thecomfychair
As part of an audio project, I'm attempting modify the contents of text-based files on an SD card (M3U playlists in this case). My initial approach is to copy the contents of the file into a std::vector, erase the contents of the file, modify the vector, then write the contents of the vector back into the file.
(This approach may be flawed, any alternative suggestions are welcome too!)
I can successfully read the contents of a file to a vector. My next step is to erase the contents of the file, but here I run into issues:
In the SdFat_Usage example, the suggested method for quickly wiping the contents of a file is to simply truncate it down to 0. However, this seems to have no effect on the file - when the file is read again after truncating it, it has retained its size and contents.
Source code (compiled with Arduino 1.8.16, using TD 1.55. Running on a Teensy 4.1):
Result:
After some time spent debugging, I'm wondering if none of the FsFile functions are working - note that when fileSize() is called it returns 0, whereas the standard SD size() function returns 292.
So basically what I'm asking is:
Any thoughts greatly appreciated!
//const int chipSelect = BUILTIN_SDCARD;
#include <string>
#include <vector>
#include <algorithm>
// some aliases to reduce typing....
using string = std::string;
using strVec = std::vector<string>;
strVec fileItems; //vector to store contents of text-based file
constexpr size_t fileItemsNameLen = 256; //max no of characters each item in a text file can be
File myFile;
while (!Serial) {;} // wait for serial port to connect
Serial.print("Initializing SD card...");
bool ok;
ok = SD.sdfs.begin(SdioConfig(FIFO_SDIO));
if (!ok) {
Serial.println("initialization failed!");
return;
Serial.println("initialization done.");
readFile();
clearFile();
readFile();
void readFile(){
myFile = SD.open("/MusicBee/Playlists/Test 3.m3u", FILE_READ); //open the playlist file in read mode
if (myFile) {
Serial.print("Opening file...");
Serial.print("File size is: ");
Serial.println(myFile.size());
fileItems.clear();//clear the contents of the fileItems vector
Serial.print("Copying file contents...");
// read from the file until there's nothing else in it: NOTE currently seems to read one extra carriage return
while (myFile.available()>1) { //if there is more than 1 byte left to read (to prevent single carriage returns being copied - playlist entries will always be >2)
char buf[fileItemsNameLen];
myFile.readBytesUntil('\n', buf,fileItemsNameLen); //reads chars from file until carriage return, although terminating char isn't included
fileItems.emplace_back(buf); //copy the line of chars to vector end of vector, increasing size automatically
else { // if the file didn't open, print an error:
Serial.println("Error opening file");
myFile.close();
Serial.print("File closed...");
Serial.println("File contains: ");
for(int i = 0; i<fileItems.size(); i++){
Serial.println(fileItems.at(i).c_str());
void clearFile(){
Serial.print("Clearing contents of file...");
Serial.print("File size before truncate: ");
myFile.close();
FsFile myFsFile = SD.sdfs.open("/MusicBee/Playlists/Test 1.m3u", O_WRITE); //open the playlist file in write mode
Serial.print("Get filesize with FsFile function: ");
Serial.println(myFsFile.fileSize());
//check to see if there's anything in the playlist file
if(myFsFile.fileSize() > 0){
myFsFile.truncate(0); //if so, delete everything in the file - seems to work when you specify a size to truncate to, otherwise it just trims off excess file size
Serial.print("Truncating...");
// Serial.print("File size after truncate: ");
// Serial.println(myFsFile.fileSize());
myFsFile.close();
myFile.close();
Result:
Initializing SD card...initialization done.
Opening file...File size is: 292
Copying file contents...File closed...File contains:
/Music/Deadmau5/4x4=12 (Deluxe Version)/1-01 - Some Chords.m4a
/Music/Deadmau5/4x4=12 (Deluxe Version)/1-09 - Raise Your Weapon.m4a
/Music/Various Artists/Oh My God...It's Electro House Vol. 5/1- - Strobe (Club Edit).m4a
Clearing contents of file...File size before truncate: 292
Get filesize with FsFile function: 0
File size after truncate: 292
- Is this the correct approach to modifying the contents of text based files on an SD card?
- Is there a better way to clear the contents of a text file?
- Am I incorrectly implemeting the SDFat functions, causing them to fail?
