mattiekempen
New member
I am using an teensy 4.1 ADC for an audio project.
I have my mic set up for 1.2 volt inputand I can't find a way to set the ADC refrence to 1.2v.
What command and values should i use for this?
Thanks!
edit:
SOLVED! found the answer on the prjc site as expected.
i need to keep in mind the audio tool is mostly written around teensy 3.*.
fixed the circuit and everything is working fine around 3.3V
Thanks!
edit:
