Results 1 to 8 of 8
Thread: Teensy 3.5 SD-Card - mechanical issue?
    Sep 2020
    14
    Hello!
    I am using <SdFat.h> in a project to read a config.txt.
    This worked well and I handed it over to a customer. Now it is not working anymore but the code was not changed.
    sd.begin(SD_CONFIG);
    with
    SD_CONFIG SdioConfig(FIFO_SDIO);
    returns false.
    My guess is that it is a problem with the SD-Card reader? Is this a know issue?
    Have a nice day
    Schlank
    Aug 2018
    Brisbane, Australia
    79
    Did you try a different SD card yet? Just to confirm that the SD card itself is not fubar
    Sep 2020
    14
    Yes tried different ones all formatted with the SD formatter tool.
    25,215
    SdFat with SdioConfig(FIFO_SDIO) definitely works. No known issues there.
    Teensyduino 1.54 started including SdFat 2.05. Versions 1.53 and earlier didn't include any copy of SdFat, but of course it was always possible to install SdFat yourself and use it. If you're using 1.54 and your code was developed using an older version of SdFat, perhaps something else about your code than these 2 lines somehow depends on an earlier version? I hope you can see this is straying pretty far from known issues into sheer guesswork about your code and even which version of the software and SdFat library you're actually using.
    In Arduino, click Help > About to check which version of Teensyduino. In File > Preferences, you can enable verbose output during compilation. Then when you compile, Arduino will tell you the exact path of the SdFat library it actually used, and if you have any other copies it ignored, it will tell you about those. This info can be critically important if you have a compatibility issue with a new vs old version of SdFat, and both happen to be installed on your computer in different folders!
    Sep 2020
    14
    Hi!
    I am using Teensyduino 1.53 and compiler tells me about this Version:
    Alternatives for SdFat.h: [SdFat@2.0.5]
    ResolveLibrary(SdFat.h)
    -> candidates: [SdFat@2.0.5]
    Should I update to 1.54?
    25,215
    Maybe first click File > Examples > SD > listfiles. Edit the chip select pin to BUILTIN_SDCARD (refer to the comments for details).
    At least run that known-good example to check whether it can access your SD card.
    Sep 2020
    14
    It was (as often) a stupid bug: in the folder was a hidden file and the code tried to open this file and not the config.txt
    Working with SD-Cards can be nasty!
    But thanks for you quick reply!
    Jul 2020
    1,362
    I'd advise always disabling file-hiding in any OS you use, otherwise it will bite you one day.
