"
    23:19:45.819 (reboot 4): Begin, version=1.56-beta2, high-res time
    23:19:45.819 (reboot 4): location = usb:0/140000/0/6/1/3
    23:19:45.819 (reboot 4): portlabel = COM7 Dual Serial
    23:19:45.819 (reboot 4): portprotocol = Teensy
    23:19:45.819 (reboot 4): Only location usb:0/140000/0/6/1/3 will be tried
    23:19:45.819 (reboot 4): LoadLibrary cfgmgr32 ok
    23:19:45.819 (reboot 4): LoadLibrary ntdll ok
    23:19:45.821 (reboot 4): found_usb_device, id=\\?\usb#vid_16c0&pid_048b#9706380#{a5dcbf10-6530-11d2-901f-00c04fb951ed}
    23:19:45.821 (reboot 4): found_usb_device, hwid=USB\VID_16C0&PID_048B&REV_0280
    23:19:45.821 (reboot 4): found_usb_device, loc=usb:0/140000/0/6/1/3    Port_#0003.Hub_#0011
    23:19:45.821 (reboot 4): found_usb_device, devinst=00000005
    23:19:45.821 (reboot 4): add: loc=usb:0/140000/0/6/1/3, class=USB, vid=16C0, pid=048B, ver=0280, serial=9706380, dev=\\?\usb#vid_16c0&pid_048b#9706380#{a5dcbf10-6530-11d2-901f-00c04fb951ed}
    23:19:45.821 (reboot 4):   comport_from_devinst_list attempt
    23:19:45.821 (reboot 4):   found Ports in classguid_list at index=1
    23:19:45.821 (reboot 4):   port COM7 found from devnode
    23:19:45.821 (reboot 4): found_usb_device complete
    23:19:45.824 (loader): remote connection 1400 opened
    23:19:45.824 (loader): remote cmd from 1400: "show:arduino_attempt_reboot"
    23:19:45.824 (loader): got request to show arduino rebooting message
    23:19:45.824 (loader): remote cmd from 1400: "comment: Teensyduino 1.56-beta2 - WINDOWS (teensy_reboot)"
    23:19:45.824 (loader): remote cmd from 1400: "status"
    23:19:45.828 (reboot 4): found Teensy Loader, version 1.56
    23:19:45.828 (reboot 4): Sending command: show:arduino_attempt_reboot
    23:19:45.830 (reboot 4): Sending command: comment: Teensyduino 1.56-beta2 - WINDOWS (teensy_reboot)
    23:19:45.832 (reboot 4): Status: 1, 1, 0, 0, 0, 0, R:\Temp\arduino_build_8523\, SerialTest2.ino.hex
    23:19:45.832 (reboot 4): do_reset (serial) COM7
    23:19:45.838 (reboot 4): Status: 1, 1, 0, 0, 0, 0, R:\Temp\arduino_build_8523\, SerialTest2.ino.hex
    23:19:45.838 (reboot 4): status read, retry 0
    23:19:45.855 (loader): remote connection 1368 opened
    23:19:45.856 (ports 5): WM_DEVICECHANGE DBT_DEVICEREMOVECOMPLETE
    23:19:45.862 (ports 5): remove: loc=usb:0/140000/0/6/1/3
    23:19:45.862 (ports 5): usb_remove: usb:0/140000/0/6/1/3
    23:19:45.862 (ports 5): nothing new, skipping HID & Ports enum
    23:19:45.872 (ports 5): WM_DEVICECHANGE DBT_DEVNODES_CHANGED
    23:19:45.872 (ports 5): WM_DEVICECHANGE DBT_DEVICEREMOVECOMPLETE
    23:19:45.873 (ports 5): nothing new, skipping HID & Ports enum
    23:19:45.950 (loader): remote cmd from 1400: "status"
    23:19:45.955 (reboot 4): Status: 1, 1, 0, 0, 0, 0, R:\Temp\arduino_build_8523\, SerialTest2.ino.hex
    23:19:45.955 (reboot 4): status read, retry 1
    23:19:46.031 (ports 5): WM_DEVICECHANGE DBT_DEVICEARRIVAL
    23:19:46.032 (ports 5): nothing new, skipping HID & Ports enum
    23:19:46.061 (loader): remote cmd from 1400: "status"
    23:19:46.061 (loader): handle 5b4
    23:19:46.061 (loader): Device came online, code_size = 100
    23:19:46.061 (loader): Board is: NXP IMXRT1062 ROM
    23:19:46.061 (loader): begin operation
    23:19:46.061 (loader): File "R:\Temp\arduino_build_8523\SerialTest2.ino.hex", 45056 bytes
    23:19:46.076 (loader): File "R:\Temp\arduino_build_8523\SerialTest2.ino.ehex", 45056 bytes, and 4992 loader utility
    23:19:46.076 (loader): ehex is valid, key hash: 85A79CC1 B7C7F866 7F5BB3ED 0F9C9BA5 B4149EE2 72846D35 86B63863 B0699942
    23:19:46.076 (loader): File "SerialTest2.ino.hex". 45056 bytes
    23:19:46.076 (loader): set background IMG_ONLINE
    23:19:46.076 (loader): nxp_write: success
    23:19:46.076 (loader): HAB locked secure mode
    23:19:46.076 (loader): sending ehex loader utility, 4992 bytes
    23:19:46.076 (loader): run it..
    23:19:46.079 (reboot 4): Status: 1, 1, 1, 1, 0, 8, R:\Temp\arduino_build_8523\, SerialTest2.ino.hex
    23:19:46.092 (loader): ehex loader utility sucessfully started
    23:19:46.092 (loader): end operation, total time = 0.031 seconds
    23:19:46.108 (loader): redraw timer set, image 80 to show for 2000 ms
    23:19:46.108 (ports 5): WM_DEVICECHANGE DBT_DEVICEREMOVECOMPLETE
    23:19:46.109 (ports 5): nothing new, skipping HID & Ports enum
    23:19:46.141 (loader): remote cmd from 1400: "status"
    23:19:46.141 (loader): HID/win32:  vid:046D pid:C52B ver:1211  usb:0/140000/0/9/4/2/4
    23:19:46.141 (loader): HID/win32:  vid:046D pid:C52B ver:1211  usb:0/140000/0/9/4/2/3
    23:19:46.144 (reboot 4): Status: 1, 1, 0, 1, 0, 0, R:\Temp\arduino_build_8523\, SerialTest2.ino.hex
    23:19:46.144 (reboot 4): status read, retry 2
    23:19:46.144 (reboot 4): Success
    23:19:46.144 (reboot 4): Disconnect
    23:19:46.157 (loader): remote connection 1400 closed
    23:19:46.157 (loader): remote connection 1364 closed
    23:19:46.398 (ports 5): WM_DEVICECHANGE DBT_DEVNODES_CHANGED
    23:19:46.399 (ports 5): nothing new, skipping HID & Ports enum
    23:19:46.509 (ports 5): WM_DEVICECHANGE DBT_DEVICEARRIVAL
    23:19:46.510 (ports 5): found_usb_device, id=\\?\usb#vid_16c0&pid_0478#000ecf8e#{a5dcbf10-6530-11d2-901f-00c04fb951ed}
    23:19:46.510 (ports 5): found_usb_device, hwid=USB\VID_16C0&PID_0478&REV_0107
    23:19:46.510 (ports 5): found_usb_device, loc=usb:0/140000/0/6/1/3    Port_#0003.Hub_#0011
    23:19:46.510 (ports 5): found_usb_device, devinst=0000001b
    23:19:46.510 (ports 5): add: loc=usb:0/140000/0/6/1/3, class=HID, vid=16C0, pid=0478, ver=0107, serial=000ecf8e, dev=\\?\usb#vid_16c0&pid_0478#000ecf8e#{a5dcbf10-6530-11d2-901f-00c04fb951ed}
    23:19:46.510 (ports 5): hiddev_from_devinst_list: iface=0
    23:19:46.511 (ports 5): found_usb_device complete
    23:19:46.512 (ports 5): usb_add: usb:0/140000/0/6/1/3  [no_device] (Teensy 4.1) Bootloader
    23:19:46.539 (loader): encryption is required, public key hash: 85A79CC1 B7C7F866 7F5BB3ED 0F9C9BA5 B4149EE2 72846D35 86B63863 B0699942
    23:19:46.539 (loader): Device came online, code_size = 8126464
    23:19:46.539 (loader): Board is: Teensy 4.1 (IMXRT1062), version 1.07
    23:19:46.550 (loader): File "R:\Temp\arduino_build_8523\SerialTest2.ino.hex", 45056 bytes
    23:19:46.555 (loader): File "R:\Temp\arduino_build_8523\SerialTest2.ino.ehex", 45056 bytes, and 4992 loader utility
    23:19:46.555 (loader): ehex is valid, key hash: 85A79CC1 B7C7F866 7F5BB3ED 0F9C9BA5 B4149EE2 72846D35 86B63863 B0699942
    23:19:46.555 (loader): File "SerialTest2.ino.hex". 45056 bytes, 1% used
    23:19:46.555 (loader): File "SerialTest2.ino.hex" opened, but "SerialTest2.ino.ehex" will actually be used
    23:19:46.575 (loader): set background IMG_ONLINE
    23:19:46.585 (loader): File "R:\Temp\arduino_build_8523\SerialTest2.ino.hex", 45056 bytes
    23:19:46.591 (loader): File "R:\Temp\arduino_build_8523\SerialTest2.ino.ehex", 45056 bytes, and 4992 loader utility
    23:19:46.591 (loader): ehex is valid, key hash: 85A79CC1 B7C7F866 7F5BB3ED 0F9C9BA5 B4149EE2 72846D35 86B63863 B0699942
    23:19:46.591 (loader): File "SerialTest2.ino.hex". 45056 bytes, 1% used
    23:19:46.591 (loader): File "SerialTest2.ino.hex" opened, but "SerialTest2.ino.ehex" will actually be used
    23:19:46.614 (loader): elf appears to be for Teensy 4.1 (IMXRT1062) (8126464 bytes)
    23:19:46.614 (loader): elf binary data matches hex file
    23:19:46.614 (loader): elf file is for Teensy 4.1 (IMXRT1062)
    23:19:46.614 (loader): using encrypted ehex (required - secure mode is locked)
    23:19:46.638 (loader): begin operation
    23:19:46.677 (ports 5): WM_DEVICECHANGE DBT_DEVNODES_CHANGED
    23:19:46.678 (ports 5): update_usb_device, devinst list change, old had 1, new has 2
    23:19:46.678 (ports 5): hiddev_from_devinst_list: iface=0
    23:19:46.678 (loader): flash, block=0, bs=1024, auto=1
    23:19:46.679 (ports 5): hid, found devinst=0000001C
    23:19:46.679 (ports 5): hid, path=\\?\hid#vid_16c0&pid_0478#8&3742ec8f&0&0000#{4d1e55b2-f16f-11cf-88cb-001111000030}
    23:19:46.679 (ports 5): hid,  opened handle
    23:19:46.679 (ports 5):  devinst=0000001C, location=usb:0/140000/0/6/1/3
    23:19:46.679 (ports 5):  vid=16C0, pid=0478, ver=0107, usepage=FF9C, use=0025
    23:19:46.679 (ports 5):  devpath=\\?\hid#vid_16c0&pid_0478#8&3742ec8f&0&0000#{4d1e55b2-f16f-11cf-88cb-001111000030}
    23:19:46.679 (loader): flash, block=1, bs=1024, auto=1
    23:19:46.679 (ports 5): usb_add: usb:0/140000/0/6/1/3  hid#vid_16c0&pid_0478 (Teensy 4.1) Bootloader
    23:19:46.680 (loader): flash, block=2, bs=1024, auto=1
    23:19:46.978 (loader): flash, block=3, bs=1024, auto=1
    23:19:46.978 (loader): flash, block=4, bs=1024, auto=1
    23:19:47.011 (loader): flash, block=5, bs=1024, auto=1
    23:19:47.013 (loader): flash, block=6, bs=1024, auto=1
    23:19:47.014 (loader): flash, block=7, bs=1024, auto=1
    23:19:47.043 (loader): flash, block=8, bs=1024, auto=1
    23:19:47.043 (loader): flash, block=9, bs=1024, auto=1
    23:19:47.043 (loader): flash, block=10, bs=1024, auto=1
    23:19:47.058 (loader): flash, block=11, bs=1024, auto=1
    23:19:47.058 (loader): flash, block=12, bs=1024, auto=1
    23:19:47.058 (loader): flash, block=13, bs=1024, auto=1
    23:19:47.089 (loader): flash, block=14, bs=1024, auto=1
    23:19:47.089 (loader): flash, block=15, bs=1024, auto=1
    23:19:47.121 (loader): flash, block=16, bs=1024, auto=1
    23:19:47.121 (loader): flash, block=17, bs=1024, auto=1
    23:19:47.152 (loader): flash, block=18, bs=1024, auto=1
    23:19:47.152 (loader): flash, block=19, bs=1024, auto=1
    23:19:47.183 (loader): flash, block=20, bs=1024, auto=1
    23:19:47.183 (loader): flash, block=21, bs=1024, auto=1
    23:19:47.214 (loader): flash, block=22, bs=1024, auto=1
    23:19:47.214 (loader): flash, block=23, bs=1024, auto=1
    23:19:47.246 (loader): flash, block=24, bs=1024, auto=1
    23:19:47.246 (loader): flash, block=25, bs=1024, auto=1
    23:19:47.280 (loader): flash, block=26, bs=1024, auto=1
    23:19:47.280 (loader): flash, block=27, bs=1024, auto=1
    23:19:47.311 (loader): flash, block=28, bs=1024, auto=1
    23:19:47.311 (loader): flash, block=29, bs=1024, auto=1
    23:19:47.342 (loader): flash, block=30, bs=1024, auto=1
    23:19:47.342 (loader): flash, block=31, bs=1024, auto=1
    23:19:47.375 (loader): flash, block=32, bs=1024, auto=1
    23:19:47.375 (loader): flash, block=33, bs=1024, auto=1
    23:19:47.408 (loader): flash, block=34, bs=1024, auto=1
    23:19:47.408 (loader): flash, block=35, bs=1024, auto=1
    23:19:47.439 (loader): flash, block=36, bs=1024, auto=1
    23:19:47.439 (loader): flash, block=37, bs=1024, auto=1
    23:19:47.471 (loader): flash, block=38, bs=1024, auto=1
    23:19:47.534 (loader): flash, block=39, bs=1024, auto=1
    23:19:47.550 (loader): flash, block=40, bs=1024, auto=1
    23:19:47.550 (loader): flash, block=41, bs=1024, auto=1
    23:19:47.564 (loader): flash, block=42, bs=1024, auto=1
    23:19:47.598 (loader): flash, block=43, bs=1024, auto=1
    23:19:47.629 (loader): sending reboot
    23:19:47.629 (loader): begin wait_until_offline
    23:19:47.658 (ports 5): WM_DEVICECHANGE DBT_DEVICEREMOVECOMPLETE
    23:19:47.659 (ports 5): remove: loc=usb:0/140000/0/6/1/3
    23:19:47.659 (ports 5): usb_remove: usb:0/140000/0/6/1/3
    23:19:47.659 (ports 5): nothing new, skipping HID & Ports enum
    23:19:47.690 (loader): offline, waited 1
    23:19:47.690 (loader): end operation, total time = 1.051 seconds
    23:19:47.690 (loader): set background IMG_REBOOT_OK
    23:19:47.690 (loader): redraw timer set, image 14 to show for 1200 ms
    23:19:47.718 (ports 5): WM_DEVICECHANGE DBT_DEVNODES_CHANGED
    23:19:47.719 (ports 5): nothing new, skipping HID & Ports enum
    23:19:47.803 (loader): HID/win32:  vid:046D pid:C52B ver:1211  usb:0/140000/0/9/4/2/4
    23:19:47.803 (loader): HID/win32:  vid:046D pid:C52B ver:1211  usb:0/140000/0/9/4/2/3
    23:19:48.084 (ports 5): WM_DEVICECHANGE DBT_DEVICEARRIVAL
    23:19:48.085 (ports 5): found_usb_device, id=\\?\usb#vid_16c0&pid_048b#9706380#{a5dcbf10-6530-11d2-901f-00c04fb951ed}
    23:19:48.085 (ports 5): found_usb_device, hwid=USB\VID_16C0&PID_048B&REV_0280
    23:19:48.085 (ports 5): found_usb_device, loc=usb:0/140000/0/6/1/3    Port_#0003.Hub_#0011
    23:19:48.085 (ports 5): found_usb_device, devinst=00000005
    23:19:48.085 (ports 5): add: loc=usb:0/140000/0/6/1/3, class=USB, vid=16C0, pid=048B, ver=0280, serial=9706380, dev=\\?\usb#vid_16c0&pid_048b#9706380#{a5dcbf10-6530-11d2-901f-00c04fb951ed}
    23:19:48.085 (ports 5):   comport_from_devinst_list attempt
    23:19:48.085 (ports 5): found_usb_device complete
    23:19:48.086 (ports 5): usb_add: usb:0/140000/0/6/1/3  [no_device] (Teensy 4.1) Dual Serial
    23:19:48.265 (ports 5): WM_DEVICECHANGE DBT_DEVICEARRIVAL
    23:19:48.266 (ports 5): update_usb_device, devinst list change, old had 1, new has 3
    23:19:48.266 (ports 5):   comport_from_devinst_list attempt
    23:19:48.266 (ports 5):   found Ports in classguid_list at index=1
    23:19:48.266 (ports 5):   port COM7 found from devnode
    23:19:48.267 (ports 5): usb_add: usb:0/140000/0/6/1/3  COM7 (Teensy 4.1) Dual Serial
    23:19:48.898 (loader): redraw, image 9
    23:19:50.051 (ports 5): WM_DEVICECHANGE DBT_DEVICEARRIVAL
    23:19:50.051 (ports 5): WM_DEVICECHANGE DBT_DEVNODES_CHANGED
    23:19:50.052 (ports 5): nothing new, skipping HID & Ports enum
    23:26:40.296 (ports 5): WM_DEVICECHANGE DBT_DEVNODES_CHANGED
    23:26:40.297 (ports 5): nothing new, skipping HID & Ports enum
    23:27:54.508 (loader): file changed
    23:27:54.525 (loader): File "R:\Temp\arduino_build_8523\SerialTest2.ino.hex", 45056 bytes
    23:27:54.532 (loader): File "R:\Temp\arduino_build_8523\SerialTest2.ino.ehex", 45056 bytes, and 4992 loader utility
    23:27:54.532 (loader): ehex is valid, key hash: 85A79CC1 B7C7F866 7F5BB3ED 0F9C9BA5 B4149EE2 72846D35 86B63863 B0699942
    23:27:54.532 (loader): File "SerialTest2.ino.hex". 45056 bytes
    23:27:54.654 (post_compile 6): Begin, version=1.56-beta2, high-res time
    23:27:54.658 (loader): remote connection 1356 opened
    23:27:54.658 (loader): remote cmd from 1356: "comment: Teensyduino 1.56-beta2 - WINDOWS (teensy_post_compile)"
    23:27:54.658 (loader): remote cmd from 1356: "status"
    23:27:54.659 (post_compile 6): Sending command: comment: Teensyduino 1.56-beta2 - WINDOWS (teensy_post_compile)
    23:27:54.661 (post_compile 6): Status: 1, 1, 0, 2, 0, 0, R:\Temp\arduino_build_8523\, SerialTest2.ino.hex
    23:27:54.661 (post_compile 6): Sending command: dir:R:\Temp\arduino_build_8523\
    23:27:54.661 (loader): remote cmd from 1356: "dir:R:\Temp\arduino_build_8523\"
    23:27:54.661 (loader): remote cmd from 1356: "file:SerialTest2.ino.hex"
    23:27:54.661 (post_compile 6): Sending command: file:SerialTest2.ino.hex
    23:27:54.668 (loader): File "R:\Temp\arduino_build_8523\SerialTest2.ino.hex", 45056 bytes
    23:27:54.674 (loader): File "R:\Temp\arduino_build_8523\SerialTest2.ino.ehex", 45056 bytes, and 4992 loader utility
    23:27:54.674 (loader): ehex is valid, key hash: 85A79CC1 B7C7F866 7F5BB3ED 0F9C9BA5 B4149EE2 72846D35 86B63863 B0699942
    23:27:54.674 (loader): File "SerialTest2.ino.hex". 45056 bytes
    23:27:54.678 (loader): remote cmd from 1356: "status"
    23:27:54.682 (post_compile 6): Status: 1, 1, 0, 2, 0, 0, R:\Temp\arduino_build_8523\, SerialTest2.ino.hex
    23:27:54.682 (post_compile 6): Disconnect
    23:27:54.696 (loader): remote connection 1356 closed
    23:27:54.950 (loader): remote connection 1356 opened
    23:27:54.950 (loader): remote cmd from 1356: "comment: Teensyduino 1.56-beta2 - WINDOWS (teensy_post_compile)"
    23:27:54.950 (loader): remote cmd from 1356: "status"
    23:27:54.950 (loader): remote cmd from 1356: "dir:R:\Temp\arduino_build_8523\"
    23:27:54.950 (loader): remote cmd from 1356: "file:SerialTest2.ino.hex"
    23:27:54.951 (post_compile 7): Begin, version=1.56-beta2, high-res time
    23:27:54.955 (post_compile 7): Sending command: comment: Teensyduino 1.56-beta2 - WINDOWS (teensy_post_compile)
    23:27:54.958 (post_compile 7): Status: 1, 1, 0, 2, 0, 0, R:\Temp\arduino_build_8523\, SerialTest2.ino.hex
    23:27:54.958 (post_compile 7): Sending command: dir:R:\Temp\arduino_build_8523\
    23:27:54.958 (post_compile 7): Sending command: file:SerialTest2.ino.hex
    23:27:54.966 (loader): File "R:\Temp\arduino_build_8523\SerialTest2.ino.hex", 45056 bytes
    23:27:54.968 (loader): File "R:\Temp\arduino_build_8523\SerialTest2.ino.ehex", 45056 bytes, and 4992 loader utility
    23:27:54.968 (loader): ehex is valid, key hash: 85A79CC1 B7C7F866 7F5BB3ED 0F9C9BA5 B4149EE2 72846D35 86B63863 B0699942
    23:27:54.968 (loader): File "SerialTest2.ino.hex". 45056 bytes
    23:27:54.968 (loader): remote cmd from 1356: "status"
    23:27:54.978 (post_compile 7): Status: 1, 1, 0, 2, 0, 0, R:\Temp\arduino_build_8523\, SerialTest2.ino.hex
    23:27:54.978 (post_compile 7): Disconnect
    23:27:54.999 (loader): remote connection 1356 closed
    23:27:54.999 (loader): remote connection 1420 opened
    23:27:54.999 (post_compile 8): Running teensy_reboot: "C:\T_Drive\Arduino_1.8.16_155\hardware\teensy\..\tools\teensy_reboot.exe" teensy_reboot.exe "-board=TEENSY41" "-port=usb:0/140000/0/6/1/3" "-portlabel=COM7 Dual Serial" "-portprotocol=Teensy"
    23:27:55.030 (reboot 9): Begin, version=1.56-beta2, high-res time
    23:27:55.030 (reboot 9): location = usb:0/140000/0/6/1/3
    23:27:55.030 (reboot 9): portlabel = COM7 Dual Serial
    23:27:55.030 (reboot 9): portprotocol = Teensy
    23:27:55.030 (reboot 9): Only location usb:0/140000/0/6/1/3 will be tried
    23:27:55.030 (reboot 9): LoadLibrary cfgmgr32 ok
    23:27:55.030 (reboot 9): LoadLibrary ntdll ok
    23:27:55.030 (loader): remote connection 1744 opened
    23:27:55.030 (loader): remote cmd from 1744: "show:arduino_attempt_reboot"
    23:27:55.030 (loader): got request to show arduino rebooting message
    23:27:55.030 (loader): remote cmd from 1744: "comment: Teensyduino 1.56-beta2 - WINDOWS (teensy_reboot)"
    23:27:55.030 (loader): remote cmd from 1744: "status"
    23:27:55.033 (reboot 9): found_usb_device, id=\\?\usb#vid_16c0&pid_048b#9706380#{a5dcbf10-6530-11d2-901f-00c04fb951ed}
    23:27:55.033 (reboot 9): found_usb_device, loc=usb:0/140000/0/6/1/3    Port_#0003.Hub_#0011
    23:27:55.033 (reboot 9): found_usb_device, hwid=USB\VID_16C0&PID_048B&REV_0280
    23:27:55.033 (reboot 9): found_usb_device, devinst=00000005
    23:27:55.033 (reboot 9): add: loc=usb:0/140000/0/6/1/3, class=USB, vid=16C0, pid=048B, ver=0280, serial=9706380, dev=\\?\usb#vid_16c0&pid_048b#9706380#{a5dcbf10-6530-11d2-901f-00c04fb951ed}
    23:27:55.033 (reboot 9):   comport_from_devinst_list attempt
    23:27:55.033 (reboot 9):   found Ports in classguid_list at index=1
    23:27:55.033 (reboot 9):   port COM7 found from devnode
    23:27:55.033 (reboot 9): found_usb_device complete
    23:27:55.040 (reboot 9): found Teensy Loader, version 1.56
    23:27:55.040 (reboot 9): Sending command: show:arduino_attempt_reboot
    23:27:55.042 (reboot 9): Sending command: comment: Teensyduino 1.56-beta2 - WINDOWS (teensy_reboot)
    23:27:55.045 (reboot 9): Status: 1, 1, 0, 2, 0, 0, R:\Temp\arduino_build_8523\, SerialTest2.ino.hex
    23:27:55.045 (reboot 9): do_reset (serial) COM7
    23:27:55.046 (loader): remote cmd from 1744: "status"
    23:27:55.051 (reboot 9): Status: 1, 1, 0, 2, 0, 0, R:\Temp\arduino_build_8523\, SerialTest2.ino.hex
    23:27:55.051 (reboot 9): status read, retry 0
    23:27:55.066 (ports 5): WM_DEVICECHANGE DBT_DEVICEREMOVECOMPLETE
    23:27:55.067 (ports 5): remove: loc=usb:0/140000/0/6/1/3
    23:27:55.067 (ports 5): usb_remove: usb:0/140000/0/6/1/3
    23:27:55.067 (ports 5): nothing new, skipping HID & Ports enum
    23:27:55.082 (ports 5): WM_DEVICECHANGE DBT_DEVNODES_CHANGED
    23:27:55.083 (ports 5): nothing new, skipping HID & Ports enum
    23:27:55.083 (ports 5): WM_DEVICECHANGE DBT_DEVICEREMOVECOMPLETE
    23:27:55.155 (loader): remote cmd from 1744: "status"
    23:27:55.159 (reboot 9): Status: 1, 1, 0, 2, 0, 0, R:\Temp\arduino_build_8523\, SerialTest2.ino.hex
    23:27:55.159 (reboot 9): status read, retry 1
    23:27:55.241 (ports 5): WM_DEVICECHANGE DBT_DEVICEARRIVAL
    23:27:55.242 (ports 5): nothing new, skipping HID & Ports enum
    23:27:55.266 (loader): handle 6c8
    23:27:55.266 (loader): Device came online, code_size = 100
    23:27:55.266 (loader): Board is: NXP IMXRT1062 ROM
    23:27:55.266 (loader): begin operation
    23:27:55.266 (loader): File "R:\Temp\arduino_build_8523\SerialTest2.ino.hex", 45056 bytes
    23:27:55.281 (loader): File "R:\Temp\arduino_build_8523\SerialTest2.ino.ehex", 45056 bytes, and 4992 loader utility
    23:27:55.281 (loader): ehex is valid, key hash: 85A79CC1 B7C7F866 7F5BB3ED 0F9C9BA5 B4149EE2 72846D35 86B63863 B0699942
    23:27:55.281 (loader): File "SerialTest2.ino.hex". 45056 bytes
    23:27:55.281 (loader): set background IMG_ONLINE
    23:27:55.281 (loader): remote cmd from 1744: "status"
    23:27:55.281 (loader): nxp_write: success
    23:27:55.281 (loader): HAB locked secure mode
    23:27:55.281 (loader): sending ehex loader utility, 4992 bytes
    23:27:55.281 (loader): run it..
    23:27:55.285 (reboot 9): Status: 1, 1, 1, 3, 0, 8, R:\Temp\arduino_build_8523\, SerialTest2.ino.hex
    23:27:55.297 (loader): ehex loader utility sucessfully started
    23:27:55.297 (loader): end operation, total time = 0.031 seconds
    23:27:55.297 (loader): redraw timer set, image 80 to show for 2000 ms
    23:27:55.321 (ports 5): WM_DEVICECHANGE DBT_DEVICEREMOVECOMPLETE
    23:27:55.322 (ports 5): nothing new, skipping HID & Ports enum
    23:27:55.368 (loader): remote cmd from 1744: "status"
    23:27:55.377 (loader): HID/win32:  vid:046D pid:C52B ver:1211  usb:0/140000/0/9/4/2/4
    23:27:55.381 (loader): HID/win32:  vid:046D pid:C52B ver:1211  usb:0/140000/0/9/4/2/4
    23:27:55.384 (loader): HID/win32:  vid:046D pid:C52B ver:1211  usb:0/140000/0/9/4/2/3
    23:27:55.390 (loader): HID/win32:  vid:046D pid:C52B ver:1211  usb:0/140000/0/9/4/2/4
    23:27:55.413 (loader): HID/win32:  vid:046D pid:C52B ver:1211  usb:0/140000/0/9/4/2/3
    23:27:55.419 (loader): HID/win32:  vid:046D pid:C52B ver:1211  usb:0/140000/0/9/4/2/3
    23:27:55.437 (loader): HID/win32:  vid:046D pid:C52B ver:1211  usb:0/140000/0/9/4/2/4
    23:27:55.457 (reboot 9): Status: 1, 1, 0, 3, 0, 0, R:\Temp\arduino_build_8523\, SerialTest2.ino.hex
    23:27:55.457 (reboot 9): status read, retry 2
    23:27:55.457 (reboot 9): Success
    23:27:55.457 (reboot 9): Disconnect
    23:27:55.477 (loader): remote connection 1744 closed
    23:27:55.477 (loader): remote connection 1420 closed
    23:27:55.738 (ports 5): WM_DEVICECHANGE DBT_DEVNODES_CHANGED
    23:27:55.739 (ports 5): nothing new, skipping HID & Ports enum
    23:27:55.739 (ports 5): WM_DEVICECHANGE DBT_DEVICEREMOVECOMPLETE
    23:27:56.723 (ports 5): purge, name=COM7 (Teensy 4.1) Dual Serial, loc=usb:0/140000/0/6/1/3, age=1.656 sec
    23:27:57.303 (loader): redraw, image 9
    23:29:18.554 (loader): Verbose Info event
    23:29:36.715 (ports 10): Begin, version=1.56-beta2, high-res time
    23:29:36.715 (ports 10): LoadLibrary cfgmgr32 ok
    23:29:36.715 (ports 10): LoadLibrary ntdll ok
    23:29:36.718 (ports 10): callback 0024
    23:29:36.718 (ports 10): callback 0081
    23:29:36.720 (ports 10): callback 0083
    23:29:36.720 (ports 10): hWnd = 1706662
    23:29:36.723 (loader): remote connection 1736 opened
    23:29:36.736 (ports 10): nothing new, skipping HID & Ports enum
    15,271
    Third time: Teensy getting Programmed - this time a button push - and all Teensy I/O goes offline: USB and Button HID.
    Plugged in a SFun Redboard and it chimmed in and then out multiple times no problem.
    Even pushing button on T_4.1 got no PC response and no RED LED until computer ( win 11 ) restarted. Then all is well and normal for some time.
    > Note the running Teensy's are mostly doing the SerialTest2 these days - so unceasing full speed Serial.print blocks - but it is UPLOAD that suddenly takes them ALL away.
    Will watch for it again and see if I can gather more details. Did add test of Redboard - but it was on alternate HUB on diff PC USB port.
    Exploring windows 11 on a computer that in theory should not support it ...
    Teensy 3.6 online, IDE 1.8.16, teensyduino 1.56-beta2
    3,339
    @defragster
    ever tried to run T4.x with reduced (12 Mbit/s) USB speed?
    IMHO, Teensy USB stack may not be most robust implementation.
    edit: uncommenting
    USB1_PORTSC1 |= USB_PORTSC1_PFSC; // force 12 Mbit/sec
    in usb.c
    15,271
    @defragster
    edit: uncommenting
    in usb.c
    I have not tried that. Current testing is trying to USB print at fastest possible 480 Mbps speeds to find a bottleneck repro case.
    This didn't happen at all the first days of testing this - even with overnight runs of three T_4.1's each pushing about 195 Mbps usable.
    Last failure was with a single unit and only 15 hours after a restart, and wasn't even running most of that time.
    It has been up 26 hours now and not had any continuous runs - and only one active so far - and all is well ...
    About to logoff for the day ... will start three copies of the curren trunning for fun.
    RAN the SeriaTest2 output echoed to RAMDRIVE file and after about 100 faulty groups - the rest finished perfectly again, but that can only handle a couple of GB.
    Not wanting to thrash the SSD - so ran 2.5 GB to HDD - and FINDSTR must have 2 BG limit so had to spilt the file - about 80 seconds worth.
    The 2,000,000 Byte portion held 499 groups - the first 108 has misses - and I see there were 4 in the rest of the 391 groups of 3,803,648 Bytes - with the EXE just pulling the bytes looking for newline as Frank originally wrote it.
    The 4 fails are probably HDD write speed? As long as the data is parsed fast enough - all seems properly handled. But that is good to Disk file or DOS box screen print using one line per 100,096 transfers for status. Trying to print them all on screen skips badly as noted.
    May 2020
    South East England
    14
    @Paul
    I do hope FrequencyCount is going to reappear in the examples, preferably with the timing constraints eliminated! Please.
    25,224
    Quote Originally Posted by RichardL View Post
    I don't understand. FreqCount is still included with the installer. Its 3 examples should still be in the Examples menu.
    Not sure what timing constraint you're talking about. On each Teensy model, that library can count at fast as the external clocking of hardware timers allows.
