Also, in C:\Program Files (x86)\Arduino is an alternate "arduino_debug" program which runs Arduino with a console window to show you any Java exceptions. Maybe try running that and see if it's showing any errors?
to Defragster, yes, I did the sample codes and tried to load the program. as I stated, it reported back "
Serial port not selected."
to Paul,
1. I ran teensy_port.exe, in admin mode. plug/unplug cable, hit program button, nothing. no output. did it output somewhere beside in console?
2. ran arduino_debug, below is the truncated output(it was long). try to upload sample code. from the log, not really see info on port itself.
partial log here:
Set log4j store directory C:\Users\wen\AppData\Local\Arduino15
Loading configuration...
Initializing packages...
DEBUG StatusLogger Using ShutdownCallbackRegistry class org.apache.logging.log4j.core.util.DefaultShutdownCallbackRegistry
DEBUG StatusLogger Not in a ServletContext environment, thus not loading WebLookup plugin.
DEBUG StatusLogger AsyncLogger.ThreadNameStrategy=UNCACHED (user specified null, default is UNCACHED)
TRACE StatusLogger Using default SystemClock for timestamps.
DEBUG StatusLogger org.apache.logging.log4j.core.util.SystemClock does not support precise timestamps.
DEBUG StatusLogger Took 0.077758 seconds to load 209 plugins from sun.misc.Launcher$AppClassLoader@1e6f5c3
DEBUG StatusLogger PluginManager 'Converter' found 44 plugins
DEBUG StatusLogger Starting OutputStreamManager SYSTEM_OUT.false.false-1
DEBUG StatusLogger Starting LoggerContext[name=1e6f5c3, org.apache.logging.log4j.core.LoggerContext@123e042]...
DEBUG StatusLogger Reconfiguration started for context[name=1e6f5c3] at URI null (org.apache.logging.log4j.core.LoggerContext@123e042) with optional ClassLoader: null
DEBUG StatusLogger PluginManager 'ConfigurationFactory' found 4 plugins
DEBUG StatusLogger Missing dependencies for Yaml support, ConfigurationFactory org.apache.logging.log4j.core.config.yaml.YamlConfigurationFactory is inactive
DEBUG StatusLogger Using configurationFactory org.apache.logging.log4j.core.config.ConfigurationFactory$Factory@166c0fb
TRACE StatusLogger Trying to find [log4j2-test1e6f5c3.properties] using context class loader sun.misc.Launcher$AppClassLoader@1e6f5c3.
TRACE StatusLogger Trying to find [log4j2-test1e6f5c3.properties] using sun.misc.Launcher$AppClassLoader@1e6f5c3 class loader.
TRACE StatusLogger Trying to find [log4j2-test1e6f5c3.properties] using ClassLoader.getSystemResource().
TRACE StatusLogger Trying to find [log4j2-test1e6f5c3.yml] using context class loader sun.misc.Launcher$AppClassLoader@1e6f5c3.
TRACE StatusLogger Trying to find [log4j2-test1e6f5c3.yml] using sun.misc.Launcher$AppClassLoader@1e6f5c3 class loader.
TRACE StatusLogger Trying to find [log4j2-test1e6f5c3.yml] using ClassLoader.getSystemResource().
TRACE StatusLogger Trying to find [log4j2-test1e6f5c3.yaml] using context class loader sun.misc.Launcher$AppClassLoader@1e6f5c3.
TRACE StatusLogger Trying to find [log4j2-test1e6f5c3.yaml] using sun.misc.Launcher$AppClassLoader@1e6f5c3 class loader.
TRACE StatusLogger Trying to find [log4j2-test1e6f5c3.yaml] using ClassLoader.getSystemResource().
TRACE StatusLogger Trying to find [log4j2-test1e6f5c3.json] using context class loader sun.misc.Launcher$AppClassLoader@1e6f5c3.
TRACE StatusLogger Trying to find [log4j2-test1e6f5c3.json] using sun.misc.Launcher$AppClassLoader@1e6f5c3 class loader.
TRACE StatusLogger Trying to find [log4j2-test1e6f5c3.json] using ClassLoader.getSystemResource().
TRACE StatusLogger Trying to find [log4j2-test1e6f5c3.jsn] using context class loader sun.misc.Launcher$AppClassLoader@1e6f5c3.
TRACE StatusLogger Trying to find [log4j2-test1e6f5c3.jsn] using sun.misc.Launcher$AppClassLoader@1e6f5c3 class loader.
TRACE StatusLogger Trying to find [log4j2-test1e6f5c3.jsn] using ClassLoader.getSystemResource().
TRACE StatusLogger Trying to find [log4j2-test1e6f5c3.xml] using context class loader sun.misc.Launcher$AppClassLoader@1e6f5c3.
TRACE StatusLogger Trying to find [log4j2-test1e6f5c3.xml] using sun.misc.Launcher$AppClassLoader@1e6f5c3 class loader.
TRACE StatusLogger Trying to find [log4j2-test1e6f5c3.xml] using ClassLoader.getSystemResource().
TRACE StatusLogger Trying to find [log4j2-test.properties] using context class loader sun.misc.Launcher$AppClassLoader@1e6f5c3.
TRACE StatusLogger Trying to find [log4j2-test.properties] using sun.misc.Launcher$AppClassLoader@1e6f5c3 class loader.
TRACE StatusLogger Trying to find [log4j2-test.properties] using ClassLoader.getSystemResource().
TRACE StatusLogger Trying to find [log4j2-test.yml] using context class loader sun.misc.Launcher$AppClassLoader@1e6f5c3.
TRACE StatusLogger Trying to find [log4j2-test.yml] using sun.misc.Launcher$AppClassLoader@1e6f5c3 class loader.
TRACE StatusLogger Trying to find [log4j2-test.yml] using ClassLoader.getSystemResource().
TRACE StatusLogger Trying to find [log4j2-test.yaml] using context class loader sun.misc.Launcher$AppClassLoader@1e6f5c3.
TRACE StatusLogger Trying to find [log4j2-test.yaml] using sun.misc.Launcher$AppClassLoader@1e6f5c3 class loader.
TRACE StatusLogger Trying to find [log4j2-test.yaml] using ClassLoader.getSystemResource().
TRACE StatusLogger Trying to find [log4j2-test.json] using context class loader sun.misc.Launcher$AppClassLoader@1e6f5c3.
TRACE StatusLogger Trying to find [log4j2-test.json] using sun.misc.Launcher$AppClassLoader@1e6f5c3 class loader.
TRACE StatusLogger Trying to find [log4j2-test.json] using ClassLoader.getSystemResource().
TRACE StatusLogger Trying to find [log4j2-test.jsn] using context class loader sun.misc.Launcher$AppClassLoader@1e6f5c3.
TRACE StatusLogger Trying to find [log4j2-test.jsn] using sun.misc.Launcher$AppClassLoader@1e6f5c3 class loader.
TRACE StatusLogger Trying to find [log4j2-test.jsn] using ClassLoader.getSystemResource().
TRACE StatusLogger Trying to find [log4j2-test.xml] using context class loader sun.misc.Launcher$AppClassLoader@1e6f5c3.
TRACE StatusLogger Trying to find [log4j2-test.xml] using sun.misc.Launcher$AppClassLoader@1e6f5c3 class loader.
TRACE StatusLogger Trying to find [log4j2-test.xml] using ClassLoader.getSystemResource().
TRACE StatusLogger Trying to find [log4j21e6f5c3.properties] using context class loader sun.misc.Launcher$AppClassLoader@1e6f5c3.
TRACE StatusLogger Trying to find [log4j21e6f5c3.properties] using sun.misc.Launcher$AppClassLoader@1e6f5c3 class loader.
TRACE StatusLogger Trying to find [log4j21e6f5c3.properties] using ClassLoader.getSystemResource().
TRACE StatusLogger Trying to find [log4j21e6f5c3.yml] using context class loader sun.misc.Launcher$AppClassLoader@1e6f5c3.
TRACE StatusLogger Trying to find [log4j21e6f5c3.yml] using sun.misc.Launcher$AppClassLoader@1e6f5c3 class loader.
TRACE StatusLogger Trying to find [log4j21e6f5c3.yml] using ClassLoader.getSystemResource().
TRACE StatusLogger Trying to find [log4j21e6f5c3.yaml] using context class loader sun.misc.Launcher$AppClassLoader@1e6f5c3.
TRACE StatusLogger Trying to find [log4j21e6f5c3.yaml] using sun.misc.Launcher$AppClassLoader@1e6f5c3 class loader.
TRACE StatusLogger Trying to find [log4j21e6f5c3.yaml] using ClassLoader.getSystemResource().
TRACE StatusLogger Trying to find [log4j21e6f5c3.json] using context class loader sun.misc.Launcher$AppClassLoader@1e6f5c3.
TRACE StatusLogger Trying to find [log4j21e6f5c3.json] using sun.misc.Launcher$AppClassLoader@1e6f5c3 class loader.
TRACE StatusLogger Trying to find [log4j21e6f5c3.json] using ClassLoader.getSystemResource().
TRACE StatusLogger Trying to find [log4j21e6f5c3.jsn] using context class loader sun.misc.Launcher$AppClassLoader@1e6f5c3.
TRACE StatusLogger Trying to find [log4j21e6f5c3.jsn] using sun.misc.Launcher$AppClassLoader@1e6f5c3 class loader.
TRACE StatusLogger Trying to find [log4j21e6f5c3.jsn] using ClassLoader.getSystemResource().
TRACE StatusLogger Trying to find [log4j21e6f5c3.xml] using context class loader sun.misc.Launcher$AppClassLoader@1e6f5c3.
TRACE StatusLogger Trying to find [log4j21e6f5c3.xml] using sun.misc.Launcher$AppClassLoader@1e6f5c3 class loader.
TRACE StatusLogger Trying to find [log4j21e6f5c3.xml] using ClassLoader.getSystemResource().
TRACE StatusLogger Trying to find [log4j2.properties] using context class loader sun.misc.Launcher$AppClassLoader@1e6f5c3.
TRACE StatusLogger Trying to find [log4j2.properties] using sun.misc.Launcher$AppClassLoader@1e6f5c3 class loader.
TRACE StatusLogger Trying to find [log4j2.properties] using ClassLoader.getSystemResource().
TRACE StatusLogger Trying to find [log4j2.yml] using context class loader sun.misc.Launcher$AppClassLoader@1e6f5c3.
TRACE StatusLogger Trying to find [log4j2.yml] using sun.misc.Launcher$AppClassLoader@1e6f5c3 class loader.
TRACE StatusLogger Trying to find [log4j2.yml] using ClassLoader.getSystemResource().
TRACE StatusLogger Trying to find [log4j2.yaml] using context class loader sun.misc.Launcher$AppClassLoader@1e6f5c3.
TRACE StatusLogger Trying to find [log4j2.yaml] using sun.misc.Launcher$AppClassLoader@1e6f5c3 class loader.
TRACE StatusLogger Trying to find [log4j2.yaml] using ClassLoader.getSystemResource().
TRACE StatusLogger Trying to find [log4j2.json] using context class loader sun.misc.Launcher$AppClassLoader@1e6f5c3.
TRACE StatusLogger Trying to find [log4j2.json] using sun.misc.Launcher$AppClassLoader@1e6f5c3 class loader.
TRACE StatusLogger Trying to find [log4j2.json] using ClassLoader.getSystemResource().
TRACE StatusLogger Trying to find [log4j2.jsn] using context class loader sun.misc.Launcher$AppClassLoader@1e6f5c3.
TRACE StatusLogger Trying to find [log4j2.jsn] using sun.misc.Launcher$AppClassLoader@1e6f5c3 class loader.
TRACE StatusLogger Trying to find [log4j2.jsn] using ClassLoader.getSystemResource().
TRACE StatusLogger Trying to find [log4j2.xml] using context class loader sun.misc.Launcher$AppClassLoader@1e6f5c3.
DEBUG StatusLogger Closing JarURLInputStream sun.net.www.protocol.jar.JarURLConnection$JarURLInputStream@fa40fe
DEBUG StatusLogger Apache Log4j Core 2.12.0 initializing configuration XmlConfiguration[location=jar:file:/C:/Program%20Files%20(x86)/Arduino/lib/pde.jar!/log4j2.xml]
DEBUG StatusLogger Installed 1 script engine
DEBUG StatusLogger Oracle Nashorn version: 1.8.0_191, language: ECMAScript, threading: Not Thread Safe, compile: true, names: [nashorn, Nashorn, js, JS, JavaScript, javascript, ECMAScript, ecmascript], factory class: jdk.nashorn.api.scripting.NashornScriptEngineFactory
INFO StatusLogger Scanning for classes in '/C:/Program Files (x86)/Arduino/lib/arduino-core.jar' matching criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.Compiler$1 matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.Compiler$BuilderAction matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.Compiler matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.CompilerProgressListener matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.CompilerUtils matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.Constants matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.DefaultUncaughtExceptionHandler matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.LoadVIDPIDSpecificPreferences matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.MessageConsumerOutputStream matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.MyStreamPumper matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.ProgressAwareMessageConsumer matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.UploaderUtils matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.contributions.ConsoleProgressListener matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.contributions.DownloadableContribution matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.contributions.DownloadableContributionVersionComparator matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.contributions.DownloadableContributionsDownloader matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.contributions.GPGDetachedSignatureVerifier matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.contributions.GZippedJsonDownloader matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.contributions.JsonDownloader matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.contributions.NoopProgressListener matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.contributions.ProgressListener matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.contributions.SignatureVerifier matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.contributions.VersionComparator matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.contributions.VersionHelper matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.contributions.filters.DownloadableContributionWithVersionPredicate matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.contributions.libraries.ContributedLibrary matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.contributions.libraries.ContributedLibraryDependency matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.contributions.libraries.ContributedLibraryReleases matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.contributions.libraries.LibrariesIndex matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.contributions.libraries.LibrariesIndexer matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.contributions.libraries.LibraryInstaller matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.contributions.libraries.UnavailableContributedLibrary matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.contributions.packages.ContributedBoard matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.contributions.packages.ContributedHelp matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.contributions.packages.ContributedPackage matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.contributions.packages.ContributedPlatform matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.contributions.packages.ContributedTargetPackage matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.contributions.packages.ContributedTargetPlatform matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.contributions.packages.ContributedTool matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.contributions.packages.ContributedToolReference matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.contributions.packages.ContributionInstaller matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.contributions.packages.ContributionsIndex matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.contributions.packages.ContributionsIndexer matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.contributions.packages.HostDependentDownloadableContribution matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.contributions.packages.filters.PlatformArchitecturePredicate matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.files.DeleteFilesOnShutdown matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.filters.FileExecutablePredicate matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.i18n.ExternalProcessOutputParser matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.i18n.I18NAwareMessageConsumer matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.i18n.Language matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.i18n.Languages matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.net.CustomProxySelector$1 matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.net.CustomProxySelector matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.net.PACSupportMethods matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.os.windows.Win32KnownFolders matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.packages.BoardPort matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.packages.Discovery matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.packages.DiscoveryManager matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.packages.Uploader matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.packages.UploaderFactory matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.packages.discoverers.NetworkDiscovery matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.packages.discoverers.PluggableDiscovery$1 matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.packages.discoverers.PluggableDiscovery matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.packages.discoverers.PluggableDiscoveryMessage matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.packages.discoverers.network.BoardReachabilityFilter matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.packages.discoverers.serial.SerialDiscovery$1 matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.packages.discoverers.serial.SerialDiscovery matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.packages.ssh.NoInteractionUserInfo matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.packages.ssh.SCP matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.packages.ssh.SSH matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.packages.ssh.SSHClientSetupChainRing matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.packages.ssh.SSHConfigFileSetup$ConfigWrapper matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.packages.ssh.SSHConfigFileSetup$OpenSSHConfigWrapper matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.packages.ssh.SSHConfigFileSetup matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.packages.ssh.SSHPwdSetup matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.packages.uploaders.GenericNetworkUploader matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.packages.uploaders.MergeSketchWithBooloader matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.packages.uploaders.SSHUploader matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.packages.uploaders.SerialUploader matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.utils.ArchiveExtractor matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.utils.FileHash matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.utils.MultiStepProgress matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.utils.Pair matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.utils.Progress matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.utils.ReverseComparator matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.utils.network.CacheControl matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.utils.network.FileDownloader$Status matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.utils.network.FileDownloader matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.utils.network.FileDownloaderCache$1 matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.utils.network.FileDownloaderCache$FileCached matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.utils.network.FileDownloaderCache matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.utils.network.HttpConnectionManager matches criteria annotated with @Plugin
INFO StatusLogger Scanning for classes in '/C:/Program Files (x86)/Arduino/lib/pde.jar' matching criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.ConsoleOutputStream matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.UpdatableBoardsLibsFakeURLsHandler matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.contributions.BuiltInCoreIsNewerCheck matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.contributions.ContributionsSelfCheck$1 matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.contributions.ContributionsSelfCheck matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.contributions.libraries.LibraryOfSameTypeComparator matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.contributions.libraries.LibraryTypeComparator matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.contributions.libraries.filters.UpdatableLibraryPredicate matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.contributions.libraries.ui.ContributedLibraryReleasesComparator matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.contributions.libraries.ui.ContributedLibraryTableCellEditor matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.contributions.libraries.ui.ContributedLibraryTableCellJPanel matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.contributions.libraries.ui.ContributedLibraryTableCellRenderer matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.contributions.libraries.ui.DropdownAllLibraries matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.contributions.libraries.ui.DropdownInstalledLibraryItem$1 matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.contributions.libraries.ui.DropdownInstalledLibraryItem matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.contributions.libraries.ui.DropdownLibraryOfCategoryItem$1 matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.contributions.libraries.ui.DropdownLibraryOfCategoryItem matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.contributions.libraries.ui.DropdownLibraryOfTypeItem$1 matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.contributions.libraries.ui.DropdownLibraryOfTypeItem matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.contributions.libraries.ui.DropdownUpdatableLibrariesItem$1 matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.contributions.libraries.ui.DropdownUpdatableLibrariesItem matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.contributions.libraries.ui.LibrariesIndexTableModel matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.contributions.libraries.ui.LibraryManagerUI$1 matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.contributions.libraries.ui.LibraryManagerUI$2 matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.contributions.libraries.ui.LibraryManagerUI matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.contributions.libraries.ui.MultiLibraryInstallDialog$Result matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.contributions.libraries.ui.MultiLibraryInstallDialog matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.contributions.packages.filters.CategoryPredicate matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.contributions.packages.filters.UpdatablePlatformPredicate matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.contributions.packages.ui.ContributedPlatformReleases matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.contributions.packages.ui.ContributedPlatformTableCellEditor matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.contributions.packages.ui.ContributedPlatformTableCellJPanel matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.contributions.packages.ui.ContributedPlatformTableCellRenderer matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.contributions.packages.ui.ContributionIndexTableModel matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.contributions.packages.ui.ContributionManagerUI$1 matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.contributions.packages.ui.ContributionManagerUI matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.contributions.packages.ui.DropdownAllCoresItem matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.contributions.packages.ui.DropdownCoreOfCategoryItem matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.contributions.packages.ui.DropdownUpdatableCoresItem matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.contributions.ui.DropdownItem matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.contributions.ui.FilterJTextField$1 matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.contributions.ui.FilterJTextField$2 matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.contributions.ui.FilterJTextField matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.contributions.ui.FilteredAbstractTableModel matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.contributions.ui.InstallerJDialog$1 matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.contributions.ui.InstallerJDialog$2 matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.contributions.ui.InstallerJDialog$3 matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.contributions.ui.InstallerJDialog$4 matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.contributions.ui.InstallerJDialog$5 matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.contributions.ui.InstallerJDialog matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.contributions.ui.InstallerJDialogUncaughtExceptionHandler matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.contributions.ui.InstallerTableCell matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.contributions.ui.ProgressJProgressBar matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.contributions.ui.listeners.AbstractKeyListener matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.contributions.ui.listeners.DelegatingKeyListener matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.packages.MonitorFactory matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.packages.formatter.AStyle matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.packages.formatter.AStyleInterface matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.view.Event matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.view.EventListener matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.view.GoToLineNumber$1 matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.view.GoToLineNumber$2 matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.view.GoToLineNumber$3 matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.view.GoToLineNumber matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.view.JMenuUtils matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.view.NotificationPopup$1 matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.view.NotificationPopup$2 matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.view.NotificationPopup$3 matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.view.NotificationPopup$4 matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.view.NotificationPopup$5 matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.view.NotificationPopup$6 matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.view.NotificationPopup$7 matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.view.NotificationPopup$8 matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.view.NotificationPopup$9 matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.view.NotificationPopup$OptionalButtonCallbacks matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.view.NotificationPopup matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.view.SplashScreenHelper matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.view.StubMenuListener matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.view.findreplace.FindReplace$1 matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.view.findreplace.FindReplace$2 matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.view.findreplace.FindReplace$3 matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.view.findreplace.FindReplace$4 matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.view.findreplace.FindReplace$5 matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.view.findreplace.FindReplace$6 matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.view.findreplace.FindReplace matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.view.preferences.AdditionalBoardsManagerURLTextArea$1 matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.view.preferences.AdditionalBoardsManagerURLTextArea$2 matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.view.preferences.AdditionalBoardsManagerURLTextArea$3 matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.view.preferences.AdditionalBoardsManagerURLTextArea matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.view.preferences.Preferences$1 matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.view.preferences.Preferences$2 matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.view.preferences.Preferences$3 matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.view.preferences.Preferences$4 matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.view.preferences.Preferences$5 matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.view.preferences.Preferences$6 matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.view.preferences.Preferences$7 matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.view.preferences.Preferences$8 matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.view.preferences.Preferences$9 matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.view.preferences.Preferences$WarningItem matches criteria annotated with @Plugin
DEBUG StatusLogger Checking to see if class cc.arduino.view.preferences.Preferences matches criteria annotated with @Plugin
DEBUG StatusLogger Took 0.083729 seconds to load 0 plugins from package cc.arduino
DEBUG StatusLogger PluginManager 'Core' found 118 plugins
DEBUG StatusLogger PluginManager 'Level' found 0 plugins
DEBUG StatusLogger PluginManager 'Lookup' found 13 plugins
DEBUG StatusLogger Building Plugin[name=layout, class=org.apache.logging.log4j.core.layout.PatternLayout].
TRACE StatusLogger TypeConverterRegistry initializing.
DEBUG StatusLogger PluginManager 'TypeConverter' found 26 plugins
DEBUG StatusLogger PatternLayout$Builder(pattern="%d{yyyy-MM-dd'T'HH:mm:ss.SSSXXX}{UTC} %p %c{1.}:%L [%t] %m%n", PatternSelector=null, Configuration(Arduino), Replace=null, charset="null", alwaysWriteExceptions="null", disableAnsi="null", noConsoleNoAnsi="null", header="null", footer="null")
DEBUG StatusLogger Building Plugin[name=appender, class=org.apache.logging.log4j.core.appender.ConsoleAppender].
DEBUG StatusLogger ConsoleAppender$Builder(target="SYSTEM_ERR", follow="null", direct="null", bufferedIo="null", bufferSize="null", immediateFlush="null", ignoreExceptions="null", PatternLayout(%d{yyyy-MM-dd'T'HH:mm:ss.SSSXXX}{UTC} %p %c{1.}:%L [%t] %m%n), name="Console", Configuration(Arduino), Filter=null, ={})
DEBUG StatusLogger Starting OutputStreamManager SYSTEM_ERR.false.false
DEBUG StatusLogger Building Plugin[name=SizeBasedTriggeringPolicy, class=org.apache.logging.log4j.core.appender.rolling.SizeBasedTriggeringPolicy].
DEBUG StatusLogger createPolicy(size="50 MB")
DEBUG StatusLogger Building Plugin[name=Policies, class=org.apache.logging.log4j.core.appender.rolling.CompositeTriggeringPolicy].
DEBUG StatusLogger createPolicy(={SizeBasedTriggeringPolicy(size=52428800)})
DEBUG StatusLogger Building Plugin[name=DefaultRolloverStrategy, class=org.apache.logging.log4j.core.appender.rolling.DefaultRolloverStrategy].
DEBUG StatusLogger DefaultRolloverStrategy$Builder(max="20", min="null", fileIndex="null", compressionLevel="null", ={}, stopCustomActionsOnError="null", tempCompressedFilePattern="null", Configuration(Arduino))
DEBUG StatusLogger Building Plugin[name=appender, class=org.apache.logging.log4j.core.appender.RollingFileAppender].
DEBUG StatusLogger RollingFileAppender$Builder(fileName="C:\Users\wen\AppData\Local\Arduino15/logs/application.log", filePattern="C:\Users\wen\AppData\Local\Arduino15/logs/application-%d{MM-dd-yyyy}-%i.log.gz", append="null", locking="null", Policies(CompositeTriggeringPolicy(policies=[SizeBasedTriggeringPolicy(size=52428800)])), DefaultRolloverStrategy(DefaultRolloverStrategy(min=1, max=20, useMax=true)), advertise="null", advertiseUri="null", createOnDemand="null", filePermissions="null", fileOwner="null", fileGroup="null", bufferedIo="null", bufferSize="null", immediateFlush="null", ignoreExceptions="false", PatternLayout(%d{yyyy-MM-dd'T'HH:mm:ss.SSSXXX}{UTC} %p %c{1.}:%L [%t] %m%n), name="RollingFile", Configuration(Arduino), Filter=null, ={})
TRACE StatusLogger New file 'C:\Users\wen\AppData\Local\Arduino15/logs/application.log' created = false
DEBUG StatusLogger Returning file creation time for C:\Users\wen\AppData\Local\Arduino15\logs\application.log
DEBUG StatusLogger Starting RollingFileManager C:\Users\wen\AppData\Local\Arduino15/logs/application.log
DEBUG StatusLogger PluginManager 'FileConverter' found 2 plugins
DEBUG StatusLogger Setting prev file time to 2021-04-07T19:19:42.031-0700
DEBUG StatusLogger Initializing triggering policy CompositeTriggeringPolicy(policies=[SizeBasedTriggeringPolicy(size=52428800)])
DEBUG StatusLogger Initializing triggering policy SizeBasedTriggeringPolicy(size=52428800)
DEBUG StatusLogger Building Plugin[name=appenders, class=org.apache.logging.log4j.core.config.AppendersPlugin].
DEBUG StatusLogger createAppenders(={Console, RollingFile})
DEBUG StatusLogger Building Plugin[name=AppenderRef, class=org.apache.logging.log4j.core.config.AppenderRef].
DEBUG StatusLogger createAppenderRef(ref="Console", level="INFO", Filter=null)
DEBUG StatusLogger createAppenderRef(ref="RollingFile", level="null", Filter=null)
DEBUG StatusLogger Building Plugin[name=root, class=org.apache.logging.log4j.core.config.LoggerConfig$RootLogger].
DEBUG StatusLogger createLogger(additivity="null", level="DEBUG", includeLocation="null", ={Console, RollingFile}, ={}, Configuration(Arduino), Filter=null)
DEBUG StatusLogger Building Plugin[name=loggers, class=org.apache.logging.log4j.core.config.LoggersPlugin].
DEBUG StatusLogger createLoggers(={root})
DEBUG StatusLogger Configuration XmlConfiguration[location=jar:file:/C:/Program%20Files%20(x86)/Arduino/lib/pde.jar!/log4j2.xml] initialized
DEBUG StatusLogger Starting configuration XmlConfiguration[location=jar:file:/C:/Program%20Files%20(x86)/Arduino/lib/pde.jar!/log4j2.xml]
DEBUG StatusLogger Started configuration XmlConfiguration[location=jar:file:/C:/Program%20Files%20(x86)/Arduino/lib/pde.jar!/log4j2.xml] OK.
TRACE StatusLogger Stopping org.apache.logging.log4j.core.config.DefaultConfiguration@2b4c69...
TRACE StatusLogger DefaultConfiguration notified 1 ReliabilityStrategies that config will be stopped.
TRACE StatusLogger DefaultConfiguration stopping root LoggerConfig.
TRACE StatusLogger DefaultConfiguration notifying ReliabilityStrategies that appenders will be stopped.
TRACE StatusLogger DefaultConfiguration stopping remaining Appenders.
DEBUG StatusLogger Shutting down OutputStreamManager SYSTEM_OUT.false.false-1
DEBUG StatusLogger Shut down OutputStreamManager SYSTEM_OUT.false.false-1, all resources released: true
DEBUG StatusLogger Appender DefaultConsole-1 stopped with status true
TRACE StatusLogger DefaultConfiguration stopped 1 remaining Appenders.
TRACE StatusLogger DefaultConfiguration cleaning Appenders from 1 LoggerConfigs.
DEBUG StatusLogger Stopped org.apache.logging.log4j.core.config.DefaultConfiguration@2b4c69 OK
TRACE StatusLogger Reregistering MBeans after reconfigure. Selector=org.apache.logging.log4j.core.selector.ClassLoaderContextSelector@144435b
TRACE StatusLogger Reregistering context (1/1): '1e6f5c3' org.apache.logging.log4j.core.LoggerContext@123e042
TRACE StatusLogger Unregistering but no MBeans found matching 'org.apache.logging.log4j2:type=1e6f5c3'
TRACE StatusLogger Unregistering but no MBeans found matching 'org.apache.logging.log4j2:type=1e6f5c3,component=StatusLogger'
TRACE StatusLogger Unregistering but no MBeans found matching 'org.apache.logging.log4j2:type=1e6f5c3,component=ContextSelector'
TRACE StatusLogger Unregistering but no MBeans found matching 'org.apache.logging.log4j2:type=1e6f5c3,component=Loggers,name=*'
TRACE StatusLogger Unregistering but no MBeans found matching 'org.apache.logging.log4j2:type=1e6f5c3,component=Appenders,name=*'
TRACE StatusLogger Unregistering but no MBeans found matching 'org.apache.logging.log4j2:type=1e6f5c3,component=AsyncAppenders,name=*'
TRACE StatusLogger Unregistering but no MBeans found matching 'org.apache.logging.log4j2:type=1e6f5c3,component=AsyncLoggerRingBuffer'
TRACE StatusLogger Unregistering but no MBeans found matching 'org.apache.logging.log4j2:type=1e6f5c3,component=Loggers,name=*,subtype=RingBuffer'
DEBUG StatusLogger Registering MBean org.apache.logging.log4j2:type=1e6f5c3
DEBUG StatusLogger Registering MBean org.apache.logging.log4j2:type=1e6f5c3,component=StatusLogger
DEBUG StatusLogger Registering MBean org.apache.logging.log4j2:type=1e6f5c3,component=ContextSelector
DEBUG StatusLogger Registering MBean org.apache.logging.log4j2:type=1e6f5c3,component=Loggers,name=
DEBUG StatusLogger Registering MBean org.apache.logging.log4j2:type=1e6f5c3,component=Appenders,name=Console
DEBUG StatusLogger Registering MBean org.apache.logging.log4j2:type=1e6f5c3,component=Appenders,name=RollingFile
TRACE StatusLogger Using DummyNanoClock for nanosecond timestamps.
DEBUG StatusLogger Reconfiguration complete for context[name=1e6f5c3] at URI jar:file:/C:/Program%20Files%20(x86)/Arduino/lib/pde.jar!/log4j2.xml (org.apache.logging.log4j.core.LoggerContext@123e042) with optional ClassLoader: null
DEBUG StatusLogger Shutdown hook enabled. Registering a new one.
DEBUG StatusLogger LoggerContext[name=1e6f5c3, org.apache.logging.log4j.core.LoggerContext@123e042] started OK.
Preparing boards...
Starting...
Opening Teensy Loader...
Sketch uses 5224 bytes (8%) of program storage space. Maximum is 63488 bytes.
Global variables use 1712 bytes (20%) of dynamic memory, leaving 6480 bytes for local variables. Maximum is 8192 bytes.
2021-10-14T15:35:51.018Z INFO c.a.c.p.ContributionInstaller:301 [Timer-0] Start download and signature check of=[
https://downloads.arduino.cc/packages/package_index.json]
2021-10-14T15:35:51.041Z INFO c.a.u.n.FileDownloaderCache:92 [Timer-0] Cache folder C:\Users\wen\AppData\Local\Arduino15\cache
2021-10-14T15:35:51.073Z INFO c.a.u.n.FileDownloaderCache:112 [Timer-0] Number of file already in the cache 4
2021-10-14T15:35:51.109Z INFO c.a.u.n.FileDownloaderCache:149 [Timer-0] Get file cached is expire true, exist true, info FileCached{eTag='e7fca8750f4777ebbe016b6665282caf', lastETag='null', remoteURL='https://downloads.arduino.cc/packages/package_index.json', localPath='C:\Users\wen\AppData\Local\Arduino15\cache\downloads.arduino.cc\packages\package_index.json', md5='MD5:e7fca8750f4777ebbe016b6665282caf', createdAt='2021-10-13T19:48:11.879', cacheControl=CacheControl{maxAge=3600, isMustRevalidate=false, isNoCache=false, isNoStore=false}}
2021-10-14T15:35:51.114Z INFO c.a.u.n.HttpConnectionManager:153 [Timer-0] Connect to
https://downloads.arduino.cc/packages/package_index.json, method=HEAD, request id=6F058D0F05364AF0
2021-10-14T15:35:51.426Z INFO c.a.u.n.HttpConnectionManager:157 [Timer-0] Request complete URL="https://downloads.arduino.cc/packages/package_index.json", method=HEAD, response code=206, request id=6F058D0F05364AF0, headers={null=[HTTP/1.1 206 Partial Content], Server=[cloudflare], Content-Range=[bytes 0-425634/425635], Last-Modified=[Fri, 08 Oct 2021 14:26:03 GMT], X-Amz-Cf-Id=[uHMcN3iVjZyypteIW2XKahdqZODEFUUfBv7r9D-Awj0nw1eUIBU6mw==], Set-Cookie=[__cf_bm=zrgC6_.qC0.lmmAjmD7qbS8j1iOFjwKJskb9zB4Fx.U-1634225752-0-AeokadzkYi0vLL0Teem7MDAvcUAj0tVAChU8aK3Bg0OnHGUJ15nKT41TMBWgJ/Dv6MnDzFjQJQd+OzX/RZQGGvw=; path=/; expires=Thu, 14-Oct-21 16:05:52 GMT; domain=.arduino.cc; HttpOnly; Secure; SameSite=None], Content-Length=[425635], Age=[3297], Content-Type=[application/json], X-Cache=[Miss from cloudfront], CF-Ray=[69e1e14abc59090d-SEA], X-Amz-Cf-Pop=[HIO50-C2], Connection=[keep-alive], x-amz-version-id=[Sq3fDDdzPpp3sg0s6eUsMOvRdVuaJLPX], Date=[Thu, 14 Oct 2021 15:35:52 GMT], Via=[1.1 98b030ba90f9fb8f8b176298ebb3ab79.cloudfront.net (CloudFront)], x-amz-replication-status=[PENDING], CF-Cache-Status=[HIT], Cache-Control=[public, max-age=3600], ETag=["e7fca8750f4777ebbe016b6665282caf"], Vary=[Accept-Encoding], x-amz-request-id=[QXP6WTS653V3HY9F], Expires=[Thu, 14 Oct 2021 16:35:52 GMT], alt-svc=[h3=":443"; ma=86400, h3-29=":443"; ma=86400, h3-28=":443"; ma=86400, h3-27=":443"; ma=86400], x-amz-id-2=[cgw0h4+iJNeWCjI3YZKpRlWwFP2cnnGDMXepqMwhr9Ir7MkpctLK3intrw4kAn5IfpOoFYY+PCc=], Expect-CT=[max-age=604800, report-uri="https://report-uri.cloudflare.com/cdn-cgi/beacon/expect-ct"]}
2021-10-14T15:35:51.429Z INFO c.a.u.n.FileDownloaderCache:160 [Timer-0] Update cached info of
https://downloads.arduino.cc/packages/package_index.json, createdAt 2021-10-13T19:48:11.879, previous eTag e7fca8750f4777ebbe016b6665282caf, last eTag e7fca8750f4777ebbe016b6665282caf, cache control header CacheControl{maxAge=3600, isMustRevalidate=false, isNoCache=false, isNoStore=false}
2021-10-14T15:35:51.476Z INFO c.a.u.n.FileDownloaderCache:226 [Timer-0] Update cache file info in C:\Users\wen\AppData\Local\Arduino15\cache\cache.json, number of cached files is 4
2021-10-14T15:35:51.505Z INFO c.a.u.n.FileDownloader:210 [Timer-0] No need to download using cached file: FileCached{eTag='e7fca8750f4777ebbe016b6665282caf', lastETag='e7fca8750f4777ebbe016b6665282caf', remoteURL='https://downloads.arduino.cc/packages/package_index.json', localPath='C:\Users\wen\AppData\Local\Arduino15\cache\downloads.arduino.cc\packages\package_index.json', md5='MD5:e7fca8750f4777ebbe016b6665282caf', createdAt='2021-10-14T08:35:51.435', cacheControl=CacheControl{maxAge=3600, isMustRevalidate=false, isNoCache=false, isNoStore=false}}
2021-10-14T15:35:51.506Z INFO c.a.u.n.FileDownloader:174 [Timer-0] The file will be taken from the cache Optional[C:\Users\wen\AppData\Local\Arduino15\cache\downloads.arduino.cc\packages\package_index.json]
2021-10-14T15:35:51.514Z INFO c.a.u.n.FileDownloaderCache:149 [Timer-0] Get file cached is expire true, exist true, info FileCached{eTag='0ae18580e49e780cd846aefd923c1e66', lastETag='null', remoteURL='https://downloads.arduino.cc/packages/package_index.json.sig', localPath='C:\Users\wen\AppData\Local\Arduino15\cache\downloads.arduino.cc\packages\package_index.json.sig', md5='MD5:0ae18580e49e780cd846aefd923c1e66', createdAt='2021-10-13T19:48:12.121', cacheControl=CacheControl{maxAge=3600, isMustRevalidate=false, isNoCache=false, isNoStore=false}}
2021-10-14T15:35:51.520Z INFO c.a.u.n.HttpConnectionManager:153 [Timer-0] Connect to
https://downloads.arduino.cc/packages/package_index.json.sig, method=HEAD, request id=EDD3475DC561407F
2021-10-14T15:35:51.573Z INFO c.a.u.n.HttpConnectionManager:157 [Timer-0] Request complete URL="https://downloads.arduino.cc/packages/package_index.json.sig", method=HEAD, response code=206, request id=EDD3475DC561407F, headers={null=[HTTP/1.1 206 Partial Content], Server=[cloudflare], Content-Range=[bytes 0-542/543], Last-Modified=[Fri, 08 Oct 2021 14:26:03 GMT], X-Amz-Cf-Id=[eT9Q5uUlQyTXRSvLd_889fWhrhWDMEi4nRet8mT7pgN0uZdgCMVX6A==], Set-Cookie=[__cf_bm=JEgnYc5J2fC7ucp1sd_DkRHBRwnQsNWgNMjwXHtVUOE-1634225753-0-AfOG3aZNr+ihgdQYTBYz/CTMWtQo6qBESaMK4aBMag9bPd1QKTpv38fiTXU2/KPhXT2uasFkcOhzAjyDF2BuK38=; path=/; expires=Thu, 14-Oct-21 16:05:53 GMT; domain=.arduino.cc; HttpOnly; Secure; SameSite=None], Content-Length=[543], Age=[3297], Content-Type=[application/pgp-signature], X-Cache=[Miss from cloudfront], CF-Ray=[69e1e14c5e64090d-SEA], X-Amz-Cf-Pop=[HIO50-C2], Connection=[keep-alive], x-amz-version-id=[EoOVTOBJ9HWk9MZZIl5Wfd8MZHUbtZdI], Date=[Thu, 14 Oct 2021 15:35:53 GMT], Via=[1.1 b9ead8d9e99fb1a70cc9b3ee9d847ec6.cloudfront.net (CloudFront)], x-amz-replication-status=[PENDING], CF-Cache-Status=[HIT], Cache-Control=[public, max-age=3600], ETag=["0ae18580e49e780cd846aefd923c1e66"], Vary=[Accept-Encoding], x-amz-request-id=[W6EM24MQAQKX96TJ], Expires=[Thu, 14 Oct 2021 16:35:53 GMT], alt-svc=[h3=":443"; ma=86400, h3-29=":443"; ma=86400, h3-28=":443"; ma=86400, h3-27=":443"; ma=86400], x-amz-id-2=[pbiDRImNxcwWl6fcls/xE0j4RE53SKcRv/Eth0RnulXZkVVZGDlfcihkEuaWlcoLpRrm1i6tS8A=], Expect-CT=[max-age=604800, report-uri="https://report-uri.cloudflare.com/cdn-cgi/beacon/expect-ct"]}
2021-10-14T15:35:51.574Z INFO c.a.u.n.FileDownloaderCache:160 [Timer-0] Update cached info of
https://downloads.arduino.cc/packages/package_index.json.sig, createdAt 2021-10-13T19:48:12.121, previous eTag 0ae18580e49e780cd846aefd923c1e66, last eTag 0ae18580e49e780cd846aefd923c1e66, cache control header CacheControl{maxAge=3600, isMustRevalidate=false, isNoCache=false, isNoStore=false}
2021-10-14T15:35:51.578Z INFO c.a.u.n.FileDownloaderCache:226 [Timer-0] Update cache file info in C:\Users\wen\AppData\Local\Arduino15\cache\cache.json, number of cached files is 4
2021-10-14T15:35:51.584Z INFO c.a.u.n.FileDownloader:210 [Timer-0] No need to download using cached file: FileCached{eTag='0ae18580e49e780cd846aefd923c1e66', lastETag='0ae18580e49e780cd846aefd923c1e66', remoteURL='https://downloads.arduino.cc/packages/package_index.json.sig', localPath='C:\Users\wen\AppData\Local\Arduino15\cache\downloads.arduino.cc\packages\package_index.json.sig', md5='MD5:0ae18580e49e780cd846aefd923c1e66', createdAt='2021-10-14T08:35:51.576', cacheControl=CacheControl{maxAge=3600, isMustRevalidate=false, isNoCache=false, isNoStore=false}}
2021-10-14T15:35:51.585Z INFO c.a.u.n.FileDownloader:174 [Timer-0] The file will be taken from the cache Optional[C:\Users\wen\AppData\Local\Arduino15\cache\downloads.arduino.cc\packages\package_index.json.sig]
2021-10-14T15:35:51.594Z INFO c.a.c.DownloadableContributionsDownloader:227 [Timer-0] Signature verified. url=https://downloads.arduino.cc/packages/package_index.json.sig, signature url=https://downloads.arduino.cc/packages/package_index.json.sig, file to verify=C:\Users\wen\AppData\Local\Temp\package_index.json6520508451283381358.tmp, signature file=C:\Users\wen\AppData\Local\Temp\package_index.json.sig1673733711288830122.tmp
2021-10-14T15:35:51.598Z INFO c.a.c.p.ContributionInstaller:310 [Timer-0] Downloaded package index URL=[
2021-10-14T15:35:51.603Z INFO c.a.u.n.FileDownloaderCache:149 [Timer-0] Get file cached is expire true, exist true, info FileCached{eTag='65766b899e4e9ee566f3ed8ee171d46f', lastETag='null', remoteURL='https://downloads.arduino.cc/libraries/library_index.json.gz', localPath='C:\Users\wen\AppData\Local\Arduino15\cache\downloads.arduino.cc\libraries\library_index.json.gz', md5='MD5:65766b899e4e9ee566f3ed8ee171d46f', createdAt='2021-10-13T19:48:12.605', cacheControl=CacheControl{maxAge=14400, isMustRevalidate=false, isNoCache=false, isNoStore=false}}
2021-10-14T15:35:51.603Z INFO c.a.u.n.HttpConnectionManager:153 [Timer-0] Connect to
https://downloads.arduino.cc/libraries/library_index.json.gz, method=HEAD, request id=7C26DE6DB4D94D51
2021-10-14T15:35:51.660Z INFO c.a.u.n.HttpConnectionManager:157 [Timer-0] Request complete URL="https://downloads.arduino.cc/libraries/library_index.json.gz", method=HEAD, response code=206, request id=7C26DE6DB4D94D51, headers={null=[HTTP/1.1 206 Partial Content], Server=[cloudflare], Content-Range=[bytes 0-2066545/2066546], Last-Modified=[Thu, 14 Oct 2021 15:11:16 GMT], X-Amz-Cf-Id=[5UL56krMeTB7Fx6QzAXV3hp_g5oRx9jn-6X37jFgTxng7wq96_zBOQ==], Set-Cookie=[__cf_bm=uS40saWZvwZ.k5AcRuB4BVFHzS6LLf02F9MCmj818bE-1634225753-0-AdxlH6ayRb5osLim0YemdR93/TyUz/q3MbUTGI0nzi/NvmITKth9fkvrbykUJX5nct5FzI11aeXAh5KXUqNhf3o=; path=/; expires=Thu, 14-Oct-21 16:05:53 GMT; domain=.arduino.cc; HttpOnly; Secure; SameSite=None], Content-Length=[2066546], Age=[1352], Content-Type=[application/json], X-Cache=[Miss from cloudfront], CF-Ray=[69e1e14cdf04090d-SEA], X-Amz-Cf-Pop=[SEA19-C2], Connection=[keep-alive], x-amz-version-id=[uP0Cg5p0_umZKBstTXll6mp4gok.BetT], Date=[Thu, 14 Oct 2021 15:35:53 GMT], Via=[1.1 e36ab1b8726f47aa5adc8e19e66d1bbe.cloudfront.net (CloudFront)], x-amz-replication-status=[COMPLETED], CF-Cache-Status=[HIT], Cache-Control=[public, max-age=14400], ETag=["4a71bdd1887c354a8fa3465be40e3496"], Vary=[Accept-Encoding], x-amz-request-id=[KYXFXH36MX590G4Z], Expires=[Thu, 14 Oct 2021 19:35:53 GMT], alt-svc=[h3=":443"; ma=86400, h3-29=":443"; ma=86400, h3-28=":443"; ma=86400, h3-27=":443"; ma=86400], x-amz-id-2=[Q6nqVRrUXFhzD4RysZEKVTHgjgsAJ1sl4PnPLr2BLVgmUZfNgINS0t29pOM/xGdDoJC6D2tZIvQ=], Expect-CT=[max-age=604800, report-uri="https://report-uri.cloudflare.com/cdn-cgi/beacon/expect-ct"]}
2021-10-14T15:35:51.661Z INFO c.a.u.n.FileDownloaderCache:160 [Timer-0] Update cached info of
https://downloads.arduino.cc/libraries/library_index.json.gz, createdAt 2021-10-13T19:48:12.605, previous eTag 65766b899e4e9ee566f3ed8ee171d46f, last eTag 4a71bdd1887c354a8fa3465be40e3496, cache control header CacheControl{maxAge=14400, isMustRevalidate=false, isNoCache=false, isNoStore=false}
2021-10-14T15:35:51.672Z INFO c.a.u.n.FileDownloaderCache:226 [Timer-0] Update cache file info in C:\Users\wen\AppData\Local\Arduino15\cache\cache.json, number of cached files is 4
2021-10-14T15:35:51.696Z INFO c.a.u.n.FileDownloader:210 [Timer-0] No need to download using cached file: FileCached{eTag='65766b899e4e9ee566f3ed8ee171d46f', lastETag='4a71bdd1887c354a8fa3465be40e3496', remoteURL='https://downloads.arduino.cc/libraries/library_index.json.gz', localPath='C:\Users\wen\AppData\Local\Arduino15\cache\downloads.arduino.cc\libraries\library_index.json.gz', md5='MD5:65766b899e4e9ee566f3ed8ee171d46f', createdAt='2021-10-14T08:35:51.667', cacheControl=CacheControl{maxAge=14400, isMustRevalidate=false, isNoCache=false, isNoStore=false}}
2021-10-14T15:35:51.700Z INFO c.a.u.n.HttpConnectionManager:153 [Timer-0] Connect to
https://downloads.arduino.cc/libraries/library_index.json.gz, method=GET, request id=152D9B6954F842E8
2021-10-14T15:35:51.755Z INFO c.a.u.n.HttpConnectionManager:157 [Timer-0] Request complete URL="https://downloads.arduino.cc/libraries/library_index.json.gz", method=GET, response code=206, request id=152D9B6954F842E8, headers={null=[HTTP/1.1 206 Partial Content], Server=[cloudflare], Content-Range=[bytes 0-2066545/2066546], Last-Modified=[Thu, 14 Oct 2021 15:11:16 GMT], X-Amz-Cf-Id=[5UL56krMeTB7Fx6QzAXV3hp_g5oRx9jn-6X37jFgTxng7wq96_zBOQ==], Set-Cookie=[__cf_bm=NCwCBzaLBHrA3sDyliYPM7L92FMHJKc1T9HNmnlieK8-1634225753-0-AR8XjkwsWSmPzaKBALWuer3ZcN+q/hRcUa5mFVYKHsCVBSeumJToMrxg8KztdjH5izPaX9VVe/Bufx9rEE8Ax60=; path=/; expires=Thu, 14-Oct-21 16:05:53 GMT; domain=.arduino.cc; HttpOnly; Secure; SameSite=None], Content-Length=[2066546], Age=[1352], Content-Type=[application/json], X-Cache=[Miss from cloudfront], CF-Ray=[69e1e14d7fcc090d-SEA], X-Amz-Cf-Pop=[SEA19-C2], Connection=[keep-alive], x-amz-version-id=[uP0Cg5p0_umZKBstTXll6mp4gok.BetT], Date=[Thu, 14 Oct 2021 15:35:53 GMT], Via=[1.1 e36ab1b8726f47aa5adc8e19e66d1bbe.cloudfront.net (CloudFront)], x-amz-replication-status=[COMPLETED], CF-Cache-Status=[HIT], Cache-Control=[public, max-age=14400], ETag=["4a71bdd1887c354a8fa3465be40e3496"], Vary=[Accept-Encoding], x-amz-request-id=[KYXFXH36MX590G4Z], Expires=[Thu, 14 Oct 2021 19:35:53 GMT], alt-svc=[h3=":443"; ma=86400, h3-29=":443"; ma=86400, h3-28=":443"; ma=86400, h3-27=":443"; ma=86400], x-amz-id-2=[Q6nqVRrUXFhzD4RysZEKVTHgjgsAJ1sl4PnPLr2BLVgmUZfNgINS0t29pOM/xGdDoJC6D2tZIvQ=], Expect-CT=[max-age=604800, report-uri="https://report-uri.cloudflare.com/cdn-cgi/beacon/expect-ct"]}
2021-10-14T15:35:52.009Z INFO c.a.u.n.FileDownloaderCache:343 [Timer-0] Update cache file: FileCached{eTag='4a71bdd1887c354a8fa3465be40e3496', lastETag='4a71bdd1887c354a8fa3465be40e3496', remoteURL='https://downloads.arduino.cc/libraries/library_index.json.gz', localPath='C:\Users\wen\AppData\Local\Arduino15\cache\downloads.arduino.cc\libraries\library_index.json.gz', md5='MD5:4a71bdd1887c354a8fa3465be40e3496', createdAt='2021-10-14T08:35:52.009', cacheControl=CacheControl{maxAge=14400, isMustRevalidate=false, isNoCache=false, isNoStore=false}}
2021-10-14T15:35:52.013Z INFO c.a.u.n.FileDownloaderCache:226 [Timer-0] Update cache file info in C:\Users\wen\AppData\Local\Arduino15\cache\cache.json, number of cached files is 4
2021-10-14T15:35:52.093Z INFO c.a.u.n.FileDownloaderCache:149 [Timer-0] Get file cached is expire true, exist true, info FileCached{eTag='86c6e13c764640349eb8e9cf5cb032d9', lastETag='null', remoteURL='https://downloads.arduino.cc/libraries/library_index.json.sig', localPath='C:\Users\wen\AppData\Local\Arduino15\cache\downloads.arduino.cc\libraries\library_index.json.sig', md5='MD5:86c6e13c764640349eb8e9cf5cb032d9', createdAt='2021-10-13T19:48:12.776', cacheControl=CacheControl{maxAge=14400, isMustRevalidate=false, isNoCache=false, isNoStore=false}}
2021-10-14T15:35:52.093Z INFO c.a.u.n.HttpConnectionManager:153 [Timer-0] Connect to
https://downloads.arduino.cc/libraries/library_index.json.sig, method=HEAD, request id=1A39351B77664C9F
2021-10-14T15:35:52.139Z INFO c.a.u.n.HttpConnectionManager:157 [Timer-0] Request complete URL="https://downloads.arduino.cc/libraries/library_index.json.sig", method=HEAD, response code=206, request id=1A39351B77664C9F, headers={null=[HTTP/1.1 206 Partial Content], Server=[cloudflare], Content-Range=[bytes 0-542/543], Last-Modified=[Thu, 14 Oct 2021 15:11:15 GMT], X-Amz-Cf-Id=[dmyYYoe_SPJ6-7_5bgZFLhbGmdXMwWrQ4l5JgSNNOvgIBcGeMLttIg==], Set-Cookie=[__cf_bm=PRbsCQvm6Xm.HqQp5F5aO1asiZQ1VK.8kCz_laMMj08-1634225753-0-AbCNPrySGZkOBl0HgNH/xylNJw0Iqk5ZWTMRzWqw1FrcmmxL6CzGj0RpbRQQkKLj3BZOlR1Hy5E2kGM/TvQix54=; path=/; expires=Thu, 14-Oct-21 16:05:53 GMT; domain=.arduino.cc; HttpOnly; Secure; SameSite=None], Content-Length=[543], Age=[1350], Content-Type=[application/pgp-signature], X-Cache=[Miss from cloudfront], CF-Ray=[69e1e14feabb090d-SEA], X-Amz-Cf-Pop=[SEA19-C2], Connection=[keep-alive], x-amz-version-id=[cKjKhoDK68tA4T4biAIzlm9cVxNc5t33], Date=[Thu, 14 Oct 2021 15:35:53 GMT], Via=[1.1 591683988172c7980c4ebb318cbf18a9.cloudfront.net (CloudFront)], x-amz-replication-status=[COMPLETED], CF-Cache-Status=[HIT], Cache-Control=[public, max-age=14400], ETag=["e008628e98686f5de7553fe125497dfc"], Vary=[Accept-Encoding], x-amz-request-id=[V6P5EEYKZBB8ZKJJ], Expires=[Thu, 14 Oct 2021 19:35:53 GMT], alt-svc=[h3=":443"; ma=86400, h3-29=":443"; ma=86400, h3-28=":443"; ma=86400, h3-27=":443"; ma=86400], x-amz-id-2=[6cvoN6irMHVR+NcRo5BTKZoFqGN3zQqMZ6jo3Z1yL1zjP8XLaJ463Orv0CclGpyILnhH14MQXkM=], Expect-CT=[max-age=604800, report-uri="https://report-uri.cloudflare.com/cdn-cgi/beacon/expect-ct"]}
2021-10-14T15:35:52.139Z INFO c.a.u.n.FileDownloaderCache:160 [Timer-0] Update cached info of
https://downloads.arduino.cc/libraries/library_index.json.sig, createdAt 2021-10-13T19:48:12.776, previous eTag 86c6e13c764640349eb8e9cf5cb032d9, last eTag e008628e98686f5de7553fe125497dfc, cache control header CacheControl{maxAge=14400, isMustRevalidate=false, isNoCache=false, isNoStore=false}
2021-10-14T15:35:52.142Z INFO c.a.u.n.FileDownloaderCache:226 [Timer-0] Update cache file info in C:\Users\wen\AppData\Local\Arduino15\cache\cache.json, number of cached files is 4
2021-10-14T15:35:52.144Z INFO c.a.u.n.FileDownloader:210 [Timer-0] No need to download using cached file: FileCached{eTag='86c6e13c764640349eb8e9cf5cb032d9', lastETag='e008628e98686f5de7553fe125497dfc', remoteURL='https://downloads.arduino.cc/libraries/library_index.json.sig', localPath='C:\Users\wen\AppData\Local\Arduino15\cache\downloads.arduino.cc\libraries\library_index.json.sig', md5='MD5:86c6e13c764640349eb8e9cf5cb032d9', createdAt='2021-10-14T08:35:52.141', cacheControl=CacheControl{maxAge=14400, isMustRevalidate=false, isNoCache=false, isNoStore=false}}
2021-10-14T15:35:52.149Z INFO c.a.u.n.HttpConnectionManager:153 [Timer-0] Connect to
https://downloads.arduino.cc/libraries/library_index.json.sig, method=GET, request id=B896199D871E4369
2021-10-14T15:35:52.203Z INFO c.a.u.n.HttpConnectionManager:157 [Timer-0] Request complete URL="https://downloads.arduino.cc/libraries/library_index.json.sig", method=GET, response code=206, request id=B896199D871E4369, headers={null=[HTTP/1.1 206 Partial Content], Server=[cloudflare], Content-Range=[bytes 0-542/543], Last-Modified=[Thu, 14 Oct 2021 15:11:15 GMT], X-Amz-Cf-Id=[dmyYYoe_SPJ6-7_5bgZFLhbGmdXMwWrQ4l5JgSNNOvgIBcGeMLttIg==], Set-Cookie=[__cf_bm=zw3q3eUavbJLLb3t9_nztqb6_o7OlROXdaVhK4rg4lc-1634225753-0-AcAqZy1n0wcGJYsdCD448OcrSzkH6AAoHHc1ueuyFR4hlu9CVuEUda7NdJbxm6k4pgCU/SYEvHnFHs/NdbuhHJo=; path=/; expires=Thu, 14-Oct-21 16:05:53 GMT; domain=.arduino.cc; HttpOnly; Secure; SameSite=None], Content-Length=[543], Age=[1350], Content-Type=[application/pgp-signature], X-Cache=[Miss from cloudfront], CF-Ray=[69e1e1503b2b090d-SEA], X-Amz-Cf-Pop=[SEA19-C2], Connection=[keep-alive], x-amz-version-id=[cKjKhoDK68tA4T4biAIzlm9cVxNc5t33], Date=[Thu, 14 Oct 2021 15:35:53 GMT], Via=[1.1 591683988172c7980c4ebb318cbf18a9.cloudfront.net (CloudFront)], x-amz-replication-status=[COMPLETED], CF-Cache-Status=[HIT], Cache-Control=[public, max-age=14400], ETag=["e008628e98686f5de7553fe125497dfc"], Vary=[Accept-Encoding], x-amz-request-id=[V6P5EEYKZBB8ZKJJ], Expires=[Thu, 14 Oct 2021 19:35:53 GMT], alt-svc=[h3=":443"; ma=86400, h3-29=":443"; ma=86400, h3-28=":443"; ma=86400, h3-27=":443"; ma=86400], x-amz-id-2=[6cvoN6irMHVR+NcRo5BTKZoFqGN3zQqMZ6jo3Z1yL1zjP8XLaJ463Orv0CclGpyILnhH14MQXkM=], Expect-CT=[max-age=604800, report-uri="https://report-uri.cloudflare.com/cdn-cgi/beacon/expect-ct"]}
2021-10-14T15:35:52.205Z INFO c.a.u.n.FileDownloaderCache:343 [Timer-0] Update cache file: FileCached{eTag='e008628e98686f5de7553fe125497dfc', lastETag='e008628e98686f5de7553fe125497dfc', remoteURL='https://downloads.arduino.cc/libraries/library_index.json.sig', localPath='C:\Users\wen\AppData\Local\Arduino15\cache\downloads.arduino.cc\libraries\library_index.json.sig', md5='MD5:e008628e98686f5de7553fe125497dfc', createdAt='2021-10-14T08:35:52.205', cacheControl=CacheControl{maxAge=14400, isMustRevalidate=false, isNoCache=false, isNoStore=false}}
2021-10-14T15:35:52.208Z INFO c.a.u.n.FileDownloaderCache:226 [Timer-0] Update cache file info in C:\Users\wen\AppData\Local\Arduino15\cache\cache.json, number of cached files is 4
2021-10-14T15:35:52.483Z INFO c.a.c.DownloadableContributionsDownloader:227 [Timer-0] Signature verified. url=https://downloads.arduino.cc/libraries/library_index.json.sig, signature url=https://downloads.arduino.cc/libraries/library_index.json.sig, file to verify=C:\Users\wen\AppData\Local\Temp\library_index.json999024732426056018.tmp, signature file=C:\Users\wen\AppData\Local\Temp\library_index.json.sig1846277622358656783.tmp
