Results 1 to 12 of 12
Thread: FastLED, SK6805, Teensy 4.1 and a Teensy rookie = full white only
    Oct 2021
    10
    Hi there, I am new to the Teensy world (while somewhat experienced with Arduinos and ESP32s) and doing my very first steps on the Teensy 4.1.
    I tried to play a little with three SK6805 RGB LEDs, the FastLED lib and the Teensy. THe following sketch ran on an Arduino Nano (except different pin names and no debug output) as I expected, but on the Teensy I only see the LEDs in stable bright white:
    #include <Arduino.h>
    #include <FastLED.h>
    #define DATA_PIN 1
    #define NUM_LEDS 3
    CRGB leds[NUM_LEDS];
    bool LEDSTATE(false);
      Serial.println("--OK--");
      FastLED.addLeds<SK6812, DATA_PIN, RGB>(leds, NUM_LEDS);
      FastLED.setBrightness(25);
      leds[1] = CRGB::Black;
      leds[2] = CRGB::Black;
      pinMode(LED_BUILTIN, OUTPUT);
      static uint32_t tic = millis();
      if (millis() - tic >= 1000) {
        digitalWrite(LED_BUILTIN, LEDSTATE ? HIGH : LOW);
        LEDSTATE = !LEDSTATE;
        // Turn the LED on with a random color
        uint8_t red = random8();
        uint8_t green = random8();
        uint8_t blue = random8();
        Serial.printf("R=%3d G=%3d B=%3d\n", red, green, blue);
        leds[0].setRGB(red, green, blue);
        // Now shift the LED
        leds[2] = leds[1];
        leds[1] = leds[0];
        // Update!
        FastLED.show();
        tic = millis();
    What am I missing here?
    25,081
    I was able to reproduce the problem.
    Looks like a bug. Teensy LC, 3.2, 3.5, 3.6 work, but Teensy 4.0, 4.1 give bright white no matter what data is used.
    I will investigate later today.
    25,081
    Yup, it's a bug in FastLED.
    If you're using version 3.003.003 (which ships with Teensyduino) here is a fix.
    Attached Files Attached Files
    25,081
    If you're using the latest 3.004.000 version, this will fix the bug.
    Oct 2021
    10
    Thanks a lot, I will try tomorrow.
    25,081
    Ugh, looks like there may be *another* bug which is limiting the output to only 3 LEDs. Looking into it now....
    25,081
    Ok, here is a fix for both bugs using FastLED 3.004.000
    25,081
    I submitted a pull request to FastLED. Hopefully they will merge it so this problem will be fixed for all future versions.
    https://github.com/FastLED/FastLED/pull/1306
    25,081
    Also, if you just want the LEDs to work, you could also try the WS2812Serial library and FastLED driver.
    First, you need the includes like this (in this order):
    #include <WS2812Serial.h>
    #define USE_WS2812SERIAL
    Then for FastLED.addLeds, use WS2812SERIAL rather than WS2812, like this:
      FastLED.addLeds<WS2812SERIAL, DATA_PIN, GBR>(leds, NUM_LEDS);
    The 2 downsides are only certain pins are supported by WS2812Serial (only the serial transmit pins) and this uses more memory. But it gives you a highly reliable DMA-based transmit, and it will work without needing to apply those patches the fix the timing bugs in FastLED's bitbang driver.
    Oct 2021
    10
    Would that work for the SK6805 as well?
    25,081
    Should work.
    Oct 2021
    10
    Should work.
    It does.
    Thanks a lot.
