FastLED, SK6805, Teensy 4.1 and a Teensy rookie = full white only
Miq58
Hi there, I am new to the Teensy world (while somewhat experienced with Arduinos and ESP32s) and doing my very first steps on the Teensy 4.1.
I tried to play a little with three SK6805 RGB LEDs, the FastLED lib and the Teensy. THe following sketch ran on an Arduino Nano (except different pin names and no debug output) as I expected, but on the Teensy I only see the LEDs in stable bright white:
#include <Arduino.h>
#include <FastLED.h>
#define DATA_PIN 1
#define NUM_LEDS 3
CRGB leds[NUM_LEDS];
bool LEDSTATE(false);
  Serial.println("--OK--");
  FastLED.addLeds<SK6812, DATA_PIN, RGB>(leds, NUM_LEDS);
  FastLED.setBrightness(25);
  leds[1] = CRGB::Black;
  leds[2] = CRGB::Black;
  pinMode(LED_BUILTIN, OUTPUT);
  static uint32_t tic = millis();
  if (millis() - tic >= 1000) {
    digitalWrite(LED_BUILTIN, LEDSTATE ? HIGH : LOW);
    LEDSTATE = !LEDSTATE;
    // Turn the LED on with a random color
    uint8_t red = random8();
    uint8_t green = random8();
    uint8_t blue = random8();
    Serial.printf("R=%3d G=%3d B=%3d\n", red, green, blue);
    leds[0].setRGB(red, green, blue);
    // Now shift the LED
    leds[2] = leds[1];
    leds[1] = leds[0];
    // Update!
    FastLED.show();
    tic = millis();
What am I missing here?
I was able to reproduce the problem.
Looks like a bug. Teensy LC, 3.2, 3.5, 3.6 work, but Teensy 4.0, 4.1 give bright white no matter what data is used.
I will investigate later today.
Yup, it's a bug in FastLED.
If you're using version 3.003.003 (which ships with Teensyduino) here is a fix.
  • clockless_arm_mxrt1062.h
If you're using the latest 3.004.000 version, this will fix the bug.
Also, if you just want the LEDs to work, you could also try the WS2812Serial library and FastLED driver.
First, you need the includes like this (in this order):
#include <WS2812Serial.h>
#define USE_WS2812SERIAL
Then for FastLED.addLeds, use WS2812SERIAL rather than WS2812, like this:
  FastLED.addLeds<WS2812SERIAL, DATA_PIN, GBR>(leds, NUM_LEDS);
The 2 downsides are only certain pins are supported by WS2812Serial (only the serial transmit pins) and this uses more memory. But it gives you a highly reliable DMA-based transmit, and it will work without needing to apply those patches the fix the timing bugs in FastLED's bitbang driver.
