T4.1 SerialFlash with soldered optional inboard flashship
microguy
I would like to use SerialFlash to write and read raw audio sample from the optional inboard flashship that I soldered on bottom face of T4.1.
How can I do that?
If it's not possible, how can I read-write raw audio sample to this flashship?
Thx
Guy
@Frank B:
I can transfer File from SD card to the flashship, so I have for exemple "MOTORLOOP.WAV" file into.
But when I wanted to play this file with a soft derived from yours, I was never been able to compiled it.
// Simple WAV file player example
#include <LittleFS.h>
LittleFS_QSPIFlash myfs;
uint64_t fTot, totSize1;
#include <Bounce.h>
AudioPlaySdWav             playSdWav1;     //xy=323,171
AudioPlaySdWav             playSdWav2;     //xy=323,171
AudioPlaySdWav             playSdWav3;     //xy=323,171
AudioPlaySdWav             playSdWav4;     //xy=323,171
AudioPlaySdWav             playSdWav5;     //xy=323,171
AudioPlaySdWav             playSdWav6;     //xy=323,171
AudioPlaySdWav             playSdWav7;     //xy=323,171
AudioPlaySdWav             playSdWav8;     //xy=323,171
AudioMixer4              mixer1;         //xy=647,123
AudioMixer4              mixer3;         //xy=648,212
//AudioOutputPT8211        pt8211_1;       //xy=828,169
//AudioOutputI2S           audioOutput;
AudioOutputMQS           mqs1;
AudioConnection          patchCord1(playSdWav1, 0, mixer1, 0);
AudioConnection          patchCord2(playSdWav2, 1, mixer3, 0);
AudioConnection          patchCord3(playSdWav3, 2, mixer1, 1);
AudioConnection          patchCord4(playSdWav4, 3, mixer3, 1);
AudioConnection          patchCord5(playSdWav5, 4, mixer1, 2);
AudioConnection          patchCord6(playSdWav6, 5, mixer3, 2);
AudioConnection          patchCord7(playSdWav7, 6, mixer1, 3);
AudioConnection          patchCord8(playSdWav8, 7, mixer3, 3);
AudioConnection          patchCord9(mixer1, 0, mqs1, 1);
AudioConnection          patchCord10(mixer3, 0, mqs1, 1);
AudioConnection          patchCord11(mixer1, 0, mqs1, 0);
AudioConnection          patchCord12(mixer3, 0, mqs1, 0);
//AudioControlSGTL5000     sgtl5000_1;
// Bounce objects to read six pushbuttons (pins 0-5)
Bounce button0 = Bounce(0, 5);
Bounce button1 = Bounce(1, 5);  // 5 ms debounce time
Bounce button2 = Bounce(2, 5);
Bounce button3 = Bounce(3, 5);
Bounce button4 = Bounce(4, 5);
Bounce button5 = Bounce(5, 5);
Bounce button6 = Bounce(6, 5);
  if (CrashReport) {
    Serial.println(CrashReport);
    CrashReport.clear();
  AudioMemory(50);
  Serial.println("LittleFS Test"); delay(5);
  if (!myfs.begin()) {
  //if (!myfs.begin(chipSelect)) {
    Serial.println("Error starting qspidisk");
    while (1) ;
  Serial.printf("TotalSize (Bytes): %d\n", myfs.totalSize());
  //myfs.deviceErase();
  Serial.println("started");
  printDirectory();
 // Configure the pushbutton pins for pullups.
  // Each button should connect from the pin to GND.
  pinMode(0, INPUT_PULLUP);
  pinMode(1, INPUT_PULLUP);
  pinMode(2, INPUT_PULLUP);
  pinMode(3, INPUT_PULLUP);
  pinMode(4, INPUT_PULLUP);
  pinMode(5, INPUT_PULLUP);
  pinMode(6, INPUT_PULLUP);
  Serial.print("Playing file: ");
  Serial.println(filename);
  // Start playing the file.  This sketch continues to
  // run while the file plays.
  File ccc = myfs.open(filename);  ///Change to play off QSPI flash
  playSdWav1.play(ccc);
  // Simply wait for the file to finish playing.
  while (playSdWav1.isPlaying()) {
        Serial.println("play wav");
 // Update all the button objects
  button0.update();
  button1.update();
  button2.update();
  button3.update();
  button4.update();
  button5.update();
  button6.update();
  // When the buttons are pressed, just start a sound playing.
  // The audio library will play each sound through the mixers
  // so any combination can play simultaneously.
  if (button0.fallingEdge()) {
    playFile("MOTORLOOP.WAV");
void printDirectory() {
  Serial.println("printDirectory\n--------------");
  printDirectory(myfs.open("/"), 0);
void printDirectory(File dir, int numTabs) {
  //dir.whoami();
  uint64_t fSize = 0;
  uint32_t dCnt = 0, fCnt = 0;
  if ( 0 == dir ) {
    Serial.printf( "\t>>>\t>>>>> No Dir\n" );
    return;
  while (true) {
    File entry =  dir.openNextFile();
    if (! entry) {
      // no more files
      Serial.printf("\n %u dirs with %u files of Size %u Bytes\n", dCnt, fCnt, fSize);
      fTot += fCnt;
      totSize1 += fSize;
    for (uint8_t i = 0; i < numTabs; i++) {
      Serial.print('\t');
    if (entry.isDirectory()) {
      Serial.print("DIR\t");
      dCnt++;
      Serial.print("FILE\t");
      fCnt++;
      fSize += entry.size();
    Serial.print(entry.name());
      Serial.println(" / ");
      printDirectory(entry, numTabs + 1);
      // files have sizes, directories do not
      Serial.print("\t\t");
      Serial.println(entry.size(), DEC);
    entry.close();
    //Serial.flush();
The compilation error is :
WavFilePlayerLittlsFS: In function 'void playFile(const char*)':
WavFilePlayerLittlsFS:100: error: no matching function for call to 'AudioPlaySdWav::play(File&)'
In file included from /home/microguy/Téléchargements/arduino-1.8.15/hardware/teensy/avr/libraries/Audio/Audio.h:128:0,
                 from /home/microguy/Nexcloud/New_Teensy_2021/Prog/test flash w25q128/WavFilePlayerLittlsFS/WavFilePlayerLittlsFS.ino:11:
/home/microguy/Téléchargements/arduino-1.8.15/hardware/teensy/avr/libraries/Audio/play_sd_wav.h:39:7: note: candidate: bool AudioPlaySdWav::play(const char*)
  bool play(const char *filename);
/home/microguy/Téléchargements/arduino-1.8.15/hardware/teensy/avr/libraries/Audio/play_sd_wav.h:39:7: note:   no known conversion for argument 1 from 'File' to 'const char*'
I tried different things to solve this problem but I didn't find the solution.....
Have updated the example.. indeed it was outdated. Sorry for that.
Just tested it - it's working.
It runs onPT8211 by default, and NAND flash - You have to edit these things.
New problem...
If I try to play a sound in a loop, it's OK. But If I add a second sound "X" time during the loop, it's always crashing with "X" beetween 2 and 300. in a first time, the "single sound" stops playing and in a second time, the loop stops too .
Some ideas?
No.
Do you have some code?
This is the code I tried :
#include <Bounce.h>
#include <play_wav.h>
AudioPlayWav           playWav1;     //xy=232,621
AudioPlayWav           playWav2; //xy=230,663
AudioPlayWav           playWav3; //xy=232,706
AudioPlayWav           playWav4; //xy=230,749
AudioPlayWav           playWav5; //xy=230,850
AudioPlayWav           playWav6; //xy=229,890
AudioPlayWav           playWav7; //xy=226,929
AudioPlayWav           playWav8; //xy=227,968
AudioMixer4              mixerSingle;         //xy=450,905
AudioMixer4              mixerloop;         //xy=455,681
AudioMixer4              mixerFinal;         //xy=654,814
AudioAmplifier           amp1;           //xy=809,815
AudioOutputMQS           mqs1;           //xy=972,818
AudioConnection          patchCord1(playWav1, 0, mixerloop, 0);
AudioConnection          patchCord2(playWav2, 0, mixerloop, 1);
AudioConnection          patchCord3(playWav3, 0, mixerloop, 2);
AudioConnection          patchCord4(playWav4, 0, mixerloop, 3);
AudioConnection          patchCord5(playWav5, 0, mixerSingle, 0);
AudioConnection          patchCord6(playWav6, 0, mixerSingle, 1);
AudioConnection          patchCord7(playWav7, 0, mixerSingle, 2);
AudioConnection          patchCord8(playWav8, 0, mixerSingle, 3);
AudioConnection          patchCord9(mixerSingle, 0, mixerFinal, 1);
AudioConnection          patchCord10(mixerloop, 0, mixerFinal, 0);
AudioConnection          patchCord11(mixerFinal, amp1);
AudioConnection          patchCord12(amp1, 0, mqs1, 0);
AudioConnection          patchCord13(amp1, 0, mqs1, 1);
extern uint32_t _AudioPlaySdWavInstances;
int count = 0;
  AudioMemory(50);
  mixerloop.gain(0, 0.3);
  mixerSingle.gain(0,1.3);
    while (1) ;
  printDirectory();
// Initialize processor and memory measurements
  AudioProcessorUsageMaxReset();
  AudioMemoryUsageMaxReset();
void playLoopFile(const char *filename)
  //Serial.print("Playing Loop file: ");
 // Serial.println(filename);
  File ccc = myfs.open(filename);  //Change to play off QSPI flash
  playWav1.play(ccc);
void playSingleFile1(const char *filename1)
  if(!playWav5.isPlaying()){
  File cc5 = myfs.open(filename1);  //Change to play off QSPI flash
  playWav5.play(cc5);
void playSingleFile2(const char *filename2)
  if(!playWav6.isPlaying()){
  File cc6 = myfs.open(filename2);  //Change to play off QSPI flash
  playWav6.play(cc6);
unsigned long last_time = millis();
  if (!playWav1.isPlaying()){
  playLoopFile("Pompe.wav");
if(millis() - last_time >= 200) {
    Serial.print("Proc = ");
    Serial.print(AudioProcessorUsage());
    Serial.print(" (");
    Serial.print(AudioProcessorUsageMax());
    Serial.print("),  Mem = ");
    Serial.print(AudioMemoryUsage());
    Serial.print(" (");
    Serial.print(AudioMemoryUsageMax());
    Serial.println(")");
    if (!playWav5.isPlaying()){
    playSingleFile1("DEMARRE.WAV");
    count++;
    Serial.println(count);
    if (!playWav6.isPlaying()){
    playSingleFile2("ding dong.wav");
  //dir.whoami();
  uint64_t fSize = 0;
  if ( 0 == dir ) {
    return;
  while (true) {
    if (! entry) {
      // no more files
      fTot += fCnt;
      totSize1 += fSize;
      Serial.print('\t');
      dCnt++;
      fCnt++;
    entry.close();
    //Serial.flush();
You need to change some part according to your setting and 3 wav to play (each wav is less than 5sec).
EDIT: it seems that if you change 1 sample sound by another, it play first sample for some time after ... I think there is a problem into the memory management.
Looks like there is no way to use several files with Littlfs.
It's just too slow.
//LittleFS_QSPIFlash myfs;
LittleFS_QPINAND   myfs;
File f1,f2,f3;
  // try to add QSPI Flash
  if (myfs.begin()) {
    Serial.println("Added QSPI Flash");
    Serial.println("No Littlefs");
    abort();
 long ms;
 ms = millis();
 f1 = myfs.open("1.txt");
 Serial.printf("%d ms\n", millis() - ms);
 ms = millis();
 f2 = myfs.open("2.txt");
 ms = millis();
 f3 = myfs.open("3.txt");
Just opening a file, without reading takes 10 milliseconds.
The Audiolibrary needs to read the files more often, so, no chance. It has to be (minimum) 10 times faster. And that's only for open(). Did not bother to measure concurrend reads().
Added QSPI Flash
9 ms
9 ms
8 ms
Then, I saw LittlFS is a very old version. Maybe this is the problem.
As my last bug reports got no answers, and one was even "fixed" by editing a comment in the sourcecode, it make no sense for me to report that. Maybe you want?
Edit: It may have more chances, then.
Frank
Edit: Also, it's not thread-safe. The newer versions seems to be and has utility funcs (which will not be supported by FS.h anyway)
From my point of view, it's really strange that the problem comes only from a problem of reading speed as sound is not hanging but crashing definitely.
I need to reset Teensy, furthermore crash happen at variable frequency....
Maybe, a solution could be to load in advance file in ram before playing? do you think it could be possible?
Some time, with a 5 second loop, I can play a 2nd sample (3sec) 500 time without crash but with the same 2 sample sometime only 2 times....
If the file open takes 10ms it gets interrupted 3 times by the audio library. This goes wrong, obviously. I added some testcode, and some of the hangs/crashes occur in open().
In your special case it's a bit of luck, because you define 8 files, so 5 are pause, which gives it a bit higher chance to succeed.
(btw, your code is a bit confusing.. and using local File() is not ideal.. :)
I did not test RAM or ERAM.
However, the _exact_ same code in the library plays 14 stereo files from SD - but that needs a very fast SD Card.
Feel free to submit a PR if you find a bug.
Added QSPI Flash
9 ms
9 ms
8 ms
Ran your test case on a QSPI Flash (64MegaByte one forgot the number) and got (I am using 1.56beta2):
Added QSPI Flash
0 ms
0 ms
0 ms
or changing your code to measure microseconds:
Added QSPI Flash
30 micros
37 micros
37 micros
Now for a QSPI NAND Flash chip (M02)
Added QSPI Flash
85 micros
92 micros
92 micros
I will try and run the audio example when I get a chance but in the middle of a couple of things around the house but wanted to try this out. Here is the sketch I used.
//LittleFS_QPINAND   myfs;
File f1,f2,f3;
  if (myfs.begin()) {
    abort();
 uint64_t ms;
 ms = micros();
 Serial.printf("%u micros\n", micros() - ms);
 ms = micros();
 ms = micros();
@Frank B
I modified the test sketch in post #12 to use multiple files with a LittleFS QSPI Flash and the audio shield (rev D) on the T4.1 and it seems to be working, i.e., heard all 3 files playing at the same time. Here is the sketch I used and printout from the serial monitor. Not sure why you are seeing such poor results with LittleFS and QSPI Flash.
#include <Bounce.h>
AudioOutputI2S           mqs1;           //xy=972,818
int count = 0;
  AudioMemory(50);
  sgtl5000_1.enable();
  sgtl5000_1.volume(0.5);
    while (1) ;
  printDirectory();
  playWav1.play(ccc);
  playWav5.play(cc5);
  playWav6.play(cc6);
  playLoopFile("operational.wav");
    Serial.print(" (");
    Serial.print(" (");
    playSingleFile1("one_moment.wav");
    count++;
    playSingleFile2("calculations.wav");
  //dir.whoami();
  uint64_t fSize = 0;
  if ( 0 == dir ) {
    return;
  while (true) {
    if (! entry) {
      // no more files
      fTot += fCnt;
      totSize1 += fSize;
      Serial.print('\t');
      dCnt++;
      fCnt++;
    entry.close();
    //Serial.flush();
LittleFS Test
TotalSize (Bytes): 16777216
started
printDirectory
FILE	calculations.wav		426812
FILE	completed.wav		276972
FILE	dangerous_to_remain.wav		373404
FILE	enough_info.wav		513900
FILE	functional.wav		237868
FILE	odd1.wav		553516
FILE	one_moment.wav		202748
FILE	operational.wav		772652
FILE	sorry_dave.wav		791676
FILE	stop.wav		201356
 0 dirs with 10 files of Size 4350904 Bytes
Proc = 0.05 (0.05),  Mem = 0 (0)
1
Proc = 6.85 (7.18),  Mem = 1 (4)
Proc = 5.87 (7.18),  Mem = 1 (4)
Proc = 0.32 (7.18),  Mem = 1 (4)
Proc = 5.13 (7.18),  Mem = 1 (4)
Proc = 0.22 (7.18),  Mem = 1 (4)
2
Proc = 6.11 (7.18),  Mem = 1 (4)
3
Proc = 0.26 (7.18),  Mem = 1 (4)
Well, the original is here, I think:
https://github.com/littlefs-project/littlefs/
It shows version number:
#define LFS_VERSION 0x00020004 and is >9 month old
and has:
#ifdef LFS_THREADSAFE
    // Lock the underlying block device. Negative error codes
    // are propogated to the user.
    int (*lock)(const struct lfs_config *c);
    // Unlock the underlying block device. Negative error codes
    int (*unlock)(const struct lfs_config *c);
So I *assume* it's a bit better - even if there is no way to call these functions with FS.h.
My lib can't even know that a file is on LittleFS. There is no way to know that.
TD version shows:
#define LFS_VERSION 0x00020002
And is from march 2020.
Github history shows work on threadsafety.
(Did not look in detail)
Speeds:
I have no idea why it takes 10ms.
Any hints?
It does not work for microguy, too
If you want to see microseconds:
Added QSPI Flash
8962 us
8457 us
8459 us
If you tell me a way to reduce these times, i'll try it.
@mjs513 : Maybe you can try to play the test software for longer than three times because a crash can happen at any time (quickly though).
I'm sorry as I can't execute the memory access time test during this week-end (no access to my teensy board).
Well... tested it with non existing files
The times match the times which Defragster and MJS posted, then.
Not that surprising.
Are you both sure you have used existing files? :)
Then, I did a low-level format and copied the files again, via MTP.
Now, I get:
Added QSPI Flash
3708 us
3808 us
3808 us
Still 4 milliseconds.
Any Idea?
Edit. Oops.. used wrong filenames. So even with non-existing files its 4 millisconds.
This is the correct test, now:
Added QSPI Flash
14138 us
12430 us
10622 us
Worse than before low level format.
This is with NAND.
Ok, resoldered my faulty board with NOR flash.
These times look way better:
546 us
418 us
593 us
Can someone confirm, that tha 10x slower times are with NAND only?
546 us
418 us
593 us
Yes Frank the NAND is slower at least for a W25M02.
[B]Added QSPI NOR Flash (16MB)[/B]
781 micros
813 micros
780 micros
[B]Added QSPI NAND Flash (256MB)
[/B]8765 micros
2937 micros
7075 micros
NOTE: These are the same files that I used for my audio test.
If I use new files as in your example
2838 micros
2937 micros
2938 micros
[QUOTE = Frank B]Well, the original is here, I think:
#define LFS_VERSION 0x00020004 and is >9 month old[/QUOTE]
Yep you are right. The LittleFS base you pointed to in Github has not been updated for awhile. But the Teensy LittleFS is a wrapper for LittleFS that allows using different media (as you know) from a single library. Also its linked to FS.h class that provides the common thread through all the file systems. Does that make sense.
So yes it can get confusing when referring to LittleFS
