I see System Volume Information on my microSD card and I think it may be why the copy all files program to move all to serial flash is failing.
>>>>>> EDIT solved see 2nd post. Sorry, I have to learn to give it more time before I ask for help. At least a day from now on.
The serial flash hardware test and SD files examples work. Trying to modify the SD files.ino program to remove System Volume Information fails too. Would non compliance to the 8.3 filename rule cause this issue? How do you get rid of the System Volume Information file on windows?
I made minor changes to the example copy files program. The changes are pointed to by <<<<<<<<<<<<<<<<<<<<<<<<<<<< on the end of applicable lines, the code below is long but only 4 lines were modified.
Changes were made to use with Teensy 3.6 and a serial flash on the same pins as the audio shield . I verified by plugging my board stacked with the audio shield using a meter.
The errors reported on the serial port:
Copy all files from SD Card to SPI Flash
System Volume Information 0
unable to create file
SlntiScan.wav 142046
MoniF1.wav 160806
MoniF2.wav 176250
Scan_Pri.wav 105442
ScanNorm.wav 104942
SDTEST1.wav 16787550
SelCal_1.wav 176914
SelCal_2.wav 176468
SDTEST4.wav 17173152
SDTEST3.wav 13617358
SDTEST2.wav 16425698
Finished All Files
PS: SlntiScan.wav is a typo I will change to SlntScan.wav. Also it looks like I need to remove SDTEST.wav files to have room on the serial flash.
const int SDchipSelect = 4; // Audio Shield has SD card CS on pin 10
const int FlashChipSelect = 6; // digital pin for flash chip CS pin
//const int FlashChipSelect = 21; // Arduino 101 built-in SPI Flash
//uncomment these if using Teensy audio shield
SPI.setSCK(14); // Audio shield has SCK on pin 14 //<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<
SPI.setMOSI(7); // Audio shield has MOSI on pin 7 //<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<
//uncomment these if you have other SPI chips connected
//to keep them disabled while using only SerialFlash
pinMode(4, INPUT_PULLUP);
pinMode(10, INPUT_PULLUP);
// wait up to 10 seconds for Arduino Serial Monitor
unsigned long startMillis = millis();
while (!Serial && (millis() - startMillis < 10000)) ;
Serial.println(F("Copy all files from SD Card to SPI Flash"));
// The Arduino SD library is used to access the card, using SD.begin(BUILTIN_SDCARD).<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<
if (!SD.begin(BUILTIN_SDCARD)) {//<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<
error("Unable to access SD card");
if (!SerialFlash.begin(FlashChipSelect)) {
error("Unable to access SPI Flash chip");
File rootdir = SD.open("/");
while (1) {
// open a file from the SD card
File f = rootdir.openNextFile();
if (!f) break;
const char *filename = f.name();
Serial.print(filename);
Serial.print(F(" "));
unsigned long length = f.size();
Serial.println(length);
// check if this file is already on the Flash chip
if (SerialFlash.exists(filename)) {
Serial.println(F(" already exists on the Flash chip"));
SerialFlashFile ff = SerialFlash.open(filename);
if (ff && ff.size() == f.size()) {
Serial.println(F(" size is the same, comparing data..."));
if (compareFiles(f, ff) == true) {
Serial.println(F(" files are identical :)"));
f.close();
ff.close();
continue; // advance to next file
Serial.println(F(" files are different"));
Serial.print(F(" size is different, "));
Serial.print(ff.size());
Serial.println(F(" bytes"));
// delete the copy on the Flash chip, if different
Serial.println(F(" delete file from Flash chip"));
SerialFlash.remove(filename);
// create the file on the Flash chip and copy data
if (SerialFlash.create(filename, length)) {
if (ff) {
Serial.print(F(" copying"));
// copy data loop
unsigned long count = 0;
unsigned char dotcount = 9;
while (count < length) {
char buf[256];
unsigned int n;
n = f.read(buf, 256);
ff.write(buf, n);
count = count + n;
Serial.print(".");
if (++dotcount > 100) {
dotcount = 0;
ff.close();
if (dotcount > 0) Serial.println();
Serial.println(F(" error opening freshly created file!"));
Serial.println(F(" unable to create file"));
f.close();
rootdir.close();
delay(10);
Serial.println(F("Finished All Files"));
bool compareFiles(File &file, SerialFlashFile &ffile) {
file.seek(0);
ffile.seek(0);
unsigned long count = file.size();
while (count > 0) {
char buf1[128], buf2[128];
unsigned long n = count;
if (n > 128) n = 128;
file.read(buf1, n);
ffile.read(buf2, n);
if (memcmp(buf1, buf2, n) != 0) return false; // differ
count = count - n;
return true; // all data identical
void error(const char *message) {
while (1) {
Serial.println(message);
delay(2500);
MoniF1.wav 160806
MoniF2.wav 176250
Scan_Pri.wav 105442
ScanNorm.wav 104942
SelCal_1.wav 176914
SelCal_2.wav 176468
Finished All Files
