Results 1 to 4 of 4
Thread: Acceleration - bandpass filter
    Nov 2020
    Czech Republic
    53
    Hi all,
    I am reading samples from ADXL via ADC (Teensy 4). I have it in buffer and then I need apply bandpass filter to calculate acceleration for 500-7500Hz and for velocity for 10-1000Hz. Anybody knows code for this type of bandpass filter?
    I am trying this but no clue if is it correct. I am testing it with signal generator, sine wave. For example when I set 300Hz and 0,02V RMS I can see 0,8gRMS and if I set 2000Hz I can see 0,6gRMS. (gRMS = pow(every sample from ADC,2) then sqrt of sum). In my opinion, if I set 2000Hz sine then I have to see near zero gRMS, right?
    https://www.norwegiancreations.com/2...top-filtering/
      float EMA_a_low = 0.001;  //10Hz
      float EMA_a_high = 0.3;   //500Hz
      float EMA_S_low = 0;
      float EMA_S_high = 0;
      float highpass = 0;
      float bandpass = 0;
    for (k = 0 ; k < TOTAL_SAMPLES; k++)
      g = data_from_adc[k];
      EMA_S_low = (EMA_a_low*g) + ((1-EMA_a_low)*EMA_S_low);
      EMA_S_high = (EMA_a_high*g) + ((1-EMA_a_high)*EMA_S_high);
      highpass = g - EMA_S_low;
      g_buffer[counter] = EMA_S_high - EMA_S_low;
    Michal
    Jul 2020
    1,364
    A wide-range bandpass filter is easiest to realize as a high-pass filter and a low-pass filter chained together.
    Can you generate Butterworth low-pass and high-pass filters? There are many on-line apps to help with this.
    Sep 2015
    102
    Audio library
    Sorry, just passing through,
    this is well in the audio range,
    and i seem to remember Tensey has a great set of audio libraries,
    would these not be the way forward ?
    Jul 2020
    1,364
    Indeed, and if you use this you'd implement the various filter sections using the AudioFilterBiquad class,
    but first you have to generate the filter coefficients - the original code just uses first-order sections which
    isn't precise at all in the frequency domain.
    With the audio library you could alternative use an FFT and sum the relevant buckets.
