Onboard R4 resistor gone
gufo2k20
New member
Hi all,
looks like i've de-soldered my Teensy2 R4 resistor by mistake.......(yes, i'm not good at soldering).
Obviously, on-board LED doesn't work anymore, uploading some simple sketch looks ok.
Whato to do? I don't think shorting the terminal is a good idea....
If pin 11 (D6) is still working, and you don't have the equipment for tiny surface mount soldering, maybe best to leave well enough alone. If you really need a LED, you can always just connect one externally with a normal size resistor.
no SMD soldering equipment (...already done enough damage with normal solder iron :( )
No need for LED with actual project, i'll test D6.
Thank you very much for the advice! :)
